cp71
September 1, 2023, 7:55am
1
IDE 2.2.1: the Upload operation frozen in updating step if serial line is not connected.
The updating popup shows a progress bar, but I can't stop the operation.
The only way I found to exit from this situation is closing the IDE.
In this case I can edit the source code, I can verify the code but I can't select the upload operation, the upload button has orange background.
This will happen if you have while not serial loop in your code.
Remove it and replace it with a two second delay.
Exactly which serial line are you referring to ? Is it the USB connection to the PC or something else ?
What else is connected to the board and which Arduino are you using ?
cp71
September 1, 2023, 8:40am
4
Sorry,
Before of all, thank you very much for your help.
I think I don’t be fully clear, my fail, my English is really poor.
I don’t believe the issue is in my code, at least I hope
Ok I try to describe the situation
First case:
The computer is connect to Arduino Mega 2560
I select the Upload button
In this case, the upload always works well and finishes the operation
Second case:
The computer is not connect to Arduino Mega 2560
In this case, the Upload starts, it obviously it can’t finish the operation
The IDE shows the popup “Uploading….” and the upload button seems disabled ( orange background)
When I connect the Mega 2560 to my computer I can’t select Upload button
In this case, the only way I found is close the Arduino IDE 2.2.1 and restart it
It seems the IDE 2.2.1 has not a timeout for Upload operation.
If it is not clear, ask me further information, as I written, my English is poor
Thank to all very much
Thank you for the clarification and don't apologise for your English, it is vastly better than my Italian
cp71
September 1, 2023, 9:34am
7
Add information: I run the Arduino IDE on Linux with appimage
Sorry I know nothing about Linux.
