I have built a small circuit to add a RTC and 15 extra i/o ports.
It all works fine but I cannot get the read digital pin section working, I have removed the RTC stuff from the sketch.
This is my current code and I think that the issue is with the digitalReadI2C(int pin) function.
#include "Wire.h"
#define I2C_ADDRESS_BV4206 0x10 // This is the I2C address
#define pinIn 0x01
#define pinOut 0x00
void digitalPinmodeI2C(int pin, int value){
Wire.beginTransmission(I2C_ADDRESS_BV4206);
Wire.send(0x01); //set pin mode command
Wire.send(pin); //the digital output id
Wire.send(value);
Wire.endTransmission();
void digitalWriteI2C(int pin, int value){
Wire.send(0x02); //set output command
Wire.send(pin); //send pin number
Wire.send(value);
boolean digitalReadI2C(int pin){
Wire.send(0x03); //set read command
if (Wire.receive()==0x01){return true;} else {return false;}
Wire.begin();
/** For BV4206 GPIO Devices **/
//change address from default (0x21) to 0x10
Wire.beginTransmission(0x21); // join I2C, talk to BV4206 by id
Wire.send(0x99); //change address command
Wire.send(I2C_ADDRESS_BV4206 << 1); //new address (7 bit)
Wire.send(0x55); //check code - do not change
Wire.send(0xaa); //double check code - do not change
Wire.send(0x21 << 1); //current address (7 bit)
Wire.endTransmission(); // leave I2C bus
//set pin IO modes
digitalPinmodeI2C(0,pinOut);
digitalPinmodeI2C(1,pinIn);
digitalPinmodeI2C(2,pinIn);
//set output 0 of BV4206 to high
Serial.println("BV4206 value set HIGH");
digitalWriteI2C(0,1);
delay(200);
//set output 0 low
Serial.println("BV4206 value set LOW");
digitalWriteI2C(0,0);
delay(200);
//read input 1 of BV4206
Serial.print("BV4206 reading values at 1 =");
if (digitalReadI2C(1)==true){Serial.println("HI"); } else {Serial.println("LOW"); }
//read input 2 of BV4206
Serial.print("BV4206 reading values at 2 =");
if (digitalReadI2C(2)==true){Serial.println("HI"); } else {Serial.println("LOW"); }
Serial.println("");
