It's my first time working with SMBUS and I've read the docs of arduino and the Wire object. It states that I can send a string. To quote the docs: string: a string to send as a series of bytes. write() - Arduino Reference
When I convert my int to a String type and pass it along to Wire.write, I can't read it with Python.
Slave address: `0x8`
Serial.begin(BaudRate); delay(10);
Wire.begin(SLAVE_ADDRESS); 0x8
Wire.onRequest(sendData);
sendData(1272); // right now hard-coded for testing purposes
// callback for sending data
void sendData(int data) {
String dataString = String(data);
int len = dataString.length() + 1;
char charDataString[len];
dataString.toCharArray(charDataString, len);
for (int i = 0; i < len; i++) {
Serial.println(charDataString[i]); -> SHOWS THE CORRECT VALUES
Wire.write(charDataString[i]);
My python code (how I read the data):
import smbus
import time
bus = smbus.SMBus(1)
address = 0x8
while True:
data = ""
for (i in range(0, 10))
##BOTH VARIANTS DO NOT WORK
data = bus.read_i2c_block_data(address, 99, 3)
data += chr(bus.read_byte(address));
print(data)
time.sleep(1)
I can't wrap my head around what I am doing wrong here. If there is a way to immediately send it over instead of each value individually I'd prefer that as well.
