I have two mega boards and want to set up a simulation but before I do that I need to ensure that the master and slave acknowledge each other and then wait. I have a test master code which sends a message but the slave shows the message with some odd characters at the end of the received message. I can't find anything by search.
Master code
#include <Wire.h>
#define I2C_SLAVE_ADDRESS 0x08
Wire.begin(); // Join I2C bus as master
Serial.println("Master device ready.");
delay(5000); // Give some time for the slave to be ready
sendHandshake();
// Placeholder for logic after handshake
void sendHandshake() {
Serial.println("Attempting to send HANDSHAKE to car");
Wire.beginTransmission(I2C_SLAVE_ADDRESS);
Wire.write("HANDSHAKE");
Wire.endTransmission();
Serial.println("Sent HANDSHAKE to car");
delay(500); // Short delay to ensure the car has time to respond
Wire.requestFrom(I2C_SLAVE_ADDRESS, 1);
if (Wire.available()) {
char response = Wire.read();
Serial.print("Response from car: ");
Serial.println(response);
if (response == '1') {
Serial.println("Handshake acknowledged by car");
Serial.println("No response from car");
slave code
#include <Wire.h>
Wire.begin(0x08); // Join I2C bus as slave with address 0x08
Wire.onReceive(receiveEvent); // Register event handler for receiving data
Serial.begin(9600); // Start serial communication for debugging
Serial.println("Slave device ready.");
// Placeholder for logic after receiving the handshake
void receiveEvent(int howMany) {
delay(50); // Ensure all data is received before processing
char buffer[10];
int i = 0;
while (Wire.available() && i < sizeof(buffer) - 1) {
buffer[i++] = Wire.read();
// buffer[i] = '\0'; // Null-terminate the string
// with this buffer line above all I get is a char 're' as the message. so i remmed it out for now
Serial.print("Received message: ");
Serial.println(buffer);
String message = String(buffer);
if (message == "HANDSHAKE") {
Serial.println("Received HANDSHAKE from master");
Wire.beginTransmission(0x08);
Wire.write('1'); // Respond to handshake
Serial.println("Sent HANDSHAKE response to master");
Serial.println("Unexpected message received.");
Output Master:
Response from car: //a square block here
Output slave:
Slave device ready.
Received message: HANDSHAKE�.
I have two pullup resistors 2.2k on the scl and sda lines using shielded rj45 cable between the two devices.
Any help would be much appreciated. Apologies if I haven't explained well enough.
Regards in advance
Thank you for that advise, it was awesome.
Now the messaging is:
slave Slave device ready.
master:
No response from car, retrying...
Response from car: 1
Handshake complete, ready to start traffic light sequence.
#include <Wire.h>
bool handshakeComplete = false;
while (!handshakeComplete) {
sendHandshake();
delay(2000); // Retry every two seconds until handshake is complete
Serial.println("Handshake complete, ready to start traffic light sequence.");
// Placeholder for logic after handshake is complete
while (Wire.available()) {
handshakeComplete = true; // Set handshakeComplete to true
if (!handshakeComplete) {
Serial.println("No response from car, retrying...");
Slave:
#include <Wire.h>
Wire.onRequest(requestEvent); // Register event handler for master requests
char buffer[10];
int i = 0;
void requestEvent() {
