I am planning to add support for the IDE so that multiple library locations can be used when compiling a project. This way, libraries would be easier to track and update across multiple projects.
Reason:
When the Arduino IDE is installed into /usr/share/arduino/ it is difficalt to add 3rd party libraries, if not imposible when you don't have admin.
How:
Besides using the default 'arduino/libraries/' location I would also like to use '~/.arduino/libraries/'.
Any feed-back or requests?
From - Libraries - Arduino Reference -
If you're using one of these libraries, you need to install it first. To do so, download the library and unzip it. It should be in a folder of its own, and will typically contain at least two files, one with a .h suffix and one with a .cpp suffix. Open your Arduino sketchbook folder. If there is already a folder there called libraries, place the library folder in there. If not, create a folder called libraries in the sketchbook folder, and drop the library folder in there. Then re-start the Arduino programming environment, and you should see your new library in the Sketch > Import Library menu.
So, you can put libraries in your sketchbook besides your project folders, no need for admin rights I assume (although I never used Arduino under Linux)
Rob
I do understand that is an option when using 3rd party libraries. When I am creating and using libraries at the same time, I don't want to have to update every project after something is changed. This could be done by creating symbolic links, but this can only be done using *nix systems.
Use case:
I am creating a WiiRemote library to help teach programming to some at a FIRST club at a local highschool. It is rather rough right now and I plan to clean it up soon. They are already using it for several projects, but I would like it so that they could just pull from my git repo when I add improvements.
To be honest, I use vim and scon when working with the Arduino platform. This just seemed to a nice feature to add to the IDE and I wanted to contribute to this awesome project. Maybe I should do something off the to-do list...
P.S. sorry for the long time between post, life got crazy for awhile
