I2C_eeprom and saving struct
Hi I’m a total newbie into into the arduino world. Trying to make a simple sketch saving/reading data structure on a 24Lc256 using the I2C_eeprom library, but it is a bit hard.
I’ve found the code writing in the internal eeprom, and tried to change it to using the external mounted on the I2C.
My code looks like:
float f = 0.00f; //Variable to store data read from EEPROM.
int eeAddress = 0; //EEPROM address to start reading from
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print(“Demo I2C eeprom library “);
Serial.print(I2C_EEPROM_VERSION);
Serial.println(”\n”);
Serial.println("\nTEST: 64 byte page boundary writeBlock");
/** Put is designed for use with custom structures also. **/
ee.setBlock(0,0,128);
dumpEEPROM(0, 128);
for (int t = 0; t <= maxread; t++) {
//Data to store.
MyObject customVar = {
t * 3.14f,
t,
“Working!”
eeAddress += 15; //Move address to the next byte after float ‘f’.
ee.writeBlock(t,customVar, 15);
dumpEEPROM(0, 128);
I’ll aprreciate som help :wink:
(deleted)
I’d appreciate if you told us what the problem is.
It would also help to use code tags, not quote tags for source code listings.
Sorry … many new things to learn…
My problem is how to save a structure on a 24lc256 ext. eeprom connected via I2C. Haven’t found any sample-code to learn from. Just found this code saving a struct in the internal eeprom:
    eeprom_put example.
    This shows how to use the EEPROM.put() method.
    Also, this sketch will pre-set the EEPROM data for the
    example sketch eeprom_get.
    Note, unlike the single byte version EEPROM.write(),
    the put method will use update semantics. As in a byte
    will only be written to the EEPROM if the data is actually
    different.
    Written by Christopher Andrews 2015
    Released under MIT licence.
#include <EEPROM.h>
int maxread=400;
struct MyObject {
  float field1;
  byte field2;
  char name[10];
  while (!Serial) {
    //Data to store.
      t * 3.14f,
      t,
      "Working!"
    eeAddress += 15; //Move address to the next byte after float 'f'.
    EEPROM.put(eeAddress, customVar);
  Serial.print("Written custom data type! \n\nView the example sketch eeprom_get to see how you can retrieve the values!");
  secondTest();
void secondTest() {
//  int eeAddress = sizeof(float); //Move address to the next byte after float 'f'.
  MyObject customVar; //Variable to store custom object read from EEPROM.
    eeAddress +=15;
    EEPROM.get(eeAddress, customVar);
    Serial.println("Read custom object from EEPROM: ");
    Serial.println(t);
    Serial.println(customVar.field1);
    Serial.println(customVar.field2);
    Serial.println(customVar.name);
  /* Empty loop */
There is something I’ve missed in converting the code…
error: eeprom_get-put-ext:61: error: no matching function for call to ‘I2C_eeprom::writeBlock(int&, MyObject&, int)’
#include <I2C_eeprom.h>
    eeprom_put example.
    different.
#include <Wire.h> //I2C library
I2C_eeprom ee(0x50);
int maxread=400;
struct MyObject {
  float field1;
  byte field2;
  char name[10];
  while (!Serial) {
Serial.print("Demo I2C eeprom library ");
Serial.println("\n");
 // dumpEEPROM(0, 128);
    //Data to store.
      t * 3.14f,
      t,
      "Working!"
  secondTest();
void secondTest() {
    eeAddress +=15;
    Serial.println(t);
  /* Empty loop */
Hopefull this will uncover my problems…
Sincerly
Steen
Have a look how to write I2C; the internal eeprom code is not applicable, forget about it.
You can cast a struct to an array of byytes and write those bytes.
struct MYDATA
MYDATA data;
// setup used to show example of cast
  // a pointer to the struct
  byte *pdata = (byte*) data.
  // size of the MYDATA struct
  int size = sizeof(MYDATA);
If MYDATA does not contain pointers or variable length variables, you can use it to determine how many bytes you need to write.
Hi
Ok- thanks ! I'll look into it...
Sincerly Steen
Hi sterretje
Have trying to make at sketch with your surgstions, combined with som read/write procedures found on the net.
I haven’t fully understood the programming language - getting an compliation-error:
Arduino: 1.6.8 (Windows 10), Board: “Arduino Nano, ATmega328”
F:\Steen\Dokumenter\Arduino\sketch_jun12a\sketch_jun12a.ino: In function ‘void setup()’:
sketch_jun12a:26: error: expected unqualified-id before ‘int’
  • int size = sizeof(MYDATA);*
    sketch_jun12a:30: error: invalid cast from type ‘MYDATA’ to type ‘byte* {aka unsigned char*}’
    i2c_eeprom_write_page(0x50, 0, (byte *)data, sizeof(MYDATA)); // write to EEPROM
The code looks like:
    Use the I2C bus with EEPROM 24LC64
    Sketch:    eeprom.pde
    Author: hkhijhe
    Date: 01/10/2010
typedef struct { // tranmission data (6 bytes)
  uint16_t ms;
  int16_t accel;
  int16_t pres;
} MYDATA;
MYDATA data;
  Wire.begin(); // initialise the connection
  delay(10); //add a small delay
  Serial.println("Memory written");
void loop(){}
void i2c_eeprom_write_byte( int deviceaddress, unsigned int eeaddress, byte data ) {
  int rdata = data;
  Wire.beginTransmission(deviceaddress);
  Wire.write((int)(eeaddress >> 8)); // MSB
  Wire.write((int)(eeaddress & 0xFF)); // LSB
  Wire.write(rdata);
  Wire.endTransmission();
// WARNING: address is a page address, 6-bit end will wrap around
// also, data can be maximum of about 30 bytes, because the Wire library has a buffer of 32 bytes
void i2c_eeprom_write_page( int deviceaddress, unsigned int eeaddresspage, byte* data, byte length ) {
  Wire.write((int)(eeaddresspage >> 8)); // MSB
  Wire.write((int)(eeaddresspage & 0xFF)); // LSB
  byte c;
  for ( c = 0; c < length; c++)
    Wire.write(data[c]);
byte i2c_eeprom_read_byte( int deviceaddress, unsigned int eeaddress ) {
  byte rdata = 0xFF;
  Wire.requestFrom(deviceaddress, 1);
  if (Wire.available()) rdata = Wire.read();
  return rdata;
// maybe let's not read more than 30 or 32 bytes at a time!
void i2c_eeprom_read_buffer( int deviceaddress, unsigned int eeaddress, byte *buffer, int length ) {
  Wire.requestFrom(deviceaddress, length);
  int c = 0;
  for ( c = 0; c < length; c++ )
    if (Wire.available()) buffer[c] = Wire.read();
Maybe you can help me ?
Sincerly
Steen
Semicolon?
dosen't change anyhing...
nether:
byte pdata = (byte) data.;
or:
byte pdata = (byte) data;
It sure won’t hurt anything…
If data is a MYDATA object, why are you using a byte pointer? What happens if you take:
and replace it with:
//  byte *pdata = (byte*) data;
  MYDATA *pdata = &data;
  i2c_eeprom_write_page(0x50, 0, (byte *)pdata, size);    // write to EEPROM
Hi
Thanks a lot !
That gave me a step in the rigth direction…
Sincerly
Steen
Sorry, mistake from my side.
The intention is to get a pointer to a byte array that you can pass to a generic write or read function for the eeprom.
This is what it should have been :frowning:
struct MYDATA
MYDATA data;
  byte *pdata = (byte*) &data;    // <----
Note the ampersand in front of data.
Hi sterretje
Thanks for your help. I've got the writing running (I'll hope) - Now struckling to read the contense that I'd wrote. :confused:
Sincerly Steen
I don't know if your above code is still up-to-date. But the below should take the address of data and not data itself.
Change it to
  i2c_eeprom_write_page(0x50, 0, (byte *)&data, sizeof(MYDATA)); // write to EEPROM
The reading should be straight forward; use i2c_eeprom_read_buffer. The buffer will be a pointer as above
// variable to store data retrieved from eeprom
MYDATA retrievedData;
// byte pointer
byte *pData = (byte*)&retrievedData;
i2c_eeprom_read_buffer(0x50, 0, pData, sizeof(MYDATA));
No option to test this.
Hi sterretje
My code is now like this:
    Sketch:    eeprom.pde
    Author: hkhijhe
    Date: 01/10/2010
  uint16_t ms;
  int16_t accel;
  int16_t pres;
} MYDATA;
MYDATA data;
int maxread = 15;
  int eeAddress = 0;
    // Some Data to store.
    MYDATA data = {
      t * 3,
      t - 2,
      t  + 10
  //  Serial.println("Rsead custom object from EEPROM: ");
  //  Serial.println(t);
  //  Serial.println(data.ms);
  //  Serial.println(data.accel);
  //  Serial.println(data.pres);
    i2c_eeprom_write_page(0x50, eeAddress, (byte *)pdata, size);    // write to EEPROM
  secondTest();
  Serial.print("End of reading ");
//  Serial.println("DONE !");
void secondTest() {
  // byte pointer
    i2c_eeprom_read_buffer(0x50, eeAddress, pData, sizeof(MYDATA));    // write to EEPROM
    Serial.println(t);
    Serial.println(retrievedData.ms);
    Serial.println(retrievedData.accel);
    Serial.println(retrievedData.pres);
    eeAddress += 15;
  Serial.println("End of reading ");
  int rdata = data;
  Wire.write(rdata);
  byte c;
  byte rdata = 0xFF;
  return rdata;
  int c = 0;
Result is all reading is “0” - I’ve checked all the writings and they look allright. What did I miss ?
Sincerly
Steen
Hi again
Ok - found out - the small delay wat to be inside the for-look, to insure the writing finishing...
Sincerly Steen
So, working now?
YES! working.
Any thing to be aware of ? I've read the eeprom have pages. Do this read/write functions handle this ?
I'm curious and want to learn and understand these lines:
Where do I find some kind of a tutorial for newbies about this ?
Thanks for your help! I've appreciate it a lot !
Sincerly Steen
