I have an KX224 accelerometer and I want to read its buffer using I2C. There is a "Sequence 4" in datasheet (http://kionixfs.kionix.com/en/datasheet/KX224-1053-Specifications-Rev-2.0.pdf - page 21) which is supposed to replicate in order to read the buffer, but I don't know how to do it. Can someone help me?
The buffer contains accelerometer data. In order to read it, you have to read one register with one byte. Because the buffer actually contains 2048 bytes, you have to send ACK after each reading to update the next value from the FIFO.
