Hello,
I have installed IDE 2.0.0. cli0.27.1 (previouly I have used 1.... working perfectly).
The serial monitor is not working at all. I suspect the baud rate.
In the sketch I set the baud rate to 9600.
In the serial monitor windows, below the sketch, I should have the baud rate drop down list at the right of the "carriage return" drop down list. But nothing.
Does someone have an idea to reveal that baud rate dropdown list.
Many thanks
Your duplicate topic has been deleted
Hi @brunodup. Do you have a board and port selected in the Tools > Board and Tools > Port menus in the Arduino IDE?
Hi, thanks for answer. Yes of course, the board selected is a mega 2560, and COM3.
I can compile and upload the sketch to that com port. And the program runs, but this is impossible to have any monitoring as the serial port stays "blank". The problem is I can't setup the serial port baud rate as I don't have the menu.
Anyway, I have a workaround, as I have installed the old IDE 1.8, where the serial monitor works fine with that board and that serial COM, and V 1.8 is much more faster to load anyway.
Sorry, thanks a lot.
No problem. I understand why you did it, but you could have flagged the original for the attentions of the moderators and asked for it to be moved
I'm sorry Arduino IDE 2.x did not work for you. If you ever decide to give it another try I will be happy to help you to fix this problem with Serial Monitor. It is usually caused by the antivirus software interfering with the installation of the serial-monitor tool. Once the tool is restored from the antivirus quarantine the Serial Monitor works as expected.
OK, thanks.
I had windows 10. Propably defender installed by default. Installed IDE 2.0. Sometimes ago, I had the impression that serial monitor was working, not sure. Install afterwads Avast antivirus, maybe avast induce the problem. Here Serial monitor was not working for sure. Anyway, my computer was very slow, I decide to remove avast. Same problem, Serial monitor not working.
Off course I want to do another try and not use the old version. I shall try it tomorrow..... Maybe reinstall from scratch.
I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
- Start Windows "File Explorer".
- Open the Arduino IDE installation folder.
(usuallyC:\Program Files\Arduino IDEorC:\Users\<user name>\AppData\Local\Programs\Arduino IDE). - In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
- From the context menu, click "Open PowerShell window here".
PowerShell will now open with the current directory set to the Arduino IDE installation folder. - Type the following command:
& ".\Arduino IDE" - Press the Enter key.
Debug output should now be printed to the PowerShell window as the Arduino IDE starts (or fails to start). - Wait for the Arduino IDE to finish starting.
- Switch back to the PowerShell window if the Arduino IDE window took the focus.
- Right click on the title bar of the PowerShell window.
This will open a context menu. - Select Edit > Select All from the context menu.
This will select all the text in the PowerShell window. - Press Ctrl+C.
This will copy the contents of the PowerShell window to the clipboard. - Open a forum reply here by clicking the Reply button.
- Click the
</>icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
- Press Ctrl+V.
This will paste the output into the code block. - Move the cursor outside of the code block markup before you add any additional text to your reply.
- Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
The IDE automatically installs new versions of the serial-monitor tool as they are released by Arduino. If an update of that tool fails, it can result in the Serial Monitor becoming non-functional even though it was previously working fine.
Hello,
Here the debug info. At this the COM port was not connected because I move my laptop to the office, far away of the arduino
+ & ".\Arduino IDE
+ CategoryInfo : ObjectNotFound: (.\Arduino IDE
:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
PS C:\Users\bruno\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Starting backend process. PID: 9132
Using browser-only version of superagent in non-browser environment
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
root INFO Configuration directory URI: 'file:///c%3A/Users/bruno/.theia'
root INFO Backend Object.initialize: 8.4 ms [Finished 6.679 s after backend start]
root INFO Backend Object.configure: 6.2 ms [Finished 6.679 s after backend start]
root INFO Backend MessagingContribution.onStart: 3.1 ms [Finished 6.679 s after backend start]
root INFO Backend OSBackendApplicationContribution.configure: 0.8 ms [Finished 7.092 s after backend start]
root INFO Backend DefaultWorkspaceServer.onStart: 0.7 ms [Finished 7.093 s after backend start]
root INFO Backend LocalizationBackendContribution.configure: 0.5 ms [Finished 7.093 s after backend start]
root WARN Backend LocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 413.6 ms [Finished 7.094 s after backend start]
root INFO Backend TaskBackendApplicationContribution.onStart: 0.5 ms [Finished 7.094 s after backend start]
root INFO Backend ElectronTokenBackendContribution.configure: 2.7 ms [Finished 7.097 s after backend start]
root INFO Backend PluginDeployerContribution.initialize: 0.9 ms [Finished 7.097 s after backend start]
root INFO Backend ConfigServiceImpl.onStart: 1.7 ms [Finished 7.099 s after backend start]
root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.8 ms [Finished 7.101 s after backend start]
root INFO Backend ArduinoDaemonImpl.onStart: 2.2 ms [Finished 7.102 s after backend start]
root INFO Backend NodeFileUploadService.configure: 4.4 ms [Finished 7.103 s after backend start]
daemon INFO Starting daemon from C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
discovery-log INFO start
discovery-log INFO start new deferred
root INFO Backend BoardDiscovery.onStart: 1.8 ms [Finished 7.106 s after backend start]
root INFO Backend FileDownloadEndpoint.configure: 1.1 ms [Finished 7.106 s after backend start]
root INFO Backend AuthenticationServiceImpl.onStart: 0.9 ms [Finished 7.109 s after backend start]
root INFO Backend PluginApiContribution.configure: 5.0 ms [Finished 7.113 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.7 ms [Finished 7.115 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 7.116 s after backend start]
root INFO Backend PlotterBackendContribution.configure: 2.2 ms [Finished 7.119 s after backend start]
root INFO Theia app listening on http://localhost:65422.
root INFO Finished starting backend application: 11.8 ms [Finished 7.126 s after backend start]
root WARN The local plugin referenced by local-dir:/c%3A/Users/bruno/.arduinoIDE/extensions does not exist.
root WARN The local plugin referenced by local-dir:/c%3A/Users/bruno/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:C:\Users\bruno\.arduinoProIDE\plugins does not exist.
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.69.0" with engines:
root ERROR ---- !!!SLOW!!! DURATION: loadCliConfig took 132.912 ms. Args: [] ----
root INFO Resolve plugins list: 214.7 ms [Finished 7.322 s after backend start]
root INFO Deployed backend plugin "cortex-debug@0.3.10" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension": 15.7 ms [Finished 7.339 s after backend start]
root INFO Deployed backend plugin "vscode-arduino-tools@0.0.2-beta.5" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 15.6 ms [Finished 7.354 s after backend start]
root INFO Deployed backend plugin "cpp@1.52.1" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 69.6 ms [Finished 7.424 s after backend start]
root INFO Deployed backend plugin "json@1.46.1" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 64.6 ms [Finished 7.489 s after backend start]
root INFO Deployed backend plugin "json-language-features@1.46.1" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 2.4 ms [Finished 7.491 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-cs@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 1253.4 ms [Finished 8.745 s after backend start]
daemon INFO {"level":"info","msg":"Using config file: c:\\Users\\bruno\\.arduinoIDE\\arduino-cli.yaml","time":"2022-10-17T23:40:02+02:00"}
{"level":"info","msg":"arduino-cli.exe version 0.27.1","time":"2022-10-17T23:40:02+02:00"}
{"level":"info","msg":"Executing `arduino-cli daemon`","time":"2022-10-17T23:40:02+02:00"}
{"IP":"127.0.0.1","Port":"65423"}
daemon INFO Daemon is running.
root INFO Deployed backend plugin "vscode-language-pack-de@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 556.0 ms [Finished 9.301 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-es@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 479.7 ms [Finished 9.780 s after backend start]
daemon INFO {"level":"info","msg":"Loading hardware from: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages","time":"2022-10-17T23:40:03+02:00"}
{"level":"info","msg":"Loading package arduino from: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware","time":"2022-10-17T23:40:03+02:00"}
{"error":"opening signature file: open C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json.sig: Le fichier sp├®cifi├® est introuvable.","index":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json.sig","time":"2022-10-17T23:40:03+02:00"}
{"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2022-10-17T23:40:03+02:00","tool":"builtin:serial-monitor"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.5","Latest":"1.8.5","Name":"Arduino AVR Boards"},"time":"2022-10-17T23:40:03+02:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-10-17T23:40:03+02:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-10-17T23:40:03+02:00"}
{"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:03+02:00","tool":{"version":"1.3.0","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_386.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_386.tar.bz2","Checksum":"SHA-256:3e7f59d6fbc7a724598303f0d3289d0c4fd137a8973437980658379a024887b2","Size":2633516,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_amd64.tar.bz2","Checksum":"SHA-256:aa45ee2441ffc3a122daec5802941d1fa2ac47adf5c5c481b5e0daa4dc259ffa","Size":2716248,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm.tar.bz2","Checksum":"SHA-256:1888587409b56aef4ba0ab0e6703b3dccba7cc3a022756ba9b908247e5d5a656","Size":2567435,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm64.tar.bz2","Checksum":"SHA-256:835ed8f37cffac37e979d1b0f6041559592d3d98be52f0e8611b76c4858e4113","Size":2472427,"CachePath":"packages"}},{"os":"i386-apple-darwin11","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-darwin_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-darwin_amd64.tar.bz2","Checksum":"SHA-256:d5d0f82ff829c0e434d12a2ee640a6fbd78f893ab37782edbb8b5bf2359d119e","Size":2766116,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-windows_386.zip","ArchiveFileName":"arduinoOTA-1.3.0-windows_386.zip","Checksum":"SHA-256:051943844eee442460d2c709edefadca184287fffd2b6c100dd53aa742aa05f6","Size":2768948,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:03+02:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","Checksum":"SHA-256:3903553d035da59e33cff9941b857c3cb379cb0638105dfdf69c97f0acc8e7b5","Size":34683056,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:03d322b9df6da17289e9e7c6233c34a8535d9c645c19efc772ba19e56914f339","Size":38045723,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","Checksum":"SHA-256:f6ed2346953fcf88df223469088633eb86de997fa27ece117fd1ef170d69c1f8","Size":36684546,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","Checksum":"SHA-256:a54f64755fff4cb792a1495e5defdd789902a2a3503982e81b898299cf39800e","Size":52519412,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:954bbffb33545bcdcd473af993da2980bf32e8461ff55a18e0eebc7b2ef69a4c","Size":37176991,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:bd8c37f6952a2130ac9ee32c53f6a660feb79bee8353c8e289eb60fdcefed91e","Size":37630618,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:03+02:00","tool":{"version":"6.3.0-arduino17","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:2a8e68c5d803aa6f902ef219f177ec3a4c28275d85cbe272962ad2cd374f50d1","Size":219631,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:6cf948f751acfe7b96684537f2291c766ec8b54b4f7dc95539864821456fa9fc","Size":229852,"CachePath":"packages"}},{"os":"x86_64-apple-darwin12","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","Checksum":"SHA-256:120cc9edaae699e7e9ac50b1b8eb0e7d51fdfa555bac54233c2511e6ee5418c9","Size":279045,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:accdfb920af2aabf4f7461d2ac73c0751760f525216dc4e7657427a78c60d13d","Size":254271,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:5c8cc6c17db9300e1451fe41cd7178b0442b4490ee6fdbc0aed9811aef96c05f","Size":244550,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","Checksum":"SHA-256:e99188873c7c5ad8f8f906f068c33600e758b2e36cce3adbd518a21bd266749d","Size":328460,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loading package builtin from: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\builtin","time":"2022-10-17T23:40:03+02:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-10-17T23:40:03+02:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-10-17T23:40:03+02:00"}
{"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:03+02:00","tool":{"version":"5.8-arduino11","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:03+02:00","tool":{"version":"1.0.6","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:03+02:00","tool":{"version":"1.3.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:03+02:00","tool":{"version":"0.10.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:03+02:00","tool":{"version":"0.9.1","systems":null}}
{"index":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\package_index.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\package_index.json.sig","time":"2022-10-17T23:40:03+02:00","trusted":true}
{"dir":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-10-17T23:40:03+02:00"}
{"index":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\library_index.json","level":"info","msg":"Loading libraries index file","time":"2022-10-17T23:40:03+02:00"}
root INFO Deployed backend plugin "vscode-language-pack-fr@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 397.5 ms [Finished 10.178 s after backend start]
daemon INFO {"dir":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-10-17T23:40:03+02:00"}
{"dir":"C:\\Users\\bruno\\Documents\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-10-17T23:40:03+02:00"}
root INFO Deployed backend plugin "vscode-language-pack-it@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 468.3 ms [Finished 10.646 s after backend start]
discovery-log INFO start request start watch
discovery-log INFO start requested start watch
discovery-log INFO start resolved watching
daemon INFO {"level":"info","msg":"starting discovery builtin:mdns-discovery process","time":"2022-10-17T23:40:04+02:00"}
{"level":"info","msg":"starting discovery builtin:serial-discovery process","time":"2022-10-17T23:40:04+02:00"}
root INFO Deployed backend plugin "vscode-language-pack-ja@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 463.5 ms [Finished 11.110 s after backend start]
daemon INFO {"level":"info","msg":"started discovery builtin:serial-discovery process","time":"2022-10-17T23:40:04+02:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:serial-discovery","time":"2022-10-17T23:40:04+02:00"}
{"level":"info","msg":"started discovery builtin:mdns-discovery process","time":"2022-10-17T23:40:04+02:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:mdns-discovery","time":"2022-10-17T23:40:04+02:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-10-17T23:40:04+02:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:serial-discovery","time":"2022-10-17T23:40:04+02:00"}
{"level":"info","msg":"from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-10-17T23:40:04+02:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: start_sync, message: OK","time":"2022-10-17T23:40:04+02:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:mdns-discovery","time":"2022-10-17T23:40:04+02:00"}
{"level":"info","msg":"from discovery builtin:mdns-discovery received message type: start_sync, message: OK","time":"2022-10-17T23:40:04+02:00"}
root INFO Deployed backend plugin "vscode-language-pack-nl@1.48.3" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 120.3 ms [Finished 11.230 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-pt-BR@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 316.5 ms [Finished 11.547 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ru@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 358.3 ms [Finished 11.905 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-tr@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 356.0 ms [Finished 12.261 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-zh-hans@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 1785.6 ms [Finished 14.047 s after backend start]
root INFO Deploy plugins list: 214.7 ms [Finished 14.069 s after backend start]
root WARN Frontend s.configure took longer than the expected maximum 100 milliseconds: 1916.1 ms [Finished 6.693 s after frontend start]
root WARN Frontend C.onStart took longer than the expected maximum 100 milliseconds: 215.9 ms [Finished 7.177 s after frontend start]
root WARN Frontend l.onStart took longer than the expected maximum 100 milliseconds: 122.0 ms [Finished 7.304 s after frontend start]
app-state-change >>> new app state <started_contributions was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <started_contributions> for window <1>
root INFO Start frontend contributions: 2691.3 ms [Finished 7.323 s after frontend start]
root INFO Changed application state from 'init' to 'started_contributions'.
app-state-change >>> new app state <attached_shell was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <attached_shell> for window <1>
root INFO Changed application state from 'started_contributions' to 'attached_shell'.
root INFO >>> Restoring the layout state...
root INFO ------- SERIALIZED LAYOUT DATA -------
root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"kind":"navigatable","uri":"file:///c%3A/Users/bruno/Documents/Arduino/DevAqua_V53/DevAqua_V53.ino","counter":0}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":892,\"column\":31},\"position\":{\"lineNumber\":892,\"column\":31}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":882,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":1460,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":true}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"},{"constructionOptions":{"factoryId":"serial-monitor"}}],"currentIndex":1}},"pinned":[false,false],"size":232,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":0.20045558086560364,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":0.20045558086560364,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":0.19817767653758542,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":0.20045558086560364,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":0.20045558086560364,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":248},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"serial-monitor"}
root INFO ------- END SERIALIZED LAYOUT DATA -------
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57] Waiting for backend deployment: 370.5 ms [Finished 7.681 s after frontend start]
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 245.330 ms. Args: [{"uri":"file:///c%3A/Users/bruno/Documents/Arduino"}] ----
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792) starting instance
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57] Sync of 16 plugins: 1575.4 ms [Finished 9.256 s after frontend start]
root INFO <<< The layout has been successfully restored.
app-state-change >>> new app state <initialized_layout was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <initialized_layout> for window <1>
root INFO Initialize the workbench layout: 2845.5 ms [Finished 10.300 s after frontend start]
root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][marus25.cortex-debug]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][vscode.cpp]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][vscode.json]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][vscode.json-language-features]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57] Load contributions of 16 plugins: 263.6 ms [Finished 10.566 s after frontend start]
root WARN Frontend I.onDidInitializeLayout took longer than the expected maximum 100 milliseconds: 270.8 ms [Finished 10.572 s after frontend start]
root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
root WARN a registered grammar configuration for 'cpp' language is overridden
app-state-change >>> new app state <ready was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <ready> for window <1>
root INFO Frontend application start: 5812.9 ms [Finished 20.042 s after backend start]
root INFO Replace loading indicator with ready workbench UI (animation): 1148.9 ms [Finished 11.726 s after frontend start]
root INFO Changed application state from 'initialized_layout' to 'ready'.
root ERROR ---- !!!SLOW!!! DURATION: installed took 101.567 ms. Args: [{}] ----
root INFO Executing startup tasks: []
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 181.153 ms. Args: [{}] ----
Checking for update
daemon INFO {"level":"info","msg":"Updating libraries index","time":"2022-10-17T23:40:14+02:00"}
daemon INFO {"level":"info","msg":"URL: https://downloads.arduino.cc/packages/package_index.tar.bz2","time":"2022-10-17T23:40:14+02:00"}
{"level":"info","msg":"Updating index","time":"2022-10-17T23:40:14+02:00","url":{"Scheme":"https","Opaque":"","User":null,"Host":"downloads.arduino.cc","Path":"/packages/package_index.tar.bz2","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
root INFO ---- DURATION: installed took 61.026 ms. Args: [{"fqbn":"arduino:avr:mega"}] ----
root INFO core-client-provider [platform-index]
root INFO core-client-provider [library-index]
Update for version 2.0.0 is not available (latest version: 2.0.0, downgrade is allowed).
root INFO ---- DURATION: installed took 55.719 ms. Args: [{"fqbn":"arduino:avr:mega"}] ----
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): PluginManagerExtImpl/init()
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(cortex-debug@0.3.10 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 9792] Debugger contribution has been registered: cortex-debug
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(vscode-arduino-tools@0.0.2-beta.5 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(cpp@1.52.1 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(json@1.46.1 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(json-language-features@1.46.1 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(vscode-language-pack-cs@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(vscode-language-pack-de@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(vscode-language-pack-es@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(vscode-language-pack-fr@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(vscode-language-pack-it@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(vscode-language-pack-ja@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(vscode-language-pack-pt-BR@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(vscode-language-pack-ru@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(vscode-language-pack-tr@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): initializing(vscode-language-pack-zh-hans@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root ERROR ---- !!!SLOW!!! DURATION: search took 3389.841 ms. Args: [{"type":"Updatable"}] ----
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): PluginManagerExtImpl/loadPlugin(C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
root INFO [hosted-plugin: 9792] PLUGIN_HOST(9792): PluginManagerExtImpl/loadPlugin(C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][marus25.cortex-debug]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][arduino.vscode-arduino-tools]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][vscode.cpp]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][vscode.json]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][vscode.json-language-features]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-cs]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-de]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-es]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-fr]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-it]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-ja]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-nl]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-ru]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-tr]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
root INFO [720dcf20-e44f-41bb-b56d-aee762a45c57] Start of 16 plugins: 6567.7 ms [Finished 17.167 s after frontend start]
root INFO Starting language server: arduino:avr:mega
daemon INFO {"level":"info","msg":"Searching tools required for board arduino:avr:mega","time":"2022-10-17T23:40:19+02:00"}
daemon INFO {"level":"info","msg":"Required tool","time":"2022-10-17T23:40:19+02:00","tool":{"ToolName":"arduinoOTA","ToolVersion":"1.3.0","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-17T23:40:19+02:00","tool":{"ToolName":"avr-gcc","ToolVersion":"7.3.0-atmel3.6.1-arduino7","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-17T23:40:19+02:00","tool":{"ToolName":"avrdude","ToolVersion":"6.3.0-arduino17","ToolPackager":"arduino"}}
{"dir":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-10-17T23:40:19+02:00"}
{"dir":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-10-17T23:40:19+02:00"}
{"dir":"C:\\Users\\bruno\\Documents\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-10-17T23:40:19+02:00"}
daemon INFO {"level":"info","msg":"Resolving include VirtuinoCM.h for arch avr","time":"2022-10-17T23:40:21+02:00"}
{"level":"info","lib":"VirtuinoCM","msg":" found better lib","prio":"643","time":"2022-10-17T23:40:21+02:00"}
daemon INFO {"level":"info","msg":"Resolving include OneWire.h for arch avr","time":"2022-10-17T23:40:21+02:00"}
daemon INFO {"level":"info","lib":"OneWire","msg":" found better lib","prio":"643","time":"2022-10-17T23:40:21+02:00"}
daemon INFO {"level":"info","msg":"Resolving include DallasTemperature.h for arch avr","time":"2022-10-17T23:40:21+02:00"}
{"level":"info","lib":"DallasTemperature","msg":" found better lib","prio":"643","time":"2022-10-17T23:40:21+02:00"}
daemon INFO {"level":"info","msg":"Resolving include DFRobot_PH.h for arch avr","time":"2022-10-17T23:40:22+02:00"}
daemon INFO {"level":"info","lib":"DFRobot_PH","msg":" found better lib","prio":"643","time":"2022-10-17T23:40:22+02:00"}
daemon INFO {"level":"info","msg":"Resolving include EEPROM.h for arch avr","time":"2022-10-17T23:40:22+02:00"}
{"level":"info","lib":"EEPROM","msg":" found better lib","prio":"64C","time":"2022-10-17T23:40:22+02:00"}
daemon INFO {"level":"info","msg":"Loading hardware from: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages","time":"2022-10-17T23:40:22+02:00"}
daemon INFO {"level":"info","msg":"Loading package arduino from: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware","time":"2022-10-17T23:40:22+02:00"}
daemon INFO {"error":"opening signature file: open C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json.sig: Le fichier sp├®cifi├® est introuvable.","index":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json.sig","time":"2022-10-17T23:40:22+02:00"}
daemon INFO {"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2022-10-17T23:40:22+02:00","tool":"builtin:serial-monitor"}
daemon INFO {"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.5","Latest":"1.8.5","Name":"Arduino AVR Boards"},"time":"2022-10-17T23:40:22+02:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-10-17T23:40:22+02:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-10-17T23:40:22+02:00"}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:22+02:00","tool":{"version":"1.3.0","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_386.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_386.tar.bz2","Checksum":"SHA-256:3e7f59d6fbc7a724598303f0d3289d0c4fd137a8973437980658379a024887b2","Size":2633516,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_amd64.tar.bz2","Checksum":"SHA-256:aa45ee2441ffc3a122daec5802941d1fa2ac47adf5c5c481b5e0daa4dc259ffa","Size":2716248,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm.tar.bz2","Checksum":"SHA-256:1888587409b56aef4ba0ab0e6703b3dccba7cc3a022756ba9b908247e5d5a656","Size":2567435,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm64.tar.bz2","Checksum":"SHA-256:835ed8f37cffac37e979d1b0f6041559592d3d98be52f0e8611b76c4858e4113","Size":2472427,"CachePath":"packages"}},{"os":"i386-apple-darwin11","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-darwin_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-darwin_amd64.tar.bz2","Checksum":"SHA-256:d5d0f82ff829c0e434d12a2ee640a6fbd78f893ab37782edbb8b5bf2359d119e","Size":2766116,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-windows_386.zip","ArchiveFileName":"arduinoOTA-1.3.0-windows_386.zip","Checksum":"SHA-256:051943844eee442460d2c709edefadca184287fffd2b6c100dd53aa742aa05f6","Size":2768948,"CachePath":"packages"}}]}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:22+02:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","Checksum":"SHA-256:3903553d035da59e33cff9941b857c3cb379cb0638105dfdf69c97f0acc8e7b5","Size":34683056,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:03d322b9df6da17289e9e7c6233c34a8535d9c645c19efc772ba19e56914f339","Size":38045723,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","Checksum":"SHA-256:f6ed2346953fcf88df223469088633eb86de997fa27ece117fd1ef170d69c1f8","Size":36684546,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","Checksum":"SHA-256:a54f64755fff4cb792a1495e5defdd789902a2a3503982e81b898299cf39800e","Size":52519412,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:954bbffb33545bcdcd473af993da2980bf32e8461ff55a18e0eebc7b2ef69a4c","Size":37176991,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:bd8c37f6952a2130ac9ee32c53f6a660feb79bee8353c8e289eb60fdcefed91e","Size":37630618,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:22+02:00","tool":{"version":"6.3.0-arduino17","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:2a8e68c5d803aa6f902ef219f177ec3a4c28275d85cbe272962ad2cd374f50d1","Size":219631,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:6cf948f751acfe7b96684537f2291c766ec8b54b4f7dc95539864821456fa9fc","Size":229852,"CachePath":"packages"}},{"os":"x86_64-apple-darwin12","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","Checksum":"SHA-256:120cc9edaae699e7e9ac50b1b8eb0e7d51fdfa555bac54233c2511e6ee5418c9","Size":279045,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:accdfb920af2aabf4f7461d2ac73c0751760f525216dc4e7657427a78c60d13d","Size":254271,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:5c8cc6c17db9300e1451fe41cd7178b0442b4490ee6fdbc0aed9811aef96c05f","Size":244550,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","Checksum":"SHA-256:e99188873c7c5ad8f8f906f068c33600e758b2e36cce3adbd518a21bd266749d","Size":328460,"CachePath":"packages"}}]}}
daemon INFO {"level":"info","msg":"Loading package builtin from: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\builtin","time":"2022-10-17T23:40:22+02:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-10-17T23:40:22+02:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-10-17T23:40:22+02:00"}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:22+02:00","tool":{"version":"5.8-arduino11","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:22+02:00","tool":{"version":"1.0.6","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:22+02:00","tool":{"version":"1.3.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:22+02:00","tool":{"version":"0.10.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-17T23:40:22+02:00","tool":{"version":"0.9.1","systems":null}}
daemon INFO {"index":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\package_index.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\package_index.json.sig","time":"2022-10-17T23:40:22+02:00","trusted":true}
daemon INFO {"level":"info","msg":"Resolving include Wire.h for arch avr","time":"2022-10-17T23:40:22+02:00"}
daemon INFO {"level":"info","lib":"Wire","msg":" found better lib","prio":"64C","time":"2022-10-17T23:40:22+02:00"}
daemon INFO {"level":"info","msg":"Resolving include LiquidCrystal_I2C.h for arch avr","time":"2022-10-17T23:40:22+02:00"}
daemon INFO {"level":"info","lib":"LiquidCrystal_I2C-1.1.2","msg":" found better lib","prio":"5E9","time":"2022-10-17T23:40:22+02:00"}
daemon INFO {"dir":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-10-17T23:40:25+02:00"}
daemon INFO {"index":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\library_index.json","level":"info","msg":"Loading libraries index file","time":"2022-10-17T23:40:25+02:00"}
daemon INFO {"dir":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-10-17T23:40:26+02:00"}
daemon INFO {"dir":"C:\\Users\\bruno\\Documents\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-10-17T23:40:26+02:00"}
daemon INFO {"level":"info","msg":"Searching tools required for board arduino:avr:mega","time":"2022-10-17T23:40:26+02:00"}
daemon INFO {"level":"info","msg":"Required tool","time":"2022-10-17T23:40:26+02:00","tool":{"ToolName":"arduinoOTA","ToolVersion":"1.3.0","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-17T23:40:26+02:00","tool":{"ToolName":"avr-gcc","ToolVersion":"7.3.0-atmel3.6.1-arduino7","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-17T23:40:26+02:00","tool":{"ToolName":"avrdude","ToolVersion":"6.3.0-arduino17","ToolPackager":"arduino"}}
discovery-log INFO restarting before stop
discovery-log INFO stop
discovery-log INFO >>> Stopping boards watcher...
discovery-log INFO Canceling boards watcher...
discovery-log INFO disposing requesting cancel
discovery-log INFO disposing canceled
discovery-log INFO error received
discovery-log INFO cancel error received!
discovery-log INFO stop received event: either end or cancel
discovery-log INFO stop stopped
discovery-log INFO received end
discovery-log INFO restarting after stop
daemon INFO {"level":"info","msg":"boards watcher stream closed","time":"2022-10-17T23:40:26+02:00"}
{"level":"info","msg":"starting discovery builtin:mdns-discovery process","time":"2022-10-17T23:40:26+02:00"}
daemon INFO {"level":"info","msg":"starting discovery builtin:serial-discovery process","time":"2022-10-17T23:40:26+02:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:mdns-discovery process","time":"2022-10-17T23:40:26+02:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:mdns-discovery","time":"2022-10-17T23:40:26+02:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:serial-discovery process","time":"2022-10-17T23:40:26+02:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:serial-discovery","time":"2022-10-17T23:40:26+02:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-10-17T23:40:26+02:00"}
daemon INFO {"level":"info","msg":"sending command START_SYNC to discovery builtin:mdns-discovery","time":"2022-10-17T23:40:26+02:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:mdns-discovery received message type: start_sync, message: OK","time":"2022-10-17T23:40:26+02:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-10-17T23:40:26+02:00"}
daemon INFO {"level":"info","msg":"sending command START_SYNC to discovery builtin:serial-discovery","time":"2022-10-17T23:40:26+02:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: start_sync, message: OK","time":"2022-10-17T23:40:27+02:00"}
Sorry, I left out a couple of steps. It is necessary to open the Serial Monitor. I'll provide the full instructions this time. It will be necessary for you to have access to your Arduino board because a serial port must be selected in order for the Serial Monitor to initialize.
Please do this:
- Select your board and port from the Arduino IDE menus.
- If it is not already open, select Tools > Serial Monitor to open the Serial Monitor view in the Arduino IDE.
- Switch back to the PowerShell window.
- Click the
- Press Ctrl+V.
Here the debug info. The com port is COM3 and is working correctly as I can upload the compiled sketch.
I notice that error in the debug:
ERROR Request startMonitor failed with error: 13 INTERNAL: Port monitor error: fork/exec C:\Users\bruno\AppData\Local\Arduino15\packages\builtin\tools\serial-monitor\0.10.0\serial-monitor.exe: Le fichier ou le r├®pertoire est endommag├® et illisible.
At the end I did a dir for that file. Seems to there correctly. But is that the good one?
Additionally I have a development desktop. Where I had IDE 2.0 Beta3. Which was working correctly. Then I install the official IDE 2.0. Result, same problem, no serial monitor. Impossible to go backward, as I don't have anymore the Beta3 kit, and is not more available on internet.
Starting backend process. PID: 5892
root INFO Backend Object.initialize: 8.6 ms [Finished 2.836 s after backend start]
root INFO Backend Object.configure: 6.2 ms [Finished 2.836 s after backend start]
root INFO Backend MessagingContribution.onStart: 3.1 ms [Finished 2.836 s after backend start]
root INFO Backend OSBackendApplicationContribution.configure: 0.7 ms [Finished 2.925 s after backend start]
root INFO Backend DefaultWorkspaceServer.onStart: 0.6 ms [Finished 2.925 s after backend start]
root INFO Backend LocalizationBackendContribution.configure: 0.4 ms [Finished 2.926 s after backend start]
root WARN Backend LocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 89.4 ms [Finished 2.926 s after backend start]
root INFO Backend TaskBackendApplicationContribution.onStart: 0.5 ms [Finished 2.926 s after backend start]
root INFO Backend ElectronTokenBackendContribution.configure: 2.5 ms [Finished 2.929 s after backend start]
root INFO Backend PluginDeployerContribution.initialize: 1.0 ms [Finished 2.930 s after backend start]
root INFO Backend ConfigServiceImpl.onStart: 1.8 ms [Finished 2.931 s after backend start]
root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.8 ms [Finished 2.933 s after backend start]
root INFO Backend ArduinoDaemonImpl.onStart: 2.3 ms [Finished 2.935 s after backend start]
root INFO Backend NodeFileUploadService.configure: 4.5 ms [Finished 2.935 s after backend start]
root INFO Backend BoardDiscovery.onStart: 4.4 ms [Finished 2.941 s after backend start]
root INFO Backend FileDownloadEndpoint.configure: 1.0 ms [Finished 2.941 s after backend start]
root INFO Backend AuthenticationServiceImpl.onStart: 0.9 ms [Finished 2.944 s after backend start]
root INFO Backend PluginApiContribution.configure: 1.1 ms [Finished 2.944 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.6 ms [Finished 2.946 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 2.946 s after backend start]
root INFO Backend PlotterBackendContribution.configure: 2.1 ms [Finished 2.949 s after backend start]
root INFO Theia app listening on http://localhost:50651.
root INFO Finished starting backend application: 10.3 ms [Finished 2.955 s after backend start]
root ERROR ---- !!!SLOW!!! DURATION: loadCliConfig took 152.974 ms. Args: [] ----
root INFO Resolve plugins list: 238.3 ms [Finished 3.180 s after backend start]
root INFO Deployed backend plugin "cortex-debug@0.3.10" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension": 68.9 ms [Finished 3.255 s after backend start]
root INFO Deployed backend plugin "vscode-arduino-tools@0.0.2-beta.5" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 17.6 ms [Finished 3.272 s after backend start]
root INFO Deployed backend plugin "cpp@1.52.1" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 30.6 ms [Finished 3.303 s after backend start]
root INFO Deployed backend plugin "json@1.46.1" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 30.2 ms [Finished 3.333 s after backend start]
root INFO Deployed backend plugin "json-language-features@1.46.1" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 2.3 ms [Finished 3.336 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-cs@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 309.3 ms [Finished 3.645 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-de@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 263.4 ms [Finished 3.908 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-es@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 299.6 ms [Finished 4.208 s after backend start]
daemon INFO {"level":"info","msg":"Using config file: c:\\Users\\bruno\\.arduinoIDE\\arduino-cli.yaml","time":"2022-10-18T17:25:16+02:00"}
{"level":"info","msg":"arduino-cli.exe version 0.27.1","time":"2022-10-18T17:25:16+02:00"}
{"level":"info","msg":"Executing `arduino-cli daemon`","time":"2022-10-18T17:25:16+02:00"}
{"IP":"127.0.0.1","Port":"50652"}
root INFO Deployed backend plugin "vscode-language-pack-fr@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 322.7 ms [Finished 4.531 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-it@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 328.4 ms [Finished 4.859 s after backend start]
daemon INFO {"level":"info","msg":"Loading hardware from: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages","time":"2022-10-18T17:25:17+02:00"}
{"level":"info","msg":"Loading package arduino from: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware","time":"2022-10-18T17:25:17+02:00"}
{"error":"opening signature file: open C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json.sig: Le fichier sp├®cifi├® est introuvable.","index":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json.sig","time":"2022-10-18T17:25:17+02:00"}
{"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2022-10-18T17:25:17+02:00","tool":"builtin:serial-monitor"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.5","Latest":"1.8.5","Name":"Arduino AVR Boards"},"time":"2022-10-18T17:25:17+02:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-10-18T17:25:17+02:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-10-18T17:25:17+02:00"}
{"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:17+02:00","tool":{"version":"1.3.0","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_386.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_386.tar.bz2","Checksum":"SHA-256:3e7f59d6fbc7a724598303f0d3289d0c4fd137a8973437980658379a024887b2","Size":2633516,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_amd64.tar.bz2","Checksum":"SHA-256:aa45ee2441ffc3a122daec5802941d1fa2ac47adf5c5c481b5e0daa4dc259ffa","Size":2716248,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm.tar.bz2","Checksum":"SHA-256:1888587409b56aef4ba0ab0e6703b3dccba7cc3a022756ba9b908247e5d5a656","Size":2567435,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm64.tar.bz2","Checksum":"SHA-256:835ed8f37cffac37e979d1b0f6041559592d3d98be52f0e8611b76c4858e4113","Size":2472427,"CachePath":"packages"}},{"os":"i386-apple-darwin11","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-darwin_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-darwin_amd64.tar.bz2","Checksum":"SHA-256:d5d0f82ff829c0e434d12a2ee640a6fbd78f893ab37782edbb8b5bf2359d119e","Size":2766116,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-windows_386.zip","ArchiveFileName":"arduinoOTA-1.3.0-windows_386.zip","Checksum":"SHA-256:051943844eee442460d2c709edefadca184287fffd2b6c100dd53aa742aa05f6","Size":2768948,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:17+02:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","Checksum":"SHA-256:3903553d035da59e33cff9941b857c3cb379cb0638105dfdf69c97f0acc8e7b5","Size":34683056,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:03d322b9df6da17289e9e7c6233c34a8535d9c645c19efc772ba19e56914f339","Size":38045723,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","Checksum":"SHA-256:f6ed2346953fcf88df223469088633eb86de997fa27ece117fd1ef170d69c1f8","Size":36684546,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","Checksum":"SHA-256:a54f64755fff4cb792a1495e5defdd789902a2a3503982e81b898299cf39800e","Size":52519412,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:954bbffb33545bcdcd473af993da2980bf32e8461ff55a18e0eebc7b2ef69a4c","Size":37176991,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:bd8c37f6952a2130ac9ee32c53f6a660feb79bee8353c8e289eb60fdcefed91e","Size":37630618,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:17+02:00","tool":{"version":"6.3.0-arduino17","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:2a8e68c5d803aa6f902ef219f177ec3a4c28275d85cbe272962ad2cd374f50d1","Size":219631,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:6cf948f751acfe7b96684537f2291c766ec8b54b4f7dc95539864821456fa9fc","Size":229852,"CachePath":"packages"}},{"os":"x86_64-apple-darwin12","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","Checksum":"SHA-256:120cc9edaae699e7e9ac50b1b8eb0e7d51fdfa555bac54233c2511e6ee5418c9","Size":279045,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:accdfb920af2aabf4f7461d2ac73c0751760f525216dc4e7657427a78c60d13d","Size":254271,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:5c8cc6c17db9300e1451fe41cd7178b0442b4490ee6fdbc0aed9811aef96c05f","Size":244550,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","Checksum":"SHA-256:e99188873c7c5ad8f8f906f068c33600e758b2e36cce3adbd518a21bd266749d","Size":328460,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loading package builtin from: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\builtin","time":"2022-10-18T17:25:17+02:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-10-18T17:25:17+02:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-10-18T17:25:17+02:00"}
{"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:17+02:00","tool":{"version":"5.8-arduino11","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:17+02:00","tool":{"version":"1.0.6","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:17+02:00","tool":{"version":"1.3.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:17+02:00","tool":{"version":"0.10.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:17+02:00","tool":{"version":"0.9.1","systems":null}}
{"index":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\package_index.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\package_index.json.sig","time":"2022-10-18T17:25:17+02:00","trusted":true}
{"dir":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-10-18T17:25:17+02:00"}
{"index":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\library_index.json","level":"info","msg":"Loading libraries index file","time":"2022-10-18T17:25:17+02:00"}
root INFO Deployed backend plugin "vscode-language-pack-ja@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 245.1 ms [Finished 5.104 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-nl@1.48.3" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 110.9 ms [Finished 5.215 s after backend start]
daemon INFO {"dir":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-10-18T17:25:17+02:00"}
{"dir":"C:\\Users\\bruno\\Documents\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-10-18T17:25:17+02:00"}
root INFO Deployed backend plugin "vscode-language-pack-pt-BR@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 277.8 ms [Finished 5.493 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ru@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 257.6 ms [Finished 5.751 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-tr@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 140.3 ms [Finished 5.891 s after backend start]
daemon INFO {"level":"info","msg":"starting discovery builtin:mdns-discovery process","time":"2022-10-18T17:25:18+02:00"}
{"level":"info","msg":"starting discovery builtin:serial-discovery process","time":"2022-10-18T17:25:18+02:00"}
root INFO Deployed backend plugin "vscode-language-pack-zh-hans@1.69.0" from "C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 255.0 ms [Finished 6.146 s after backend start]
root INFO Deploy plugins list: 238.3 ms [Finished 6.174 s after backend start]
daemon INFO {"level":"info","msg":"started discovery builtin:mdns-discovery process","time":"2022-10-18T17:25:18+02:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:mdns-discovery","time":"2022-10-18T17:25:18+02:00"}
{"level":"info","msg":"started discovery builtin:serial-discovery process","time":"2022-10-18T17:25:18+02:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:serial-discovery","time":"2022-10-18T17:25:18+02:00"}
{"level":"info","msg":"from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-10-18T17:25:18+02:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:mdns-discovery","time":"2022-10-18T17:25:18+02:00"}
{"level":"info","msg":"from discovery builtin:mdns-discovery received message type: start_sync, message: OK","time":"2022-10-18T17:25:18+02:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-10-18T17:25:18+02:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:serial-discovery","time":"2022-10-18T17:25:18+02:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: start_sync, message: OK","time":"2022-10-18T17:25:18+02:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM3","time":"2022-10-18T17:25:18+02:00"}
discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x7523"],["serialNumber",""],["vid","0x1A86"]]}},"error":""}
root WARN Frontend s.configure took longer than the expected maximum 100 milliseconds: 373.9 ms [Finished 4.619 s after frontend start]
root WARN Frontend commands.onStart took longer than the expected maximum 100 milliseconds: 107.0 ms [Finished 4.728 s after frontend start]
root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 170.1 ms [Finished 4.899 s after frontend start]
root WARN Frontend C.onStart took longer than the expected maximum 100 milliseconds: 101.6 ms [Finished 5.052 s after frontend start]
root WARN Frontend C.onStart took longer than the expected maximum 100 milliseconds: 298.1 ms [Finished 5.390 s after frontend start]
root INFO Start frontend contributions: 1573.4 ms [Finished 5.511 s after frontend start]
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23] Waiting for backend deployment: 278.6 ms [Finished 5.782 s after frontend start]
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 210.803 ms. Args: [{"uri":"file:///c%3A/Users/bruno/Documents/Arduino"}] ----
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896) starting instance
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23] Sync of 16 plugins: 1489.1 ms [Finished 7.271 s after frontend start]
root INFO Initialize the workbench layout: 2221.5 ms [Finished 7.859 s after frontend start]
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][marus25.cortex-debug]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][vscode.cpp]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][vscode.json]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][vscode.json-language-features]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23] Load contributions of 16 plugins: 276.5 ms [Finished 8.137 s after frontend start]
root WARN Frontend I.onDidInitializeLayout took longer than the expected maximum 100 milliseconds: 284.1 ms [Finished 8.143 s after frontend start]
root INFO Frontend application start: 5315.7 ms [Finished 13.080 s after backend start]
root INFO Replace loading indicator with ready workbench UI (animation): 1028.4 ms [Finished 9.176 s after frontend start]
root INFO ---- DURATION: installed took 90.072 ms. Args: [{}] ----
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 170.965 ms. Args: [{}] ----
Checking for update
root INFO ---- DURATION: installed took 25.304 ms. Args: [{"fqbn":"arduino:avr:mega"}] ----
root INFO ---- DURATION: installed took 34.711 ms. Args: [{"fqbn":"arduino:avr:mega"}] ----
root ERROR ---- !!!SLOW!!! DURATION: search took 2774.264 ms. Args: [{"type":"Updatable"}] ----
daemon INFO {"level":"info","msg":"Updating libraries index","time":"2022-10-18T17:25:29+02:00"}
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): PluginManagerExtImpl/init()
daemon INFO {"level":"info","msg":"URL: https://downloads.arduino.cc/packages/package_index.tar.bz2","time":"2022-10-18T17:25:29+02:00"}
{"level":"info","msg":"Updating index","time":"2022-10-18T17:25:29+02:00","url":{"Scheme":"https","Opaque":"","User":null,"Host":"downloads.arduino.cc","Path":"/packages/package_index.tar.bz2","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(cortex-debug@0.3.10 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] Debugger contribution has been registered: cortex-debug
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(vscode-arduino-tools@0.0.2-beta.5 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(cpp@1.52.1 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(json@1.46.1 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(json-language-features@1.46.1 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(vscode-language-pack-cs@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(vscode-language-pack-de@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(vscode-language-pack-es@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(vscode-language-pack-fr@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(vscode-language-pack-it@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(vscode-language-pack-ja@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(vscode-language-pack-pt-BR@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(vscode-language-pack-ru@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(vscode-language-pack-tr@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): initializing(vscode-language-pack-zh-hans@1.69.0 with C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): PluginManagerExtImpl/loadPlugin(C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
root INFO [hosted-plugin: 6896] PLUGIN_HOST(6896): PluginManagerExtImpl/loadPlugin(C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][marus25.cortex-debug]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][arduino.vscode-arduino-tools]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][vscode.cpp]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][vscode.json]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][vscode.json-language-features]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-cs]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-de]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-es]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-fr]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-it]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-ja]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-nl]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-ru]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-tr]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
root INFO [d2bfd446-87bb-4506-a3a5-9cd67fb03c23] Start of 16 plugins: 6176.0 ms [Finished 14.342 s after frontend start]
daemon INFO {"level":"info","msg":"Searching tools required for board arduino:avr:mega","time":"2022-10-18T17:25:31+02:00"}
daemon INFO {"level":"info","msg":"Required tool","time":"2022-10-18T17:25:31+02:00","tool":{"ToolName":"arduinoOTA","ToolVersion":"1.3.0","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-18T17:25:31+02:00","tool":{"ToolName":"avr-gcc","ToolVersion":"7.3.0-atmel3.6.1-arduino7","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-18T17:25:31+02:00","tool":{"ToolName":"avrdude","ToolVersion":"6.3.0-arduino17","ToolPackager":"arduino"}}
{"dir":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-10-18T17:25:31+02:00"}
{"dir":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-10-18T17:25:31+02:00"}
daemon INFO {"dir":"C:\\Users\\bruno\\Documents\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-10-18T17:25:31+02:00"}
root ERROR ---- !!!SLOW!!! DURATION: installed took 117.127 ms. Args: [{"fqbn":"arduino:avr:mega"}] ----
daemon INFO {"level":"info","msg":"Resolving include VirtuinoCM.h for arch avr","time":"2022-10-18T17:25:31+02:00"}
daemon INFO {"level":"info","lib":"VirtuinoCM","msg":" found better lib","prio":"643","time":"2022-10-18T17:25:31+02:00"}
monitor-service INFO starting monitor
daemon INFO {"level":"info","monitor":"serial-monitor","msg":"Starting monitor process","time":"2022-10-18T17:25:32+02:00"}
root ERROR Request startMonitor failed with error: 13 INTERNAL: Port monitor error: fork/exec C:\Users\bruno\AppData\Local\Arduino15\packages\builtin\tools\serial-monitor\0.10.0\serial-monitor.exe: Le fichier ou le r├®pertoire est endommag├® et illisible.
root ERROR Uncaught Exception:
root ERROR Error: 13 INTERNAL: Port monitor error: fork/exec C:\Users\bruno\AppData\Local\Arduino15\packages\builtin\tools\serial-monitor\0.10.0\serial-monitor.exe: Le fichier ou le r├®pertoire est endommag├® et illisible.
at Object.callErrorFromStatus (C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\call.js:31:26)
at Object.onReceiveStatus (C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client.js:189:52)
at Object.onReceiveStatus (C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client-interceptors.js:365:141)
at Object.onReceiveStatus (C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client-interceptors.js:328:181)
at C:\Users\bruno\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\call-stream.js:187:78
at processTicksAndRejections (node:internal/process/task_queues:78:11)
daemon INFO {"level":"info","msg":"Resolving include OneWire.h for arch avr","time":"2022-10-18T17:25:32+02:00"}
{"level":"info","lib":"OneWire","msg":" found better lib","prio":"643","time":"2022-10-18T17:25:32+02:00"}
daemon INFO {"level":"info","msg":"Resolving include DallasTemperature.h for arch avr","time":"2022-10-18T17:25:32+02:00"}
daemon INFO {"level":"info","lib":"DallasTemperature","msg":" found better lib","prio":"643","time":"2022-10-18T17:25:32+02:00"}
daemon INFO {"level":"info","msg":"Resolving include DFRobot_PH.h for arch avr","time":"2022-10-18T17:25:32+02:00"}
daemon INFO {"level":"info","lib":"DFRobot_PH","msg":" found better lib","prio":"643","time":"2022-10-18T17:25:32+02:00"}
daemon INFO {"level":"info","msg":"Resolving include EEPROM.h for arch avr","time":"2022-10-18T17:25:33+02:00"}
{"level":"info","lib":"EEPROM","msg":" found better lib","prio":"64C","time":"2022-10-18T17:25:33+02:00"}
daemon INFO {"level":"info","msg":"Resolving include Wire.h for arch avr","time":"2022-10-18T17:25:33+02:00"}
{"level":"info","lib":"Wire","msg":" found better lib","prio":"64C","time":"2022-10-18T17:25:33+02:00"}
daemon INFO {"level":"info","msg":"Resolving include LiquidCrystal_I2C.h for arch avr","time":"2022-10-18T17:25:33+02:00"}
daemon INFO {"level":"info","lib":"LiquidCrystal_I2C-1.1.2","msg":" found better lib","prio":"5E9","time":"2022-10-18T17:25:33+02:00"}
daemon INFO {"level":"info","msg":"Loading hardware from: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages","time":"2022-10-18T17:25:33+02:00"}
daemon INFO {"level":"info","msg":"Loading package arduino from: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware","time":"2022-10-18T17:25:33+02:00"}
daemon INFO {"error":"opening signature file: open C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json.sig: Le fichier sp├®cifi├® est introuvable.","index":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json.sig","time":"2022-10-18T17:25:33+02:00"}
daemon INFO {"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2022-10-18T17:25:33+02:00","tool":"builtin:serial-monitor"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.5","Latest":"1.8.5","Name":"Arduino AVR Boards"},"time":"2022-10-18T17:25:33+02:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-10-18T17:25:33+02:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-10-18T17:25:33+02:00"}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:33+02:00","tool":{"version":"1.3.0","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_386.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_386.tar.bz2","Checksum":"SHA-256:3e7f59d6fbc7a724598303f0d3289d0c4fd137a8973437980658379a024887b2","Size":2633516,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_amd64.tar.bz2","Checksum":"SHA-256:aa45ee2441ffc3a122daec5802941d1fa2ac47adf5c5c481b5e0daa4dc259ffa","Size":2716248,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm.tar.bz2","Checksum":"SHA-256:1888587409b56aef4ba0ab0e6703b3dccba7cc3a022756ba9b908247e5d5a656","Size":2567435,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm64.tar.bz2","Checksum":"SHA-256:835ed8f37cffac37e979d1b0f6041559592d3d98be52f0e8611b76c4858e4113","Size":2472427,"CachePath":"packages"}},{"os":"i386-apple-darwin11","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-darwin_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-darwin_amd64.tar.bz2","Checksum":"SHA-256:d5d0f82ff829c0e434d12a2ee640a6fbd78f893ab37782edbb8b5bf2359d119e","Size":2766116,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-windows_386.zip","ArchiveFileName":"arduinoOTA-1.3.0-windows_386.zip","Checksum":"SHA-256:051943844eee442460d2c709edefadca184287fffd2b6c100dd53aa742aa05f6","Size":2768948,"CachePath":"packages"}}]}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:33+02:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","Checksum":"SHA-256:3903553d035da59e33cff9941b857c3cb379cb0638105dfdf69c97f0acc8e7b5","Size":34683056,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:03d322b9df6da17289e9e7c6233c34a8535d9c645c19efc772ba19e56914f339","Size":38045723,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","Checksum":"SHA-256:f6ed2346953fcf88df223469088633eb86de997fa27ece117fd1ef170d69c1f8","Size":36684546,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","Checksum":"SHA-256:a54f64755fff4cb792a1495e5defdd789902a2a3503982e81b898299cf39800e","Size":52519412,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:954bbffb33545bcdcd473af993da2980bf32e8461ff55a18e0eebc7b2ef69a4c","Size":37176991,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:bd8c37f6952a2130ac9ee32c53f6a660feb79bee8353c8e289eb60fdcefed91e","Size":37630618,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:33+02:00","tool":{"version":"6.3.0-arduino17","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:2a8e68c5d803aa6f902ef219f177ec3a4c28275d85cbe272962ad2cd374f50d1","Size":219631,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:6cf948f751acfe7b96684537f2291c766ec8b54b4f7dc95539864821456fa9fc","Size":229852,"CachePath":"packages"}},{"os":"x86_64-apple-darwin12","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","Checksum":"SHA-256:120cc9edaae699e7e9ac50b1b8eb0e7d51fdfa555bac54233c2511e6ee5418c9","Size":279045,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:accdfb920af2aabf4f7461d2ac73c0751760f525216dc4e7657427a78c60d13d","Size":254271,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:5c8cc6c17db9300e1451fe41cd7178b0442b4490ee6fdbc0aed9811aef96c05f","Size":244550,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","Checksum":"SHA-256:e99188873c7c5ad8f8f906f068c33600e758b2e36cce3adbd518a21bd266749d","Size":328460,"CachePath":"packages"}}]}}
daemon INFO {"level":"info","msg":"Loading package builtin from: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\builtin","time":"2022-10-18T17:25:33+02:00"}
daemon INFO {"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-10-18T17:25:33+02:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-10-18T17:25:33+02:00"}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:33+02:00","tool":{"version":"5.8-arduino11","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:33+02:00","tool":{"version":"1.0.6","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:33+02:00","tool":{"version":"1.3.2","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:33+02:00","tool":{"version":"0.10.0","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-10-18T17:25:33+02:00","tool":{"version":"0.9.1","systems":null}}
daemon INFO {"index":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\package_index.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\package_index.json.sig","time":"2022-10-18T17:25:33+02:00","trusted":true}
daemon INFO {"dir":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-10-18T17:25:36+02:00"}
daemon INFO {"index":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\library_index.json","level":"info","msg":"Loading libraries index file","time":"2022-10-18T17:25:36+02:00"}
daemon INFO {"level":"info","msg":"Searching tools required for board arduino:avr:mega","time":"2022-10-18T17:25:36+02:00"}
daemon INFO {"level":"info","msg":"Required tool","time":"2022-10-18T17:25:36+02:00","tool":{"ToolName":"arduinoOTA","ToolVersion":"1.3.0","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-18T17:25:36+02:00","tool":{"ToolName":"avr-gcc","ToolVersion":"7.3.0-atmel3.6.1-arduino7","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-10-18T17:25:36+02:00","tool":{"ToolName":"avrdude","ToolVersion":"6.3.0-arduino17","ToolPackager":"arduino"}}
daemon INFO {"dir":"C:\\Users\\bruno\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-10-18T17:25:36+02:00"}
daemon INFO {"dir":"C:\\Users\\bruno\\Documents\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-10-18T17:25:36+02:00"}
discovery-log INFO start
discovery-log INFO start new deferred
discovery-log INFO start request start watch
discovery-log INFO start requested start watch
discovery-log INFO start resolved watching
daemon INFO {"level":"info","msg":"boards watcher stream closed","time":"2022-10-18T17:25:37+02:00"}
daemon INFO {"level":"info","msg":"starting discovery builtin:mdns-discovery process","time":"2022-10-18T17:25:37+02:00"}
daemon INFO {"level":"info","msg":"starting discovery builtin:serial-discovery process","time":"2022-10-18T17:25:37+02:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:mdns-discovery process","time":"2022-10-18T17:25:37+02:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:mdns-discovery","time":"2022-10-18T17:25:37+02:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:serial-discovery process","time":"2022-10-18T17:25:37+02:00"}
daemon INFO {"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:serial-discovery","time":"2022-10-18T17:25:37+02:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-10-18T17:25:37+02:00"}
daemon INFO {"level":"info","msg":"sending command START_SYNC to discovery builtin:serial-discovery","time":"2022-10-18T17:25:37+02:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-10-18T17:25:37+02:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: start_sync, message: OK","time":"2022-10-18T17:25:37+02:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:mdns-discovery","time":"2022-10-18T17:25:37+02:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:mdns-discovery received message type: start_sync, message: OK","time":"2022-10-18T17:25:37+02:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM3","time":"2022-10-18T17:25:38+02:00"}
discovery-log WARN Port 'COM3 Serial Port (USB)' was already available. Known boards before override: []
root INFO Attached boards and available ports changed:
root INFO No changes.
root INFO ------------------------------------------
Microsoft Windows [version 10.0.19044.2130]
(c) Microsoft Corporation. Tous droits réservés.
C:\Users\bruno>dir C:\Users\bruno\AppData\Local\Arduino15\packages\builtin\tools\serial-monitor\0.10.0
Le volume dans le lecteur C n’a pas de nom.
Le numéro de série du volume est 72B5-8BCB
Répertoire de C:\Users\bruno\AppData\Local\Arduino15\packages\builtin\tools\serial-monitor\0.10.0
20-09-22 16:15 <DIR> .
20-09-22 16:15 <DIR> ..
20-09-22 16:15 35.149 LICENSE.txt
20-09-22 16:15 3.409.920 serial-monitor.exe
2 fichier(s) 3.445.069 octets
2 Rép(s) 85.223.763.968 octets libres
C:\Users\bruno>
Excellent. Please try this:
- Select File > Quit from the Arduino IDE menus if it is running.
- Delete the folder at this path:
If looking for it with your file browser or command line, note that the C:\Users\bruno\AppData\folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
Please be very careful when deleting things from your computer. When in doubt, back up! - Start the Arduino IDE.
- Wait for the IDE to finish starting.
Now open Serial Monitor. The Arduino IDE automatically installs the serial-monitor tool on startup if it was missing, so deleting that folder forced the IDE to install a fresh copy of the tool. Hopefully this will fix the problem that caused the startup of the tool to fail before and Serial Monitor will now work correctly.
Please let me know if you have any questions or problems while following those instructions.
OK, I did it. Unfortunately, same problem afterwards.
So, I rename the directory to ...old
Restart IDE, it recreates the same dir with the same file, and still no baud rate in the serialmonitor.
Keep in mind that it seems that with the IDE2.0beta3 I did'nt had the issue, and the version 1.8.13 is still install on pc.
Any other idea?
Thanks anyway....
C:\Users\bruno\AppData\Local\Arduino15\packages\builtin\tools\serial-monitor>dir
Le volume dans le lecteur C s’appelle SSD Interne 256GB
Le numéro de série du volume est DC32-E8D0
18/10/2022 22:31 <DIR> .
18/10/2022 22:31 <DIR> ..
18/10/2022 17:22 <DIR> 0.10.0.old
0 fichier(s) 0 octets
3 Rép(s) 60 362 088 448 octets libres
18/10/2022 22:31 <DIR> 0.10.0
4 Rép(s) 60 361 953 280 octets libres
C:\Users\bruno\AppData\Local\Arduino15\packages\builtin\tools\serial-monitor>dir 0.10.0
18/10/2022 22:31 35 149 LICENSE.txt
18/10/2022 22:31 3 409 920 serial-monitor.exe
2 fichier(s) 3 445 069 octets
2 Rép(s) 60 361 949 184 octets libres
C:\Users\bruno\AppData\Local\Arduino15\packages\builtin\tools\serial-monitor>dir 0.10.0.old
Répertoire de C:\Users\bruno\AppData\Local\Arduino15\packages\builtin\tools\serial-monitor\0.10.0.old
18/10/2022 17:22 <DIR> .
18/10/2022 17:22 <DIR> ..
18/10/2022 17:22 35 149 LICENSE.txt
18/10/2022 17:22 3 409 920 serial-monitor.exe
Do you still get the same error in the command line output as before?
Today I deinstall/remove everything, every version concerning arduino. I re-install the ide 2.0 nightly, same problem, remove, and install the official V2.0, same problem.
Then I decide to record a video to show you, then sundainly, the baud rate drop down appears, and the serial monitor works perfect.
Mysterious, not clear to me what happened. Anyway it's ok. I leave it so.
Many thanks for your collaboration.
This is very odd. Even though it is not so satisfying as finding the cause of the problem, I guess we can be happy that it is working now.
Please let us know if you experience the problem again.
Regards,
Per
Hello,
I see this topic was closed after no solution. I have the very same problem and I try everything that you suggested. I also try to upload any programme to my board and it does not work (I changed the board and it happens the same issue)
Thank you
Which version of the IDE are you using and which Operating System ?
