IDE hangs on startup: "connectex: A connection attempt failed"
Hi, I am new to Arduino and just tried installing Arduino IDE. The installation process when smooth but when tried opening the IDE, it won't open. It's stuck at the window where the logo keeps on zooming in and out.
The first reason can be that the IDE 2.x needs internet access to install some additional stuff. If you're in a corporate environment, that access by the IDE might be blocked by your IT department.
Which operating system are you using?
For windows you can follow the instructions in I can´t see and install any libraris in my Library Manager - #23 by ptillisch and post the results here.
i'm using Windows 11 Enterprise and since i'm a new user, i can't upload attachments. will try to paste the results here
PS C:\Users\njamalab\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 6408
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/njamalab/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-09-24T05:19:54.016Z root INFO Backend Object.initialize: 3.4 ms [Finished 0.439 s after backend start]
2024-09-24T05:19:54.018Z root INFO Backend Object.configure: 2.8 ms [Finished 0.439 s after backend start]
2024-09-24T05:19:54.018Z root INFO Backend s.onStart: 1.3 ms [Finished 0.439 s after backend start]
2024-09-24T05:19:54.018Z root INFO Backend s.configure: 0.3 ms [Finished 0.458 s after backend start]
2024-09-24T05:19:54.019Z root INFO Backend d.onStart: 0.2 ms [Finished 0.458 s after backend start]
2024-09-24T05:19:54.019Z root INFO Backend d.configure: 0.1 ms [Finished 0.458 s after backend start]
2024-09-24T05:19:54.020Z root INFO Backend d.initialize: 19.4 ms [Finished 0.459 s after backend start]
2024-09-24T05:19:54.020Z root INFO Backend c.onStart: 0.2 ms [Finished 0.459 s after backend start]
2024-09-24T05:19:54.020Z root INFO Backend a.configure: 1.6 ms [Finished 0.460 s after backend start]
2024-09-24T05:19:54.021Z config INFO >>> Initializing CLI configuration...
2024-09-24T05:19:54.021Z root INFO Backend c.initialize: 0.4 ms [Finished 0.461 s after backend start]
2024-09-24T05:19:54.021Z root INFO Backend R.onStart: 0.6 ms [Finished 0.461 s after backend start]
2024-09-24T05:19:54.022Z config INFO Loading CLI configuration from c:\Users\njamalab\.arduinoIDE\arduino-cli.yaml...
2024-09-24T05:19:54.022Z daemon INFO Starting daemon from C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-09-24T05:19:54.023Z root INFO Backend a.initialize: 0.3 ms [Finished 0.462 s after backend start]
2024-09-24T05:19:54.023Z root INFO Backend w.onStart: 0.8 ms [Finished 0.462 s after backend start]
2024-09-24T05:19:54.023Z root INFO Backend r.configure: 1.3 ms [Finished 0.462 s after backend start]
2024-09-24T05:19:54.023Z discovery-log INFO start
2024-09-24T05:19:54.023Z discovery-log INFO start new deferred
2024-09-24T05:19:54.023Z root INFO Backend d.initialize: 0.3 ms [Finished 0.463 s after backend start]
2024-09-24T05:19:54.023Z root INFO Backend y.onStart: 1.4 ms [Finished 0.464 s after backend start]
2024-09-24T05:19:54.023Z root INFO Backend r.configure: 1.2 ms [Finished 0.464 s after backend start]
2024-09-24T05:19:54.023Z root INFO Backend a.onStart: 0.4 ms [Finished 0.465 s after backend start]
2024-09-24T05:19:54.023Z root INFO Backend h.configure: 0.3 ms [Finished 0.465 s after backend start]
2024-09-24T05:19:54.023Z root INFO Backend s.configure: 0.1 ms [Finished 0.465 s after backend start]
2024-09-24T05:19:54.023Z root INFO Backend l.configure: 0.0 ms [Finished 0.465 s after backend start]
2024-09-24T05:19:54.025Z root INFO Theia app listening on http://127.0.0.1:50848.
2024-09-24T05:19:54.025Z root INFO Finished starting backend application: 2.2 ms [Finished 0.467 s after backend start]
2024-09-24T05:19:54.037Z root WARN The local plugin referenced by local-dir:/c%3A/Users/njamalab/.arduinoIDE/plugins does not exist.
2024-09-24T05:19:54.037Z root WARN The local plugin referenced by local-dir:/c%3A/Users/njamalab/.arduinoIDE/extensions does not exist.
2024-09-24T05:19:54.038Z root WARN The local plugin referenced by local-dir:C:\Users\njamalab\.arduinoIDE\plugins does not exist.
2024-09-24T05:19:54.043Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\njamalab\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\njamalab\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\njamalab\\OneDrive - Intel Corporation\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-09-24T05:19:54.043Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-09-24T05:19:54.043Z config INFO Loaded the CLI configuration.
2024-09-24T05:19:54.048Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/njamalab/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/njamalab/OneDrive%20-%20Intel%20Corporation/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-09-24T05:19:54.048Z config INFO Validating the CLI configuration...
2024-09-24T05:19:54.049Z config INFO The CLI config is valid.
2024-09-24T05:19:54.049Z config INFO <<< Initialized the CLI configuration.
2024-09-24T05:19:54.071Z root INFO Resolve plugins list: 49.0 ms [Finished 0.513 s after backend start]
2024-09-24T05:19:54.293Z daemon INFO time="2024-09-24T13:19:54+08:00" level=info msg="Using config file: c:\\Users\\njamalab\\.arduinoIDE\\arduino-cli.yaml"
time="2024-09-24T13:19:54+08:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-09-24T13:19:54+08:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:50854
{"IP":"127.0.0.1","Port":"50854"}
2024-09-24T05:19:54.293Z root ERROR E "proxy.jf.intel.com:" scheme not supported in proxy URI
2024-09-24T05:19:54.293Z daemon INFO Daemon is running.
2024-09-24T05:19:54.308Z daemon INFO time="2024-09-24T13:19:54+08:00" level=info msg="Updating libraries index"
2024-09-24T05:19:54.314Z daemon INFO time="2024-09-24T13:19:54+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-09-24T05:19:54.850Z root INFO Deploy plugins list: 49.0 ms [Finished 1.292 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-09-24T05:19:55.654Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 139.4 ms [Finished 1.521 s after frontend start]
2024-09-24T05:19:55.654Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-09-24T05:20:36.437Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.11.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24T05:20:36.438Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\njamalab\AppData\Local\Arduino15\package_index.json: open C:\Users\njamalab\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-09-24T05:20:36.439Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-09-24T05:20:36.439Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-09-24T05:20:36.439Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\njamalab\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-09-24T05:20:36.443Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\njamalab\AppData\Local\Arduino15\package_index.json: open C:\Users\njamalab\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\njamalab\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-09-24T05:20:36.444Z daemon INFO time="2024-09-24T13:20:36+08:00" level=info msg="Loading hardware from: C:\\Users\\njamalab\\AppData\\Local\\Arduino15\\packages"
time="2024-09-24T13:20:36+08:00" level=info msg="Loading libraries index file" index="C:\\Users\\njamalab\\AppData\\Local\\Arduino15\\library_index.json"
time="2024-09-24T13:20:36+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\njamalab\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-09-24T13:20:36+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\njamalab\\OneDrive - Intel Corporation\\Documents\\Arduino\\libraries" location=user
2024-09-24T05:20:36.444Z daemon INFO time="2024-09-24T13:20:36+08:00" level=info msg="Updating libraries index"
2024-09-24T05:20:36.444Z daemon INFO time="2024-09-24T13:20:36+08:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-09-24T05:20:36.445Z daemon INFO time="2024-09-24T13:20:36+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-09-24T05:20:36.447Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-09-24T05:20:36.448Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-09-24T05:20:36.448Z daemon INFO time="2024-09-24T13:20:36+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-09-24T05:21:18.529Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Some indexes could not be updated.
    at t.callErrorFromStatus (C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:763461)
    at Object.onReceiveStatus (C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:791078)
    at Object.onReceiveStatus (C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:784102)
    at C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:870224
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
    at s.makeServerStreamRequest (C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:790845)
    at s.updateIndex (C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:855121)
    at C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:623733
    at C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:624081
    at new Promise (<anonymous>)
    at E.doUpdateIndex (C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:624060)
    at E.updatePlatformIndex (C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:623705)
    at E.updateIndex (C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:623073)
    at E.initInstanceWithFallback (C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:621317)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-09-24T05:21:18.531Z daemon INFO time="2024-09-24T13:21:18+08:00" level=info msg="Updating libraries index"
2024-09-24T05:21:18.536Z daemon INFO time="2024-09-24T13:21:18+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-09-24T05:22:00.611Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp 104.18.11.21:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24T05:22:00.612Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\njamalab\AppData\Local\Arduino15\package_index.json: open C:\Users\njamalab\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-09-24T05:22:00.612Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-09-24T05:22:00.613Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-09-24T05:22:00.613Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\njamalab\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-09-24T05:22:00.613Z daemon INFO time="2024-09-24T13:22:00+08:00" level=info msg="Loading hardware from: C:\\Users\\njamalab\\AppData\\Local\\Arduino15\\packages"
time="2024-09-24T13:22:00+08:00" level=info msg="Loading libraries index file" index="C:\\Users\\njamalab\\AppData\\Local\\Arduino15\\library_index.json"
time="2024-09-24T13:22:00+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\njamalab\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-09-24T13:22:00+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\njamalab\\OneDrive - Intel Corporation\\Documents\\Arduino\\libraries" location=user
2024-09-24T05:22:00.616Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-09-24T05:22:00.616Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
    at C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:622877
    at E.evaluateErrorStatus (C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:622893)
    at async a.<anonymous> (C:\Users\njamalab\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:622563)
I think that the above is the problem; it sounds like the IDE can't access the internet.
Are you in a corporate environment or using a corporate computer?
yes I am.. but, there's internet connected on my pc currently. is there any workaround on how to solve this?
Talk to your IT department; if you need it for work you have a case. They have probably blocked at the application level.
The workaround could be to use an other Windows PC that is not subjected to it, install the IDE and let it do it's thing. Next copy the needed files over to your computer.
If that is an option, let us know for further assistance once you have done the work on the other PC.
Be aware that e.g. installing libraries using library manager or another board package using the board manager will still be subject to the IT rules; for libraries you can work around it by downloading ZIPs, for other board packages it should be again using another PC as described above.
