I am not able to figure out how to make an if-then statement with a sensor. I am using an Adafruit Floraboard. I need a Neopixel to light up if the UV sensor value goes too high. How would I go about programming this?
I don't know what exact commands to use to read your sensor or light up your pixels, but pseudo code something like this:
read the sensor
if (sensor reading > some threshold)
turn on the neopixel
turn off the neopixel
Perhaps id you posted you code so far you will get more specific help?
You may need to ad some hysteresis if things sit at the threshold.
if (sensor reading >= threshold)
else if (sensor reading < threshold - hysteresis )
OR
if (sensor reading >= threshold - hysteresis)
hysteresis = 1; //or some value
hysteresis = 0;
Konstantinr:
boolean sensorIsTooHigh = false;
boolean sensorWasTooHigh = sensorIsTooHigh;
sensorIsTooHigh = is_the_sensor_tooHigh();
if(sensorWasTooHigh && !sensorIsTooHigh) {
turn_the_neopixels_off();
else if(!sensorWasTooHigh && sensorIsTooHigh) {
turn_the_neopixels_on();
// else do nothing - leave the pixels as they are.
