I hope you can help me. Apparently I am to dump to run this I2C/TWI LCD1602 Module! >:(
I used the "Hello Word"-Example from the LiquidCrystal_I2C-Library which I installed.
I haven't found an example how to connect the module. All I found was always normal 16-pin interfaces like the arduino-liquidCrystal Tutorial
I've connected VCC + GND and SCL to analog pin 5 and SDA to 4. Another project used this setting for a i2c-connection. But I can't see if these are the right pins! How can I figure that out? Anywhere in the library?
When I upload Hello-word the display glows but no characters are shown
Hey, thx guys for the fast reply. It's still not working.
Year, I checked the connection. I had no resistors in the circuit and I don't have 4K-resistors left In another IC2-Arduino Project I saw a guy using just a 2K resistor for each wire. How exact has the resistor(s) to be? I tried to place them in a row. Now I have 2,3 Kohm and 2,2Kohm. No success. I changed the contrast as well.
I connected the resistors like that:
Are the LCDs easy to destroy? :-?
This is the code I used. Pretty simple:
//DFRobot.com #include <Wire.h> #include <LiquidCrystal_I2C.h> LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display void setup() { lcd.init(); // initialize the lcd // Print a message to the LCD. lcd.backlight(); lcd.print("Hello, world!"); } void loop() { }
The resistors are needed to the i2c work, without then the i2c connection will never work, and no it doesn't kill anything without then, but using something in the 4-10k would be better, 2k is pretty low and maybe the arduino cant pull the line low.
Are you sure that you have the right lcd address?
That picture you posted is not what you have implemented because it is not an LCD display that is shown. Can you post a picture of what you have.
However it is most likely the address that is wrong. There are two ways of specifying an I2C address, one with the least significant bit being the read / write line and the other with the read / write not specified.
As you have printed on the device and address of 0x27 try shifting it up and using 0x4E.
//LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display LiquidCrystal_I2C lcd(0x4E,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
mmm. I don't have a 4k7. I just read that I can use resistors from 4-10k.
So I tried my two 10k-resistors but it doesn't help. I was not sure if the resistor I used has orange or brown mulitplcator (hence 1 or 10k) so I changed them and even the arduino board.
Nothing The display glows but no information is shown. What does the blinking PMW mean? The LCD needs 5 V?! There is no datasheet ...
Ok, during the first try I didn't use a resistor either so maybe I really burned it :-/
That would be horrible. Need the display urgent and they a sold out at my local dealer here (Sydney)
Is there any way to check if it's burned or not? And yes ... I used the code from http://www.dfrobot.com and from the library. I modified it with your new adress. but ...
There is but you will need an oscilloscope. Check the clock pulses on the clock line first. If they are Ok you have to check to see if the data line is being pulled down by the LCD at the end of the address. If it is burner out (or if the address is wrong) it will not pull down. Also make sure in normal operation this line is high and not being permanently pulled down.
I do realise you might not have a scope but see if you can get access to one or even try one of the arduino scopes if you have access to more than one arudion.
If you got the last one you might have been sold a dud.
We switched the wires (of pin 4 and 5) and changed the example code. This line was the problem:
lcd.setCursor(0, 1);
The new code looks like that: ///Arduino Sample Code ///www.DFRobot.com ///Last modified on 17th September 2010 #include <Wire.h> #include <LiquidCrystal_I2C.h> LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display void setup() { lcd.init(); // initialize the lcd // Print a message to the LCD. lcd.backlight(); //lcd.setCursor(0, 1); lcd.print("Hello, world!"); } void loop() { // when characters arrive over the serial port... if (Serial.available()) { // wait a bit for the entire message to arrive delay(100); // clear the screen lcd.clear(); // read all the available characters while (Serial.available() > 0) { // display each character to the LCD lcd.write(Serial.read()); } } }
