Ide is not recognizing the keyboard library
I am trying to make a button box keyboard with an Arduino Nano, but IDE seems to be unable to recognize the commands for the library. It doesn't generate and error for the "#include <Keyboard.h>", only for the attempts to use functions from the library. The file location is set correctly in preferences and the library is downloaded, I have tried redownloading it by several methods, nothing has worked. please help.
Error code:
F:\4 - Projects\DEWYED\PE Electronics\PE 100 Arduino\PE 110 Sketches\PE 111 Keyboard\sketch_jul10a\sketch_jul10a.ino: In function 'void setup()':
F:\4 - Projects\DEWYED\PE Electronics\PE 100 Arduino\PE 110 Sketches\PE 111 Keyboard\sketch_jul10a\sketch_jul10a.ino:16:1: error: 'Keyboard' was not declared in this scope
 Keyboard.begin();
F:\4 - Projects\DEWYED\PE Electronics\PE 100 Arduino\PE 110 Sketches\PE 111 Keyboard\sketch_jul10a\sketch_jul10a.ino: In function 'void loop()':
F:\4 - Projects\DEWYED\PE Electronics\PE 100 Arduino\PE 110 Sketches\PE 111 Keyboard\sketch_jul10a\sketch_jul10a.ino:24:5: error: 'Keyboard' was not declared in this scope
     Keyboard.write('A');                            //Sending the "A" character
exit status 1
Compilation error: 'Keyboard' not found. Does your sketch include the line '#include <Keyboard.h
My code:
int pinA = 2;                                       //Declaring variables for the pins
int pinB = 3;
int pinC = 4;
int pinD = 5;
int pinE = 6;
pinMode(pinA, INPUT_PULLUP);                        //Setting up the internal pull-ups resistors
pinMode(pinB, INPUT_PULLUP);                        //and also setting the pins to inputs.
pinMode(pinC, INPUT_PULLUP);
pinMode(pinD, INPUT_PULLUP);
pinMode(pinE, INPUT_PULLUP);
Keyboard.begin();
  if (digitalRead(pinA) == LOW)                     //Checking if the first switch has been pressed
If this is in the wrong category let me know.
From the Keyboard library reference page
Compatible Hardware
HID is supported on the following boards:
Board Supported Pins
Leonardo All digital & analog pins >
Micro All digital & analog pins
Due All digital & analog pins
Zero All digital & analog pins
UNO R4 Minima All digital & analog pins
UNO R4 WiFi All digital & analog pins
GIGA R1 WiFi All digital & analog pins
Nano ESP32 All digital & analog pins
MKR Family All digital & analog pins
The Nano is not on the list. It will not work with the Keyboard library.
USB OTG Host and device also work on the ESP32-S3
some ESP32-S3 modules have a second USB connector for connecting USB OTG devices, e.g. ESP32-S3-DevKitC-1 v1.1
