Hello,
I have made a box to monitor my nodes around the house (like a security control panel) and the program enclosed will give you an idea about the structure. My mqtt server is running on a Pi4 with mosquitto and node-red.
I also have node-red client running on a PC without any problems.
And the problem is my monitor box ignores and subscriptions greater than 15 (out of 20) and swapping subscriptions proved it too. Also played with number inside “while ((subscription = mqtt.readSubscription(5000))) “ with no avail. So I appreciate any help.
// c8:2b:96:2e:d4:89 IP:24
20/11/23 updated: 28/8/25
Arduino IDE 2.3.4
code for NodeMCU v.3 mqtt_monitor
using ESP-12E module in IDE boards
pin nmap-
A0 -
GPIO D Device
16 0 N/O
05 1 i2c pcfx4 + oled (https://www.youtube.com/watch?v=ssB6pJ3JH5w&t=22s)
04 2 i2c same
00 3 pulled-up
02 4 N/O
14 5 alarmreset (button)
12 6 alarmled (led)
13 7 beeper
15 8 software serial-pulled to ground
#include <time.h>
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "Arduino.h"
#include "PCF8574.h"
#include <Wire.h>
#define WLAN_SSID "coke"
#define WLAN_PASS "withbacardis"
#define AIO_SERVER "192.168.1.11"
#define AIO_SERVERPORT 1883
#define AIO_USERNAME ""
#define AIO_KEY ""
#define STASSID "coke"
#define STAPSK "**********"
const int masterledpin = D6;
const int beeppin = D7;
bool SALFLASH = false;
bool firstrun = true;
char message;
int linecounter=0;
int x, minX;
bool deviceActive = false;
PCF8574 cluster1(0x20); // for dead nodes
PCF8574 cluster2(0x21); // for activity
PCF8574 cluster3(0x22); // for warning
PCF8574 cluster4(0x26); // extra
//Timers
long interval = 50000;
long interval1 = 120000;
long screentimer = 30000;
unsigned long previousMillis = 0;
unsigned long previousMillis1 = 0;
unsigned long screentimerMillis = 0;
long intervalive = 180000;
unsigned long previouslives = 0;
bool isitdark = true; //activates after time is installed
WiFiClient client;
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY); //Retain requires lots of workaround so prospone
Adafruit_MQTT_Subscribe GUPANICALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "GUPANICALARM");
Adafruit_MQTT_Subscribe GUTEMPALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "GUTEMPALARM");
Adafruit_MQTT_Subscribe GULDRALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "GULDRALARM");
Adafruit_MQTT_Subscribe WC1PANICALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "WC1PANICALARM");
Adafruit_MQTT_Subscribe WC1TEMPALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "WC1TEMPALARM");
Adafruit_MQTT_Subscribe WC2TEMPALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "WC2TEMPALARM");
Adafruit_MQTT_Subscribe WC1LDRALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "WC1LDRALARM");
Adafruit_MQTT_Subscribe WC1FLOODALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "WC1FLOODALARM");
Adafruit_MQTT_Subscribe WRTEMP1ALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "WRTEMP1ALARM");
Adafruit_MQTT_Subscribe WRTEMP2ALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "WRTEMP2ALARM");
Adafruit_MQTT_Subscribe DETEMPALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "DETEMPALARM");
Adafruit_MQTT_Subscribe DEFLOODALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "DEFLOODALARM");
Adafruit_MQTT_Subscribe DETOOHIGHALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "DETOOHIGHALARM");
Adafruit_MQTT_Subscribe DEPUMP = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "DEPUMP");
Adafruit_MQTT_Subscribe ZETEMPALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "ZETEMPALARM");
Adafruit_MQTT_Subscribe ZELDRALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "ZELDRALARM");
Adafruit_MQTT_Subscribe EBTEMPALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "EBTEMPALARM");
Adafruit_MQTT_Subscribe EBLDRALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "EBLDRALARM");
Adafruit_MQTT_Subscribe SATEMPALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "SATEMPALARM");
Adafruit_MQTT_Subscribe SALDOORALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "SALDOORALARM");
Adafruit_MQTT_Subscribe SALLDRALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "SALLDR");
Adafruit_MQTT_Subscribe MUTEMPALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "MUTEMPALARM");
Adafruit_MQTT_Subscribe IDLDRALARM = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "IDLDRALARM");
//local vars to be used later for post processing of alarms
String WC1PANICALARMLOCAL ="";
String WC1TEMPALARMLOCAL ="";
String WC2TEMPALARMLOCAL ="";
String WC1LDRALARMLOCAL ="";
String WC1FLOODALARMLOCAL ="";
String WRTEMP1ALARMLOCAL ="";
String WRTEMP2ALARMLOCAL ="";
String DETEMPALARMLOCAL ="";
String DEFLOODALARMLOCAL ="";
String DEPUMPLOCAL ="";
String DETOOHIGHALARMLOCAL ="";
String SATEMPALARMLOCAL ="";
String SALDOORALARMLOCAL ="";
String SALLDRALARMLOCAL ="";
String IDLDRALARMLOCAL ="";
String MUTEMPALARMLOCAL ="";
String ZETEMPALARMLOCAL ="";
String ZELDRALARMLOCAL ="";
String EBTEMPALARMLOCAL ="";
String EBLDRALARMLOCAL ="";
String GUPANICALARMLOCAL ="";
String GULDRALARMLOCAL ="";
String GUTEMPALARMLOCAL ="";
void MQTT_connect();
Wire.begin();
WiFi.begin(WLAN_SSID, WLAN_PASS);
while (WiFi.status() != WL_CONNECTED)
magazine(); //subscriptions
Serial.println("before OTA");
ArduinoOTA.onStart([]() {
String type;
if (ArduinoOTA.getCommand() == U_FLASH) {
type = "sketch";
} else { // U_SPIFFS
type = "filesystem";
ArduinoOTA.onEnd([]() {
//Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
ArduinoOTA.onError([](ota_error_t error) {
if (error == OTA_AUTH_ERROR) {
} else if (error == OTA_BEGIN_ERROR) {
} else if (error == OTA_CONNECT_ERROR) {
} else if (error == OTA_RECEIVE_ERROR) {
} else if (error == OTA_END_ERROR) {
ArduinoOTA.begin();
//LED Array
cluster1.begin();cluster2.begin();cluster3.begin();cluster4.begin();
cluster1.pinMode(P0, OUTPUT); //IDalarm
cluster1.pinMode(P1, OUTPUT);//Idalive
cluster1.pinMode(P2, OUTPUT);//IDactivity
cluster1.pinMode(P3, OUTPUT);//gualarm
cluster1.pinMode(P4, OUTPUT);//gualive
cluster1.pinMode(P5, OUTPUT);//left red brick led
cluster1.pinMode(P6, OUTPUT);//mid yellow brick led
cluster1.pinMode(P7, OUTPUT);//guactivity
//------------------- green LED WARNING
cluster2.pinMode(P0, OUTPUT);
cluster2.pinMode(P1, OUTPUT);
cluster2.pinMode(P2, OUTPUT);
cluster2.pinMode(P3, OUTPUT);
cluster2.pinMode(P4, OUTPUT);
cluster2.pinMode(P5, OUTPUT);
cluster2.pinMode(P6, OUTPUT);
cluster2.pinMode(P7, OUTPUT);
//------------------ yellow LED ACTIVITY
cluster3.pinMode(P0, OUTPUT);
cluster3.pinMode(P1, OUTPUT);
cluster3.pinMode(P2, OUTPUT);
cluster3.pinMode(P3, OUTPUT);
cluster3.pinMode(P4, OUTPUT);
cluster3.pinMode(P5, OUTPUT);
cluster3.pinMode(P6, OUTPUT);
cluster3.pinMode(P7, OUTPUT);
//------------------ RED LED ACTIVITY
cluster4.pinMode(P0, OUTPUT);
cluster4.pinMode(P1, OUTPUT);
cluster4.pinMode(P2, OUTPUT);
cluster4.pinMode(P3, OUTPUT);
cluster4.pinMode(P4, OUTPUT);
cluster4.pinMode(P5, OUTPUT);
cluster4.pinMode(P6, OUTPUT);
cluster4.pinMode(P7, OUTPUT);
Serial.println("will test");
resetclusters(); //all LOW
selftest();
Serial.println("will enter loop");
ArduinoOTA.handle();
MQTT_connect();
Adafruit_MQTT_Subscribe *subscription;
if (subscription == &WC1PANICALARM)
if (strcmp((char *)WC1PANICALARM.lastread, "0") == 1) {cluster4.digitalWrite(P6, LOW);} else {cluster4.digitalWrite(P6, HIGH);}
Serial.println(" 1 WC1PANIC=");
else if (subscription == &MUTEMPALARM)
if (strcmp((char *)MUTEMPALARM.lastread, "0") == 1) {cluster4.digitalWrite(P0, LOW);} else {cluster4.digitalWrite(P0, HIGH);}
Serial.println(" 2 MUTEMP=");
else if (subscription == &WC1TEMPALARM)
if (strcmp((char *)WC1TEMPALARM.lastread, "0") == 1) {cluster4.digitalWrite(P6, LOW);} else {cluster4.digitalWrite(P6, HIGH);}
Serial.println(" 3 WC1TEMP=");
else if (subscription == &GUPANICALARM)
if (strcmp((char *)GUPANICALARM.lastread, "0") == 1) {cluster1.digitalWrite(P3, LOW);} else {cluster1.digitalWrite(P3, HIGH);}
Serial.println(" 4 GUPANIC=");
else if (subscription == &WC1FLOODALARM)
if (strcmp((char *)WC1FLOODALARM.lastread, "0") == 1) {cluster4.digitalWrite(P6, LOW);} else {cluster4.digitalWrite(P6, HIGH);}
Serial.println(" 5 WC1FLOOD=");
else if (subscription == &WC1LDRALARM)
if (strcmp((char *)WC1LDRALARM.lastread, "0") == 1) {cluster2.digitalWrite(P6, LOW);} else {cluster2.digitalWrite(P6, HIGH);}
Serial.println(" 6 WC1LDR=");
else if (subscription == &ZELDRALARM)
if (strcmp((char *)ZELDRALARM.lastread, "0") == 1) {cluster2.digitalWrite(P2, LOW);} else {cluster2.digitalWrite(P2, HIGH);}
Serial.println(" 7 ZELDR=");
else if (subscription == &GULDRALARM)
if (strcmp((char *)GULDRALARM.lastread, "0") == 1) {cluster1.digitalWrite(P7, LOW);} else {cluster1.digitalWrite(P7, HIGH);}
Serial.println(" 8 GULDR=");
else if (subscription == &WRTEMP1ALARM)
if (strcmp((char *)WRTEMP1ALARM.lastread, "0") == 1) {cluster4.digitalWrite(P5, LOW);} else {cluster4.digitalWrite(P5, HIGH);}
Serial.println(" 9 WRTEMP=");
else if (subscription == &WRTEMP2ALARM)
if (strcmp((char *)WRTEMP2ALARM.lastread, "0") == 1) {cluster4.digitalWrite(P5, LOW);} else {cluster4.digitalWrite(P5, HIGH);}
Serial.println(" 10 WRTEMP2=");
else if (subscription == &DETEMPALARM)
if (strcmp((char *)DETEMPALARM.lastread, "0") == 1) {cluster4.digitalWrite(P7, LOW);} else {cluster4.digitalWrite(P7, HIGH);}
Serial.println(" 11 DETEMP=");
else if (subscription == &GUTEMPALARM)
if (strcmp((char *)GUTEMPALARM.lastread, "0") == 1) {cluster1.digitalWrite(P5, LOW);} else {cluster1.digitalWrite(P5, HIGH);}
Serial.println(" 12 GUTEMP=");
else if (subscription == &DEFLOODALARM)
if (strcmp((char *)DEFLOODALARM.lastread, "0") == 1) {cluster4.digitalWrite(P7, LOW);} else {cluster4.digitalWrite(P7, HIGH);}
Serial.println(" 13 DEFLOOD=");
else if (subscription == &DEPUMP)
if (strcmp((char *)DEPUMP.lastread, "0") == 1) {cluster2.digitalWrite(P7, LOW);} else {cluster2.digitalWrite(P7, HIGH);}
Serial.println(" 14 DEPUMP=");
else if (subscription == &ZETEMPALARM)
if (strcmp((char *)ZETEMPALARM.lastread, "0") == 1) {cluster4.digitalWrite(P2, LOW);} else {cluster4.digitalWrite(P2, HIGH);}
Serial.println(" 15 ZETEMP=");
//From here after nothing works
else if (subscription == &EBTEMPALARM)
if (strcmp((char *)EBTEMPALARM.lastread, "0") == 1) {cluster4.digitalWrite(P3, LOW);} else {cluster4.digitalWrite(P3, HIGH);}
Serial.println(" 16 EBTEMP=");
else if (subscription == &EBLDRALARM)
if (strcmp((char *)EBLDRALARM.lastread, "0") == 1) {cluster2.digitalWrite(P3, LOW);} else {cluster2.digitalWrite(P3, HIGH);}
Serial.println(" 17 EBLDR=");
else if (subscription == &SATEMPALARM)
if (strcmp((char *)SATEMPALARM.lastread, "0") == 1) {cluster4.digitalWrite(P1, LOW);} else {cluster4.digitalWrite(P1, HIGH);}
Serial.println(" 18 SATEMP=");
else if (subscription == &SALDOORALARM)
if (strcmp((char *)SALDOORALARM.lastread, "0") == 1) {cluster1.digitalWrite(P0, LOW);} else {cluster1.digitalWrite(P0, HIGH);}
Serial.println(" 19 SALDOOR=");
else if (subscription == &SALLDRALARM)
if (strcmp((char *)SALLDRALARM.lastread, "0") == 1) {cluster1.digitalWrite(P5, LOW);} else {cluster1.digitalWrite(P5, HIGH);}
Serial.println(" 20 SALLDR=");
processalarm();
if(! mqtt.ping()) {mqtt.disconnect();}
void processalarm() //further processing bells etc..
void beepfire()
cluster1.digitalWrite(P5, LOW);cluster1.digitalWrite(P6, HIGH);tone(beeppin, 1000); delay(75); noTone(beeppin); delay (75);cluster1.digitalWrite(P5, HIGH);cluster1.digitalWrite(P6, LOW); //short beep
delay(3000);
void beeppanic()
delay(3000);
void beepalarm()
void beepflood()
delay(3000);
void MQTT_connect() {int8_t ret;if (mqtt.connected()) {return;}
uint8_t retries = 3;
while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
Serial.println(mqtt.connectErrorString(ret));
Serial.println("Retrying MQTT connection in 5 seconds...");
mqtt.disconnect();
delay(5000); // wait 5 seconds
retries--;
if (retries == 0) {
// basically die and wait for WDT to reset me
while (1);
Serial.println("MQTT Connected!");
void magazine()
mqtt.subscribe(&GUPANICALARM);
mqtt.subscribe(&GUTEMPALARM);
mqtt.subscribe(&GULDRALARM);
mqtt.subscribe(&WC1PANICALARM);
mqtt.subscribe(&WC1TEMPALARM);
mqtt.subscribe(&WC2TEMPALARM);
mqtt.subscribe(&WC1LDRALARM);
mqtt.subscribe(&WC1FLOODALARM);
mqtt.subscribe(&WRTEMP1ALARM);
mqtt.subscribe(&WRTEMP2ALARM);
mqtt.subscribe(&DETEMPALARM);
mqtt.subscribe(&DEFLOODALARM);
mqtt.subscribe(&DETOOHIGHALARM);
mqtt.subscribe(&DEPUMP);
mqtt.subscribe(&ZETEMPALARM);
mqtt.subscribe(&ZELDRALARM);
mqtt.subscribe(&EBTEMPALARM);
mqtt.subscribe(&EBLDRALARM);
mqtt.subscribe(&SATEMPALARM);
mqtt.subscribe(&SALDOORALARM);
mqtt.subscribe(&SALLDRALARM);
mqtt.subscribe(&MUTEMPALARM);
mqtt.subscribe(&IDLDRALARM);
void selftest()
int delayed=50;
delay(delayed);
delay(delayed);
cluster1.digitalWrite(P1, LOW);
delay(delayed);
cluster1.digitalWrite(P1, HIGH);
delay(delayed);
cluster1.digitalWrite(P2, LOW);
delay(delayed);
cluster1.digitalWrite(P2, HIGH);
delay(delayed);
delay(delayed);
delay(delayed);
cluster1.digitalWrite(P4, LOW);
delay(delayed);
cluster1.digitalWrite(P4, HIGH);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
cluster2.digitalWrite(P0, LOW);
delay(delayed);
cluster2.digitalWrite(P0, HIGH);
delay(delayed);
cluster2.digitalWrite(P1, LOW);
delay(delayed);
cluster2.digitalWrite(P1, HIGH);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
cluster2.digitalWrite(P4, LOW);
delay(delayed);
cluster2.digitalWrite(P4, HIGH);
delay(delayed);
cluster2.digitalWrite(P5, LOW);
delay(delayed);
cluster2.digitalWrite(P5, HIGH);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
cluster3.digitalWrite(P0, LOW);
delay(delayed);
cluster3.digitalWrite(P0, HIGH);
delay(delayed);
cluster3.digitalWrite(P1, LOW);
delay(delayed);
cluster3.digitalWrite(P1, HIGH);
delay(delayed);
cluster3.digitalWrite(P2, LOW);
delay(delayed);
cluster3.digitalWrite(P2, HIGH);
delay(delayed);
cluster3.digitalWrite(P3, LOW);
delay(delayed);
cluster3.digitalWrite(P3, HIGH);
delay(delayed);
cluster3.digitalWrite(P4, LOW);
delay(delayed);
cluster3.digitalWrite(P4, HIGH);
delay(delayed);
cluster3.digitalWrite(P5, LOW);
delay(delayed);
cluster3.digitalWrite(P5, HIGH);
delay(delayed);
cluster3.digitalWrite(P6, LOW);
delay(delayed);
cluster3.digitalWrite(P6, HIGH);
delay(delayed);
cluster3.digitalWrite(P7, LOW);
delay(delayed);
cluster3.digitalWrite(P7, HIGH);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
cluster4.digitalWrite(P4, LOW);
delay(delayed);
cluster4.digitalWrite(P4, HIGH);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
delay(delayed);
void resetclusters()
void processlogs() //need to log all incidents into a log file...under construction.. come back later
