IDE 1.x misbehaving after installation of IDE 2.x
I have both versions 2.x and 1.8 .
If I open 1.8 now I get a small ide screen top left and big white ( app box) area with the minimise /close button top right . I have to minimise the window using that , then open again to fix it .
( I’m not bothered about a fix it for this ) just wondered if this gives any insight into the OP’s issue as it seems the old 1.8 is affected after recent 2 install
I've split your comment into it's own topic.
IDE 1.x and IDE 2.x do not share anything except for the board packages and sketchbook directory.
So I doubt that it's due to the installation of IDE 2.x.
I do run IDE 1.x and IDE 2.x as well and haven't experienced problems like you describe.
As I said I wasn’t looking for a solution or would have created a separate thread - I thought the issue I described may have a bearing on this thread , maybe same cause and would assist sorting it .
Can you put it back or delete this thread , I don’t want people wasting their time on a new thread that I’m not looking at !!
I did say “
( I’m not bothered about a fix it for this ) just wondered if this gives any insight into the OP’s issue as it seems the old 1.8 is affected after recent 2 install”
I know that you were not looking for a solution. But the subject of your comment was sufficiently different from the original question that it did warrant a split (in my opinion).
I will lock this topic so people can not reply and will not waste their time.
If you don't agree with the lock you can contact me via PM or flag one of the posts.
