Often stuck on uploading (IDE 2.0.3)
I'm using the IDE v2.0.3 with a Raspberry Pi Pico W.
The program compiles correctly, it starts to upload the compiled program but most of the time the popup with "upload in progress..." (or something similar, I have the IDE in italian) stays forever and so the "upload" button is disabled.
So I have to close the IDE and start it again.
Sometime the popup (and the disabled button) stays forever even if the program is uploaded and is running.
Is there something that I could check?
Thank you, regards.
Roberto
Hi @rg70ita. In order to gather more information that might help us to troubleshoot your problem, I'm going to ask you to post the full output from the upload when in verbose mode.
:exclamation: NOTE: These instructions will not solve the problem. They are only intended to gather more information which might provide a clue that eventually leads to a solution.
Please do this:
  1. Select File > Preferences from the Arduino IDE menus.
  2. Uncheck the checkbox next to Show verbose output during: โ˜‘ compilation
  3. Check the checkbox next to Show verbose output during: โ˜ upload.
  4. Click the OK button.
  5. Attempt an upload, as you did before.
  6. Wait until you are sure the upload process has gone into the hang state
    (as indicated by no additional output being printed to the "Output" panel at the bottom of the Arduino IDE window).
  7. Right click on the black "Output" panel at the bottom of the Arduino IDE window.
  8. From the context menu, click Copy All.
  9. Open a forum reply here by clicking the Reply button.
  10. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  11. Press Ctrl+V.
    This will paste the compilation output into the code block.
  12. Move the cursor outside of the code tags before you add any additional text to your reply.
  13. Click the Reply button to post the output.
I tried three times and the third time it compiled but the upload failed:
In file included from e:\Sorgenti\ESP8266\libraries\TFT_eSPI/User_Setup_Select.h:92,
                 from e:\Sorgenti\ESP8266\libraries\TFT_eSPI/TFT_eSPI.h:68,
                 from E:\Sorgenti\RPi Pico\Pre Amp CPU IL9341\pre_amp_cpu\pre_amp_cpu.ino:14:
e:\Sorgenti\ESP8266\libraries\TFT_eSPI/User_Setups/Setup60_RP2040_ILI9341.h:128: warning: "TFT_CS" redefined
  128 | #define TFT_CS   20  // Chip select control pin
In file included from e:\Sorgenti\ESP8266\libraries\TFT_eSPI/User_Setup_Select.h:30,
e:\Sorgenti\ESP8266\libraries\TFT_eSPI/User_Setup.h:169: note: this is the location of the previous definition
  169 | #define TFT_CS   PIN_D8  // Chip select control pin D8
e:\Sorgenti\ESP8266\libraries\TFT_eSPI/User_Setups/Setup60_RP2040_ILI9341.h:129: warning: "TFT_DC" redefined
  129 | #define TFT_DC   18  // Data Command control pin
e:\Sorgenti\ESP8266\libraries\TFT_eSPI/User_Setup.h:170: note: this is the location of the previous definition
  170 | #define TFT_DC   PIN_D3  // Data Command control pin
e:\Sorgenti\ESP8266\libraries\TFT_eSPI/User_Setups/Setup60_RP2040_ILI9341.h:130: warning: "TFT_RST" redefined
  130 | #define TFT_RST  19  // Reset pin (could connect to Arduino RESET pin)
e:\Sorgenti\ESP8266\libraries\TFT_eSPI/User_Setup.h:171: note: this is the location of the previous definition
  171 | #define TFT_RST  PIN_D4  // Reset pin (could connect to NodeMCU RST, see next line)
e:\Sorgenti\ESP8266\libraries\TFT_eSPI/User_Setups/Setup60_RP2040_ILI9341.h:181: warning: "SPI_FREQUENCY" redefined
  181 | #define SPI_FREQUENCY  32000000
e:\Sorgenti\ESP8266\libraries\TFT_eSPI/User_Setup.h:357: note: this is the location of the previous definition
  357 | #define SPI_FREQUENCY  27000000
E:\Sorgenti\RPi Pico\Pre Amp CPU IL9341\pre_amp_cpu\pre_amp_cpu.ino: In function 'void ShowMenu()':
E:\Sorgenti\RPi Pico\Pre Amp CPU IL9341\pre_amp_cpu\pre_amp_cpu.ino:369:60: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
  369 |   tasti[0].initButton(&tft, CFG_X, CFG_Y, 64, 64, 0, 0, 0, "", 0); //tutti i parametri a 0 sono relativi a colore e dimensione del font
E:\Sorgenti\RPi Pico\Pre Amp CPU IL9341\pre_amp_cpu\pre_amp_cpu.ino:370:66: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
  370 |   tasti[1].initButton(&tft, SOURCE_X, SOURCE_Y, 64, 64, 0, 0, 0, "", 0);
E:\Sorgenti\RPi Pico\Pre Amp CPU IL9341\pre_amp_cpu\pre_amp_cpu.ino:371:66: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
  371 |   tasti[2].initButton(&tft, VOL_UP_X, VOL_UP_Y, 64, 64, 0, 0, 0, "", 0);
E:\Sorgenti\RPi Pico\Pre Amp CPU IL9341\pre_amp_cpu\pre_amp_cpu.ino:372:66: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
  372 |   tasti[3].initButton(&tft, VOL_DN_X, VOL_DN_Y, 64, 64, 0, 0, 0, "", 0);
Lo sketch usa 522860 byte (24%) dello spazio disponibile per i programmi. Il massimo รจ 2093056 byte.
Le variabili globali usano 70200 byte (26%) di memoria dinamica, lasciando altri 191944 byte liberi per le variabili locali. Il massimo รจ 262144 byte.
"C:\Users\bob\AppData\Local\Arduino15\packages\rp2040\tools\pqt-python3\1.0.1-base-3a57aed/python3" -I "C:\Users\r.guardamagna\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\2.6.2/tools/uf2conv.py" --serial "COM7" --family RP2040 --deploy "C:\Users\bob\AppData\Local\Temp\arduino-sketch-3944E36E00117C681E06B7CF41F777CF/pre_amp_cpu.ino.uf2"
Resetting COM7
Converting to uf2, output size: 1077760, start address: 0x2000
No drive to deploy.
Caricamento non riuscito: errore durante il caricamento: exit status 1
The 2nd time it uploaded but the "upload in progress" popup didn't closed, no errors where present.
I found that I get this error when uploading to my Raspberry Pi Pico under either of the following conditions:
Wrong port is selected
Make sure you have selected the port of your Arduino board from the Tools > Port menu in the Arduino IDE.
You can determine the port of the board by doing this:
  1. Unplug your Arduino board from the computer.
  2. Select Tools > Port from the Arduino IDE menus.
  3. Note the ports, if any, listed in the menu.
  4. Close the Tools menu.
    The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  5. Plug your Arduino board into the computer.
  6. Select Tools > Port from the Arduino IDE menus. - The new port listed in the menu is the one for your Arduino board.
Port is open in other application
Make sure COM7 isn't open in some other application while you are trying to upload in Arduino IDE.
In rare cases a glitch can cause the port to get stuck in an unusable state. Restarting the computer fixes this.
I also found a couple of posts about this upload error that indicated other possible causes (it seems it is quite a generic error that can be caused by many different things) and also provided some useful solutions:
Even though those are about the Pico instead of Pico W, there is no significant difference between the two boards as far as uploads are concerned, so any general information you find about uploading to the Pico should also apply to your Pico W.
This is a more perplexing problem, and I don't think the things I mentioned above can help with it.
There is a known bug in Arduino IDE that can cause the IDE to be stuck in the uploading state even after the upload process was apparently finished:
However, I think all the reports of that (including my own limited experience with the bug) have been while doing uploads over the network port, not a standard upload like you are doing.
Would you mind providing the verbose output from the upload when the "upload in progress" popup didn't close. It is possible there will be some useful information in that output.
Thanks for the reply.
As for the "2nd time" in the output window the only difference from the "error time" output is that line "no drive to deploy".
in the running code there are some lines with "Serial.println" while the Pico tries to connect to the WiFi using the 2nd Core of the CPU.
I mean...in the Core 0 there are some lines, in the Core1 there is only the connection to the WiFi.
Often it doesn't connect to the WiFi so in the "loop1" cycle it tries to connect "forever" until the connection is successful.
Every try is sent to "Serial.println"...could this conflicts with the upload process?
It should not. The conflict would be if you had some other application (e.g., an external terminal program such as RealTerm or a Python program that communicates with the board over the serial port) connected to the port.
Although it is more common that you are intentionally running and connecting such a program to the port, there have been cases where poorly designed background applications would open serial ports without any action from the user and break the ability to upload via Arduino IDE. There was some sort of a Bluetooth driver for Windows that was a frequent source of these problems years ago, but we don't see that specific one anymore. But you can see in HELP! keep getting "Error opening serial port 'com3'.(port busy)" - #3 by drmpf and HELP! keep getting "Error opening serial port 'com3'.(port busy)" - #4 by spuds the cause of the upload failure was tracked down to applications that were somehow unexpectedly opening the port.
But as I said, this is only one possible cause. It might be this "No drive to deploy" error has a completely different cause, so I wouldn't get too focused on this specific potential cause if you don't know of any applications that might be using the port. When uploading to other boards, I would expect to see a more specific message something like "Access denied" or "Port busy" and I see that in the output shared in HELP! keep getting "Error opening serial port 'com3'.(port busy)", but I don't get any helpful error like that in the experiments I run uploading to my Pico using the Earle Philhower RP2040 boards platform as I see you are using so I guess that error message was specific to the upload tool used by an older versions of the platform?
I tried to disable completely the code of the "setup1/loop1" and to leave WiFi disconnected.
Compiled and uploaded 10/10 times without errors.
It's worth investigating it...
I am experiencing the same problem using a RPi Pico H. Compiles OK, after upload the IDE (v2.0.3) hangs most of the time in "uploading..."
Hi @anon61476959. In order to gather more information that might help us to troubleshoot your problem, I'm going to ask you to post the full output from the upload when in verbose mode.
Please do this:
  6. Wait for the upload to hang (likely indicated by some time passing without any new text printed to the black "Output" panel at the bottom of the Arduino IDE window).
    Code block
  11. Press Ctrl+V.
Note: username in path names replaced by ''.
Reply in 2 parts because length exceeded maximum.
Using board 'rpipico' from platform in folder: C:\Users\<User>\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\2.6.5
Using core 'rp2040' from platform in folder: C:\Users\<User>\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\2.6.5
Detecting libraries used...
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\sketch\\flash_info.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\sketch\\flash_info.ino.cpp" -o nul
Alternatives for SdFat.h: [SdFat - Adafruit Fork@2.2.1 SdFat - Adafruit Fork@1.5.1 ESP8266SdFat@2.1.1]
ResolveLibrary(SdFat.h)
  -> candidates: [SdFat - Adafruit Fork@2.2.1 SdFat - Adafruit Fork@1.5.1 ESP8266SdFat@2.1.1]
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\sketch\\flash_info.ino.cpp" -o nul
Alternatives for Adafruit_SPIFlash.h: [Adafruit SPIFlash@4.0.0]
ResolveLibrary(Adafruit_SPIFlash.h)
  -> candidates: [Adafruit SPIFlash@4.0.0]
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\sketch\\flash_info.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\<User>\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\2.6.5\libraries\SPI\src\SPI.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\ExFatLib\ExFatDbg.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\ExFatLib\ExFatFile.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\ExFatLib\ExFatFilePrint.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\ExFatLib\ExFatFileWrite.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\ExFatLib\ExFatFormatter.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\ExFatLib\ExFatName.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\ExFatLib\ExFatPartition.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\ExFatLib\ExFatVolume.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\FatLib\FatDbg.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\FatLib\FatFile.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\FatLib\FatFileLFN.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\FatLib\FatFilePrint.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\FatLib\FatFileSFN.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\FatLib\FatFormatter.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\FatLib\FatName.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\FatLib\FatPartition.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\FatLib\FatVolume.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\FreeStack.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\FsLib\FsFile.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\FsLib\FsNew.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\FsLib\FsVolume.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\MinimumSerial.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\SdCard\SdCardInfo.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\SdCard\SdSpiCard.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\SdCard\SdioTeensy.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\SpiDriver\SdSpiArtemis.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\SpiDriver\SdSpiChipSelect.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\SpiDriver\SdSpiDue.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\SpiDriver\SdSpiESP.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\SpiDriver\SdSpiParticle.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\SpiDriver\SdSpiSTM32.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\SpiDriver\SdSpiSTM32Core.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\SpiDriver\SdSpiTeensy3.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\common\FmtNumber.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\common\FsCache.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\common\FsDateTime.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\common\FsName.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\common\FsStructs.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\common\FsUtf.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\common\PrintBasic.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\common\upcase.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\iostream\StdioStream.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\iostream\StreamBaseClass.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\iostream\istream.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\SdFat-master\src\iostream\ostream.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\Adafruit_SPIFlash-master\src\Adafruit_FlashCache.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\Adafruit_SPIFlash-master\src\Adafruit_SPIFlash.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\Adafruit_SPIFlash-master\src\Adafruit_SPIFlashBase.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\Adafruit_SPIFlash-master\src\esp32\Adafruit_FlashTransport_ESP32.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\Adafruit_SPIFlash-master\src\qspi\Adafruit_FlashTransport_QSPI_NRF.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\Adafruit_SPIFlash-master\src\qspi\Adafruit_FlashTransport_QSPI_SAMD.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\Adafruit_SPIFlash-master\src\rp2040\Adafruit_FlashTransport_RP2040.cpp
Using cached library dependencies for file: c:\Users\<User>\Documenten\Arduino\libraries\Adafruit_SPIFlash-master\src\spi\Adafruit_FlashTransport_SPI.cpp
Generating function prototypes...
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\sketch\\flash_info.ino.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-python3\\1.0.1-base-3a57aed/python3" -I "C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/tools/signing.py" --mode header --publickey "I:\\pico\\adafruit\\Adafruit_SPIFlash-master\\examples\\flash_info/public.key" --out "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core/Updater_Signing.h"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\sketch\\flash_info.ino.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\sketch\\flash_info.ino.cpp.o"
Compiling libraries...
Compiling library "SPI"
Using previously compiled file: C:\Users\<User>\AppData\Local\Temp\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\libraries\SPI\SPI.cpp.o
Using previously compiled file: C:\Users\<User>\AppData\Local\Temp\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\libraries\SPI\SPI.a
Compiling library "SdFat - Adafruit Fork"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\FreeStack.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FreeStack.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\MinimumSerial.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\MinimumSerial.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\SdCard\\SdSpiCard.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SdCard\\SdSpiCard.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\ExFatLib\\ExFatDbg.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatDbg.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\FatLib\\FatFileSFN.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatFileSFN.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\SdCard\\SdCardInfo.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SdCard\\SdCardInfo.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\FsLib\\FsFile.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FsLib\\FsFile.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\FsLib\\FsNew.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FsLib\\FsNew.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\FsLib\\FsVolume.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FsLib\\FsVolume.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\ExFatLib\\ExFatFilePrint.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatFilePrint.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\ExFatLib\\ExFatName.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatName.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\ExFatLib\\ExFatPartition.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatPartition.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\FatLib\\FatName.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatName.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\ExFatLib\\ExFatFile.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatFile.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\ExFatLib\\ExFatFormatter.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatFormatter.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\ExFatLib\\ExFatFileWrite.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatFileWrite.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\FatLib\\FatPartition.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatPartition.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\ExFatLib\\ExFatVolume.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatVolume.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\FatLib\\FatFileLFN.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatFileLFN.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\FatLib\\FatFilePrint.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatFilePrint.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\FatLib\\FatFormatter.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatFormatter.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\FatLib\\FatVolume.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatVolume.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\FatLib\\FatFile.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatFile.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\FatLib\\FatDbg.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatDbg.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\SdCard\\SdioTeensy.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SdCard\\SdioTeensy.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\SpiDriver\\SdSpiArtemis.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiArtemis.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\SpiDriver\\SdSpiChipSelect.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiChipSelect.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\SpiDriver\\SdSpiDue.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiDue.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\SpiDriver\\SdSpiESP.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiESP.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\SpiDriver\\SdSpiParticle.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiParticle.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\SpiDriver\\SdSpiSTM32.cpp" -o
"C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiSTM32.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\SpiDriver\\SdSpiSTM32Core.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiSTM32Core.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\common\\FmtNumber.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\FmtNumber.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\SpiDriver\\SdSpiTeensy3.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiTeensy3.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\common\\FsCache.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\FsCache.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\common\\FsUtf.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\FsUtf.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\common\\FsStructs.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\FsStructs.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\common\\FsDateTime.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\FsDateTime.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\common\\FsName.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\FsName.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\common\\PrintBasic.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\PrintBasic.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\common\\upcase.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\upcase.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\iostream\\StreamBaseClass.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\iostream\\StreamBaseClass.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\iostream\\ostream.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\iostream\\ostream.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\iostream\\istream.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\iostream\\istream.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src\\iostream\\StdioStream.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\iostream\\StdioStream.cpp.o"
Compiling library "Adafruit SPIFlash"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src\\Adafruit_SPIFlashBase.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\Adafruit_SPIFlashBase.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src\\Adafruit_SPIFlash.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\Adafruit_SPIFlash.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src\\Adafruit_FlashCache.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\Adafruit_FlashCache.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src\\spi\\Adafruit_FlashTransport_SPI.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\spi\\Adafruit_FlashTransport_SPI.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src\\qspi\\Adafruit_FlashTransport_QSPI_NRF.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\qspi\\Adafruit_FlashTransport_QSPI_NRF.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src\\esp32\\Adafruit_FlashTransport_ESP32.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\esp32\\Adafruit_FlashTransport_ESP32.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src\\rp2040\\Adafruit_FlashTransport_RP2040.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\rp2040\\Adafruit_FlashTransport_RP2040.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" -I "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/core" -c -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/" "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_inc.txt" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/include" -fno-rtti -std=gnu++17 -g -pipe -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\cores\\rp2040" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\variants\\rpipico" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5\\libraries\\SPI\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\SdFat-master\\src" "-Ic:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src" "c:\\Users\\<User>\\Documenten\\Arduino\\libraries\\Adafruit_SPIFlash-master\\src\\qspi\\Adafruit_FlashTransport_QSPI_SAMD.cpp" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\qspi\\Adafruit_FlashTransport_QSPI_SAMD.cpp.o"
Compiling core...
Using precompiled core: C:\Users\<User>\AppData\Local\Temp\arduino-core-cache\core_0d030c07f38f5a655fe3cc87b20d0838.a
Linking everything together...
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-python3\\1.0.1-base-3a57aed/python3" -I "C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/tools/simplesub.py" --input "C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/memmap_default.ld" --out "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/memmap_default.ld" --sub __FLASH_LENGTH__ 2093056 --sub __EEPROM_START__ 270528512 --sub __FS_START__ 270528512 --sub __FS_END__ 270528512 --sub __RAM_LENGTH__ 256k
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-gcc" -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -Os -u _printf_float -u _scanf_float -c "C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/boot2/boot2_w25q080_2_padded_checksum.S" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/pico-sdk/src/rp2040/hardware_regs/include/" "-IC:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/pico-sdk/src/common/pico_binary_info/include" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/boot2.o"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-g++" "-LC:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB" -Werror=return-type -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=0 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -Os -u _printf_float -u _scanf_float "@C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/platform_wrap.txt" -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common "-Wl,--script=C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/memmap_default.ld" "-Wl,-Map,C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/flash_info.ino.map" -o "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/flash_info.ino.elf" -Wl,--start-group "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\sketch\\flash_info.ino.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SPI\\SPI.a" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatDbg.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatFile.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatFilePrint.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatFileWrite.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatFormatter.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatName.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatPartition.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\ExFatLib\\ExFatVolume.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatDbg.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatFile.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatFileLFN.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatFilePrint.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatFileSFN.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatFormatter.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatName.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatPartition.cpp.o"
"C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FatLib\\FatVolume.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FreeStack.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FsLib\\FsFile.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FsLib\\FsNew.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\FsLib\\FsVolume.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\MinimumSerial.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SdCard\\SdCardInfo.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SdCard\\SdSpiCard.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SdCard\\SdioTeensy.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiArtemis.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiChipSelect.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiDue.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiESP.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiParticle.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiSTM32.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiSTM32Core.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\SpiDriver\\SdSpiTeensy3.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\FmtNumber.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\FsCache.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\FsDateTime.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\FsName.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\FsStructs.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\FsUtf.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\PrintBasic.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\common\\upcase.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\iostream\\StdioStream.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\iostream\\StreamBaseClass.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\iostream\\istream.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\SdFat-master\\iostream\\ostream.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\Adafruit_FlashCache.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\Adafruit_SPIFlash.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\Adafruit_SPIFlashBase.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\esp32\\Adafruit_FlashTransport_ESP32.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\qspi\\Adafruit_FlashTransport_QSPI_NRF.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\qspi\\Adafruit_FlashTransport_QSPI_SAMD.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\rp2040\\Adafruit_FlashTransport_RP2040.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB\\libraries\\Adafruit_SPIFlash-master\\spi\\Adafruit_FlashTransport_SPI.cpp.o" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/..\\arduino-core-cache\\core_0d030c07f38f5a655fe3cc87b20d0838.a" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/boot2.o" "C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/ota.o" "C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/libpico.a" "C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/lib/libbearssl.a" -lm -lc -lstdc++ -lc -Wl,--end-group
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin//arm-none-eabi-objcopy" -Obinary "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/flash_info.ino.elf" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/flash_info.ino.bin"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-python3\\1.0.1-base-3a57aed/python3" -I "C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\2.6.5/tools/signing.py" --mode sign --privatekey "I:\\pico\\adafruit\\Adafruit_SPIFlash-master\\examples\\flash_info/private.key" --bin "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/flash_info.ino.bin" --out "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/flash_info.ino.bin.signed"
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-elf2uf2\\1.4.0-c-0196c06/elf2uf2" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/flash_info.ino.elf" "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/flash_info.ino.uf2"
Multiple libraries were found for "SdFat.h"
  Used: C:\Users\<User>\Documenten\Arduino\libraries\SdFat-master
  Not used: C:\Users\<User>\Documenten\Arduino\libraries\SdFat_-_Adafruit_Fork
  Not used: C:\Users\<User>\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\2.6.5\libraries\ESP8266SdFat
Using library SPI at version 1.0 in folder: C:\Users\<User>\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\2.6.5\libraries\SPI
Using library SdFat - Adafruit Fork at version 2.2.1 in folder: C:\Users\<User>\Documenten\Arduino\libraries\SdFat-master
Using library Adafruit SPIFlash at version 4.0.0 in folder: C:\Users\<User>\Documenten\Arduino\libraries\Adafruit_SPIFlash-master
"C:\\Users\\<User>\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\1.4.0-c-0196c06/bin/arm-none-eabi-size" -A "C:\\Users\\<User>\\AppData\\Local\\Temp\\arduino-sketch-48A5CFEF72E11ED432901CE2648051FB/flash_info.ino.elf"
Sketch uses 56596 bytes (2%) of program storage space. Maximum is 2093056 bytes.
Global variables use 8088 bytes (3%) of dynamic memory, leaving 254056 bytes for local variables. Maximum is 262144 bytes.
Converting to uf2, output size: 144384, start address: 0x2000
Flashing D: (RPI-RP2)
Wrote 144384 bytes to D:/NEW.UF2
This output looks like a successful upload. Did the upload process hang during the run that produced this output?
Yes, the build and the upload were successful, however, the IDE hang in a sense that it was continuously showing the text "Uploading..." and the 'action indicator' (the horizontal green piece of bar moving from left to right in that window) while the RPi Pico had obviously been reset. The IDE, in the menu Tools > Port was showing the COM19 port of the Pico instead of "UF2 board". In that moment the Upload button had color orange. To get out of this situation I had to exit the IDE and start it up again.
I seem to have the same issue with 2.0.3. The first upload after restart of the IDE works in the sense that the code gets uploaded to the Pico, but the IDE does not seem to recognize that the upload is finished and so the "progress animation" just keeps on scrolling around forever:
Here is the output of the verbose upload log:
Sketch uses 56180 bytes (2%) of program storage space. Maximum is 2093056 bytes.
Global variables use 7548 bytes (2%) of dynamic memory, leaving 254596 bytes for local variables. Maximum is 262144 bytes.
"C:\Users\Per\AppData\Local\Arduino15\packages\rp2040\tools\pqt-python3\1.0.1-base-3a57aed/python3" -I "C:\Users\Per\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\2.6.5/tools/uf2conv.py" --serial "UF2_Board" --family RP2040 --deploy "C:\Users\Per\AppData\Local\Temp\arduino-sketch-C3A1E98DCB6061CC6BF6CD9084F2FFAC/144m_Si5351.ino.uf2"
Converting to uf2, output size: 142848, start address: 0x2000
Flashing G: (RPI-RP2)
Wrote 142848 bytes to G:/NEW.UF2
I think it says that all is fine, but as I mentioned, the "progress animation" just keeps saying that "Uploading..." is still in progress and I am therefore unable to upload again until I restart the IDE. Other functions, like verifying code, still works in this state. The port changed from UF2 to COM8 during the upload. Unplugging the Pico does not have any effect on the persistent progress bar.
Similiar issues with pico W but may not be pico W specific.
Doing some basic testing of getting Dallas OneWire code work for temp sensor. Blink works no problem. Download basic code for Dallas OneWire that works on old school Arduino and get the uploading message stuck on the IDE. I think it is most likely a race condition in that the IDE is doing the upload via the mounted drive and suspect that the Serial.begin(9600) in the setup code triggers a com port registration. If something in the code is problematic then the establishing of the com port has an issue.
I commented out code related to reading the OneWire pin and the normal/expected behavior of downloading code, having it run and loading message go away returns. More importantly can change code and redownload. When the IDE gets hung up in the Loading message that doesn't go away need to exit IDE and restart with boot sel button on pico W.
For the pico W seem to recall the blink code is problematic in that pico W used that pin for the wifi module but gave it back via some other process. If you try using the RP2040 arudino board definition doesn't work. Use the RP2040 pico W board definition from earlephilhower then works.
The point is given the dynamic nature of RP2040 setting up pins to have a specific function may be creating some hardware issues that causes the board to not respond as expected.
It would be nice if the IDE didn't require a restart to recover from code on the board not working as expected.
There is now an additional formal bug report about the IDE remaining stuck in the uploading state after completion of a normal (as opposed to network port upload) upload process:
Same problem here. (Pico W)
I think it's a UI problem only.
It's well known, that pico can cause problem, as it just disappears from the system when the file uploading has finished.
I'm just guessing, but I think at the end of the upload, the process try to close the connection to the filesystem, that is not presented (pico are already rebooting), what cause an exception with the UI process... Everything is fine, but the popup not closed, and the button can not be pressed again.
My config: UF2 board selected for at tools/port and Default uf2 selected at Tools/Upload method.
Let me know if I can provide any more information!
type or paste Sketch uses 310700 bytes (14%) of program storage space. Maximum is 2093056 bytes.
Global variables use 68248 bytes (26%) of dynamic memory, leaving 193896 bytes for local variables. Maximum is 262144 bytes.
"/home/dingo/.arduino15/packages/rp2040/tools/pqt-python3/1.0.1-base-3a57aed/python3" -I "/home/dingo/.arduino15/packages/rp2040/hardware/rp2040/2.7.1/tools/uf2conv.py" --serial "UF2_Board" --family RP2040 --deploy "/tmp/arduino-sketch-C9BFFAF69C92682BEFC3495DCB33D367/basic_test_tmp117_nhs.ino.uf2"
Converting to uf2, output size: 652288, start address: 0x2000
Flashing /media/dingo/RPI-RP2 (RPI-RP2)
Wrote 652288 bytes to /media/dingo/RPI-RP2/NEW.UF2
code here
Same probleme for me. I just purchased an arduino Nano and it just says "Uploading..." and then after quite a while it says
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x59
Hi @spllit1. I think you are having a different problem. In order to gather more information that might help us to troubleshoot your problem, I'm going to ask you to post the full output from the upload when in verbose mode.
:exclamation: NOTE: These instructions will not solve the problem. They are only intended to gather more information which might provide a clue that eventually leads to a solution.
Please do this:
  1. Select File > Preferences from the Arduino IDE menus.
  2. Uncheck the checkbox next to Show verbose output during: โ˜‘ compilation
  3. Check the checkbox next to Show verbose output during: โ˜ upload.
  4. Click the OK button.
  5. Attempt an upload, as you did before.
  6. Wait for the upload to fail.
  7. You will see a "Upload error: ..." notification at the bottom right corner of the Arduino IDE window. Click the COPY ERROR MESSAGES button on that notification.
  8. Open a forum reply here by clicking the Reply button.
  9. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  10. Press Ctrl+V.
    This will paste the error output from the upload into the code block.
  11. Move the cursor outside of the code tags before you add any additional text to your reply.
  12. Click the Reply button to post the output.
