I gave the IDE version 2.1 a new chance for testing
still no success
The compiler does not finish
verify button stays yellow
compilation process hangs at see code-section for 10 minutes now
windows 10 taskmanager says processorload 0,5%
FQBN: esp32:esp32:esp32
Using board 'esp32' from platform in folder: C:\Users\dipl-\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7
Using core 'esp32' from platform in folder: C:\Users\dipl-\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7
cmd /c if exist "F:\\myData\\Arduino\\Sketchbook\\ESP32-Datalogger-Lu-022-OTA-Daily-FileName-4060\\partitions.csv" COPY /y "F:\\myData\\Arduino\\Sketchbook\\ESP32-Datalogger-Lu-022-OTA-Daily-FileName-4060\\partitions.csv" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\1CE3D3B241A60380DCD166925541CC7E\\partitions.csv"
cmd /c if not exist "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\1CE3D3B241A60380DCD166925541CC7E\\partitions.csv" if exist "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7\\variants\\esp32\\partitions.csv" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\1CE3D3B241A60380DCD166925541CC7E\\partitions.csv"
cmd /c if not exist "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\1CE3D3B241A60380DCD166925541CC7E\\partitions.csv" COPY "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7\\tools\\partitions\\default.csv" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\1CE3D3B241A60380DCD166925541CC7E\\partitions.csv"
cmd /c IF EXIST "F:\\myData\\Arduino\\Sketchbook\\ESP32-Datalogger-Lu-022-OTA-Daily-FileName-4060\\bootloader.bin" ( COPY /y "F:\\myData\\Arduino\\Sketchbook\\ESP32-Datalogger-Lu-022-OTA-Daily-FileName-4060\\bootloader.bin" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\1CE3D3B241A60380DCD166925541CC7E\\ESP32-Datalogger-Lu-022-OTA-Daily-FileName-4060.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7\\variants\\esp32\\bootloader.bin" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\1CE3D3B241A60380DCD166925541CC7E\\ESP32-Datalogger-Lu-022-OTA-Daily-FileName-4060.ino.bootloader.bin" ) ELSE ( "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino\\sketches\\1CE3D3B241A60380DCD166925541CC7E\\ESP32-Datalogger-Lu-022-OTA-Daily-FileName-4060.ino.bootloader.bin" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.7\\tools\\sdk\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.5.1
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
Multiple libraries were found for "ESPAsyncWebServer.h"
Used: F:\myData\Arduino\libraries\ESPAsyncWebServer
Not used: F:\myData\Arduino\libraries\ESPAsyncWebServer-master
Multiple libraries were found for "OneWire.h"
Used: F:\myData\Arduino\libraries\OneWire
Not used: F:\myData\Arduino\libraries\OneWireNg
Using library SafeString at version 4.1.25 in folder: F:\myData\Arduino\libraries\SafeString
Using library WiFi at version 2.0.0 in folder: C:\Users\dipl-\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7\libraries\WiFi
Using library AsyncTCP at version 1.1.4 in folder: F:\myData\Arduino\libraries\AsyncTCP
Using library ESP Async WebServer at version 1.2.3 in folder: F:\myData\Arduino\libraries\ESPAsyncWebServer
Using library FS at version 2.0.0 in folder: C:\Users\dipl-\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7\libraries\FS
Using library AsyncElegantOTA at version 2.2.7 in folder: F:\myData\Arduino\libraries\AsyncElegantOTA
Using library Update at version 2.0.0 in folder: C:\Users\dipl-\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7\libraries\Update
Using library ESP-DASH Pro at version 4.1.1 in folder: F:\myData\Arduino\libraries\ESP-DASH-Pro-4.1.1
Using library ArduinoJson at version 6.20.1 in folder: F:\myData\Arduino\libraries\ArduinoJson
Using library WebSerialPro at version 1.1.0 in folder: F:\myData\Arduino\libraries\WebSerialPro
Using library OneWire at version 2.3.7 in folder: F:\myData\Arduino\libraries\OneWire
Using library DallasTemperature at version 3.9.0 in folder: F:\myData\Arduino\libraries\DallasTemperature
```you
I recommend that the development team installs a function that makes it easy for users to reports
the OS, preferences and logfiles of the whole processes
