IDE Arduino non parte
salve ho un problema. Uso linux mint e fino a ieri non avevo problemi. oggi faccio per far partire l'ide di arduino e non so cosa ho combinato ma parte l'icona di avvio del programma ma il programma non parte. avviando da terminale ricevo questi errori che non riesco a risolvere:
OpenJDK Server VM warning: You have loaded library /usr/lib/jvm/java-7-openjdk-i386/jre/lib/i386/librxtxSerial.so which might have disabled stack guard. The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with 'execstack -c ', or link it with '-z noexecstack'.
java.lang.UnsatisfiedLinkError: /usr/lib/jvm/java-7-openjdk-i386/jre/lib/i386/librxtxSerial.so: /usr/lib/jvm/java-7-openjdk-i386/jre/lib/i386/librxtxSerial.so: classe ELF errata: ELFCLASS64 (Possible cause: architecture word width mismatch) thrown while loading gnu.io.RXTXCommDriver
Exception in thread "main" java.lang.UnsatisfiedLinkError: /usr/lib/jvm/java-7-openjdk-i386/jre/lib/i386/librxtxSerial.so: /usr/lib/jvm/java-7-openjdk-i386/jre/lib/i386/librxtxSerial.so: classe ELF errata: ELFCLASS64 (Possible cause: architecture word width mismatch)
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary1(ClassLoader.java:1965)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1890)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1872)
at java.lang.Runtime.loadLibrary0(Runtime.java:849)
at java.lang.System.loadLibrary(System.java:1088)
at gnu.io.CommPortIdentifier.(CommPortIdentifier.java:123)
at processing.app.Editor.populateSerialMenu(Editor.java:962)
at processing.app.Editor.buildToolsMenu(Editor.java:691)
at processing.app.Editor.buildMenuBar(Editor.java:476)
at processing.app.Editor.(Editor.java:205)
at processing.app.Base.handleOpen(Base.java:705)
at processing.app.Base.handleOpen(Base.java:670)
at processing.app.Base.handleNew(Base.java:566)
at processing.app.Base.(Base.java:306)
at processing.app.Base.main(Base.java:195)
Essendo il tuo primo post Ti invitiamo a presentarti QUI (dicci quali conoscenze hai di elettronica e di programmazione) e a leggere il regolamento QUI se non lo hai già fatto.
Comunque benvenuto sul forum.
Attilio
Secondo me stai usando la libserial a 32bit invece della 64 bit
secondo me la cosa più veloce è disinstallare e reinstallare l'IDE a 64 bit per Linux.
Ciao grazie per la risposta. Ma il problema che poi oggi verifico è che il sistema che uso è a 32
