IDE hangs on startup: "connectex: An attempt was made to access a socket in a way forbidden by its access permissions."
Continuing the discussion from Arduino 2.0 will not start past the loading screen:
PS C:\Program Files\Arduino IDE> .\Arduino IDE
.\Arduino : The term '.\Arduino' is not recognized as the name of a cmdlet, function, script file, or operable
program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:1
+ .\Arduino IDE
    + CategoryInfo          : ObjectNotFound: (.\Arduino:String) [], CommandNotFoundException
    + FullyQualifiedErrorId : CommandNotFoundException
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 6000
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Mauro/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-04-16T23:42:20.796Z root INFO Backend Object.initialize: 6.9 ms [Finished 0.612 s after backend start]
2024-04-16T23:42:20.797Z root INFO Backend Object.configure: 6.1 ms [Finished 0.612 s after backend start]
2024-04-16T23:42:20.797Z root INFO Backend s.onStart: 4.0 ms [Finished 0.612 s after backend start]
2024-04-16T23:42:20.798Z root INFO Backend s.configure: 0.4 ms [Finished 0.643 s after backend start]
2024-04-16T23:42:20.799Z root INFO Backend d.onStart: 0.3 ms [Finished 0.643 s after backend start]
2024-04-16T23:42:20.801Z root INFO Backend d.configure: 0.1 ms [Finished 0.644 s after backend start]
2024-04-16T23:42:20.802Z root INFO Backend d.initialize: 31.0 ms [Finished 0.644 s after backend start]
2024-04-16T23:42:20.803Z root INFO Backend c.onStart: 0.3 ms [Finished 0.644 s after backend start]
2024-04-16T23:42:20.804Z root INFO Backend a.configure: 1.5 ms [Finished 0.645 s after backend start]
2024-04-16T23:42:20.806Z config INFO >>> Initializing CLI configuration...
2024-04-16T23:42:20.807Z root INFO Backend c.initialize: 0.8 ms [Finished 0.646 s after backend start]
2024-04-16T23:42:20.807Z root INFO Backend R.onStart: 1.0 ms [Finished 0.647 s after backend start]
2024-04-16T23:42:20.809Z config INFO Loading CLI configuration from c:\Users\Mauro\.arduinoIDE\arduino-cli.yaml...
2024-04-16T23:42:20.809Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-04-16T23:42:20.809Z root INFO Backend a.initialize: 1.1 ms [Finished 0.649 s after backend start]
2024-04-16T23:42:20.809Z root INFO Backend w.onStart: 2.3 ms [Finished 0.650 s after backend start]
2024-04-16T23:42:20.809Z root INFO Backend r.configure: 3.7 ms [Finished 0.650 s after backend start]
2024-04-16T23:42:20.812Z discovery-log INFO start
2024-04-16T23:42:20.812Z discovery-log INFO start new deferred
2024-04-16T23:42:20.812Z root INFO Backend d.initialize: 1.3 ms [Finished 0.652 s after backend start]
2024-04-16T23:42:20.812Z root INFO Backend y.onStart: 3.6 ms [Finished 0.654 s after backend start]
2024-04-16T23:42:20.812Z root INFO Backend r.configure: 2.5 ms [Finished 0.654 s after backend start]
2024-04-16T23:42:20.812Z root INFO Backend a.onStart: 0.8 ms [Finished 0.657 s after backend start]
2024-04-16T23:42:20.812Z root INFO Backend h.configure: 0.7 ms [Finished 0.657 s after backend start]
2024-04-16T23:42:20.812Z root INFO Backend s.configure: 2.2 ms [Finished 0.659 s after backend start]
2024-04-16T23:42:20.812Z root INFO Backend l.configure: 0.4 ms [Finished 0.660 s after backend start]
2024-04-16T23:42:20.817Z root INFO Theia app listening on http://127.0.0.1:57783.
2024-04-16T23:42:20.817Z root INFO Finished starting backend application: 7.5 ms [Finished 0.665 s after backend start]
2024-04-16T23:42:20.823Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Mauro/.arduinoIDE/plugins does not exist.
2024-04-16T23:42:20.823Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Mauro/.arduinoIDE/extensions does not exist.
2024-04-16T23:42:20.824Z root WARN The local plugin referenced by local-dir:C:\Users\Mauro\.arduinoIDE\plugins does not exist.
2024-04-16T23:42:20.846Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\Mauro\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Mauro\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\Mauro\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-04-16T23:42:20.846Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-04-16T23:42:20.846Z config INFO Loaded the CLI configuration.
2024-04-16T23:42:20.869Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Mauro/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Mauro/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-04-16T23:42:20.869Z config INFO Validating the CLI configuration...
2024-04-16T23:42:20.870Z config INFO The CLI config is valid.
2024-04-16T23:42:20.870Z config INFO <<< Initialized the CLI configuration.
2024-04-16T23:42:20.896Z root INFO Resolve plugins list: 88.8 ms [Finished 0.743 s after backend start]
2024-04-16T23:42:21.043Z daemon INFO time="2024-04-16T20:42:20-03:00" level=info msg="Using config file: c:\\Users\\Mauro\\.arduinoIDE\\arduino-cli.yaml"
time="2024-04-16T20:42:20-03:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-04-16T20:42:20-03:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:57784
{"IP":"127.0.0.1","Port":"57784"}
2024-04-16T23:42:21.043Z daemon INFO Daemon is running.
2024-04-16T23:42:21.148Z daemon INFO time="2024-04-16T20:42:21-03:00" level=info msg="Updating libraries index"
time="2024-04-16T20:42:21-03:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-04-16T23:42:21.176Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp [2606:4700::6812:a15]:443: connectex: An attempt was made to access a socket in a way forbidden by its access permissions.
2024-04-16T23:42:21.177Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\Mauro\AppData\Local\Arduino15\package_index.json: open C:\Users\Mauro\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-04-16T23:42:21.179Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-04-16T23:42:21.180Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-04-16T23:42:21.181Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\Mauro\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-04-16T23:42:21.186Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\Mauro\AppData\Local\Arduino15\package_index.json: open C:\Users\Mauro\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\Mauro\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-04-16T23:42:21.187Z daemon INFO time="2024-04-16T20:42:21-03:00" level=info msg="Loading hardware from: C:\\Users\\Mauro\\AppData\\Local\\Arduino15\\packages"
time="2024-04-16T20:42:21-03:00" level=info msg="Loading libraries index file" index="C:\\Users\\Mauro\\AppData\\Local\\Arduino15\\library_index.json"
time="2024-04-16T20:42:21-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Mauro\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-04-16T20:42:21-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Mauro\\Documents\\Arduino\\libraries" location=user
2024-04-16T23:42:21.188Z daemon INFO time="2024-04-16T20:42:21-03:00" level=info msg="Updating libraries index"
2024-04-16T23:42:21.200Z daemon INFO time="2024-04-16T20:42:21-03:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
time="2024-04-16T20:42:21-03:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
time="2024-04-16T20:42:21-03:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-04-16T23:42:21.202Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-04-16T23:42:21.203Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-04-16T23:42:21.205Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Some indexes could not be updated.
    at t.callErrorFromStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:763461)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:791078)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:784102)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:870224
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
    at s.makeServerStreamRequest (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:790845)
    at s.updateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:855121)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:623733
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:624081
    at new Promise (<anonymous>)
    at E.doUpdateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:624060)
    at E.updatePlatformIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:623705)
    at E.updateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:623073)
    at E.initInstanceWithFallback (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:621317)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-04-16T23:42:21.230Z daemon INFO time="2024-04-16T20:42:21-03:00" level=info msg="Updating libraries index"
2024-04-16T23:42:21.248Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp [2606:4700::6812:a15]:443: connectex: An attempt was made to access a socket in a way forbidden by its access permissions.
2024-04-16T23:42:21.249Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\Mauro\AppData\Local\Arduino15\package_index.json: open C:\Users\Mauro\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-04-16T23:42:21.249Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-04-16T23:42:21.250Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-04-16T23:42:21.251Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\Mauro\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-04-16T23:42:21.253Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-04-16T23:42:21.253Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622877
    at E.evaluateErrorStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622893)
    at async a.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622563)
2024-04-16T23:42:22.156Z root INFO Deploy plugins list: 88.8 ms [Finished 2.003 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-04-16T23:42:23.137Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 178.5 ms [Finished 2.174 s after frontend start]
2024-04-16T23:42:23.137Z root WARN A command editor.action.toggleStickyScroll is already registered.
