IDE 2.1.1 - Changing Serial Monitor Baud Rate ?
I can't seem to locate any method of changing the baud rate for the Serial monitor. There are no drop-downs or settings that I can find. seeking assistance.
Thanks
What do you see bottom/right of the Serial monitor window ?
Nothing like you show (v1??) Here's my window:
I have seen reports of that before, hence my question
@ptillisch Can you please advise ?
Hi @Bwanna. I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
  1. Close all Arduino IDE windows if the IDE is already running.
  2. Start Windows "File Explorer".
  3. Open the Arduino IDE installation folder.
    The default installation location is at one of the following paths:
    • C:\Program Files\Arduino IDE
    • C:\Users\<username>\AppData\Local\Programs\Arduino IDE
      (where <username> is your Windows username)
      :exclamation: If looking for it with your file manager or command line, note that the AppData folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
  4. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  5. From the context menu, click "Open PowerShell window here".
    Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  6. Type the following command:
    & ".\Arduino IDE"
  7. Press the Enter key.
    Debug output should now be printed to the PowerShell window as Arduino IDE starts.
  8. Wait for Arduino IDE to finish starting.
  9. Switch back to the PowerShell window.
  10. Right click on the title bar of the PowerShell window.
    This will open a context menu.
  11. Select Edit > Select All from the context menu.
    This will select all the text in the PowerShell window.
  12. Press Ctrl+C.
    This will copy the contents of the PowerShell window to the clipboard.
  13. Open a forum reply here by clicking the Reply button.
  14. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code tags icon on toolbar
  15. Press Ctrl+V.
    This will paste the output into the code block.
  16. Move the cursor outside of the code block markup before you add any additional text to your reply.
  17. Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
the board needs to be connected for serial to work and libraries installed/
see this
2023-07-27 17_19_42-IDE 2.1.1 - Changing Serial Monitor Baud Rate _ - Software _ IDE 2.x - Arduino F
it suggests it's connected on com8 , Check device manager to confirm the port
Confirmed. Board has been connected to Com8 and interacting normally with the IDE. It seems just the display of the baud controls is missing.
I strongly suggest that you provide the information requested in post #5. The missing baud rate is an indication that the serial monitor can not connect to the board (for some reason).
ok , this in "Application Layer" Problem
RE The O.S.I. Model
Likely your Board is not detected or processes are stuck or in use
  1. CTRL+ALT+DEL then terminate all Arduino and Arduino CLI processes
  2. Restart Computer , Then back into step 1 to confirm no Arduino processes are running
  3. Uninstall the IDE
  4. go to search bar in windows and type "regedit"
    Open the Registry and go EDIT then FIND and type in ARDUINO
    Press NEXT
    Delete all deletable entries if any
  5. Go to Device Manager and delete the arduino drivers
  6. Restart Computer
  7. Disable windows defender and antivirus for 15mins
  8. RE install IDE (latest Version) running as Administrator
  9. Reinstall Drivers
What happens now ?
if all ok , Re-enable firewalls
also consider doing all this in Safe Mode Start up
if you like i can look at remote connecting to you to sort this out quicker (just an option)
The serial monitor is connected to the board correctly and fully interacts as appropriate... sending/receiving information without any issues. It wasn't until I tried some new library examples that had a different baud rate than my normal sketches and I couldn't find the controls. It seems like an IDE installation issue and will try the recommendations later when I get back home and can access.
Sorry, I probably first should connect up to one of my ESP32 boards and check to see for myself.
But maybe, it is not there by design.
That is, for example with Teensy boards, it also does not give you any way to select a Baud rate. I believe that this is controlled by one of the Pluggable interfaces (Pluggable Monitor?)
Why, in the case of the Teensy it makes almost no sense. That is, it has no bearing on the speed of the communications between the host and the teensy, as the teensy has native USB support. This is different than many other boards, that use some other chip (FTDI, ESP32, AVR..) that handles the USB communications to the Host, but the baud rate is actually used to setup the communication rate between that chip and the actual processor.
Guessing, that this could be the case for the ESP32 as well.
Very minor side note: there is one usage case with the teensy where having the drop down list can make sense. That is if you are using the board as a USBToSerial adapter and need to update your output UART to the proper baud rate (and parity...). And the sketch can retrieve the baud rate that the host requested...
Here's what I get:
...\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
& : The term '.\Arduino IDE' is not recognized as the name of a cmdlet, function, script file, or operable program.
Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:3
+ & ".\Arduino IDE"
    + CategoryInfo          : ObjectNotFound: (.\Arduino IDE:String) [], CommandNotFoundException
    + FullyQualifiedErrorId : CommandNotFoundException
This result indicates that Arduino IDE is not installed in the <...>\AppData\Local\Programs\Arduino IDE folder. You'll need to find where Arduino IDE is installed on your computer and repeat the instructions, opening the PowerShell terminal in that folder.
I uninstalled all the Arduino stuff and did a wiping through regedit. Reinstalled v2.1.1.
Here's the Powershell dump:
PS C:\Users\Steve\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
PS C:\Users\Steve\AppData\Local\Programs\Arduino IDE> Arduino IDE 2.1.1
Starting backend process. PID: 14924
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Steve/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-07-28T16:54:54.118Z root INFO Backend Object.initialize: 8.4 ms [Finished 5.381 s after backend start]
2023-07-28T16:54:54.119Z root INFO Backend Object.configure: 7.0 ms [Finished 5.381 s after backend start]
2023-07-28T16:54:54.120Z root INFO Backend MessagingContribution.onStart: 3.2 ms [Finished 5.381 s after backend start]
2023-07-28T16:54:54.122Z root INFO Backend OSBackendApplicationContribution.configure: 2.6 ms [Finished 5.475 s after backend start]
2023-07-28T16:54:54.124Z root INFO Backend DefaultWorkspaceServer.onStart: 0.6 ms [Finished 5.475 s after backend start]2023-07-28T16:54:54.126Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.2 ms [Finished 5.475 s after backend start]
2023-07-28T16:54:54.128Z root WARN Backend PluginLocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 93.4 ms [Finished 5.476 s after backend start]
2023-07-28T16:54:54.129Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.4 ms [Finished 5.476 s after backend start]
2023-07-28T16:54:54.131Z root INFO Backend ElectronTokenBackendContribution.configure: 3.0 ms [Finished 5.479 s after backend start]
2023-07-28T16:54:54.133Z config INFO >>> Initializing CLI configuration...
2023-07-28T16:54:54.135Z root INFO Backend PluginDeployerContribution.initialize: 1.1 ms [Finished 5.479 s after backend start]
2023-07-28T16:54:54.136Z root INFO Backend ConfigServiceImpl.onStart: 2.4 ms [Finished 5.481 s after backend start]
2023-07-28T16:54:54.139Z config INFO Loading CLI configuration from c:\Users\Steve\.arduinoIDE\arduino-cli.yaml...
2023-07-28T16:54:54.140Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.8 ms [Finished 5.484 s after backend start]
2023-07-28T16:54:54.141Z root INFO Backend ArduinoDaemonImpl.onStart: 2.8 ms [Finished 5.486 s after backend start]
2023-07-28T16:54:54.141Z root INFO Backend NodeFileUploadService.configure: 5.5 ms [Finished 5.487 s after backend start]
2023-07-28T16:54:54.142Z daemon INFO Starting daemon from C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-07-28T16:54:54.142Z discovery-log INFO start
2023-07-28T16:54:54.144Z discovery-log INFO start new deferred
2023-07-28T16:54:54.145Z root INFO Backend HostedPluginLocalizationService.initialize: 0.8 ms [Finished 5.489 s after backend start]
2023-07-28T16:54:54.145Z root INFO Backend BoardDiscovery.onStart: 4.5 ms [Finished 5.493 s after backend start]
2023-07-28T16:54:54.146Z root INFO Backend FileDownloadEndpoint.configure: 4.2 ms [Finished 5.494 s after backend start]2023-07-28T16:54:54.147Z root INFO Backend AuthenticationServiceImpl.onStart: 0.8 ms [Finished 5.498 s after backend start]
2023-07-28T16:54:54.147Z root INFO Backend PluginApiContribution.configure: 1.2 ms [Finished 5.499 s after backend start]
2023-07-28T16:54:54.150Z root INFO Backend HostedPluginReader.configure: 3.0 ms [Finished 5.503 s after backend start]
2023-07-28T16:54:54.151Z root INFO Backend HostedPluginReader.configure: 0.3 ms [Finished 5.504 s after backend start]
2023-07-28T16:54:54.151Z root INFO Backend PlotterBackendContribution.configure: 2.2 ms [Finished 5.508 s after backend start]
2023-07-28T16:54:54.158Z root INFO Theia app listening on http://localhost:52813.
2023-07-28T16:54:54.159Z root INFO Finished starting backend application: 15.6 ms [Finished 5.516 s after backend start]2023-07-28T16:54:54.180Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Steve/.arduinoIDE/plugins does not exist.
2023-07-28T16:54:54.191Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Steve/.arduinoIDE/extensions does not exist.
2023-07-28T16:54:54.198Z root WARN The local plugin referenced by local-dir:C:\Users\Steve\.arduinoIDE\plugins does not exist.
Restoring workspace roots: d:\Arduinofiles\Blink_copy_20230728125005
isTempSketch: false. Input was d:\Arduinofiles\Blink_copy_20230728125005\Blink_copy_20230728125005.ino
2023-07-28T16:54:54.269Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.278Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-07-28T16:54:54.299Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.307Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-07-28T16:54:54.325Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.330Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-07-28T16:54:54.337Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.340Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-07-28T16:54:54.341Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.344Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-07-28T16:54:54.345Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.347Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-07-28T16:54:54.348Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.351Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-07-28T16:54:54.354Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.360Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-07-28T16:54:54.378Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.381Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-07-28T16:54:54.398Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.409Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-07-28T16:54:54.420Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.446Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-07-28T16:54:54.448Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.450Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-07-28T16:54:54.456Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.460Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-07-28T16:54:54.463Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.465Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-07-28T16:54:54.467Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.488Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-07-28T16:54:54.496Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.502Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-07-28T16:54:54.532Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.541Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-07-28T16:54:54.556Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.568Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-07-28T16:54:54.570Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.576Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-07-28T16:54:54.591Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.601Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-07-28T16:54:54.620Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-28T16:54:54.632Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-07-28T16:54:54.669Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"]},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\Steve\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Steve\\AppData\\Local\\Arduino15\\staging","user":"d:\\Arduinofiles"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-07-28T16:54:54.684Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-07-28T16:54:54.706Z config INFO Loaded the CLI configuration.
2023-07-28T16:54:55.070Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Steve/AppData/Local/Arduino15","sketchDirUri":"file:///d%3A/Arduinofiles","additionalUrls":["https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"],"network":"none","locale":"en"}
2023-07-28T16:54:55.072Z config INFO Validating the CLI configuration...
2023-07-28T16:54:55.076Z config INFO The CLI config is valid.
2023-07-28T16:54:55.077Z config INFO <<< Initialized the CLI configuration.
2023-07-28T16:54:55.399Z root INFO Resolve plugins list: 1228.2 ms [Finished 6.723 s after backend start]
2023-07-28T16:54:55.410Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 11.0 ms [Finished 6.767 s after backend start]
2023-07-28T16:54:55.449Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 38.5 ms [Finished 6.806 s after backend start]
2023-07-28T16:54:55.500Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 50.6 ms [Finished 6.857 s after backend start]
2023-07-28T16:54:55.536Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 36.9 ms [Finished 6.894 s after backend start]
2023-07-28T16:54:55.538Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 2.0 ms [Finished 6.896 s after backend start]
2023-07-28T16:54:55.759Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 220.9 ms [Finished 7.117 s after backend start]
2023-07-28T16:54:56.087Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 327.4 ms [Finished 7.444 s after backend start]
2023-07-28T16:54:56.558Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 471.4 ms [Finished 7.916 s after backend start]
2023-07-28T16:54:56.969Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 410.2 ms [Finished 8.326 s after backend start]
2023-07-28T16:54:57.398Z daemon INFO INFO[0000] Using config file: c:\Users\Steve\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.32.3
INFO[0000] Executing `arduino-cli daemon`
Daemon is now listening on 127.0.0.1:50084
{"IP":"127.0.0.1","Port":"50084"}
2023-07-28T16:54:57.488Z daemon INFO Daemon is running.
2023-07-28T16:54:57.910Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 941.7 ms [Finished 9.268 s after backend start]
2023-07-28T16:54:58.396Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 485.2 ms [Finished 9.753 s after backend start]
2023-07-28T16:54:58.760Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 363.9 ms [Finished 10.117 s after backend start]
2023-07-28T16:54:58.830Z daemon INFO INFO[0001] Loading hardware from: c:\Users\Steve\AppData\Local\Arduino15\packages
INFO[0001] Loading package Cosa from: C:\Users\Steve\AppData\Local\Arduino15\packages\Cosa\hardware
INFO[0001] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0001] Loaded platform                               platform="Cosa:avr@1.2.0"
INFO[0001] Loading package MightyCore from: C:\Users\Steve\AppData\Local\Arduino15\packages\MightyCore\hardware
INFO[0002] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0002] Loaded platform                               platform="MightyCore:avr@2.1.3"
INFO[0002] Loading package MiniCore from: C:\Users\Steve\AppData\Local\Arduino15\packages\MiniCore\hardware
2023-07-28T16:54:58.915Z daemon INFO INFO[0002] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0002] Loaded platform                               platform="MiniCore:avr@2.1.3"
INFO[0002] Loading package arduino from: C:\Users\Steve\AppData\Local\Arduino15\packages\arduino\hardware
2023-07-28T16:54:58.971Z daemon INFO INFO[0002] Checking signature                            error="opening signature file: open C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
2023-07-28T16:54:59.262Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 502.3 ms [Finished 10.620 s after backend start]
2023-07-28T16:54:59.312Z daemon INFO INFO[0002] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0002] Loaded platform                               platform="arduino:avr@1.8.6"
INFO[0002] Checking signature                            error="opening signature file: open C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\installed.json" signatureFile="C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\installed.json.sig"
INFO[0002] Loaded platform                               platform="arduino:megaavr@1.8.8"
INFO[0002] Checking existence of 'tools' path: C:\Users\Steve\AppData\Local\Arduino15\packages\arduino\tools
INFO[0002] Loading tools from dir: C:\Users\Steve\AppData\Local\Arduino15\packages\arduino\tools
INFO[0002] Loaded tool                                   tool="arduino:arduinoOTA@1.3.0"
INFO[0002] Loaded tool                                   tool="arduino:avr-gcc@4.8.1-arduino5"
INFO[0002] Loaded tool                                   tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
INFO[0002] Loaded tool                                   tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0002] Loaded tool                                   tool="arduino:avrdude@6.0.1-arduino5"
INFO[0002] Loaded tool                                   tool="arduino:avrdude@6.3.0-arduino17"
INFO[0002] Loaded tool                                   tool="arduino:avrdude@6.3.0-arduino18"
INFO[0002] Loaded tool                                   tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0002] Loading package builtin from: C:\Users\Steve\AppData\Local\Arduino15\packages\builtin
INFO[0002] Checking existence of 'tools' path: C:\Users\Steve\AppData\Local\Arduino15\packages\builtin\tools
INFO[0002] Loading tools from dir: C:\Users\Steve\AppData\Local\Arduino15\packages\builtin\tools
INFO[0002] Loaded tool                                   tool="builtin:ctags@5.8-arduino11"
INFO[0002] Loaded tool                                   tool="builtin:dfu-discovery@0.1.2"
INFO[0002] Loaded tool                                   tool="builtin:mdns-discovery@1.0.6"
INFO[0002] Loaded tool                                   tool="builtin:mdns-discovery@1.0.8"
INFO[0002] Loaded tool                                   tool="builtin:mdns-discovery@1.0.9"
INFO[0002] Loaded tool                                   tool="builtin:serial-discovery@1.3.2"
2023-07-28T16:54:59.392Z daemon INFO INFO[0002] Loaded tool                                   tool="builtin:serial-discovery@1.4.0"
INFO[0002] Loaded tool                                   tool="builtin:serial-monitor@0.10.0"
INFO[0002] Loaded tool                                   tool="builtin:serial-monitor@0.11.0"
INFO[0002] Loaded tool                                   tool="builtin:serial-monitor@0.13.0"
INFO[0002] Loading package esp32 from: C:\Users\Steve\AppData\Local\Arduino15\packages\esp32\hardware
Opening channel for service path '/services/ide-updater'.
2023-07-28T16:54:59.686Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 424.0 ms [Finished 11.044 s after backend start]
2023-07-28T16:54:59.787Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 100.5 ms [Finished 11.145 s after backend start]
2023-07-28T16:55:00.130Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 343.1 ms [Finished 11.488 s after backend start]
2023-07-28T16:55:00.187Z daemon INFO INFO[0003] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0003] Loaded platform                               platform="esp32:esp32@1.0.6"
INFO[0003] Checking signature                            error="opening signature file: open C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\installed.json" signatureFile="C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\installed.json.sig"
2023-07-28T16:55:00.659Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 528.7 ms [Finished 12.017 s after backend start]
2023-07-28T16:55:00.726Z daemon INFO INFO[0004] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0004] Loaded platform                               platform="esp32:esp32@2.0.11"
INFO[0004] Checking existence of 'tools' path: C:\Users\Steve\AppData\Local\Arduino15\packages\esp32\tools
INFO[0004] Loading tools from dir: C:\Users\Steve\AppData\Local\Arduino15\packages\esp32\tools
INFO[0004] Loaded tool                                   tool="esp32:esptool_py@3.0.0"
INFO[0004] Loaded tool                                   tool="esp32:esptool_py@4.5.1"
INFO[0004] Loaded tool                                   tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0004] Loaded tool                                   tool="esp32:mkspiffs@0.2.3"
INFO[0004] Loaded tool                                   tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0004] Loaded tool                                   tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0004] Loaded tool                                   tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0004] Loaded tool                                   tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0004] Loaded tool                                   tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
INFO[0004] Loaded tool                                   tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0004] Loaded tool                                   tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0004] Loaded tool                                   tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0004] Loading package esp8266 from: C:\Users\Steve\AppData\Local\Arduino15\packages\esp8266\hardware
2023-07-28T16:55:01.042Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 383.3 ms [Finished 12.400 s after backend start]
2023-07-28T16:55:01.132Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 1112.9 ms [Finished 6.495 s after frontend start]
2023-07-28T16:55:01.144Z daemon INFO INFO[0004] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0004] Loaded platform                               platform="esp8266:esp8266@3.0.2"
INFO[0004] Checking existence of 'tools' path: C:\Users\Steve\AppData\Local\Arduino15\packages\esp8266\tools
INFO[0004] Loading tools from dir: C:\Users\Steve\AppData\Local\Arduino15\packages\esp8266\tools
INFO[0004] Loaded tool                                   tool="esp8266:mklittlefs@3.0.4-gcc10.3-1757bed"
INFO[0004] Loaded tool                                   tool="esp8266:mkspiffs@3.0.4-gcc10.3-1757bed"
INFO[0004] Loaded tool                                   tool="esp8266:python3@3.7.2-post1"
INFO[0004] Loaded tool                                   tool="esp8266:xtensa-lx106-elf-gcc@3.0.4-gcc10.3-1757bed"
INFO[0004] Loading package megax8 from: C:\Users\Steve\AppData\Local\Arduino15\packages\megax8\hardware
INFO[0004] Loaded platform                               platform="megax8:avr@1.0.3"
INFO[0004] Checking signature                            index="c:\\Users\\Steve\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\Steve\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0004] Checking signature                            error="opening signature file: open c:\\Users\\Steve\\AppData\\Local\\Arduino15\\package_esp32_index.json.sig: The system cannot find the file specified." index="c:\\Users\\Steve\\AppData\\Local\\Arduino15\\package_esp32_index.json" signatureFile="c:\\Users\\Steve\\AppData\\Local\\Arduino15\\package_esp32_index.json.sig"
2023-07-28T16:55:01.442Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 399.3 ms [Finished 12.799 s after backend start]
2023-07-28T16:55:01.480Z daemon INFO INFO[0004] Adding libraries dir                          dir="C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\Cosa\\hardware\\avr\\1.2.0\\libraries" location=platform
INFO[0004] Adding libraries dir                          dir="C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\libraries" location=platform
INFO[0004] Adding libraries dir                          dir="C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries" location=platform
INFO[0004] Adding libraries dir                          dir="C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\megax8\\hardware\\avr\\1.0.3\\libraries" location=platform
INFO[0004] Adding libraries dir                          dir="C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
INFO[0004] Adding libraries dir                          dir="C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries" location=platform
INFO[0004] Adding libraries dir                          dir="C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.1.3\\libraries" location=platform
2023-07-28T16:55:01.573Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 429.5 ms [Finished 6.975 s after frontend start]
2023-07-28T16:55:01.600Z daemon INFO INFO[0004] Adding libraries dir                          dir="C:\\Users\\Steve\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\libraries" location=platform
INFO[0004] Loading libraries index file                  index="c:\\Users\\Steve\\AppData\\Local\\Arduino15\\library_index.json"
2023-07-28T16:55:01.892Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 449.9 ms [Finished 13.249 s after backend start]
2023-07-28T16:55:02.206Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 278.6 ms [Finished 13.528 s after backend start]
2023-07-28T16:55:02.219Z root INFO Deploy plugins list: 1228.2 ms [Finished 13.564 s after backend start]
2023-07-28T16:55:02.609Z daemon INFO INFO[0006] Adding libraries dir                          dir="C:\\Users\\Steve\\AppData\\Local\\Arduino15\\libraries" location=ide
2023-07-28T16:55:02.615Z daemon INFO INFO[0006] Adding libraries dir                          dir="d:\\Arduinofiles\\libraries" location=user
2023-07-28T16:55:13.426Z discovery-log INFO start request start watch
2023-07-28T16:55:13.428Z discovery-log INFO start requested start watch
2023-07-28T16:55:13.429Z discovery-log INFO start resolved watching
2023-07-28T16:55:13.432Z daemon INFO INFO[0016] starting discovery builtin:dfu-discovery process
2023-07-28T16:55:13.434Z daemon INFO INFO[0016] starting discovery builtin:serial-discovery process
2023-07-28T16:55:13.436Z daemon INFO INFO[0016] starting discovery builtin:mdns-discovery process
2023-07-28T16:55:13.443Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <d:\Arduinofiles\Blink_copy_20230728125005\Blink_copy_20230728125005.ino>, response: <d:\Arduinofiles\Blink_copy_20230728125005>.
2023-07-28T16:55:13.531Z root ERROR Uncaught Exception:
2023-07-28T16:55:13.532Z root ERROR Error: EPERM: operation not permitted, open 'c:\Users\Steve\.arduinoIDE\recentworkspace.json'
2023-07-28T16:55:13.536Z daemon INFO INFO[0016] started discovery builtin:dfu-discovery process
INFO[0016] sending command HELLO 1 "arduino-cli 0.32.3" to discovery builtin:dfu-discovery
2023-07-28T16:55:13.541Z daemon INFO INFO[0016] started discovery builtin:serial-discovery process
INFO[0016] sending command HELLO 1 "arduino-cli 0.32.3" to discovery builtin:serial-discovery
2023-07-28T16:55:13.571Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 12139.6 ms [Finished 19.306 s after frontend start]
2023-07-28T16:55:13.801Z root INFO Start frontend contributions: 14184.9 ms [Finished 19.323 s after frontend start]
2023-07-28T16:55:13.801Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-07-28T16:55:13.803Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-07-28T16:55:13.806Z root INFO >>> Restoring the layout state...
2023-07-28T16:55:13.806Z root INFO ------- SERIALIZED LAYOUT DATA -------
2023-07-28T16:55:13.807Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/Arduinofiles/Blink_copy_20230728125005/Blink_copy_20230728125005.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":38,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":null},"pinned":[],"expanded":false},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"},\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"},\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"},\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"code-editor-opener:file:///d%3A/Arduinofiles/Blink_copy_20230728125005/Blink_copy_20230728125005.ino:0"}
2023-07-28T16:55:13.810Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2023-07-28T16:55:13.816Z daemon INFO INFO[0017] started discovery builtin:mdns-discovery process
INFO[0017] sending command HELLO 1 "arduino-cli 0.32.3" to discovery builtin:mdns-discovery
2023-07-28T16:55:14.019Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25] Waiting for backend deployment: 444.8 ms [Finished 19.754 s after frontend start]
2023-07-28T16:55:14.306Z daemon INFO INFO[0017] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
INFO[0017] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
INFO[0017] sending command START_SYNC to discovery builtin:serial-discovery
INFO[0017] sending command START_SYNC to discovery builtin:mdns-discovery
2023-07-28T16:55:14.331Z daemon INFO INFO[0017] from discovery builtin:dfu-discovery received message type: hello, message: OK, protocol version: 1
INFO[0017] sending command START_SYNC to discovery builtin:dfu-discovery
2023-07-28T16:55:14.351Z daemon INFO INFO[0017] from discovery builtin:serial-discovery received message type: start_sync, message: OK
2023-07-28T16:55:15.286Z daemon INFO INFO[0017] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
INFO[0018] from discovery builtin:dfu-discovery received message type: start_sync, message: OK
INFO[0018] from discovery builtin:serial-discovery received message type: add, port: COM7
INFO[0018] from discovery builtin:serial-discovery received message type: add, port: COM9
INFO[0018] from discovery builtin:serial-discovery received message type: add, port: COM5
INFO[0018] from discovery builtin:serial-discovery received message type: add, port: COM4
INFO[0018] from discovery builtin:serial-discovery received message type: add, port: COM6
2023-07-28T16:55:15.321Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM7","label":"COM7","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-07-28T16:55:15.337Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM9","label":"COM9","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x7523"],["serialNumber",""],["vid","0x1A86"]],"hardwareId":""}},"error":""}
2023-07-28T16:55:15.363Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM5","label":"COM5","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-07-28T16:55:15.367Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM4","label":"COM4","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-07-28T16:55:15.418Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM6","label":"COM6","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-07-28T16:55:15.723Z root INFO [hosted-plugin: 7732] PLUGIN_HOST(7732) starting instance
2023-07-28T16:55:16.208Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25] Sync of 21 plugins: 2191.2 ms [Finished 21.945 s after frontend start]
2023-07-28T16:55:16.223Z root INFO Attached boards and available ports changed:
2023-07-28T16:55:16.223Z root INFO  - New port is available on COM7 Serial Port
2023-07-28T16:55:16.224Z root INFO ------------------------------------------
2023-07-28T16:55:16.233Z root INFO Attached boards and available ports changed:
2023-07-28T16:55:16.233Z root INFO  - New port is available on COM9 Serial Port (USB)
2023-07-28T16:55:16.234Z root INFO ------------------------------------------
2023-07-28T16:55:16.245Z root INFO Attached boards and available ports changed:
2023-07-28T16:55:16.245Z root INFO  - New port is available on COM5 Serial Port
2023-07-28T16:55:16.246Z root INFO ------------------------------------------
2023-07-28T16:55:16.249Z root INFO Attached boards and available ports changed:
2023-07-28T16:55:16.249Z root INFO  - New port is available on COM4 Serial Port
2023-07-28T16:55:16.250Z root INFO ------------------------------------------
2023-07-28T16:55:16.260Z root INFO Attached boards and available ports changed:
2023-07-28T16:55:16.260Z root INFO  - New port is available on COM6 Serial Port
2023-07-28T16:55:16.261Z root INFO ------------------------------------------
2023-07-28T16:55:16.717Z root INFO <<< The layout has been successfully restored.
2023-07-28T16:55:16.952Z root INFO Initialize the workbench layout: 3032.9 ms [Finished 22.455 s after frontend start]
2023-07-28T16:55:16.956Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-07-28T16:55:16.961Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][marus25.cortex-debug]: Loaded contributions.
2023-07-28T16:55:16.961Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][arduino.vscode-arduino-tools]: Loaded contributions.
2023-07-28T16:55:16.964Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][vscode.cpp]: Loaded contributions.
2023-07-28T16:55:16.964Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][vscode.json]: Loaded contributions.
2023-07-28T16:55:16.965Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][vscode.json-language-features]: Loaded contributions.
2023-07-28T16:55:16.968Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-bg]: Loaded contributions.
2023-07-28T16:55:16.968Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
2023-07-28T16:55:16.969Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
2023-07-28T16:55:16.972Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
2023-07-28T16:55:16.978Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
2023-07-28T16:55:16.985Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-hu]: Loaded contributions.
2023-07-28T16:55:16.987Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
2023-07-28T16:55:16.989Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
2023-07-28T16:55:16.992Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-ko]: Loaded contributions.
2023-07-28T16:55:16.994Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
2023-07-28T16:55:16.995Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-pl]: Loaded contributions.
2023-07-28T16:55:16.996Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
2023-07-28T16:55:16.999Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
2023-07-28T16:55:17.004Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
2023-07-28T16:55:17.009Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-uk]: Loaded contributions.
2023-07-28T16:55:17.012Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
2023-07-28T16:55:17.013Z root INFO [d1ddd08d-aa47-4833-a779-37ffcfeddf25] Load contributions of 21 plugins: 227.3 ms [Finished 22.685 s after frontend start]
2023-07-28T16:55:17.150Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-07-28T16:55:17.152Z root WARN a registered grammar configuration for 'cpp' language is overridden
2023-07-28T16:55:17.171Z root ERROR Request markAsRecentlyOpened failed with error: EPERM: operation not permitted, open 'c:\Users\Steve\.arduinoIDE\recent-sketches.json'
2023-07-28T16:55:18.783Z root INFO Frontend application start: 18037.7 ms [Finished 30.140 s after backend start]
Checking for update
2023-07-28T16:55:19.142Z root INFO Replace loading indicator with ready workbench UI (animation): 1028.5 ms [Finished 23.716 s after frontend start]
2023-07-28T16:55:19.165Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-07-28T16:55:19.198Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
Update for version 2.1.1 is not available (latest version: 2.1.1, downgrade is allowed).
2023-07-28T16:55:19.658Z daemon INFO INFO[0022] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0022] Required tool                                 tool="esp32:esptool_py@4.5.1"
INFO[0022] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0022] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0022] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0022] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0022] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0022] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0022] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0022] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0022] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T16:55:20.519Z daemon INFO INFO[0023] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0023] Required tool                                 tool="esp32:esptool_py@4.5.1"
INFO[0023] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0023] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0023] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0023] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0023] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0023] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0023] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0023] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0023] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T16:55:22.550Z root INFO [hosted-plugin: 7732] PLUGIN_HOST(7732): PluginManagerExtImpl/init()
PLUGIN_HOST(7732): initializing(cortex-debug@1.5.1 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-28T16:55:24.008Z root INFO [hosted-plugin: 7732] Debugger contribution has been registered: cortex-debug
PLUGIN_HOST(7732): initializing(vscode-arduino-tools@0.0.2-beta.8 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(cpp@1.52.1 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(json@1.46.1 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(json-language-features@1.46.1 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-cs@1.53.2 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-de@1.53.2 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-es@1.53.2 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-fr@1.53.2 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-it@1.53.2 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-ja@1.53.2 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-ko@1.53.2 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-pl@1.53.2 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-pt-BR@1.53.2 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-ru@1.53.2 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-tr@1.53.2 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(7732): initializing(vscode-language-pack-zh-hans@1.53.2 with C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
Thanks. Does the problem with Serial Monitor still occur, or was it fixed after the uninstallation and registry operations you performed?
It's intermittent. Sometime the Baud Dropdown menu will show and then it will disappear. Sometimes it will not show initially, but then show later. Kinda weird.
When doing upload action then the Serial Monitor will show the Baud DD... but complete, if I close the Serial Monitor and then open it again the Baud DD won't show until an Upload action is initiated. It also seems to lag a bit in these transitions.
Hope that helps!
That is indeed weird. I am aware of some things that can cause this fault, but none of them cause it intermittently.
Unfortunately I don't see anything that looks significant in the logs you shared. But it is possible that is because the fault did not occur during the time the logs were being generated. Please try it again, only this time with a small adjustment:
Please do this:
    & ".\Arduino IDE"
  9. Perform whatever actions are needed to reproduce the problem with the baud rate menu not showing in Serial Monitor.
  10. Switch back to the PowerShell window.
  11. Right click on the title bar of the PowerShell window.
  12. Select Edit > Select All from the context menu.
  13. Press Ctrl+C.
  14. Open a forum reply here by clicking the Reply button.
  15. Click the <CODE/> icon on the post composer toolbar.
  16. Press Ctrl+V.
  17. Move the cursor outside of the code block markup before you add any additional text to your reply.
  18. Click the Reply button to post the output.
The difference from the procedure is that, instead of immediately switching back to the PowerShell window after the startup completes as in my previous instructions, there is an added step (9):
  1. Perform whatever actions are needed to reproduce the problem with the baud rate menu not showing in Serial Monitor.
Following debug instructions. After everything settled, I did the following:
  1. Opened Serial Monitor -> no Baud DD
  2. Resets PCB board, nothing shown in SM Window (installed sketch is supposed to send text to Serial Monitor... nothing shows)
  3. Initiate Upload Command -> Initiates "Compiling sketch..." but nothing else happens
Does the DEBUG state prevent normal Arduino IDE operations from occuring?
2023-07-28T22:52:09.661Z daemon INFO INFO[0132] Resolving include SPIFFS.h for arch esp32
2023-07-28T22:52:09.662Z daemon INFO INFO[0132]   found better lib                            lib=SPIFFS prio=64C
2023-07-28T22:53:02.081Z monitor-service INFO starting monitor
2023-07-28T22:53:02.109Z daemon INFO INFO[0184] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0184] Required tool                                 tool="esp32:esptool_py@4.5.1"
INFO[0184] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2023-07-28T22:53:02.110Z daemon INFO INFO[0184] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0184] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0184] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0184] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0184] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0184] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0184] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0184] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:02.117Z daemon INFO INFO[0184] Starting monitor process                      monitor=serial-monitor
2023-07-28T22:53:02.126Z daemon INFO INFO[0184] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:02.127Z daemon INFO INFO[0184] Required tool                                 tool="esp32:esptool_py@4.5.1"
2023-07-28T22:53:02.134Z daemon INFO INFO[0184] Monitor process started successfully!         monitor=serial-monitor
2023-07-28T22:53:02.136Z daemon INFO INFO[0184] sending command                               command="HELLO 1 \"arduino-cli 0.32.3\"" monitor=serial-monitor
2023-07-28T22:53:02.153Z daemon INFO INFO[0184] Monitor process started successfully!         monitor=serial-monitor
2023-07-28T22:53:02.176Z daemon INFO INFO[0184] received message                              error=false event_type=hello message=OK monitor=serial-monitor
2023-07-28T22:53:02.177Z daemon INFO INFO[0184] sending command                               command=DESCRIBE monitor=serial-monitor
2023-07-28T22:53:02.178Z daemon INFO INFO[0184] received message                              error=false event_type=describe message=OK monitor=serial-monitor
2023-07-28T22:53:02.179Z daemon INFO INFO[0184] sending command                               command=QUIT monitor=serial-monitor
2023-07-28T22:53:02.182Z daemon INFO INFO[0184] received message                              error=false event_type=quit message=OK monitor=serial-monitor
2023-07-28T22:53:02.184Z daemon INFO INFO[0184] Killing monitor process                       monitor=serial-monitor
2023-07-28T22:53:02.185Z daemon INFO ERRO[0184] Sent kill signal                              error="TerminateProcess: Access is denied." monitor=serial-monitor
2023-07-28T22:53:02.193Z daemon INFO INFO[0184] received message                              error=false event_type=hello message=OK monitor=serial-monitor
2023-07-28T22:53:02.194Z daemon INFO INFO[0184] sending command                               command=DESCRIBE monitor=serial-monitor
2023-07-28T22:53:02.198Z daemon INFO INFO[0184] received message                              error=false event_type=describe message=OK monitor=serial-monitor
2023-07-28T22:53:02.199Z daemon INFO INFO[0184] sending command                               command=QUIT monitor=serial-monitor
2023-07-28T22:53:02.200Z daemon INFO INFO[0184] received message                              error=false event_type=quit message=OK monitor=serial-monitor
2023-07-28T22:53:02.202Z daemon INFO INFO[0184] Killing monitor process                       monitor=serial-monitor
2023-07-28T22:53:02.203Z daemon INFO ERRO[0184] Sent kill signal                              error="TerminateProcess: Access is denied." monitor=serial-monitor
2023-07-28T22:53:02.254Z daemon INFO ERRO[0184] stopped decode loop: EOF                      monitor=serial-monitor
2023-07-28T22:53:02.271Z daemon INFO INFO[0184] Monitor process killed                        monitor=serial-monitor
2023-07-28T22:53:02.275Z daemon INFO ERRO[0184] stopped decode loop: EOF                      monitor=serial-monitor
2023-07-28T22:53:02.290Z daemon INFO INFO[0184] Monitor process killed                        monitor=serial-monitor
2023-07-28T22:53:02.346Z daemon INFO INFO[0184] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:02.347Z daemon INFO INFO[0184] Required tool                                 tool="esp32:mkspiffs@0.2.3"
2023-07-28T22:53:02.355Z daemon INFO INFO[0184] Starting monitor process                      monitor=serial-monitor
2023-07-28T22:53:02.375Z daemon INFO INFO[0184] Monitor process started successfully!         monitor=serial-monitor
2023-07-28T22:53:02.381Z daemon INFO INFO[0184] sending command                               command="HELLO 1 \"arduino-cli 0.32.3\"" monitor=serial-monitor
2023-07-28T22:53:02.421Z daemon INFO INFO[0184] received message                              error=false event_type=hello message=OK monitor=serial-monitor
2023-07-28T22:53:02.423Z daemon INFO INFO[0184] sending command                               command=DESCRIBE monitor=serial-monitor
2023-07-28T22:53:02.425Z daemon INFO INFO[0184] received message                              error=false event_type=describe message=OK monitor=serial-monitor
2023-07-28T22:53:02.426Z daemon INFO INFO[0184] sending command                               command="CONFIGURE stop_bits 1" monitor=serial-monitor
2023-07-28T22:53:02.427Z daemon INFO INFO[0184] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:02.428Z daemon INFO INFO[0184] sending command                               command="CONFIGURE baudrate 115200" monitor=serial-monitor
2023-07-28T22:53:02.429Z daemon INFO INFO[0184] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:02.431Z daemon INFO INFO[0184] sending command                               command="CONFIGURE bits 8" monitor=serial-monitor
2023-07-28T22:53:02.435Z daemon INFO INFO[0184] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:02.436Z daemon INFO INFO[0184] sending command                               command="CONFIGURE dtr off" monitor=serial-monitor
2023-07-28T22:53:02.437Z daemon INFO INFO[0184] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:02.438Z daemon INFO INFO[0184] sending command                               command="CONFIGURE parity none" monitor=serial-monitor
2023-07-28T22:53:02.439Z daemon INFO INFO[0184] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:02.440Z daemon INFO INFO[0184] sending command                               command="CONFIGURE rts off" monitor=serial-monitor
2023-07-28T22:53:02.442Z daemon INFO INFO[0184] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:02.443Z daemon INFO INFO[0184] sending command                               command="OPEN 127.0.0.1:63510 COM9" monitor=serial-monitor
2023-07-28T22:53:02.444Z daemon INFO INFO[0184] received message                              error=true event_type=open message="Serial port busy" monitor=serial-monitor
2023-07-28T22:53:02.445Z daemon INFO INFO[0184] sending command                               command=QUIT monitor=serial-monitor
2023-07-28T22:53:02.452Z daemon INFO INFO[0184] received message                              error=false event_type=quit message=OK monitor=serial-monitor
2023-07-28T22:53:02.456Z daemon INFO INFO[0184] Killing monitor process                       monitor=serial-monitor
2023-07-28T22:53:02.539Z daemon INFO ERRO[0185] stopped decode loop: EOF                      monitor=serial-monitor
2023-07-28T22:53:02.556Z daemon INFO INFO[0185] Monitor process killed                        monitor=serial-monitor
2023-07-28T22:53:02.559Z monitor-service ERROR Error: 2 UNKNOWN: Port monitor error: command 'open' failed: Serial port busy
    at Object.callErrorFromStatus (C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\call.js:31:19)
    at Object.onReceiveStatus (C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client.js:413:49)
    at Object.onReceiveStatus (C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client-interceptors.js:328:181)
    at C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\call-stream.js:187:78
    at processTicksAndRejections (node:internal/process/task_queues:78:11)
for call at
    at ServiceClientImpl.makeBidiStreamRequest (C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client.js:398:30)
    at ServiceClientImpl.monitor (C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\make-client.js:105:19)
    at MonitorService.createDuplex (C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\monitor-service.js:184:34)
    at processTicksAndRejections (node:internal/process/task_queues:96:5)
    at async C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\monitor-service.js:257:37
    at async retry (C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\core\lib\common\promise-util.js:73:20)
    at async MonitorService.start (C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\monitor-service.js:148:13)
    at async MonitorManager.startMonitor (C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\monitor-manager.js:90:13)
    at async JsonRpcProxyFactory.onRequest (C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\core\lib\common\messaging\proxy-factory.js:132:24)
    at async RpcProtocol.handleRequest (C:\Users\Steve\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\core\lib\common\message-rpc\rpc-protocol.js:150:28)
2023-07-28T22:53:02.560Z monitor-service INFO monitor to COM9 using serial closed by server
2023-07-28T22:53:02.561Z monitor-service INFO monitor to COM9 using serial closed by client
2023-07-28T22:53:04.604Z daemon INFO INFO[0187] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0187] Required tool                                 tool="esp32:esptool_py@4.5.1"
INFO[0187] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2023-07-28T22:53:04.606Z daemon INFO INFO[0187] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0187] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0187] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0187] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0187] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0187] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0187] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0187] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:04.610Z daemon INFO INFO[0187] Starting monitor process                      monitor=serial-monitor
2023-07-28T22:53:04.634Z daemon INFO INFO[0187] Monitor process started successfully!         monitor=serial-monitor
INFO[0187] sending command                               command="HELLO 1 \"arduino-cli 0.32.3\"" monitor=serial-monitor
2023-07-28T22:53:04.674Z daemon INFO INFO[0187] received message                              error=false event_type=hello message=OK monitor=serial-monitor
2023-07-28T22:53:04.676Z daemon INFO INFO[0187] sending command                               command=DESCRIBE monitor=serial-monitor
2023-07-28T22:53:04.677Z daemon INFO INFO[0187] received message                              error=false event_type=describe message=OK monitor=serial-monitor
2023-07-28T22:53:04.679Z daemon INFO INFO[0187] sending command                               command="CONFIGURE stop_bits 1" monitor=serial-monitor
2023-07-28T22:53:04.685Z daemon INFO INFO[0187] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:04.685Z daemon INFO INFO[0187] sending command                               command="CONFIGURE baudrate 115200" monitor=serial-monitor
2023-07-28T22:53:04.686Z daemon INFO INFO[0187] received message                              error=false event_type=configure message=OK monitor=serial-monitor
INFO[0187] sending command                               command="CONFIGURE bits 8" monitor=serial-monitor
2023-07-28T22:53:04.689Z daemon INFO INFO[0187] received message                              error=false event_type=configure message=OK monitor=serial-monitor
INFO[0187] sending command                               command="CONFIGURE dtr off" monitor=serial-monitor
INFO[0187] sending command                               command="CONFIGURE parity none" monitor=serial-monitor
INFO[0187] sending command                               command="CONFIGURE rts off" monitor=serial-monitor
INFO[0187] sending command                               command="OPEN 127.0.0.1:63513 COM9" monitor=serial-monitor
2023-07-28T22:53:04.691Z daemon INFO INFO[0187] received message                              error=true event_type=open message="Serial port busy" monitor=serial-monitor
INFO[0187] sending command                               command=QUIT monitor=serial-monitor
INFO[0187] received message                              error=false event_type=quit message=OK monitor=serial-monitor
2023-07-28T22:53:04.692Z daemon INFO INFO[0187] Killing monitor process                       monitor=serial-monitor
2023-07-28T22:53:04.692Z daemon INFO ERRO[0187] Sent kill signal                              error="TerminateProcess: Access is denied." monitor=serial-monitor
2023-07-28T22:53:04.755Z daemon INFO ERRO[0187] stopped decode loop: EOF                      monitor=serial-monitor
2023-07-28T22:53:04.764Z daemon INFO INFO[0187] Monitor process killed                        monitor=serial-monitor
2023-07-28T22:53:04.767Z monitor-service ERROR Error: 2 UNKNOWN: Port monitor error: command 'open' failed: Serial port busy
for call at
2023-07-28T22:53:04.768Z monitor-service INFO monitor to COM9 using serial closed by server
2023-07-28T22:53:04.768Z monitor-service INFO monitor to COM9 using serial closed by client
2023-07-28T22:53:06.804Z daemon INFO INFO[0189] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0189] Required tool                                 tool="esp32:esptool_py@4.5.1"
INFO[0189] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0189] Required tool                                 tool="esp32:mkspiffs@0.2.3"
2023-07-28T22:53:06.805Z daemon INFO INFO[0189] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0189] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0189] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0189] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0189] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0189] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0189] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:06.811Z daemon INFO INFO[0189] Starting monitor process                      monitor=serial-monitor
2023-07-28T22:53:06.825Z daemon INFO INFO[0189] Monitor process started successfully!         monitor=serial-monitor
INFO[0189] sending command                               command="HELLO 1 \"arduino-cli 0.32.3\"" monitor=serial-monitor
2023-07-28T22:53:06.861Z daemon INFO INFO[0189] received message                              error=false event_type=hello message=OK monitor=serial-monitor
2023-07-28T22:53:06.862Z daemon INFO INFO[0189] sending command                               command=DESCRIBE monitor=serial-monitor
INFO[0189] received message                              error=false event_type=describe message=OK monitor=serial-monitor
2023-07-28T22:53:06.865Z daemon INFO INFO[0189] sending command                               command="CONFIGURE stop_bits 1" monitor=serial-monitor
2023-07-28T22:53:06.867Z daemon INFO INFO[0189] received message                              error=false event_type=configure message=OK monitor=serial-monitor
INFO[0189] sending command                               command="CONFIGURE baudrate 115200" monitor=serial-monitor
2023-07-28T22:53:06.868Z daemon INFO INFO[0189] received message                              error=false event_type=configure message=OK monitor=serial-monitor
INFO[0189] sending command                               command="CONFIGURE bits 8" monitor=serial-monitor
INFO[0189] sending command                               command="CONFIGURE dtr off" monitor=serial-monitor
2023-07-28T22:53:06.869Z daemon INFO INFO[0189] received message                              error=false event_type=configure message=OK monitor=serial-monitor
INFO[0189] sending command                               command="CONFIGURE parity none" monitor=serial-monitor
INFO[0189] sending command                               command="CONFIGURE rts off" monitor=serial-monitor
2023-07-28T22:53:06.870Z daemon INFO INFO[0189] received message                              error=false event_type=configure message=OK monitor=serial-monitor
INFO[0189] sending command                               command="OPEN 127.0.0.1:63514 COM9" monitor=serial-monitor
INFO[0189] received message                              error=true event_type=open message="Serial port busy" monitor=serial-monitor
2023-07-28T22:53:06.871Z daemon INFO INFO[0189] sending command                               command=QUIT monitor=serial-monitor
INFO[0189] received message                              error=false event_type=quit message=OK monitor=serial-monitor
2023-07-28T22:53:06.873Z daemon INFO INFO[0189] Killing monitor process                       monitor=serial-monitor
ERRO[0189] Sent kill signal                              error="TerminateProcess: Access is denied." monitor=serial-monitor
2023-07-28T22:53:06.938Z daemon INFO ERRO[0189] stopped decode loop: EOF                      monitor=serial-monitor
2023-07-28T22:53:06.954Z daemon INFO INFO[0189] Monitor process killed                        monitor=serial-monitor
2023-07-28T22:53:06.956Z monitor-service ERROR Error: 2 UNKNOWN: Port monitor error: command 'open' failed: Serial port busy
for call at
    at runNextTicks (node:internal/process/task_queues:61:5)
    at processTimers (node:internal/timers:497:9)
2023-07-28T22:53:06.957Z monitor-service INFO monitor to COM9 using serial closed by server
2023-07-28T22:53:06.958Z monitor-service INFO monitor to COM9 using serial closed by client
2023-07-28T22:53:09.170Z daemon INFO INFO[0191] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:09.174Z daemon INFO INFO[0191] Required tool                                 tool="esp32:esptool_py@4.5.1"
INFO[0191] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0191] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0191] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0191] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0191] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0191] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0191] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0191] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0191] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:09.210Z daemon INFO INFO[0191] Starting monitor process                      monitor=serial-monitor
2023-07-28T22:53:09.327Z daemon INFO INFO[0191] Monitor process started successfully!         monitor=serial-monitor
2023-07-28T22:53:09.338Z daemon INFO INFO[0191] sending command                               command="HELLO 1 \"arduino-cli 0.32.3\"" monitor=serial-monitor
2023-07-28T22:53:09.392Z daemon INFO INFO[0191] received message                              error=false event_type=hello message=OK monitor=serial-monitor
2023-07-28T22:53:09.396Z daemon INFO INFO[0191] sending command                               command=DESCRIBE monitor=serial-monitor
2023-07-28T22:53:09.399Z daemon INFO INFO[0191] received message                              error=false event_type=describe message=OK monitor=serial-monitor
2023-07-28T22:53:09.400Z daemon INFO INFO[0191] sending command                               command="CONFIGURE stop_bits 1" monitor=serial-monitor
2023-07-28T22:53:09.402Z daemon INFO INFO[0191] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:09.403Z daemon INFO INFO[0191] sending command                               command="CONFIGURE baudrate 115200" monitor=serial-monitor
2023-07-28T22:53:09.404Z daemon INFO INFO[0191] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:09.405Z daemon INFO INFO[0191] sending command                               command="CONFIGURE bits 8" monitor=serial-monitor
2023-07-28T22:53:09.405Z daemon INFO INFO[0191] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:09.406Z daemon INFO INFO[0191] sending command                               command="CONFIGURE dtr off" monitor=serial-monitor
2023-07-28T22:53:09.408Z daemon INFO INFO[0191] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:09.409Z daemon INFO INFO[0191] sending command                               command="CONFIGURE parity none" monitor=serial-monitor
2023-07-28T22:53:09.410Z daemon INFO INFO[0191] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:09.413Z daemon INFO INFO[0191] sending command                               command="CONFIGURE rts off" monitor=serial-monitor
2023-07-28T22:53:09.414Z daemon INFO INFO[0191] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:09.416Z daemon INFO INFO[0191] sending command                               command="OPEN 127.0.0.1:63515 COM9" monitor=serial-monitor
2023-07-28T22:53:09.422Z daemon INFO INFO[0191] received message                              error=true event_type=open message="Serial port busy" monitor=serial-monitor
2023-07-28T22:53:09.423Z daemon INFO INFO[0191] sending command                               command=QUIT monitor=serial-monitor
2023-07-28T22:53:09.424Z daemon INFO INFO[0191] received message                              error=false event_type=quit message=OK monitor=serial-monitor
2023-07-28T22:53:09.427Z daemon INFO INFO[0191] Killing monitor process                       monitor=serial-monitor
2023-07-28T22:53:09.430Z daemon INFO ERRO[0191] Sent kill signal                              error="TerminateProcess: Access is denied." monitor=serial-monitor
2023-07-28T22:53:09.507Z daemon INFO ERRO[0191] stopped decode loop: EOF                      monitor=serial-monitor
2023-07-28T22:53:09.531Z daemon INFO INFO[0192] Monitor process killed                        monitor=serial-monitor
2023-07-28T22:53:09.533Z monitor-service ERROR Error: 2 UNKNOWN: Port monitor error: command 'open' failed: Serial port busy
for call at
2023-07-28T22:53:09.534Z monitor-service INFO monitor to COM9 using serial closed by server
2023-07-28T22:53:09.535Z monitor-service INFO monitor to COM9 using serial closed by client
2023-07-28T22:53:11.582Z daemon INFO INFO[0194] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0194] Required tool                                 tool="esp32:esptool_py@4.5.1"
INFO[0194] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2023-07-28T22:53:11.583Z daemon INFO INFO[0194] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0194] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0194] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0194] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0194] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0194] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0194] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0194] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:11.589Z daemon INFO INFO[0194] Starting monitor process                      monitor=serial-monitor
2023-07-28T22:53:11.602Z daemon INFO INFO[0194] Monitor process started successfully!         monitor=serial-monitor
INFO[0194] sending command                               command="HELLO 1 \"arduino-cli 0.32.3\"" monitor=serial-monitor
2023-07-28T22:53:11.640Z daemon INFO INFO[0194] received message                              error=false event_type=hello message=OK monitor=serial-monitor
2023-07-28T22:53:11.642Z daemon INFO INFO[0194] sending command                               command=DESCRIBE monitor=serial-monitor
2023-07-28T22:53:11.646Z daemon INFO INFO[0194] received message                              error=false event_type=describe message=OK monitor=serial-monitor
2023-07-28T22:53:11.647Z daemon INFO INFO[0194] sending command                               command="CONFIGURE stop_bits 1" monitor=serial-monitor
2023-07-28T22:53:11.647Z daemon INFO INFO[0194] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:11.648Z daemon INFO INFO[0194] sending command                               command="CONFIGURE baudrate 115200" monitor=serial-monitor
2023-07-28T22:53:11.649Z daemon INFO INFO[0194] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:11.649Z daemon INFO INFO[0194] sending command                               command="CONFIGURE bits 8" monitor=serial-monitor
2023-07-28T22:53:11.650Z daemon INFO INFO[0194] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:11.651Z daemon INFO INFO[0194] sending command                               command="CONFIGURE dtr off" monitor=serial-monitor
2023-07-28T22:53:11.651Z daemon INFO INFO[0194] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:11.652Z daemon INFO INFO[0194] sending command                               command="CONFIGURE parity none" monitor=serial-monitor
2023-07-28T22:53:11.653Z daemon INFO INFO[0194] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:11.653Z daemon INFO INFO[0194] sending command                               command="CONFIGURE rts off" monitor=serial-monitor
2023-07-28T22:53:11.654Z daemon INFO INFO[0194] received message                              error=false event_type=configure message=OK monitor=serial-monitor
INFO[0194] sending command                               command="OPEN 127.0.0.1:63516 COM9" monitor=serial-monitor
2023-07-28T22:53:11.655Z daemon INFO INFO[0194] received message                              error=true event_type=open message="Serial port busy" monitor=serial-monitor
INFO[0194] sending command                               command=QUIT monitor=serial-monitor
2023-07-28T22:53:11.662Z daemon INFO INFO[0194] received message                              error=false event_type=quit message=OK monitor=serial-monitor
INFO[0194] Killing monitor process                       monitor=serial-monitor
ERRO[0194] Sent kill signal                              error="TerminateProcess: Access is denied." monitor=serial-monitor
2023-07-28T22:53:11.721Z daemon INFO ERRO[0194] stopped decode loop: EOF                      monitor=serial-monitor
2023-07-28T22:53:11.734Z daemon INFO INFO[0194] Monitor process killed                        monitor=serial-monitor
2023-07-28T22:53:11.735Z monitor-service ERROR Error: 2 UNKNOWN: Port monitor error: command 'open' failed: Serial port busy
for call at
2023-07-28T22:53:11.736Z monitor-service INFO monitor to COM9 using serial closed by server
2023-07-28T22:53:11.736Z monitor-service INFO monitor to COM9 using serial closed by client
2023-07-28T22:53:13.793Z daemon INFO INFO[0196] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:13.796Z daemon INFO INFO[0196] Required tool                                 tool="esp32:esptool_py@4.5.1"
INFO[0196] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0196] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0196] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0196] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0196] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0196] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0196] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0196] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0196] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:13.800Z daemon INFO INFO[0196] Starting monitor process                      monitor=serial-monitor
2023-07-28T22:53:13.823Z daemon INFO INFO[0196] Monitor process started successfully!         monitor=serial-monitor
2023-07-28T22:53:13.828Z daemon INFO INFO[0196] sending command                               command="HELLO 1 \"arduino-cli 0.32.3\"" monitor=serial-monitor
2023-07-28T22:53:13.873Z daemon INFO INFO[0196] received message                              error=false event_type=hello message=OK monitor=serial-monitor
2023-07-28T22:53:13.874Z daemon INFO INFO[0196] sending command                               command=DESCRIBE monitor=serial-monitor
2023-07-28T22:53:13.877Z daemon INFO INFO[0196] received message                              error=false event_type=describe message=OK monitor=serial-monitor
2023-07-28T22:53:13.879Z daemon INFO INFO[0196] sending command                               command="CONFIGURE stop_bits 1" monitor=serial-monitor
2023-07-28T22:53:13.881Z daemon INFO INFO[0196] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:13.882Z daemon INFO INFO[0196] sending command                               command="CONFIGURE baudrate 115200" monitor=serial-monitor
2023-07-28T22:53:13.883Z daemon INFO INFO[0196] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:13.885Z daemon INFO INFO[0196] sending command                               command="CONFIGURE bits 8" monitor=serial-monitor
2023-07-28T22:53:13.890Z daemon INFO INFO[0196] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:13.892Z daemon INFO INFO[0196] sending command                               command="CONFIGURE dtr off" monitor=serial-monitor
2023-07-28T22:53:13.896Z daemon INFO INFO[0196] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:13.897Z daemon INFO INFO[0196] sending command                               command="CONFIGURE parity none" monitor=serial-monitor
2023-07-28T22:53:13.897Z daemon INFO INFO[0196] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:13.898Z daemon INFO INFO[0196] sending command                               command="CONFIGURE rts off" monitor=serial-monitor
2023-07-28T22:53:13.900Z daemon INFO INFO[0196] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:13.904Z daemon INFO INFO[0196] sending command                               command="OPEN 127.0.0.1:63517 COM9" monitor=serial-monitor
2023-07-28T22:53:13.911Z daemon INFO INFO[0196] received message                              error=true event_type=open message="Serial port busy" monitor=serial-monitor
2023-07-28T22:53:13.913Z daemon INFO INFO[0196] sending command                               command=QUIT monitor=serial-monitor
2023-07-28T22:53:13.916Z daemon INFO INFO[0196] received message                              error=false event_type=quit message=OK monitor=serial-monitor
2023-07-28T22:53:13.918Z daemon INFO INFO[0196] Killing monitor process                       monitor=serial-monitor
ERRO[0196] Sent kill signal                              error="TerminateProcess: Access is denied." monitor=serial-monitor
2023-07-28T22:53:13.993Z daemon INFO ERRO[0196] stopped decode loop: EOF                      monitor=serial-monitor
2023-07-28T22:53:14.013Z daemon INFO INFO[0196] Monitor process killed                        monitor=serial-monitor
2023-07-28T22:53:14.016Z monitor-service ERROR Error: 2 UNKNOWN: Port monitor error: command 'open' failed: Serial port busy
for call at
2023-07-28T22:53:14.017Z monitor-service INFO monitor to COM9 using serial closed by server
2023-07-28T22:53:14.017Z monitor-service INFO monitor to COM9 using serial closed by client
2023-07-28T22:53:16.061Z daemon INFO INFO[0198] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0198] Required tool                                 tool="esp32:esptool_py@4.5.1"
INFO[0198] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0198] Required tool                                 tool="esp32:mkspiffs@0.2.3"
2023-07-28T22:53:16.064Z daemon INFO INFO[0198] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0198] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0198] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0198] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0198] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0198] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0198] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:16.071Z daemon INFO INFO[0198] Starting monitor process                      monitor=serial-monitor
2023-07-28T22:53:16.103Z daemon INFO INFO[0198] Monitor process started successfully!         monitor=serial-monitor
2023-07-28T22:53:16.106Z daemon INFO INFO[0198] sending command                               command="HELLO 1 \"arduino-cli 0.32.3\"" monitor=serial-monitor
2023-07-28T22:53:16.148Z daemon INFO INFO[0198] received message                              error=false event_type=hello message=OK monitor=serial-monitor
2023-07-28T22:53:16.150Z daemon INFO INFO[0198] sending command                               command=DESCRIBE monitor=serial-monitor
2023-07-28T22:53:16.153Z daemon INFO INFO[0198] received message                              error=false event_type=describe message=OK monitor=serial-monitor
2023-07-28T22:53:16.155Z daemon INFO INFO[0198] sending command                               command="CONFIGURE stop_bits 1" monitor=serial-monitor
2023-07-28T22:53:16.161Z daemon INFO INFO[0198] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:16.162Z daemon INFO INFO[0198] sending command                               command="CONFIGURE baudrate 115200" monitor=serial-monitor
2023-07-28T22:53:16.164Z daemon INFO INFO[0198] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:16.165Z daemon INFO INFO[0198] sending command                               command="CONFIGURE bits 8" monitor=serial-monitor
2023-07-28T22:53:16.167Z daemon INFO INFO[0198] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:16.168Z daemon INFO INFO[0198] sending command                               command="CONFIGURE dtr off" monitor=serial-monitor
2023-07-28T22:53:16.169Z daemon INFO INFO[0198] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:16.170Z daemon INFO INFO[0198] sending command                               command="CONFIGURE parity none" monitor=serial-monitor
2023-07-28T22:53:16.172Z daemon INFO INFO[0198] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:16.178Z daemon INFO INFO[0198] sending command                               command="CONFIGURE rts off" monitor=serial-monitor
2023-07-28T22:53:16.180Z daemon INFO INFO[0198] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:16.180Z daemon INFO INFO[0198] sending command                               command="OPEN 127.0.0.1:63518 COM9" monitor=serial-monitor
2023-07-28T22:53:16.181Z daemon INFO INFO[0198] received message                              error=true event_type=open message="Serial port busy" monitor=serial-monitor
2023-07-28T22:53:16.183Z daemon INFO INFO[0198] sending command                               command=QUIT monitor=serial-monitor
2023-07-28T22:53:16.185Z daemon INFO INFO[0198] received message                              error=false event_type=quit message=OK monitor=serial-monitor
2023-07-28T22:53:16.187Z daemon INFO INFO[0198] Killing monitor process                       monitor=serial-monitor
2023-07-28T22:53:16.189Z daemon INFO ERRO[0198] Sent kill signal                              error="TerminateProcess: Access is denied." monitor=serial-monitor
2023-07-28T22:53:16.269Z daemon INFO ERRO[0198] stopped decode loop: EOF                      monitor=serial-monitor
2023-07-28T22:53:16.283Z daemon INFO INFO[0198] Monitor process killed                        monitor=serial-monitor
2023-07-28T22:53:16.285Z monitor-service ERROR Error: 2 UNKNOWN: Port monitor error: command 'open' failed: Serial port busy
for call at
2023-07-28T22:53:16.286Z monitor-service INFO monitor to COM9 using serial closed by server
2023-07-28T22:53:16.287Z monitor-service INFO monitor to COM9 using serial closed by client
2023-07-28T22:53:18.330Z daemon INFO INFO[0200] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0200] Required tool                                 tool="esp32:esptool_py@4.5.1"
INFO[0200] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2023-07-28T22:53:18.331Z daemon INFO INFO[0200] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0200] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0200] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0200] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0200] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0200] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0200] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0200] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:18.336Z daemon INFO INFO[0200] Starting monitor process                      monitor=serial-monitor
2023-07-28T22:53:18.350Z daemon INFO INFO[0200] Monitor process started successfully!         monitor=serial-monitor
INFO[0200] sending command                               command="HELLO 1 \"arduino-cli 0.32.3\"" monitor=serial-monitor
2023-07-28T22:53:18.382Z daemon INFO INFO[0200] received message                              error=false event_type=hello message=OK monitor=serial-monitor
2023-07-28T22:53:18.383Z daemon INFO INFO[0200] sending command                               command=DESCRIBE monitor=serial-monitor
2023-07-28T22:53:18.385Z daemon INFO INFO[0200] received message                              error=false event_type=describe message=OK monitor=serial-monitor
INFO[0200] sending command                               command="CONFIGURE stop_bits 1" monitor=serial-monitor
2023-07-28T22:53:18.386Z daemon INFO INFO[0200] received message                              error=false event_type=configure message=OK monitor=serial-monitor
INFO[0200] sending command                               command="CONFIGURE baudrate 115200" monitor=serial-monitor
INFO[0200] sending command                               command="CONFIGURE bits 8" monitor=serial-monitor
INFO[0200] sending command                               command="CONFIGURE dtr off" monitor=serial-monitor
INFO[0200] sending command                               command="CONFIGURE parity none" monitor=serial-monitor
2023-07-28T22:53:18.388Z daemon INFO INFO[0200] received message                              error=false event_type=configure message=OK monitor=serial-monitor
INFO[0200] sending command                               command="CONFIGURE rts off" monitor=serial-monitor
INFO[0200] sending command                               command="OPEN 127.0.0.1:63519 COM9" monitor=serial-monitor
2023-07-28T22:53:18.391Z daemon INFO INFO[0200] received message                              error=true event_type=open message="Serial port busy" monitor=serial-monitor
INFO[0200] sending command                               command=QUIT monitor=serial-monitor
2023-07-28T22:53:18.392Z daemon INFO INFO[0200] received message                              error=false event_type=quit message=OK monitor=serial-monitor
INFO[0200] Killing monitor process                       monitor=serial-monitor
ERRO[0200] Sent kill signal                              error="TerminateProcess: Access is denied." monitor=serial-monitor
2023-07-28T22:53:18.455Z daemon INFO ERRO[0200] stopped decode loop: EOF                      monitor=serial-monitor
2023-07-28T22:53:18.477Z daemon INFO INFO[0200] Monitor process killed                        monitor=serial-monitor
2023-07-28T22:53:18.478Z monitor-service ERROR Error: 2 UNKNOWN: Port monitor error: command 'open' failed: Serial port busy
for call at
2023-07-28T22:53:18.479Z monitor-service INFO monitor to COM9 using serial closed by server
2023-07-28T22:53:18.479Z monitor-service INFO monitor to COM9 using serial closed by client
2023-07-28T22:53:20.532Z daemon INFO INFO[0203] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0203] Required tool                                 tool="esp32:esptool_py@4.5.1"
INFO[0203] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2023-07-28T22:53:20.533Z daemon INFO INFO[0203] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0203] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0203] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0203] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0203] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0203] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0203] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0203] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:20.539Z daemon INFO INFO[0203] Starting monitor process                      monitor=serial-monitor
2023-07-28T22:53:20.552Z daemon INFO INFO[0203] Monitor process started successfully!         monitor=serial-monitor
INFO[0203] sending command                               command="HELLO 1 \"arduino-cli 0.32.3\"" monitor=serial-monitor
2023-07-28T22:53:20.587Z daemon INFO INFO[0203] received message                              error=false event_type=hello message=OK monitor=serial-monitor
2023-07-28T22:53:20.589Z daemon INFO INFO[0203] sending command                               command=DESCRIBE monitor=serial-monitor
INFO[0203] received message                              error=false event_type=describe message=OK monitor=serial-monitor
INFO[0203] sending command                               command="CONFIGURE stop_bits 1" monitor=serial-monitor
2023-07-28T22:53:20.590Z daemon INFO INFO[0203] received message                              error=false event_type=configure message=OK monitor=serial-monitor
INFO[0203] sending command                               command="CONFIGURE baudrate 115200" monitor=serial-monitor
INFO[0203] sending command                               command="CONFIGURE bits 8" monitor=serial-monitor
INFO[0203] sending command                               command="CONFIGURE dtr off" monitor=serial-monitor
INFO[0203] sending command                               command="CONFIGURE parity none" monitor=serial-monitor
2023-07-28T22:53:20.593Z daemon INFO INFO[0203] sending command                               command="CONFIGURE rts off" monitor=serial-monitor
INFO[0203] sending command                               command="OPEN 127.0.0.1:63521 COM9" monitor=serial-monitor
INFO[0203] received message                              error=true event_type=open message="Serial port busy" monitor=serial-monitor
INFO[0203] sending command                               command=QUIT monitor=serial-monitor
INFO[0203] received message                              error=false event_type=quit message=OK monitor=serial-monitor
2023-07-28T22:53:20.594Z daemon INFO INFO[0203] Killing monitor process                       monitor=serial-monitor
2023-07-28T22:53:20.595Z daemon INFO ERRO[0203] Sent kill signal                              error="TerminateProcess: Access is denied." monitor=serial-monitor
2023-07-28T22:53:20.666Z daemon INFO ERRO[0203] stopped decode loop: EOF                      monitor=serial-monitor
2023-07-28T22:53:20.677Z daemon INFO INFO[0203] Monitor process killed                        monitor=serial-monitor
2023-07-28T22:53:20.679Z monitor-service ERROR Error: 2 UNKNOWN: Port monitor error: command 'open' failed: Serial port busy
for call at
2023-07-28T22:53:20.680Z monitor-service INFO monitor to COM9 using serial closed by server
2023-07-28T22:53:20.681Z monitor-service INFO monitor to COM9 using serial closed by client
2023-07-28T22:53:22.730Z daemon INFO INFO[0205] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0205] Required tool                                 tool="esp32:esptool_py@4.5.1"
INFO[0205] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2023-07-28T22:53:22.731Z daemon INFO INFO[0205] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0205] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0205] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0205] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0205] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0205] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0205] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0205] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:22.739Z daemon INFO INFO[0205] Starting monitor process                      monitor=serial-monitor
2023-07-28T22:53:22.763Z daemon INFO INFO[0205] Monitor process started successfully!         monitor=serial-monitor
2023-07-28T22:53:22.766Z daemon INFO INFO[0205] sending command                               command="HELLO 1 \"arduino-cli 0.32.3\"" monitor=serial-monitor
2023-07-28T22:53:22.833Z daemon INFO INFO[0205] received message                              error=false event_type=hello message=OK monitor=serial-monitor
INFO[0205] sending command                               command=DESCRIBE monitor=serial-monitor
2023-07-28T22:53:22.834Z daemon INFO INFO[0205] received message                              error=false event_type=describe message=OK monitor=serial-monitor
2023-07-28T22:53:22.835Z daemon INFO INFO[0205] sending command                               command="CONFIGURE stop_bits 1" monitor=serial-monitor
2023-07-28T22:53:22.837Z daemon INFO INFO[0205] received message                              error=false event_type=configure message=OK monitor=serial-monitor
INFO[0205] sending command                               command="CONFIGURE baudrate 115200" monitor=serial-monitor
2023-07-28T22:53:22.838Z daemon INFO INFO[0205] received message                              error=false event_type=configure message=OK monitor=serial-monitor
INFO[0205] sending command                               command="CONFIGURE bits 8" monitor=serial-monitor
INFO[0205] sending command                               command="CONFIGURE dtr off" monitor=serial-monitor
2023-07-28T22:53:22.840Z daemon INFO INFO[0205] received message                              error=false event_type=configure message=OK monitor=serial-monitor
INFO[0205] sending command                               command="CONFIGURE parity none" monitor=serial-monitor
INFO[0205] sending command                               command="CONFIGURE rts off" monitor=serial-monitor
2023-07-28T22:53:22.841Z daemon INFO INFO[0205] received message                              error=false event_type=configure message=OK monitor=serial-monitor
INFO[0205] sending command                               command="OPEN 127.0.0.1:63523 COM9" monitor=serial-monitor
2023-07-28T22:53:22.842Z daemon INFO INFO[0205] received message                              error=true event_type=open message="Serial port busy" monitor=serial-monitor
INFO[0205] sending command                               command=QUIT monitor=serial-monitor
2023-07-28T22:53:22.844Z daemon INFO INFO[0205] received message                              error=false event_type=quit message=OK monitor=serial-monitor
INFO[0205] Killing monitor process                       monitor=serial-monitor
ERRO[0205] Sent kill signal                              error="TerminateProcess: Access is denied." monitor=serial-monitor
2023-07-28T22:53:22.916Z daemon INFO ERRO[0205] stopped decode loop: EOF                      monitor=serial-monitor
2023-07-28T22:53:22.938Z daemon INFO INFO[0205] Monitor process killed                        monitor=serial-monitor
2023-07-28T22:53:22.940Z monitor-service ERROR Error: 2 UNKNOWN: Port monitor error: command 'open' failed: Serial port busy
for call at
2023-07-28T22:53:22.940Z monitor-service INFO monitor to COM9 using serial closed by server
2023-07-28T22:53:22.941Z monitor-service INFO monitor to COM9 using serial closed by client
2023-07-28T22:53:24.954Z monitor-service WARN failed starting monitor to COM9 using serial
2023-07-28T22:53:30.411Z daemon INFO INFO[0212] sending command                               command=CLOSE monitor=serial-monitor
2023-07-28T22:53:30.419Z daemon INFO INFO[0212] received message                              error=true event_type=port_closed message="readfrom tcp 127.0.0.1:60972->127.0.0.1:60971: Access is denied." monitor=serial-monitor
INFO[0212] monitor port has been closed externally       monitor=serial-monitor
2023-07-28T22:53:30.426Z daemon INFO INFO[0212] received message                              error=true event_type=close message="port already closed" monitor=serial-monitor
2023-07-28T22:53:30.435Z daemon INFO INFO[0212] sending command                               command=QUIT monitor=serial-monitor
2023-07-28T22:53:30.453Z daemon INFO INFO[0212] received message                              error=false event_type=quit message=OK monitor=serial-monitor
2023-07-28T22:53:30.457Z daemon INFO INFO[0212] Killing monitor process                       monitor=serial-monitor
2023-07-28T22:53:30.458Z daemon INFO ERRO[0212] Sent kill signal                              error="TerminateProcess: Access is denied." monitor=serial-monitor
2023-07-28T22:53:30.463Z daemon INFO ERRO[0212] stopped decode loop: EOF                      monitor=serial-monitor
2023-07-28T22:53:30.470Z daemon INFO INFO[0212] Monitor process killed                        monitor=serial-monitor
2023-07-28T22:53:30.471Z monitor-service INFO monitor to COM9 using serial closed by server
2023-07-28T22:53:30.576Z daemon INFO INFO[0213] from discovery builtin:serial-discovery received message type: remove, port: COM9
2023-07-28T22:53:30.581Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"COM9","label":"","protocol":"serial","protocolLabel":"","propertiesMap":[],"hardwareId":""}},"error":""}
2023-07-28T22:53:32.614Z daemon INFO INFO[0215] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:32.619Z daemon INFO INFO[0215] Required tool                                 tool="esp32:esptool_py@4.5.1"
INFO[0215] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0215] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0215] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0215] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0215] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0215] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0215] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0215] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0215] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:32.630Z daemon INFO INFO[0215] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:32.633Z daemon INFO INFO[0215] Required tool                                 tool="esp32:esptool_py@4.5.1"
2023-07-28T22:53:32.740Z daemon INFO INFO[0215] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:32.747Z daemon INFO INFO[0215] Required tool                                 tool="esp32:esptool_py@4.5.1"
2023-07-28T22:53:32.792Z daemon INFO INFO[0215] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:32.822Z daemon INFO INFO[0215] Required tool                                 tool="esp32:esptool_py@4.5.1"
2023-07-28T22:53:32.886Z daemon INFO INFO[0215] from discovery builtin:serial-discovery received message type: add, port: COM9
2023-07-28T22:53:32.905Z root INFO Attached boards and available ports changed:
2023-07-28T22:53:32.928Z root INFO  - Port is no longer available on COM9 Serial Port (USB)
2023-07-28T22:53:32.940Z root INFO ------------------------------------------
2023-07-28T22:53:32.954Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM9","label":"COM9","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x7523"],["serialNumber",""],["vid","0x1A86"]],"hardwareId":""}},"error":""}
2023-07-28T22:53:32.970Z daemon INFO INFO[0215] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:33.707Z root INFO Attached boards and available ports changed:
2023-07-28T22:53:33.782Z root INFO  - New port is available on COM9 Serial Port (USB)
2023-07-28T22:53:33.883Z root INFO ------------------------------------------
2023-07-28T22:53:34.200Z daemon INFO INFO[0216] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:34.207Z daemon INFO INFO[0216] Required tool                                 tool="esp32:esptool_py@4.5.1"
INFO[0216] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0216] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0216] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0216] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0216] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0216] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0216] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0216] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0216] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:34.389Z daemon INFO INFO[0216] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:34.391Z daemon INFO INFO[0216] Required tool                                 tool="esp32:esptool_py@4.5.1"
2023-07-28T22:53:34.651Z daemon INFO INFO[0217] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0217] Required tool                                 tool="esp32:esptool_py@4.5.1"
2023-07-28T22:53:34.655Z daemon INFO INFO[0217] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0217] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0217] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0217] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0217] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0217] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0217] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0217] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0217] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:34.661Z daemon INFO INFO[0217] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:34.664Z daemon INFO INFO[0217] Required tool                                 tool="esp32:esptool_py@4.5.1"
2023-07-28T22:53:34.912Z daemon INFO INFO[0217] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:34.921Z daemon INFO INFO[0217] Required tool                                 tool="esp32:esptool_py@4.5.1"
2023-07-28T22:53:35.862Z daemon INFO INFO[0218] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0218] Required tool                                 tool="esp32:esptool_py@4.5.1"
2023-07-28T22:53:35.873Z daemon INFO INFO[0218] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0218] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0218] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0218] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0218] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0218] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0218] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0218] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0218] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:36.524Z daemon INFO INFO[0219] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0219] Required tool                                 tool="esp32:esptool_py@4.5.1"
2023-07-28T22:53:36.535Z daemon INFO INFO[0219] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0219] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0219] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0219] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0219] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0219] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0219] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0219] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0219] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:37.151Z daemon INFO INFO[0219] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:37.153Z daemon INFO INFO[0219] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2023-07-28T22:53:37.211Z daemon INFO INFO[0219] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:37.213Z daemon INFO INFO[0219] Required tool                                 tool="esp32:esptool_py@4.5.1"
2023-07-28T22:53:37.709Z monitor-service INFO starting monitor
2023-07-28T22:53:37.873Z daemon INFO INFO[0220] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:37.899Z daemon INFO INFO[0220] Required tool                                 tool="esp32:esptool_py@4.5.1"
INFO[0220] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0220] Required tool                                 tool="esp32:mkspiffs@0.2.3"
INFO[0220] Required tool                                 tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0220] Required tool                                 tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0220] Required tool                                 tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0220] Required tool                                 tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0220] Required tool                                 tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0220] Required tool                                 tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0220] Required tool                                 tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-28T22:53:37.931Z daemon INFO INFO[0220] Starting monitor process                      monitor=serial-monitor
2023-07-28T22:53:37.951Z daemon INFO INFO[0220] Monitor process started successfully!         monitor=serial-monitor
2023-07-28T22:53:37.959Z daemon INFO INFO[0220] sending command                               command="HELLO 1 \"arduino-cli 0.32.3\"" monitor=serial-monitor
2023-07-28T22:53:38.023Z daemon INFO INFO[0220] received message                              error=false event_type=hello message=OK monitor=serial-monitor
2023-07-28T22:53:38.025Z daemon INFO INFO[0220] sending command                               command=DESCRIBE monitor=serial-monitor
2023-07-28T22:53:38.031Z daemon INFO INFO[0220] received message                              error=false event_type=describe message=OK monitor=serial-monitor
2023-07-28T22:53:38.031Z daemon INFO INFO[0220] sending command                               command=QUIT monitor=serial-monitor
2023-07-28T22:53:38.032Z daemon INFO INFO[0220] received message                              error=false event_type=quit message=OK monitor=serial-monitor
2023-07-28T22:53:38.034Z daemon INFO INFO[0220] Killing monitor process                       monitor=serial-monitor
2023-07-28T22:53:38.035Z daemon INFO ERRO[0220] Sent kill signal                              error="TerminateProcess: Access is denied." monitor=serial-monitor
2023-07-28T22:53:38.105Z daemon INFO ERRO[0220] stopped decode loop: EOF                      monitor=serial-monitor
2023-07-28T22:53:38.118Z daemon INFO INFO[0220] Monitor process killed                        monitor=serial-monitor
2023-07-28T22:53:38.163Z daemon INFO INFO[0220] Required tool                                 tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-28T22:53:38.164Z daemon INFO INFO[0220] Required tool                                 tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2023-07-28T22:53:38.169Z daemon INFO INFO[0220] Starting monitor process                      monitor=serial-monitor
2023-07-28T22:53:38.188Z daemon INFO INFO[0220] Monitor process started successfully!         monitor=serial-monitor
2023-07-28T22:53:38.197Z daemon INFO INFO[0220] sending command                               command="HELLO 1 \"arduino-cli 0.32.3\"" monitor=serial-monitor
2023-07-28T22:53:38.245Z daemon INFO INFO[0220] received message                              error=false event_type=hello message=OK monitor=serial-monitor
2023-07-28T22:53:38.246Z daemon INFO INFO[0220] sending command                               command=DESCRIBE monitor=serial-monitor
2023-07-28T22:53:38.247Z daemon INFO INFO[0220] received message                              error=false event_type=describe message=OK monitor=serial-monitor
2023-07-28T22:53:38.248Z daemon INFO INFO[0220] sending command                               command="CONFIGURE stop_bits 1" monitor=serial-monitor
2023-07-28T22:53:38.249Z daemon INFO INFO[0220] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:38.249Z daemon INFO INFO[0220] sending command                               command="CONFIGURE baudrate 115200" monitor=serial-monitor
2023-07-28T22:53:38.251Z daemon INFO INFO[0220] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:38.252Z daemon INFO INFO[0220] sending command                               command="CONFIGURE bits 8" monitor=serial-monitor
2023-07-28T22:53:38.252Z daemon INFO INFO[0220] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:38.253Z daemon INFO INFO[0220] sending command                               command="CONFIGURE dtr off" monitor=serial-monitor
2023-07-28T22:53:38.254Z daemon INFO INFO[0220] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:38.255Z daemon INFO INFO[0220] sending command                               command="CONFIGURE parity none" monitor=serial-monitor
2023-07-28T22:53:38.255Z daemon INFO INFO[0220] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:38.256Z daemon INFO INFO[0220] sending command                               command="CONFIGURE rts off" monitor=serial-monitor
2023-07-28T22:53:38.262Z daemon INFO INFO[0220] received message                              error=false event_type=configure message=OK monitor=serial-monitor
2023-07-28T22:53:38.263Z daemon INFO INFO[0220] sending command                               command="OPEN 127.0.0.1:63525 COM9" monitor=serial-monitor
2023-07-28T22:53:38.271Z daemon INFO INFO[0220] received message                              error=false event_type=open message=OK monitor=serial-monitor
2023-07-28T22:53:38.274Z daemon INFO INFO[0220] Port COM9 successfully opened
2023-07-28T22:53:38.276Z monitor-service INFO Using port configuration for serial:COM9: {"settingsList":[{"settingId":"stop_bits","value":"1"},{"settingId":"baudrate","value":"115200"},{"settingId":"bits","value":"8"},{"settingId":"dtr","value":"off"},{"settingId":"parity","value":"none"},{"settingId":"rts","value":"off"}]}
2023-07-28T22:53:38.276Z monitor-service INFO started monitor to COM9 using serial
2023-07-28T22:53:39.120Z root ERROR Uncaught Exception:
2023-07-28T22:53:39.121Z root ERROR Error: EPERM: operation not permitted, open 'c:\Users\Steve\.arduinoIDE\pluggable-monitor-settings.json'
2023-07-28T22:53:39.775Z root ERROR Uncaught Exception:
2023-07-28T22:53:39.776Z root ERROR Error: EPERM: operation not permitted, open 'c:\Users\Steve\.arduinoIDE\pluggable-monitor-settings.json'
2023-07-28T22:54:10.316Z monitor-service INFO stopped monitor to COM9 using serial
No. It does take a bit more computing resources (CPU/RAM) to print the logs to PowerShell, but I only ever found that noticeable in extreme cases where I had a special configuration of the IDE that caused it to print tens of megabytes of output, which the terminal is not designed for (the log files generated by the IDE should instead be used when there is such a high quantity of logs).
So is this just a BUG with the v2.1.1 that can't be fixed? Would it be better to just have the BAUD dropdown always be shown?
