Arduino IDE 2.3.6 freezes on loading screen.
I have Windows 10
Here is my startup log.
Arduino IDE 2.3.6
Checking for frontend application configuration customizations. Module path: D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': D:\Development\ArduinoIDE\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.6" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.2.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2025-04-09T11:26:55.498Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{},"showWindowEarly":true,"splashScreenOptions":{},"uriScheme":"arduino-ide"},"defaultLocale":"","validatePreferencesSchema":false,"reloadOnReconnect":true,"uriScheme":"theia","preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.6","cliVersion":"1.2.0","buildDate":"2025-04-09T11:26:55.498Z"}
Starting backend process. PID: 1732
Showing main window early
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/politick/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-05-08T19:25:56.439Z root INFO Backend u.initialize: 33.0 ms [Finished 0.704 s after backend start]
2025-05-08T19:25:56.440Z root INFO Backend Object.initialize: 31.3 ms [Finished 0.704 s after backend start]
2025-05-08T19:25:56.440Z root INFO Backend a.initialize: 1.6 ms [Finished 0.704 s after backend start]
2025-05-08T19:25:56.440Z root INFO Backend a.initialize: 1.3 ms [Finished 0.704 s after backend start]
2025-05-08T19:25:56.440Z root INFO Backend u.initialize: 1.6 ms [Finished 0.704 s after backend start]
2025-05-08T19:25:56.443Z root INFO Backend l.initialize: 32.8 ms [Finished 0.705 s after backend start]
2025-05-08T19:25:56.450Z root INFO configured all backend app contributions
2025-05-08T19:25:56.451Z root INFO Backend l.onStart: 1.3 ms [Finished 0.717 s after backend start]
2025-05-08T19:25:56.451Z root INFO Backend d.onStart: 0.1 ms [Finished 0.717 s after backend start]
2025-05-08T19:25:56.452Z root INFO Backend a.onStart: 0.4 ms [Finished 0.718 s after backend start]
2025-05-08T19:25:56.452Z config INFO >>> Initializing CLI configuration...
2025-05-08T19:25:56.453Z root INFO Backend x.onStart: 0.4 ms [Finished 0.718 s after backend start]
2025-05-08T19:25:56.453Z config INFO Loading CLI configuration from c:\Users\politick\.arduinoIDE\arduino-cli.yaml...
2025-05-08T19:25:56.453Z daemon INFO Starting daemon from D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-05-08T19:25:56.453Z root INFO Backend w.onStart: 0.4 ms [Finished 0.719 s after backend start]
2025-05-08T19:25:56.453Z discovery-log INFO start
2025-05-08T19:25:56.453Z discovery-log INFO start new deferred
2025-05-08T19:25:56.453Z root INFO Backend v.onStart: 0.2 ms [Finished 0.719 s after backend start]
2025-05-08T19:25:56.453Z root INFO Backend a.onStart: 0.1 ms [Finished 0.720 s after backend start]
2025-05-08T19:25:56.459Z root INFO Theia app listening on http://127.0.0.1:50163.
2025-05-08T19:25:56.459Z root INFO Finished starting backend application: 5.9 ms [Finished 0.726 s after backend start]
2025-05-08T19:25:56.460Z root WARN The local plugin referenced by local-dir:/c%3A/Users/politick/.arduinoIDE/plugins does not exist.
2025-05-08T19:25:56.460Z root WARN The local plugin referenced by local-dir:/c%3A/Users/politick/.arduinoIDE/deployedPlugins does not exist.
2025-05-08T19:25:56.460Z root WARN The local plugin referenced by local-dir:C:\Users\politick\.arduinoIDE\plugins does not exist.
2025-05-08T19:25:56.464Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["http://arduino.esp8266.com/stable/package_esp8266com_index.json","https://static-cdn.m5stack.com/resource/arduino/package_m5stack_index.json"]},"directories":{"builtin":{"libraries":"C:\\Users\\politick\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\politick\\AppData\\Local\\Arduino15","user":"c:\\Users\\politick\\Documents\\Arduino"},"locale":"ru"}
2025-05-08T19:25:56.464Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2025-05-08T19:25:56.464Z config INFO Loaded the CLI configuration.
Restoring workspace roots: d:\Development\!line_fallow\sketch_dec5b
isTempSketch: false. Input was d:\Development\!line_fallow\sketch_dec5b\sketch_dec5b.ino
2025-05-08T19:25:56.487Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/politick/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/politick/Documents/Arduino","additionalUrls":["http://arduino.esp8266.com/stable/package_esp8266com_index.json","https://static-cdn.m5stack.com/resource/arduino/package_m5stack_index.json"],"network":"none","locale":"ru"}
2025-05-08T19:25:56.487Z config INFO Validating the CLI configuration...
2025-05-08T19:25:56.488Z config INFO The CLI config is valid.
2025-05-08T19:25:56.488Z config INFO <<< Initialized the CLI configuration.
2025-05-08T19:25:56.528Z root INFO Resolve plugins list: 72.7 ms [Finished 0.794 s after backend start]
2025-05-08T19:25:56.625Z daemon INFO time="2025-05-08T23:25:56+04:00" level=info msg="arduino-cli version 1.2.0"
time="2025-05-08T23:25:56+04:00" level=info msg="Using config file: c:\\Users\\politick\\.arduinoIDE\\arduino-cli.yaml"
time="2025-05-08T23:25:56+04:00" level=info msg="Executing `arduino-cli daemon`"
╨Ф╨╡╨╝╨╛╨╜ ╤Б╨╡╨╣╤З╨░╤Б ╤Б╨╗╤Г╤И╨░╨╡╤В 127.0.0.1: 50164
{"IP":"127.0.0.1","Port":"50164"}
2025-05-08T19:25:56.625Z daemon INFO Daemon is running.
2025-05-08T19:25:56.768Z daemon INFO time="2025-05-08T23:25:56+04:00" level=info msg="Checking signature" index="c:\\Users\\politick\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\politick\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2025-05-08T19:25:56.778Z daemon INFO time="2025-05-08T23:25:56+04:00" level=info msg="Missing signature file" index="c:\\Users\\politick\\AppData\\Local\\Arduino15\\package_esp8266com_index.json"
time="2025-05-08T23:25:56+04:00" level=info msg="Missing signature file" index="c:\\Users\\politick\\AppData\\Local\\Arduino15\\package_m5stack_index.json"
time="2025-05-08T23:25:56+04:00" level=info msg="Loading hardware from: c:\\Users\\politick\\AppData\\Local\\Arduino15\\packages"
time="2025-05-08T23:25:56+04:00" level=info msg="Loading package arduino from: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2025-05-08T19:25:56.778Z daemon INFO time="2025-05-08T23:25:56+04:00" level=info msg="Missing signature file" index="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
2025-05-08T19:25:56.789Z daemon INFO time="2025-05-08T23:25:56+04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2025-05-08T23:25:56+04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-05-08T23:25:56+04:00" level=info msg="Loading tools from dir: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2025-05-08T23:25:56+04:00" level=info msg="Loading package builtin from: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2025-05-08T23:25:56+04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-05-08T23:25:56+04:00" level=info msg="Loading tools from dir: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2025-05-08T19:25:56.793Z daemon INFO time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2025-05-08T19:25:56.800Z daemon INFO time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@0.9.2"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.0.0"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.0-rc1"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
time="2025-05-08T23:25:56+04:00" level=info msg="Loading package esp8266 from: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
2025-05-08T19:25:56.812Z daemon INFO time="2025-05-08T23:25:56+04:00" level=info msg="Missing signature file" index="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\installed.json"
2025-05-08T19:25:56.852Z daemon INFO time="2025-05-08T23:25:56+04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
time="2025-05-08T23:25:56+04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2025-05-08T23:25:56+04:00" level=info msg="Loading tools from dir: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
time="2025-05-08T23:25:56+04:00" level=info msg="Loading package m5stack from: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware"
time="2025-05-08T23:25:56+04:00" level=info msg="Missing signature file" index="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\2.1.4\\installed.json"
2025-05-08T19:25:56.879Z daemon INFO time="2025-05-08T23:25:56+04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded platform" platform="m5stack:esp32@2.1.4"
time="2025-05-08T23:25:56+04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\m5stack\\tools"
time="2025-05-08T23:25:56+04:00" level=info msg="Loading tools from dir: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\m5stack\\tools"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="m5stack:esptool_py@4.5.1"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="m5stack:mklittlefs@3.0.0-gnu12-dc7f933"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="m5stack:mkspiffs@0.2.3"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="m5stack:openocd-esp32@v0.12.0-esp32-20230419"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="m5stack:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="m5stack:riscv32-esp-elf-gdb@11.2_20220823"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="m5stack:xtensa-esp-elf-gdb@11.2_20220823"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="m5stack:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="m5stack:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2025-05-08T23:25:56+04:00" level=info msg="Loaded tool" tool="m5stack:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2025-05-08T19:25:56.907Z daemon INFO time="2025-05-08T23:25:56+04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
2025-05-08T19:25:56.915Z daemon INFO time="2025-05-08T23:25:56+04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\2.1.4\\libraries" isSingleLibrary=false location=platform
2025-05-08T19:25:56.919Z daemon INFO time="2025-05-08T23:25:56+04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" isSingleLibrary=false location=platform
time="2025-05-08T23:25:56+04:00" level=info msg="Loading libraries index file" index="c:\\Users\\politick\\AppData\\Local\\Arduino15\\library_index.json"
2025-05-08T19:25:57.151Z root INFO Deploy plugins list: 696.6 ms [Finished 1.418 s after backend start]
2025-05-08T19:25:57.257Z daemon INFO time="2025-05-08T23:25:57+04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\politick\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-05-08T19:25:57.257Z daemon INFO time="2025-05-08T23:25:57+04:00" level=info msg="Adding libraries dir" dir="c:\\Users\\politick\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-05-08T19:25:57.746Z root INFO creating connection for 1
2025-05-08T19:25:58.634Z discovery-log INFO start resolved watching
2025-05-08T19:25:58.717Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 123.3 ms [Finished 2.243 s after frontend start]
2025-05-08T19:25:58.748Z root WARN A command editor.action.toggleStickyScroll is already registered.
2025-05-08T19:25:58.756Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-05-08T19:25:58.758Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM4","label":"COM4","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-05-08T19:25:58.758Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM5","label":"COM5","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-05-08T19:25:58.758Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-05-08T19:25:58.772Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <d:\Development\!line_fallow\sketch_dec5b\sketch_dec5b.ino>, response: <d:\Development\!line_fallow\sketch_dec5b>.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2025-05-08T19:25:58.871Z root INFO Start frontend contributions: 345.2 ms [Finished 2.384 s after frontend start]
2025-05-08T19:25:58.871Z root INFO Changed application state from 'init' to 'started_contributions'.
2025-05-08T19:25:58.881Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2025-05-08T19:25:58.881Z root INFO >>> Restoring the layout state...
2025-05-08T19:25:58.921Z root INFO [b6359f8e-8c9a-4bb7-a980-e6d86c2a2a9f] Waiting for backend deployment: 67.4 ms [Finished 2.445 s after frontend start]
2025-05-08T19:25:59.664Z root ERROR [hosted-plugin: 18108] [0508/232559.178:ERROR:crashpad_client_win.cc(868)] not connected
2025-05-08T19:25:59.666Z root ERROR [hosted-plugin: 18108] IPC exited, with signal: null, and exit code: 4294930435
2025-05-08T19:25:59.670Z root ERROR Error: spawn UNKNOWN
at ChildProcess.spawn (node:internal/child_process:421:11)
at spawn (node:child_process:776:9)
at fork (node:child_process:172:10)
at e.fork (node:electron/js2c/node_init:2:15063)
at u.fork (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:6849885)
at u.doListen (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:6849331)
at D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:6849592
at D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:1018551
at s.invoke (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:1018641)
at a.fire (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:1020444)
<--- Last few GCs --->
[3644:000073A8007DC000] 3371 ms: Scavenge (interleaved) 38.5 (45.4) -> 37.3 (45.6) MB, pooled: 0 MB, 2.01 / 0.00 ms (average mu = 0.859, current mu = 0.001) allocation failure;
[3644:000073A8007DC000] 3381 ms: Scavenge (interleaved) 38.8 (45.6) -> 37.7 (45.6) MB, pooled: 0 MB, 2.16 / 0.00 ms (average mu = 0.859, current mu = 0.001) allocation failure;
<--- JS stacktrace --->
FATAL ERROR: NewSpace::EnsureCurrentCapacity Allocation failed - JavaScript heap out of memory
----- Native stack trace -----
1: 00007FF73475FA6A uv_cpumask_size+72266
2: 00007FF7346DAB8E node::OnFatalError+654
3: 00007FF73781CBF4 v8::Function::NewInstance+868
4: 00007FF73781CB63 v8::Function::NewInstance+723
5: 00007FF7378CEC67 v8::CppHeap::wrapper_descriptor+61447
6: 00007FF73322330A v8::CppHeap::CollectStatistics+207946
7: 00007FF73320ABFA v8::CppHeap::CollectStatistics+107834
8: 00007FF73320A139 v8::CppHeap::CollectStatistics+105081
9: 00007FF733213A6E v8::CppHeap::CollectStatistics+144302
10: 00007FF7332136D4 v8::CppHeap::CollectStatistics+143380
11: 00007FF7334BE0E5 cppgc::internal::WriteBarrier::SteeleMarkingBarrierSlow+2661
2025-05-08T19:25:59.980Z root INFO socked closed
2025-05-08T19:25:59.980Z root INFO closing connection for 1
2025-05-08T19:25:59.980Z root INFO Closing channel on service path '/localization-server'.
2025-05-08T19:25:59.980Z root INFO Closing channel on service path '/os'.
2025-05-08T19:25:59.980Z root INFO Closing channel on service path '/services/commands'.
2025-05-08T19:25:59.980Z root INFO Closing channel on service path '/services/keyboard'.
2025-05-08T19:25:59.980Z root INFO Closing channel on service path '/services/logger'.
2025-05-08T19:25:59.980Z root INFO Closing channel on service path '/services/messageService'.
2025-05-08T19:25:59.980Z root INFO Closing channel on service path '/services/ChannelCloseService'.
2025-05-08T19:25:59.980Z root INFO Closing channel on service path '/services/remote-filesystem'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/envs'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/authentication-service'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/sketches-service'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/config-service'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/workspace'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/notification-service'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/arduino-daemon'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/stopwatch'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/application'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/i18n'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/quickInput'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/debug'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/shell-terminal'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/quickPick'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/task'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/search'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/hostedPlugin'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/plugin-ext'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/plugin-paths'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/cli-preferences'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/boards-service'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/response-service'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/file-system-ext'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/core-service'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/example-service'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/library-service'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/executable-service'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/arduino-firmware-uploader'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/formatter'.
2025-05-08T19:25:59.981Z root INFO Closing channel on service path '/services/search-in-workspace'.
2025-05-08T19:25:59.981Z root ERROR Error from plugin host: Channel closed
2025-05-08T19:25:59.981Z root ERROR Uncaught Exception: Error: transport close
2025-05-08T19:25:59.981Z root ERROR Error: transport close
at D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:6813621
at Map.forEach (<anonymous>)
at D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:6813600
at D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:2680888
at Object.<anonymous> (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:2680858)
at e.dispose (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:3741352)
Here is another one
Arduino IDE 2.3.6
Starting backend process. PID: 12936
2025-05-08T19:28:39.439Z root INFO Backend u.initialize: 34.1 ms [Finished 0.699 s after backend start]
2025-05-08T19:28:39.440Z root INFO Backend Object.initialize: 32.4 ms [Finished 0.699 s after backend start]
2025-05-08T19:28:39.440Z root INFO Backend a.initialize: 1.6 ms [Finished 0.699 s after backend start]
2025-05-08T19:28:39.440Z root INFO Backend a.initialize: 1.3 ms [Finished 0.699 s after backend start]
2025-05-08T19:28:39.440Z root INFO Backend u.initialize: 1.7 ms [Finished 0.700 s after backend start]
2025-05-08T19:28:39.443Z root INFO Backend l.initialize: 33.8 ms [Finished 0.701 s after backend start]
2025-05-08T19:28:39.452Z root INFO configured all backend app contributions
2025-05-08T19:28:39.452Z root INFO Backend l.onStart: 2.3 ms [Finished 0.714 s after backend start]
2025-05-08T19:28:39.453Z root INFO Backend d.onStart: 0.1 ms [Finished 0.714 s after backend start]
2025-05-08T19:28:39.454Z root INFO Backend a.onStart: 0.4 ms [Finished 0.715 s after backend start]
2025-05-08T19:28:39.454Z config INFO >>> Initializing CLI configuration...
2025-05-08T19:28:39.454Z root INFO Backend x.onStart: 0.5 ms [Finished 0.715 s after backend start]
2025-05-08T19:28:39.454Z config INFO Loading CLI configuration from c:\Users\politick\.arduinoIDE\arduino-cli.yaml...
2025-05-08T19:28:39.454Z daemon INFO Starting daemon from D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-05-08T19:28:39.454Z root INFO Backend w.onStart: 0.4 ms [Finished 0.716 s after backend start]
2025-05-08T19:28:39.454Z discovery-log INFO start
2025-05-08T19:28:39.454Z discovery-log INFO start new deferred
2025-05-08T19:28:39.454Z root INFO Backend v.onStart: 0.2 ms [Finished 0.716 s after backend start]
2025-05-08T19:28:39.454Z root INFO Backend a.onStart: 0.1 ms [Finished 0.717 s after backend start]
2025-05-08T19:28:39.460Z root INFO Theia app listening on http://127.0.0.1:50251.
2025-05-08T19:28:39.460Z root INFO Finished starting backend application: 5.4 ms [Finished 0.722 s after backend start]
Restoring workspace roots: d:\Development\!line_fallow\sketch_dec5b\sketch_dec5b.ino
2025-05-08T19:28:39.462Z root WARN The local plugin referenced by local-dir:/c%3A/Users/politick/.arduinoIDE/plugins does not exist.
2025-05-08T19:28:39.462Z root WARN The local plugin referenced by local-dir:/c%3A/Users/politick/.arduinoIDE/deployedPlugins does not exist.
2025-05-08T19:28:39.462Z root WARN The local plugin referenced by local-dir:C:\Users\politick\.arduinoIDE\plugins does not exist.
2025-05-08T19:28:39.467Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["http://arduino.esp8266.com/stable/package_esp8266com_index.json","https://static-cdn.m5stack.com/resource/arduino/package_m5stack_index.json"]},"directories":{"builtin":{"libraries":"C:\\Users\\politick\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\politick\\AppData\\Local\\Arduino15","user":"c:\\Users\\politick\\Documents\\Arduino"},"locale":"ru"}
2025-05-08T19:28:39.467Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2025-05-08T19:28:39.467Z config INFO Loaded the CLI configuration.
2025-05-08T19:28:39.487Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/politick/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/politick/Documents/Arduino","additionalUrls":["http://arduino.esp8266.com/stable/package_esp8266com_index.json","https://static-cdn.m5stack.com/resource/arduino/package_m5stack_index.json"],"network":"none","locale":"ru"}
2025-05-08T19:28:39.487Z config INFO Validating the CLI configuration...
2025-05-08T19:28:39.487Z config INFO The CLI config is valid.
2025-05-08T19:28:39.487Z config INFO <<< Initialized the CLI configuration.
2025-05-08T19:28:39.553Z root INFO Resolve plugins list: 94.6 ms [Finished 0.813 s after backend start]
2025-05-08T19:28:39.581Z daemon INFO time="2025-05-08T23:28:39+04:00" level=info msg="arduino-cli version 1.2.0"
2025-05-08T19:28:39.582Z daemon INFO time="2025-05-08T23:28:39+04:00" level=info msg="Using config file: c:\\Users\\politick\\.arduinoIDE\\arduino-cli.yaml"
time="2025-05-08T23:28:39+04:00" level=info msg="Executing `arduino-cli daemon`"
2025-05-08T19:28:39.594Z daemon INFO ╨Ф╨╡╨╝╨╛╨╜ ╤Б╨╡╨╣╤З╨░╤Б ╤Б╨╗╤Г╤И╨░╨╡╤В 127.0.0.1: 50252
{"IP":"127.0.0.1","Port":"50252"}
2025-05-08T19:28:39.594Z daemon INFO Daemon is running.
2025-05-08T19:28:39.640Z daemon INFO time="2025-05-08T23:28:39+04:00" level=info msg="Checking signature" index="c:\\Users\\politick\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\politick\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2025-05-08T19:28:39.670Z daemon INFO time="2025-05-08T23:28:39+04:00" level=info msg="Missing signature file" index="c:\\Users\\politick\\AppData\\Local\\Arduino15\\package_esp8266com_index.json"
time="2025-05-08T23:28:39+04:00" level=info msg="Missing signature file" index="c:\\Users\\politick\\AppData\\Local\\Arduino15\\package_m5stack_index.json"
time="2025-05-08T23:28:39+04:00" level=info msg="Loading hardware from: c:\\Users\\politick\\AppData\\Local\\Arduino15\\packages"
time="2025-05-08T23:28:39+04:00" level=info msg="Loading package arduino from: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2025-05-08T23:28:39+04:00" level=info msg="Missing signature file" index="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
2025-05-08T19:28:39.696Z daemon INFO time="2025-05-08T23:28:39+04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2025-05-08T23:28:39+04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-05-08T23:28:39+04:00" level=info msg="Loading tools from dir: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2025-05-08T23:28:39+04:00" level=info msg="Loading package builtin from: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2025-05-08T23:28:39+04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-05-08T23:28:39+04:00" level=info msg="Loading tools from dir: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@0.9.2"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.0.0"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.0-rc1"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
time="2025-05-08T23:28:39+04:00" level=info msg="Loading package esp8266 from: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
time="2025-05-08T23:28:39+04:00" level=info msg="Missing signature file" index="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\installed.json"
2025-05-08T19:28:39.754Z daemon INFO time="2025-05-08T23:28:39+04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
time="2025-05-08T23:28:39+04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2025-05-08T23:28:39+04:00" level=info msg="Loading tools from dir: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
2025-05-08T19:28:39.763Z daemon INFO time="2025-05-08T23:28:39+04:00" level=info msg="Loading package m5stack from: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware"
time="2025-05-08T23:28:39+04:00" level=info msg="Missing signature file" index="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\2.1.4\\installed.json"
2025-05-08T19:28:39.782Z daemon INFO time="2025-05-08T23:28:39+04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded platform" platform="m5stack:esp32@2.1.4"
time="2025-05-08T23:28:39+04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\m5stack\\tools"
time="2025-05-08T23:28:39+04:00" level=info msg="Loading tools from dir: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\m5stack\\tools"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="m5stack:esptool_py@4.5.1"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="m5stack:mklittlefs@3.0.0-gnu12-dc7f933"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="m5stack:mkspiffs@0.2.3"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="m5stack:openocd-esp32@v0.12.0-esp32-20230419"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="m5stack:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="m5stack:riscv32-esp-elf-gdb@11.2_20220823"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="m5stack:xtensa-esp-elf-gdb@11.2_20220823"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="m5stack:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="m5stack:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2025-05-08T23:28:39+04:00" level=info msg="Loaded tool" tool="m5stack:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2025-05-08T19:28:39.819Z daemon INFO time="2025-05-08T23:28:39+04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\2.1.4\\libraries" isSingleLibrary=false location=platform
2025-05-08T19:28:39.823Z daemon INFO time="2025-05-08T23:28:39+04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" isSingleLibrary=false location=platform
2025-05-08T19:28:39.840Z daemon INFO time="2025-05-08T23:28:39+04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
time="2025-05-08T23:28:39+04:00" level=info msg="Loading libraries index file" index="c:\\Users\\politick\\AppData\\Local\\Arduino15\\library_index.json"
2025-05-08T19:28:40.174Z root INFO Deploy plugins list: 718.3 ms [Finished 1.436 s after backend start]
2025-05-08T19:28:40.203Z daemon INFO time="2025-05-08T23:28:40+04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\politick\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-05-08T19:28:40.204Z daemon INFO time="2025-05-08T23:28:40+04:00" level=info msg="Adding libraries dir" dir="c:\\Users\\politick\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-05-08T19:28:40.736Z root INFO creating connection for 1
2025-05-08T19:28:41.611Z discovery-log INFO start resolved watching
2025-05-08T19:28:41.677Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-05-08T19:28:41.677Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-05-08T19:28:41.678Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM4","label":"COM4","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-05-08T19:28:41.678Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM5","label":"COM5","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-05-08T19:28:41.719Z root ERROR Error: spawn UNKNOWN
at u.listen (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:6849258)
at w (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:4320441)
at e.dynamicValue (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:4848888)
at D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:5583234
2025-05-08T19:28:41.790Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 188.2 ms [Finished 2.320 s after frontend start]
2025-05-08T19:28:41.825Z root WARN A command editor.action.toggleStickyScroll is already registered.
2025-05-08T19:28:41.944Z root INFO Start frontend contributions: 410.9 ms [Finished 2.460 s after frontend start]
2025-05-08T19:28:41.945Z root INFO Changed application state from 'init' to 'started_contributions'.
2025-05-08T19:28:41.955Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2025-05-08T19:28:41.956Z root INFO >>> Restoring the layout state...
2025-05-08T19:28:41.986Z root ERROR [4e5f4fc9-ae53-4cf1-90db-acf662473eca] Backend deployment failed.: 62.5 ms [Finished 2.516 s after frontend start]
2025-05-08T19:28:41.987Z root ERROR Failed to load plugins: Error: spawn UNKNOWN
at f.fork (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:149590)
at f.runPluginServer (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:148727)
at c.runPluginServer (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:4042919)
at h.getDeployedPluginIds (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:5458331)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async u.onRequest (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:2704705)
[10052:0508/232842.068:ERROR:gpu_process_host.cc(997)] GPU process exited unexpectedly: exit_code=34
[10052:0508/232842.705:ERROR:gpu_process_host.cc(997)] GPU process exited unexpectedly: exit_code=34
[2064:0508/232843.276:ERROR:command_buffer_proxy_impl.cc(131)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
Marking workspace as a closed sketch. Workspace URI: file:///d%3A/Development/%21line_fallow/sketch_dec5b/sketch_dec5b.ino. Date: 1746732564375.
Closing channel on service path '/services/electron-window'.
Closing channel on service path '/services/ide-updater'.
Storing the sketch as a workspace root: <d:\Development\!line_fallow\sketch_dec5b\sketch_dec5b.ino>.
Stored workspaces roots: d:\Development\!line_fallow\sketch_dec5b\sketch_dec5b.ino
No sketches were scheduled for deletion.
And another
Arduino IDE 2.3.6
Starting backend process. PID: 15184
2025-05-08T19:31:08.812Z root INFO Backend u.initialize: 30.7 ms [Finished 0.700 s after backend start]
2025-05-08T19:31:08.814Z root INFO Backend Object.initialize: 28.7 ms [Finished 0.700 s after backend start]
2025-05-08T19:31:08.814Z root INFO Backend a.initialize: 1.6 ms [Finished 0.700 s after backend start]
2025-05-08T19:31:08.814Z root INFO Backend a.initialize: 1.3 ms [Finished 0.700 s after backend start]
2025-05-08T19:31:08.814Z root INFO Backend u.initialize: 1.6 ms [Finished 0.700 s after backend start]
2025-05-08T19:31:08.817Z root INFO Backend l.initialize: 30.0 ms [Finished 0.701 s after backend start]
2025-05-08T19:31:08.825Z root INFO configured all backend app contributions
2025-05-08T19:31:08.825Z root INFO Backend l.onStart: 1.3 ms [Finished 0.714 s after backend start]
2025-05-08T19:31:08.826Z root INFO Backend d.onStart: 0.1 ms [Finished 0.714 s after backend start]
2025-05-08T19:31:08.827Z root INFO Backend a.onStart: 0.4 ms [Finished 0.714 s after backend start]
2025-05-08T19:31:08.827Z config INFO >>> Initializing CLI configuration...
2025-05-08T19:31:08.827Z root INFO Backend x.onStart: 0.4 ms [Finished 0.715 s after backend start]
2025-05-08T19:31:08.827Z config INFO Loading CLI configuration from c:\Users\politick\.arduinoIDE\arduino-cli.yaml...
2025-05-08T19:31:08.827Z daemon INFO Starting daemon from D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-05-08T19:31:08.827Z root INFO Backend w.onStart: 0.6 ms [Finished 0.716 s after backend start]
2025-05-08T19:31:08.828Z discovery-log INFO start
2025-05-08T19:31:08.828Z discovery-log INFO start new deferred
2025-05-08T19:31:08.828Z root INFO Backend v.onStart: 0.4 ms [Finished 0.716 s after backend start]
2025-05-08T19:31:08.828Z root INFO Backend a.onStart: 0.1 ms [Finished 0.716 s after backend start]
2025-05-08T19:31:08.834Z root INFO Theia app listening on http://127.0.0.1:50317.
2025-05-08T19:31:08.834Z root INFO Finished starting backend application: 6.3 ms [Finished 0.723 s after backend start]
2025-05-08T19:31:08.835Z root WARN The local plugin referenced by local-dir:/c%3A/Users/politick/.arduinoIDE/plugins does not exist.
2025-05-08T19:31:08.835Z root WARN The local plugin referenced by local-dir:/c%3A/Users/politick/.arduinoIDE/deployedPlugins does not exist.
2025-05-08T19:31:08.835Z root WARN The local plugin referenced by local-dir:C:\Users\politick\.arduinoIDE\plugins does not exist.
2025-05-08T19:31:08.839Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["http://arduino.esp8266.com/stable/package_esp8266com_index.json","https://static-cdn.m5stack.com/resource/arduino/package_m5stack_index.json"]},"directories":{"builtin":{"libraries":"C:\\Users\\politick\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\politick\\AppData\\Local\\Arduino15","user":"c:\\Users\\politick\\Documents\\Arduino"},"locale":"ru"}
2025-05-08T19:31:08.839Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2025-05-08T19:31:08.839Z config INFO Loaded the CLI configuration.
2025-05-08T19:31:08.858Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/politick/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/politick/Documents/Arduino","additionalUrls":["http://arduino.esp8266.com/stable/package_esp8266com_index.json","https://static-cdn.m5stack.com/resource/arduino/package_m5stack_index.json"],"network":"none","locale":"ru"}
2025-05-08T19:31:08.858Z config INFO Validating the CLI configuration...
2025-05-08T19:31:08.859Z config INFO The CLI config is valid.
2025-05-08T19:31:08.859Z config INFO <<< Initialized the CLI configuration.
2025-05-08T19:31:08.918Z root INFO Resolve plugins list: 87.7 ms [Finished 0.806 s after backend start]
2025-05-08T19:31:08.984Z daemon INFO time="2025-05-08T23:31:08+04:00" level=info msg="arduino-cli version 1.2.0"
time="2025-05-08T23:31:08+04:00" level=info msg="Using config file: c:\\Users\\politick\\.arduinoIDE\\arduino-cli.yaml"
time="2025-05-08T23:31:08+04:00" level=info msg="Executing `arduino-cli daemon`"
╨Ф╨╡╨╝╨╛╨╜ ╤Б╨╡╨╣╤З╨░╤Б ╤Б╨╗╤Г╤И╨░╨╡╤В 127.0.0.1: 50318
{"IP":"127.0.0.1","Port":"50318"}
2025-05-08T19:31:08.984Z daemon INFO Daemon is running.
2025-05-08T19:31:09.087Z daemon INFO time="2025-05-08T23:31:09+04:00" level=info msg="Checking signature" index="c:\\Users\\politick\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\politick\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2025-05-08T19:31:09.121Z daemon INFO time="2025-05-08T23:31:09+04:00" level=info msg="Missing signature file" index="c:\\Users\\politick\\AppData\\Local\\Arduino15\\package_esp8266com_index.json"
time="2025-05-08T23:31:09+04:00" level=info msg="Missing signature file" index="c:\\Users\\politick\\AppData\\Local\\Arduino15\\package_m5stack_index.json"
time="2025-05-08T23:31:09+04:00" level=info msg="Loading hardware from: c:\\Users\\politick\\AppData\\Local\\Arduino15\\packages"
time="2025-05-08T23:31:09+04:00" level=info msg="Loading package arduino from: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2025-05-08T23:31:09+04:00" level=info msg="Missing signature file" index="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2025-05-08T23:31:09+04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2025-05-08T23:31:09+04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-05-08T23:31:09+04:00" level=info msg="Loading tools from dir: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
2025-05-08T19:31:09.134Z daemon INFO time="2025-05-08T23:31:09+04:00" level=info msg="Loading package builtin from: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2025-05-08T23:31:09+04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-05-08T23:31:09+04:00" level=info msg="Loading tools from dir: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@0.9.2"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.0.0"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.0-rc1"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
time="2025-05-08T23:31:09+04:00" level=info msg="Loading package esp8266 from: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
time="2025-05-08T23:31:09+04:00" level=info msg="Missing signature file" index="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\installed.json"
2025-05-08T19:31:09.177Z daemon INFO time="2025-05-08T23:31:09+04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
time="2025-05-08T23:31:09+04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2025-05-08T23:31:09+04:00" level=info msg="Loading tools from dir: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
2025-05-08T19:31:09.177Z daemon INFO time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
2025-05-08T19:31:09.177Z daemon INFO time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
2025-05-08T19:31:09.190Z daemon INFO time="2025-05-08T23:31:09+04:00" level=info msg="Loading package m5stack from: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware"
2025-05-08T19:31:09.195Z daemon INFO time="2025-05-08T23:31:09+04:00" level=info msg="Missing signature file" index="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\2.1.4\\installed.json"
2025-05-08T19:31:09.216Z daemon INFO time="2025-05-08T23:31:09+04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded platform" platform="m5stack:esp32@2.1.4"
time="2025-05-08T23:31:09+04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\m5stack\\tools"
time="2025-05-08T23:31:09+04:00" level=info msg="Loading tools from dir: C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\m5stack\\tools"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="m5stack:esptool_py@4.5.1"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="m5stack:mklittlefs@3.0.0-gnu12-dc7f933"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="m5stack:mkspiffs@0.2.3"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="m5stack:openocd-esp32@v0.12.0-esp32-20230419"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="m5stack:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="m5stack:riscv32-esp-elf-gdb@11.2_20220823"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="m5stack:xtensa-esp-elf-gdb@11.2_20220823"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="m5stack:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="m5stack:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
2025-05-08T19:31:09.217Z daemon INFO time="2025-05-08T23:31:09+04:00" level=info msg="Loaded tool" tool="m5stack:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2025-05-08T19:31:09.272Z daemon INFO time="2025-05-08T23:31:09+04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
time="2025-05-08T23:31:09+04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" isSingleLibrary=false location=platform
2025-05-08T19:31:09.274Z daemon INFO time="2025-05-08T23:31:09+04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\politick\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\2.1.4\\libraries" isSingleLibrary=false location=platform
time="2025-05-08T23:31:09+04:00" level=info msg="Loading libraries index file" index="c:\\Users\\politick\\AppData\\Local\\Arduino15\\library_index.json"
2025-05-08T19:31:09.526Z root INFO Deploy plugins list: 696.4 ms [Finished 1.415 s after backend start]
2025-05-08T19:31:09.618Z daemon INFO time="2025-05-08T23:31:09+04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\politick\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-05-08T19:31:09.619Z daemon INFO time="2025-05-08T23:31:09+04:00" level=info msg="Adding libraries dir" dir="c:\\Users\\politick\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-05-08T19:31:10.124Z root INFO creating connection for 1
2025-05-08T19:31:11.136Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 142.7 ms [Finished 2.292 s after frontend start]
2025-05-08T19:31:11.174Z root WARN A command editor.action.toggleStickyScroll is already registered.
2025-05-08T19:31:11.207Z discovery-log INFO start resolved watching
2025-05-08T19:31:11.213Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <d:\Development\!line_fallow\sketch_dec5b\sketch_dec5b.ino>, response: <d:\Development\!line_fallow\sketch_dec5b>.
2025-05-08T19:31:11.305Z root INFO Start frontend contributions: 379.3 ms [Finished 2.447 s after frontend start]
2025-05-08T19:31:11.305Z root INFO Changed application state from 'init' to 'started_contributions'.
2025-05-08T19:31:11.317Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2025-05-08T19:31:11.318Z root INFO >>> Restoring the layout state...
2025-05-08T19:31:11.356Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-05-08T19:31:11.356Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-05-08T19:31:11.357Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM4","label":"COM4","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-05-08T19:31:11.357Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM5","label":"COM5","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-05-08T19:31:11.366Z root INFO [edf6ce9c-704f-4eb8-a33f-1b17a04174e2] Waiting for backend deployment: 76.9 ms [Finished 2.518 s after frontend start]
2025-05-08T19:31:11.654Z root ERROR [hosted-plugin: 13276] <--- Last few GCs --->
[13276:0000043800318000] 128 ms: Scavenge 2.1 (4.3) -> 1.8 (4.3) MB, pooled: 0 MB, 1.38 / 0.00 ms (average mu = 1.000, current mu = 1.000) allocation failure;
1: 00007FF73475FA6A
2: 00007FF7346DAB8E
3: 00007FF73781CBF4
4: 00007FF73781CB63
5: 00007FF7378CEC67
6: 00007FF73322330A
7: 00007FF73320ABFA
8: 00007FF73320A139
9: 00007FF733213A6E
2025-05-08T19:31:11.654Z daemon INFO time="2025-05-08T23:31:11+04:00" level=error msg="Killing discovery process: TerminateProcess: Access is denied." discovery="builtin:dfu-discovery"
time="2025-05-08T23:31:11+04:00" level=info msg="Discovery event channel closed builtin:dfu-discovery. Exiting goroutine."
time="2025-05-08T23:31:11+04:00" level=error msg="Killing discovery process: TerminateProcess: Access is denied." discovery="builtin:mdns-discovery"
time="2025-05-08T23:31:11+04:00" level=info msg="Discovery event channel closed builtin:mdns-discovery. Exiting goroutine."
time="2025-05-08T23:31:11+04:00" level=error msg="Waiting discovery process termination: exit status 2" discovery="builtin:mdns-discovery"
time="2025-05-08T23:31:11+04:00" level=error msg="Stopped decode loop: EOF" discovery="builtin:mdns-discovery"
time="2025-05-08T23:31:11+04:00" level=error msg="Waiting discovery process termination: exit status 2" discovery="builtin:dfu-discovery"
time="2025-05-08T23:31:11+04:00" level=error msg="Stopped decode loop: EOF" discovery="builtin:dfu-discovery"
2025-05-08T19:31:12.034Z root INFO socked closed
2025-05-08T19:31:12.034Z root INFO closing connection for 1
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/localization-server'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/os'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/commands'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/keyboard'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/logger'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/messageService'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/ChannelCloseService'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/remote-filesystem'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/envs'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/authentication-service'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/sketches-service'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/config-service'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/workspace'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/notification-service'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/arduino-daemon'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/stopwatch'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/application'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/i18n'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/quickInput'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/debug'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/shell-terminal'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/quickPick'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/task'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/search'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/hostedPlugin'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/plugin-ext'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/plugin-paths'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/cli-preferences'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/boards-service'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/response-service'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/file-system-ext'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/core-service'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/example-service'.
2025-05-08T19:31:12.034Z root INFO Closing channel on service path '/services/library-service'.
2025-05-08T19:31:12.035Z root INFO Closing channel on service path '/services/executable-service'.
2025-05-08T19:31:12.035Z root INFO Closing channel on service path '/services/arduino-firmware-uploader'.
2025-05-08T19:31:12.035Z root INFO Closing channel on service path '/services/formatter'.
2025-05-08T19:31:12.035Z root INFO Closing channel on service path '/services/search-in-workspace'.
2025-05-08T19:31:12.035Z root ERROR Error from plugin host: write EPIPE
2025-05-08T19:31:26.611Z root ERROR Uncaught Exception: Error: Child process has been terminated
2025-05-08T19:31:26.611Z root ERROR Error: Child process has been terminated
at ChildProcess.<anonymous> (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\main.js:2:4710087)
at Object.onceWrapper (node:events:634:26)
at ChildProcess.emit (node:events:531:35)
at ChildProcess._handle.onexit (node:internal/child_process:294:12)
Marking workspace as a closed sketch. Workspace URI: file:///d%3A/Development/%21line_fallow/sketch_dec5b/sketch_dec5b.ino. Date: 1746732693961.
Marking workspace as a closed sketch. Workspace URI: file:///d%3A/Development/%21line_fallow/sketch_dec5b/sketch_dec5b.ino. Date: 1746732693987.
Error sending from webFrameMain: Error: Render frame was disposed before WebFrameMain could be accessed
at s.send (node:electron/js2c/browser_init:2:88846)
at _.send (node:electron/js2c/browser_init:2:73458)
at e.sendWindowEvent (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\electron-main.js:5:1694934)
at BrowserWindow.<anonymous> (D:\Development\ArduinoIDE\Arduino IDE\resources\app\lib\backend\electron-main.js:5:229495)
at BrowserWindow.emit (node:events:531:35)
Skipped storing sketch as workspace root. Already visited: <d:\Development\!line_fallow\sketch_dec5b\sketch_dec5b.ino>.
looks like I'm getting different errors every time
