Problems Writing and Reading I2C Data unknown chip
Recently I got a RX38130CE RTC module. Unfortunately there arent any libraries for it so I have to write and receive I2C data on my own.
In the data sheet I saw that there is an example of how to set the register to set a certain time.
However if I try to read the time values I get wierd numbers:
Here is my code:
void SetRTC()
  Wire.beginTransmission(RTC_ADDRESS);
  Wire.write(0x1E);
  Wire.write(0x00);
  Wire.write(0x10);
  Wire.write(Seconds);
  Wire.write(0x11);
  Wire.write(Minute);
  Wire.write(0x12);
  Wire.write(Hour);
  Wire.write(0x13);
  Wire.write(0x01);
  Wire.write(0x14);
  Wire.write(0x29);
  Wire.write(0x15);
  Wire.write(0x02);
  Wire.write(0x16);
  Wire.write(0x89);
  Wire.endTransmission();
void ReadRTC()
  Wire.write(0x10);
  Wire.requestFrom(RTC_ADDRESS, 1);
  byte s = Wire.read();
  Wire.write(0x11);
  byte m = Wire.read();
  Wire.write(0x12);
  byte h = Wire.read();
  Serial.println(h);
  Serial.println(m);
  Serial.println(s);
Is my code wrong or do you think I have to look for my problem somewhere else?
I'd try to address individual registers by only writing a register number and data in one transfer. For transfer of multiple registers, if ever implemented, I'd assume auto-increment and omit all register numbers but the very first.
That denotes a complete transfer of 1 byte. Either read multiple bytes in one requestFrom() or each byte in a single sequence:
  Wire.write(0x10);
Wire.endTransmission(); //write the register number
  Wire.requestFrom(RTC_ADDRESS, 1); //read the register content
I have a feeling that you did not look very hard for it. I used duckduckgo and got several pages. This is the first hit using "RX38130CE RTC module." as the search term. RX8130CE | Real Time Clock | Product | Epson crystal device It should answer all of your questions.
