Version 2.3.3
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Install the latest PowerShell for new features and improvements! https://aka.ms/PSWindows
PS D:\arduino-ide_2.3.3_Windows_64bit> "./Arduino IDE"
./Arduino IDE
PS D:\arduino-ide_2.3.3_Windows_64bit> ".\Arduino IDE"
.\Arduino IDE
PS D:\arduino-ide_2.3.3_Windows_64bit> & ".\Arduino IDE"
Arduino IDE 2.3.3
Checking for frontend application configuration customizations. Module path: D:\arduino-ide_2.3.3_Windows_64bit\resources\app\lib\backend\electron-main.js, destination 'package.json': D:\arduino-ide_2.3.3_Windows_64bit\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:41:18.242Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:41:18.242Z"}
Starting backend process. PID: 34160
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Bhone%20Pyae%20Sone%20Hein/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-09-30T11:36:56.214Z root INFO Backend Object.initialize: 4.4 ms [Finished 0.486 s after backend start]
2024-09-30T11:36:56.215Z root INFO Backend Object.configure: 3.6 ms [Finished 0.486 s after backend start]
2024-09-30T11:36:56.215Z root INFO Backend a.onStart: 1.9 ms [Finished 0.486 s after backend start]
2024-09-30T11:36:56.215Z root INFO Backend a.configure: 0.3 ms [Finished 0.506 s after backend start]
2024-09-30T11:36:56.216Z root INFO Backend d.onStart: 0.2 ms [Finished 0.506 s after backend start]
2024-09-30T11:36:56.217Z root INFO Backend d.configure: 0.1 ms [Finished 0.507 s after backend start]
2024-09-30T11:36:56.218Z root INFO Backend d.initialize: 20.7 ms [Finished 0.507 s after backend start]
2024-09-30T11:36:56.218Z root INFO Backend c.onStart: 0.2 ms [Finished 0.507 s after backend start]
2024-09-30T11:36:56.219Z root INFO Backend s.configure: 1.0 ms [Finished 0.508 s after backend start]
2024-09-30T11:36:56.220Z config INFO >>> Initializing CLI configuration...
2024-09-30T11:36:56.220Z root INFO Backend c.initialize: 0.6 ms [Finished 0.508 s after backend start]
2024-09-30T11:36:56.220Z root INFO Backend x.onStart: 1.0 ms [Finished 0.509 s after backend start]
2024-09-30T11:36:56.221Z config INFO Loading CLI configuration from c:\Users\Bhone Pyae Sone Hein\.arduinoIDE\arduino-cli.yaml...
2024-09-30T11:36:56.221Z daemon INFO Starting daemon from D:\arduino-ide_2.3.3_Windows_64bit\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-30T11:36:56.221Z root INFO Backend s.initialize: 0.4 ms [Finished 0.510 s after backend start]
2024-09-30T11:36:56.221Z root INFO Backend w.onStart: 1.2 ms [Finished 0.511 s after backend start]
2024-09-30T11:36:56.221Z root INFO Backend r.configure: 2.1 ms [Finished 0.511 s after backend start]
2024-09-30T11:36:56.221Z discovery-log INFO start
2024-09-30T11:36:56.221Z discovery-log INFO start new deferred
2024-09-30T11:36:56.221Z root INFO Backend d.initialize: 0.3 ms [Finished 0.511 s after backend start]
2024-09-30T11:36:56.221Z root INFO Backend y.onStart: 1.6 ms [Finished 0.513 s after backend start]
2024-09-30T11:36:56.221Z root INFO Backend r.configure: 1.4 ms [Finished 0.513 s after backend start]
2024-09-30T11:36:56.221Z root INFO Backend s.onStart: 0.4 ms [Finished 0.514 s after backend start]
2024-09-30T11:36:56.221Z root INFO Backend h.configure: 0.3 ms [Finished 0.514 s after backend start]
2024-09-30T11:36:56.221Z root INFO Backend a.configure: 0.1 ms [Finished 0.514 s after backend start]
2024-09-30T11:36:56.221Z root INFO Backend l.configure: 0.0 ms [Finished 0.514 s after backend start]
2024-09-30T11:36:56.224Z root INFO Theia app listening on http://127.0.0.1:52374.
2024-09-30T11:36:56.224Z root INFO Finished starting backend application: 3.2 ms [Finished 0.517 s after backend start]
2024-09-30T11:36:56.238Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Bhone%20Pyae%20Sone%20Hein/.arduinoIDE/plugins does not exist.
2024-09-30T11:36:56.238Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Bhone%20Pyae%20Sone%20Hein/.arduinoIDE/extensions does not exist.
2024-09-30T11:36:56.238Z root WARN The local plugin referenced by local-dir:C:\Users\Bhone Pyae Sone Hein\.arduinoIDE\plugins does not exist.
2024-09-30T11:36:56.242Z root ERROR Uncaught Exception: Error: EPERM: operation not permitted, mkdir 'C:\Users\Bhone Pyae Sone Hein\.arduinoIDE'
2024-09-30T11:36:56.243Z root ERROR Error: EPERM: operation not permitted, mkdir 'C:\Users\Bhone Pyae Sone Hein\.arduinoIDE'
2024-09-30T11:36:56.267Z root INFO Resolve plugins list: 46.1 ms [Finished 0.559 s after backend start]
2024-09-30T11:36:56.370Z root INFO Error: Error executing D:\arduino-ide_2.3.3_Windows_64bit\resources\app\lib\backend\resources\arduino-cli.exe config init --dest-dir c:\Users\Bhone Pyae Sone Hein\.arduinoIDE: Cannot create config file directory: mkdir c:\Users\Bhone Pyae Sone Hein\.arduinoIDE: Access is denied.
at ChildProcess.<anonymous> (D:\arduino-ide_2.3.3_Windows_64bit\resources\app\lib\backend\main.js:2:788280)
at ChildProcess.emit (node:events:514:28)
at Process.onexit (node:internal/child_process:291:12)
2024-09-30T11:36:56.370Z config ERROR Failed to initialize the CLI configuration. Error: Error executing D:\arduino-ide_2.3.3_Windows_64bit\resources\app\lib\backend\resources\arduino-cli.exe config init --dest-dir c:\Users\Bhone Pyae SoneHein\.arduinoIDE: Cannot create config file directory: mkdir c:\Users\Bhone Pyae Sone Hein\.arduinoIDE: Access is denied.
2024-09-30T11:36:56.380Z daemon INFO time="2024-09-30T18:06:56+06:30" level=info msg="arduino-cli version 1.0.4"
time="2024-09-30T18:06:56+06:30" level=info msg="Using config file: c:\\Users\\Bhone Pyae Sone Hein\\.arduinoIDE\\arduino-cli.yaml"
time="2024-09-30T18:06:56+06:30" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:52375
{"IP":"127.0.0.1","Port":"52375"}
2024-09-30T11:36:56.380Z daemon INFO Daemon is running.
2024-09-30T11:36:56.453Z daemon INFO time="2024-09-30T18:06:56+06:30" level=info msg="Checking signature" index="C:\\Users\\Bhone Pyae Sone Hein\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Bhone Pyae Sone Hein\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2024-09-30T18:06:56+06:30" level=info msg="Loading hardware from: C:\\Users\\Bhone Pyae Sone Hein\\AppData\\Local\\Arduino15\\packages"
time="2024-09-30T18:06:56+06:30" level=info msg="Loading package builtin from: C:\\Users\\Bhone Pyae Sone Hein\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-09-30T18:06:56+06:30" level=info msg="Checking existence of 'tools' path: C:\\Users\\Bhone Pyae Sone Hein\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-09-30T18:06:56+06:30" level=info msg="Loading tools from dir: C:\\Users\\Bhone Pyae Sone Hein\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-09-30T18:06:56+06:30" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-09-30T18:06:56+06:30" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-09-30T18:06:56+06:30" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-09-30T18:06:56+06:30" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2024-09-30T18:06:56+06:30" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-09-30T18:06:56+06:30" level=info msg="Loading libraries index file" index="C:\\Users\\Bhone Pyae Sone Hein\\AppData\\Local\\Arduino15\\library_index.json"
2024-09-30T11:36:56.679Z daemon INFO time="2024-09-30T18:06:56+06:30" level=info msg="Adding libraries dir" dir="C:\\Users\\Bhone Pyae Sone Hein\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2024-09-30T18:06:56+06:30" level=info msg="Adding libraries dir" dir="C:\\Users\\Bhone Pyae Sone Hein\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-09-30T11:36:57.859Z root ERROR Failed to initialize global state path: Error: EPERM: operation not permitted, mkdir 'c:\Users\Bhone Pyae Sone Hein\.arduinoIDE'
2024-09-30T11:36:57.914Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 130.4 ms [Finished 1.584 s after frontend start]
2024-09-30T11:36:57.914Z root WARN A command editor.action.toggleStickyScroll is already registered.
