IDE stopped communicating with mega
I was uploading a sketch and all of the sudden I started getting errors:
Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 56496 bytes (22%) of program storage space. Maximum is 253952 bytes.
Global variables use 1978 bytes (24%) of dynamic memory, leaving 6214 bytes for local variables. Maximum is 8192 bytes.
avrdude: ser_open(): can't open device "\.\COM5": Access is denied.
avrdude: ser_drain(): read error: The handle is invalid.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: The handle is invalid.
avrdude: stk500v2_ReceiveMessage(): timeout
the selected serial port avrdude: stk500_send(): failed to send command to serial port
does not exist or your board is not connected
avrdude: stk500v2_getsync(): timeout communicating with programmer
option enabled in File -> Preferences.
I am on a windows 7 machine, under device manager I see the mega on com5.
Any help would be great.
This means something has that port open. If you have another application using COM5 then you will need to close it. Otherwise just restart your computer and that should solve the problem.
