PS C:\Users\loloa\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.3
Checking for frontend application configuration customizations. Module path: C:\Users\loloa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\loloa\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:41:18.242Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:41:18.242Z"}
Starting backend process. PID: 26560
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/loloa/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-11-02T17:10:36.135Z root INFO Backend Object.initialize: 3.3 ms [Finished 0.446 s after backend start]
2024-11-02T17:10:36.136Z root INFO Backend Object.configure: 2.7 ms [Finished 0.446 s after backend start]
2024-11-02T17:10:36.136Z root INFO Backend a.onStart: 1.4 ms [Finished 0.446 s after backend start]
2024-11-02T17:10:36.136Z root INFO Backend a.configure: 0.3 ms [Finished 0.466 s after backend start]
2024-11-02T17:10:36.137Z root INFO Backend d.onStart: 0.2 ms [Finished 0.467 s after backend start]
2024-11-02T17:10:36.137Z root INFO Backend d.configure: 0.1 ms [Finished 0.467 s after backend start]
2024-11-02T17:10:36.138Z root INFO Backend d.initialize: 20.5 ms [Finished 0.467 s after backend start]
2024-11-02T17:10:36.138Z root INFO Backend c.onStart: 0.2 ms [Finished 0.467 s after backend start]
2024-11-02T17:10:36.139Z root INFO Backend s.configure: 1.1 ms [Finished 0.468 s after backend start]
2024-11-02T17:10:36.140Z config INFO >>> Initializing CLI configuration...
2024-11-02T17:10:36.140Z root INFO Backend c.initialize: 0.5 ms [Finished 0.468 s after backend start]
2024-11-02T17:10:36.140Z root INFO Backend x.onStart: 0.8 ms [Finished 0.469 s after backend start]
2024-11-02T17:10:36.141Z config INFO Loading CLI configuration from c:\Users\loloa\.arduinoIDE\arduino-cli.yaml...
2024-11-02T17:10:36.141Z daemon INFO Starting daemon from C:\Users\loloa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-11-02T17:10:36.141Z root INFO Backend s.initialize: 0.3 ms [Finished 0.470 s after backend start]
2024-11-02T17:10:36.141Z root INFO Backend w.onStart: 1.0 ms [Finished 0.470 s after backend start]
2024-11-02T17:10:36.141Z root INFO Backend r.configure: 1.6 ms [Finished 0.470 s after backend start]
2024-11-02T17:10:36.141Z discovery-log INFO start
2024-11-02T17:10:36.141Z discovery-log INFO start new deferred
2024-11-02T17:10:36.141Z root INFO Backend d.initialize: 0.4 ms [Finished 0.471 s after backend start]
2024-11-02T17:10:36.141Z root INFO Backend y.onStart: 1.8 ms [Finished 0.472 s after backend start]
2024-11-02T17:10:36.141Z root INFO Backend r.configure: 1.4 ms [Finished 0.472 s after backend start]
2024-11-02T17:10:36.141Z root INFO Backend s.onStart: 0.3 ms [Finished 0.473 s after backend start]
2024-11-02T17:10:36.141Z root INFO Backend h.configure: 0.3 ms [Finished 0.473 s after backend start]
2024-11-02T17:10:36.141Z root INFO Backend a.configure: 0.1 ms [Finished 0.473 s after backend start]
2024-11-02T17:10:36.141Z root INFO Backend l.configure: 0.0 ms [Finished 0.473 s after backend start]
2024-11-02T17:10:36.144Z root INFO Theia app listening on http://127.0.0.1:52813.
2024-11-02T17:10:36.144Z root INFO Finished starting backend application: 2.5 ms [Finished 0.476 s after backend start]
Restoring workspace roots: c:\Users\loloa\OneDrive\Bureau\Projet Piston Arduino\Piston_Minecraft\Piston_Minecraft.ino
2024-11-02T17:10:36.160Z root WARN The local plugin referenced by local-dir:/c%3A/Users/loloa/.arduinoIDE/plugins does not exist.
2024-11-02T17:10:36.160Z root WARN The local plugin referenced by local-dir:/c%3A/Users/loloa/.arduinoIDE/extensions does not exist.
2024-11-02T17:10:36.160Z root WARN The local plugin referenced by local-dir:C:\Users\loloa\.arduinoIDE\plugins does not exist.
isTempSketch: false. Input was c:\Users\loloa\OneDrive\Bureau\Projet Piston Arduino\Piston_Minecraft\Piston_Minecraft.ino
2024-11-02T17:10:36.162Z root ERROR Uncaught Exception: Error: EPERM: operation not permitted, mkdir 'C:\Users\loloa\.arduinoIDE'
2024-11-02T17:10:36.162Z root ERROR Error: EPERM: operation not permitted, mkdir 'C:\Users\loloa\.arduinoIDE'
2024-11-02T17:10:36.181Z root INFO Resolve plugins list: 40.1 ms [Finished 0.513 s after backend start]
2024-11-02T17:10:36.252Z daemon INFO time="2024-11-02T13:10:36-04:00" level=info msg="arduino-cli version 1.0.4"
time="2024-11-02T13:10:36-04:00" level=info msg="Using config file: c:\\Users\\loloa\\.arduinoIDE\\arduino-cli.yaml"
time="2024-11-02T13:10:36-04:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:52814
{"IP":"127.0.0.1","Port":"52814"}
2024-11-02T17:10:36.252Z daemon INFO Daemon is running.
2024-11-02T17:10:36.253Z root INFO Error: Error executing C:\Users\loloa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe config init --dest-dir c:\Users\loloa\.arduinoIDE: Cannot create config file directory: mkdir c:\Users\loloa\.arduinoIDE: Access is denied.
at ChildProcess.<anonymous> (C:\Users\loloa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:788280)
at ChildProcess.emit (node:events:514:28)
at Process.onexit (node:internal/child_process:291:12)
2024-11-02T17:10:36.253Z config ERROR Failed to initialize the CLI configuration. Error: Error executing C:\Users\loloa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe config init --dest-dir c:\Users\loloa\.arduinoIDE: Cannot create config file directory: mkdir c:\Users\loloa\.arduinoIDE: Access is denied.
2024-11-02T17:10:36.309Z daemon INFO time="2024-11-02T13:10:36-04:00" level=info msg="Checking signature" index="C:\\Users\\loloa\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\loloa\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2024-11-02T13:10:36-04:00" level=info msg="Loading hardware from: C:\\Users\\loloa\\AppData\\Local\\Arduino15\\packages"
time="2024-11-02T13:10:36-04:00" level=info msg="Loading package builtin from: C:\\Users\\loloa\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-11-02T13:10:36-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\loloa\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-11-02T13:10:36-04:00" level=info msg="Loading tools from dir: C:\\Users\\loloa\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-11-02T13:10:36-04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-11-02T13:10:36-04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-11-02T13:10:36-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-11-02T13:10:36-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2024-11-02T13:10:36-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-11-02T13:10:36-04:00" level=info msg="Loading libraries index file" index="C:\\Users\\loloa\\AppData\\Local\\Arduino15\\library_index.json"
2024-11-02T17:10:36.808Z daemon INFO time="2024-11-02T13:10:36-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\loloa\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2024-11-02T13:10:36-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\loloa\\OneDrive\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-11-02T17:10:37.604Z root ERROR Failed to initialize global state path: Error: EPERM: operation not permitted, mkdir 'c:\Users\loloa\.arduinoIDE'
2024-11-02T17:10:37.653Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 115.7 ms [Finished 1.435 s after frontend start]
2024-11-02T17:10:37.653Z root WARN A command editor.action.toggleStickyScroll is already registered.
[34392:1102/131037.728:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+é"
I've browsed the other topics with this issue but none of the solutions seems to be working for me. I did the Powershell method and here's the code it send back:
Arduino IDE 2.3.3
Starting backend process. PID: 3348
2024-11-02T17:35:56.880Z root INFO Backend Object.initialize: 3.1 ms [Finished 0.551 s after backend start]
2024-11-02T17:35:56.881Z root INFO Backend Object.configure: 2.4 ms [Finished 0.551 s after backend start]
2024-11-02T17:35:56.881Z root INFO Backend a.onStart: 1.2 ms [Finished 0.552 s after backend start]
2024-11-02T17:35:56.881Z root INFO Backend a.configure: 0.3 ms [Finished 0.571 s after backend start]
2024-11-02T17:35:56.882Z root INFO Backend d.onStart: 0.2 ms [Finished 0.571 s after backend start]
2024-11-02T17:35:56.882Z root INFO Backend d.configure: 0.1 ms [Finished 0.571 s after backend start]
2024-11-02T17:35:56.883Z root INFO Backend d.initialize: 19.6 ms [Finished 0.571 s after backend start]
2024-11-02T17:35:56.883Z root INFO Backend c.onStart: 0.2 ms [Finished 0.571 s after backend start]
2024-11-02T17:35:56.883Z root INFO Backend s.configure: 1.0 ms [Finished 0.572 s after backend start]
2024-11-02T17:35:56.884Z config INFO >>> Initializing CLI configuration...
2024-11-02T17:35:56.884Z root INFO Backend c.initialize: 0.4 ms [Finished 0.573 s after backend start]
2024-11-02T17:35:56.884Z root INFO Backend x.onStart: 0.5 ms [Finished 0.573 s after backend start]
2024-11-02T17:35:56.885Z config INFO Loading CLI configuration from c:\Users\loloa\.arduinoIDE\arduino-cli.yaml...
2024-11-02T17:35:56.885Z daemon INFO Starting daemon from C:\Users\loloa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-11-02T17:35:56.885Z root INFO Backend s.initialize: 0.3 ms [Finished 0.574 s after backend start]
2024-11-02T17:35:56.885Z root INFO Backend w.onStart: 0.8 ms [Finished 0.574 s after backend start]
2024-11-02T17:35:56.885Z root INFO Backend r.configure: 1.2 ms [Finished 0.574 s after backend start]
2024-11-02T17:35:56.885Z discovery-log INFO start
2024-11-02T17:35:56.885Z discovery-log INFO start new deferred
2024-11-02T17:35:56.885Z root INFO Backend d.initialize: 0.3 ms [Finished 0.575 s after backend start]
2024-11-02T17:35:56.885Z root INFO Backend y.onStart: 1.4 ms [Finished 0.576 s after backend start]
2024-11-02T17:35:56.885Z root INFO Backend r.configure: 1.2 ms [Finished 0.576 s after backend start]
2024-11-02T17:35:56.885Z root INFO Backend s.onStart: 0.3 ms [Finished 0.577 s after backend start]
2024-11-02T17:35:56.885Z root INFO Backend h.configure: 0.3 ms [Finished 0.577 s after backend start]
2024-11-02T17:35:56.885Z root INFO Backend a.configure: 0.1 ms [Finished 0.577 s after backend start]
2024-11-02T17:35:56.885Z root INFO Backend l.configure: 0.0 ms [Finished 0.577 s after backend start]
2024-11-02T17:35:56.887Z root INFO Theia app listening on http://127.0.0.1:51357.
2024-11-02T17:35:56.887Z root INFO Finished starting backend application: 2.0 ms [Finished 0.579 s after backend start]
2024-11-02T17:35:56.950Z root WARN The local plugin referenced by local-dir:/c%3A/Users/loloa/.arduinoIDE/plugins does not exist.
2024-11-02T17:35:56.950Z root WARN The local plugin referenced by local-dir:/c%3A/Users/loloa/.arduinoIDE/extensions does not exist.
2024-11-02T17:35:56.950Z root WARN The local plugin referenced by local-dir:C:\Users\loloa\.arduinoIDE\plugins does not exist.
2024-11-02T17:35:56.952Z root ERROR Uncaught Exception: Error: EPERM: operation not permitted, mkdir 'C:\Users\loloa\.arduinoIDE'
2024-11-02T17:35:56.952Z root ERROR Error: EPERM: operation not permitted, mkdir 'C:\Users\loloa\.arduinoIDE'
2024-11-02T17:35:57.007Z root INFO Resolve plugins list: 121.9 ms [Finished 0.698 s after backend start]
2024-11-02T17:35:57.040Z daemon INFO time="2024-11-02T13:35:57-04:00" level=info msg="arduino-cli version 1.0.4"
2024-11-02T17:35:57.045Z daemon INFO time="2024-11-02T13:35:57-04:00" level=info msg="Using config file: c:\\Users\\loloa\\.arduinoIDE\\arduino-cli.yaml"
2024-11-02T17:35:57.045Z daemon INFO time="2024-11-02T13:35:57-04:00" level=info msg="Executing `arduino-cli daemon`"
2024-11-02T17:35:57.051Z daemon INFO Daemon is now listening on 127.0.0.1:51359
{"IP":"127.0.0.1","Port":"51359"}
2024-11-02T17:35:57.051Z daemon INFO Daemon is running.
2024-11-02T17:35:57.056Z root INFO Error: Error executing C:\Users\loloa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe config init --dest-dir c:\Users\loloa\.arduinoIDE: Cannot create config file directory: mkdir c:\Users\loloa\.arduinoIDE: Access is denied.
2024-11-02T17:35:57.056Z config ERROR Failed to initialize the CLI configuration. Error: Error executing C:\Users\loloa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe config init --dest-dir c:\Users\loloa\.arduinoIDE: Cannot create config file directory: mkdir c:\Users\loloa\.arduinoIDE: Access is denied.
2024-11-02T17:35:57.163Z daemon INFO time="2024-11-02T13:35:57-04:00" level=info msg="Checking signature" index="C:\\Users\\loloa\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\loloa\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-11-02T17:35:57.165Z daemon INFO time="2024-11-02T13:35:57-04:00" level=info msg="Loading hardware from: C:\\Users\\loloa\\AppData\\Local\\Arduino15\\packages"
2024-11-02T17:35:57.166Z daemon INFO time="2024-11-02T13:35:57-04:00" level=info msg="Loading package builtin from: C:\\Users\\loloa\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-11-02T17:35:57.166Z daemon INFO time="2024-11-02T13:35:57-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\loloa\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-11-02T13:35:57-04:00" level=info msg="Loading tools from dir: C:\\Users\\loloa\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-11-02T17:35:57.166Z daemon INFO time="2024-11-02T13:35:57-04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-11-02T17:35:57.167Z daemon INFO time="2024-11-02T13:35:57-04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-11-02T17:35:57.167Z daemon INFO time="2024-11-02T13:35:57-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-11-02T17:35:57.167Z daemon INFO time="2024-11-02T13:35:57-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
2024-11-02T17:35:57.167Z daemon INFO time="2024-11-02T13:35:57-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-11-02T17:35:57.179Z daemon INFO time="2024-11-02T13:35:57-04:00" level=info msg="Loading libraries index file" index="C:\\Users\\loloa\\AppData\\Local\\Arduino15\\library_index.json"
2024-11-02T17:35:58.172Z daemon INFO time="2024-11-02T13:35:58-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\loloa\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2024-11-02T17:35:58.172Z daemon INFO time="2024-11-02T13:35:58-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\loloa\\OneDrive\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2024-11-02T17:35:58.642Z root ERROR Failed to initialize global state path: Error: EPERM: operation not permitted, mkdir 'c:\Users\loloa\.arduinoIDE'
2024-11-02T17:35:58.803Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 240.6 ms [Finished 1.798 s after frontend start]
2024-11-02T17:35:58.803Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-11-02T17:35:58.928Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 124.2 ms [Finished 1.939 s after frontend start]
[30592:1102/133558.958:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+é"
2024-11-02T17:35:59.063Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 106.0 ms [Finished 2.083 s after frontend start]
Can you think of any reason why the IDE can't create that directory? Check permissions.
You can try to create the directory c:\Users\loloa\.arduinoIDE manually; do not forget the dot.
Do not cross post; it wastes peoples time.
Posts merged.
I got it to open by running it through admin
You shouldn't but OK. Try to sort out why you could not create that directory.
It now works without me having to use admin
