Please Read how to use the forum. Especially the part about code tags, posting a complete program and posting the complete error!
But I can tell you, BOTH statements are wrong. The byte keyword tells the compiler to create a NEW variable which is initialized to an unknown value. So pretty useless to make a comparison against that. If you want to check against an already initialized variable called 'counter', drop the byte keyword.
thanks for the quick reply. It compiled atleast. but it doesn't work as planned. heh. any suggestions? It seems to cycle thru the byte counter entirely at the press of my button
You still have the same problem in other places. This line:
avender:
byte counter = counter + 1;
Creates a variable named counter that is local to the if statement. If you wanted to change the value of the global variable named counter, then you need to remove the "byte".
