New one for you.
No OneDrive
Documents folder is an SMB mount
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Install the latest PowerShell for new features and improvements! https://aka.ms/PSWindows
PS C:\Users\sraas\AppData\Local\Programs\Arduino IDE> $Env:GRPC_VERBOSITY = "DEBUG"
PS C:\Users\sraas\AppData\Local\Programs\Arduino IDE> $Env:GRPC_TRACE = "all"
PS C:\Users\sraas\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
D 2022-12-09T23:13:29.074Z | index | Loading @grpc/grpc-js version 1.6.8
Arduino IDE 2.0.3
Starting backend process. PID: 220732
D 2022-12-09T23:13:30.190Z | index | Loading @grpc/grpc-js version 1.6.8
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/sraas/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2022-12-09T23:13:30.404Z root INFO Backend Object.initialize: 3.6 ms [Finished 1.219 s after backend start]
2022-12-09T23:13:30.404Z root INFO Backend Object.configure: 2.8 ms [Finished 1.219 s after backend start]
2022-12-09T23:13:30.404Z root INFO Backend MessagingContribution.onStart: 1.3 ms [Finished 1.219 s after backend start]
2022-12-09T23:13:30.405Z root INFO Backend OSBackendApplicationContribution.configure: 0.4 ms [Finished 1.251 s after backend start]
2022-12-09T23:13:30.405Z root INFO Backend DefaultWorkspaceServer.onStart: 0.4 ms [Finished 1.251 s after backend start]
2022-12-09T23:13:30.406Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.2 ms [Finished 1.251 s after backend start]
2022-12-09T23:13:30.407Z root INFO Backend PluginLocalizationBackendContribution.initialize: 32.5 ms [Finished 1.252 s after backend start]
2022-12-09T23:13:30.407Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.252 s after backend start]
2022-12-09T23:13:30.408Z root INFO Backend ElectronTokenBackendContribution.configure: 0.8 ms [Finished 1.253 s after backend start]
2022-12-09T23:13:30.408Z root INFO Backend PluginDeployerContribution.initialize: 0.4 ms [Finished 1.253 s after backend start]
2022-12-09T23:13:30.409Z root INFO Backend ConfigServiceImpl.onStart: 0.7 ms [Finished 1.253 s after backend start]
2022-12-09T23:13:30.410Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.4 ms [Finished 1.254 s after backend start]
2022-12-09T23:13:30.410Z root INFO Backend ArduinoDaemonImpl.onStart: 0.9 ms [Finished 1.255 s after backend start]
2022-12-09T23:13:30.410Z root INFO Backend NodeFileUploadService.configure: 1.8 ms [Finished 1.255 s after backend start]
2022-12-09T23:13:30.410Z daemon INFO Starting daemon from C:\Users\sraas\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2022-12-09T23:13:30.410Z discovery-log INFO start
2022-12-09T23:13:30.410Z discovery-log INFO start new deferred
2022-12-09T23:13:30.410Z root INFO Backend HostedPluginLocalizationService.initialize: 0.4 ms [Finished 1.256 s after backend start]
2022-12-09T23:13:30.410Z root INFO Backend BoardDiscovery.onStart: 0.8 ms [Finished 1.256 s after backend start]
2022-12-09T23:13:30.411Z root INFO Backend FileDownloadEndpoint.configure: 0.7 ms [Finished 1.257 s after backend start]
2022-12-09T23:13:30.411Z root INFO Backend AuthenticationServiceImpl.onStart: 0.3 ms [Finished 1.258 s after backend start]
2022-12-09T23:13:30.411Z root INFO Backend PluginApiContribution.configure: 0.4 ms [Finished 1.258 s after backend start]
2022-12-09T23:13:30.412Z root INFO Backend HostedPluginReader.configure: 0.4 ms [Finished 1.259 s after backend start]
2022-12-09T23:13:30.412Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 1.259 s after backend start]
2022-12-09T23:13:30.412Z root INFO Backend PlotterBackendContribution.configure: 0.8 ms [Finished 1.260 s after backend start]
2022-12-09T23:13:30.415Z root INFO Theia app listening on http://localhost:52179.
2022-12-09T23:13:30.416Z root INFO Finished starting backend application: 5.2 ms [Finished 1.263 s after backend start]
2022-12-09T23:13:30.423Z root WARN The local plugin referenced by local-dir:/c%3A/Users/sraas/.arduinoIDE/plugins does not exist.
2022-12-09T23:13:30.423Z root WARN The local plugin referenced by local-dir:/c%3A/Users/sraas/.arduinoIDE/extensions does not exist.
2022-12-09T23:13:30.424Z root WARN The local plugin referenced by local-dir:C:\Users\sraas\.arduinoProIDE\plugins does not exist.
2022-12-09T23:13:30.439Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-09T23:13:30.439Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2022-12-09T23:13:30.439Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
2022-12-09T23:13:30.439Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2022-12-09T23:13:30.440Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-09T23:13:30.440Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2022-12-09T23:13:30.440Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2022-12-09T23:13:30.440Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2022-12-09T23:13:30.440Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2022-12-09T23:13:30.440Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2022-12-09T23:13:30.440Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2022-12-09T23:13:30.441Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2022-12-09T23:13:30.441Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-09T23:13:30.441Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2022-12-09T23:13:30.441Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2022-12-09T23:13:30.441Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2022-12-09T23:13:30.441Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2022-12-09T23:13:30.441Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2022-12-09T23:13:30.442Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-09T23:13:30.442Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2022-12-09T23:13:30.442Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2022-12-09T23:13:30.442Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2022-12-09T23:13:30.442Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2022-12-09T23:13:30.442Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2022-12-09T23:13:30.443Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-09T23:13:30.443Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2022-12-09T23:13:30.456Z root INFO Resolve plugins list: 46.5 ms [Finished 1.303 s after backend start]
2022-12-09T23:13:30.460Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Users\sraas\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 3.8 ms [Finished 1.307 s after backend start]
2022-12-09T23:13:30.461Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2022-12-09T23:13:30.461Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
at Socket.<anonymous> (C:\Users\sraas\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\arduino-daemon-impl.js:219:42)
at Socket.emit (node:events:394:28)
at addChunk (node:internal/streams/readable:312:12)
at readableAddChunk (node:internal/streams/readable:287:9)
at Socket.Readable.push (node:internal/streams/readable:226:10)
at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2022-12-09T23:13:30.461Z daemon INFO Starting daemon from C:\Users\sraas\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2022-12-09T23:13:30.466Z daemon INFO time="2022-12-09T17:13:30-06:00" level=error msg="Unable to get Documents Folder: The system cannot find the path specified."
