Json Parsing Issue
Hopefully this will be a quick one, I am using a ESP32 to read values from a MQTT server over Wi-Fi.
The topic is in this format:
{"time":"15:19:49","windspeed":3,"windgust":10,"wgustTM":16,"YearGustH":39,"winddir":133,"press":29.95,"presstrend":"Rising slowly","temp":42.2,"temptrendtext":"Rising","tempTH":42.5,"tempTL":37.0,"dew":39.2,"heatindex":42.2,"wchill":40.1,"feelslike":40.1,"tempH":96.7,"tempL":-10.6,"outhum":89,"raintoday":0.26,"rainrate":0.00,"rmonth":1.00,"ryear":30.38,"IsRaining":0,"moonphase":"Waning Crescent",}
My code successfully connects and can publish to the MQTT server; however, I can’t figure out how to extract the values for say, "temp":42.2,"
I think I am close but could use some help to get this working!
#include <WiFi.h>
#include <PubSubClient.h>
#include <ArduinoJson.h>
const size_t capacity = JSON_OBJECT_SIZE(2) + JSON_ARRAY_SIZE(2) + 60; // Example capacity
    StaticJsonDocument<capacity> doc;
// WiFi
const char *ssid = "";
const char *password = "";
// MQTT Broker
const char *mqtt_broker = "";
const char *topic = "TEST";
const int mqtt_port = 1883;
WiFiClient espClient;
PubSubClient client(espClient);
    // Set software serial baud to 115200;
    // Connecting to a WiFi network
    WiFi.begin(ssid, password);
        delay(5000);
        Serial.println("Connecting to WiFi..");
    Serial.println("Connected to the Wi-Fi network");
    //connecting to a mqtt broker
    client.setServer(mqtt_broker, mqtt_port);
    client.setCallback(callback);
    while (!client.connected()) {
        String client_id = "esp32-client-";
        client_id += String(WiFi.macAddress());
        if (client.connect(client_id.c_str())) {
            Serial.println("Connected to the MQTT Broker");
            Serial.print("failed with state ");
            Serial.print(client.state());
            delay(2000);
    // Publish and subscribe
   //Client.publish(topic, "Hi, I'm ESP32 ^^");
    client.subscribe("CumulusMX/DataUpdate");
void callback(char *topic, byte *payload, unsigned int length) {
   char jsonString[length + 1];
   memcpy(jsonString, payload, length);
        jsonString[length] = '\0';
        DeserializationError error = deserializeJson(doc, jsonString);
        if (error) {
            Serial.print(F("deserializeJson() failed: "));
            Serial.println(error.f_str());
            return;
    int windspeed = doc["windspeed"];
    int winddir = doc["winddir"];
    float press = doc["press"];
    Serial.println(windspeed);
    Serial.println(winddir);
    client.loop();
Here is formatted result:
  "time": "15:19:49",
  "windspeed": 3,
  "windgust": 10,
  "wgustTM": 16,
  "YearGustH": 39,
  "winddir": 133,
  "press": 29.95,
  "presstrend": "Rising slowly",
  "temp": 42.2,
  "temptrendtext": "Rising",
  "tempTH": 42.5,
  "tempTL": 37.0,
  "dew": 39.2,
  "heatindex": 42.2,
  "wchill": 40.1,
  "feelslike": 40.1,
  "tempH": 96.7,
  "tempL": -10.6,
  "outhum": 89,
  "raintoday": 0.26,
  "rainrate": 0.00,
  "rmonth": 1.00,
  "ryear": 30.38,
  "IsRaining": 0,
  "moonphase": "Waning Crescent"
So you can extract the value for "temp" like this:
float temp = doc["temp"]; // 42.2
I added this to the end of the code
Serial.println(temp);
But I am not seeing any values in the serial monitor
Just this:"
So you could not get the topic message?
Why this line is comment out?
This has a trailing comma, which should cause the JSON parse to fail with InvalidInput. But if that's just a typo, the JSON parsing part works for me after removing that comma
const char *payload{ R"({"time":"15:19:49","windspeed":3,"windgust":10,"wgustTM":16,"YearGustH":39,"winddir":133,"press":29.95,"presstrend":"Rising slowly","temp":42.2,"temptrendtext":"Rising","tempTH":42.5,"tempTL":37.0,"dew":39.2,"heatindex":42.2,"wchill":40.1,"feelslike":40.1,"tempH":96.7,"tempL":-10.6,"outhum":89,"raintoday":0.26,"rainrate":0.00,"rmonth":1.00,"ryear":30.38,"IsRaining":0,"moonphase":"Waning Crescent"})" };
  JsonDocument doc;
  auto length = strlen(payload);
  Serial.print("payload\t");
  Serial.println(jsonString);
  if (error) {
    for (;;);
  delay(2500);
That prints the expected numbers. Note that all the static JSON stuff is deprecated; just use JsonDocument.
I am trying to incorporate your suggestion, this won’t compile for me..
#include <WiFi.h>
// WiFi
const char *ssid = "FRANKWIFI-2.4";
// MQTT Broker
        delay(5000);
    //client.setCallback(callback);
            delay(2000);
  JsonDocument doc;
  if (error) {
    for (;;);
  delay(2500);
    client.loop();
Hi @kenb4 ,
If OP were able to receive the topic message and the JSON data had a trailing ,, OP should see deserializeJson() failed: InvalidInput.
Therefore, I assume that callback() wasn't executed.
That's a good point. When I add Serial.printf("size: %d\n", measureJson(doc)); to your code and I found the size of doc is 392 bytes.
However, capacity is 108, so there's insufficient space.
It helps to include the error. Posting the message verbatim, as <CODE/>, will preserve spacing to indicate the exact position.
But I'm guessing it's because you have two functions named loop
Here is what I am seeing now, I did have two “Void Loop” I commented the one at the end out, but it just created another error.
Arduino: 1.8.19 (Windows 10), Board: "ESP32 Dev Module, Disabled, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None, Disabled, Disabled"
Mqtt-Example-2:80:5: error: 'client' does not name a type; did you mean 'Client'?
   80 |     client.loop();
      |     Client
Mqtt-Example-2:81:1: error: expected declaration before '}' token
   81 | }
exit status 1
option enabled in File -> Preferences.
#include <WiFi.h>
// WiFi
const char *password = "Kiya1020";
// MQTT Broker
const char *mqtt_broker = "192.168.4.53";
        delay(5000);
            delay(2000);
  JsonDocument doc;
  if (error) {
    for (;;);
  delay(2500);
//void loop() {
    client.loop();
Ok, I just renamed that function at the end and the code compiles and runs but it seems to just be returning the values from this line:
I am not seeing the live data from the MQTT server.
#include <WiFi.h>
// WiFi
// MQTT Broker
        delay(5000);
            delay(2000);
  JsonDocument doc;
  if (error) {
    for (;;);
  delay(2500);
void loops() {
    client.loop();
As expected. Did you intend something different?
Not a fan of calling the various clients just client. Try this (I redacted the WiFi credentials)
#include <WiFi.h>
// WiFi
const char *ssid = "yyyy";
const char *password = "zzzz";
// MQTT Broker
WiFiClient wifi;
PubSubClient mqtt(wifi);
void printPayload(const void *payload, unsigned int length) {
  JsonDocument doc;
  if (error) {
    return;
  Serial.print("mqtt callback\t");
  Serial.println(topic);
  printPayload(payload, length);
        delay(5000);
    mqtt.setServer(mqtt_broker, mqtt_port);
    mqtt.setCallback(callback);
    while (!mqtt.connected()) {
        if (mqtt.connect(client_id.c_str())) {
            Serial.print(mqtt.state());
            delay(2000);
    mqtt.subscribe("CumulusMX/DataUpdate");
const char *testPayload{ R"({"time":"15:19:49","windspeed":3,"windgust":10,"wgustTM":16,"YearGustH":39,"winddir":133,"press":29.95,"presstrend":"Rising slowly","temp":42.2,"temptrendtext":"Rising","tempTH":42.5,"tempTL":37.0,"dew":39.2,"heatindex":42.2,"wchill":40.1,"feelslike":40.1,"tempH":96.7,"tempL":-10.6,"outhum":89,"raintoday":0.26,"rainrate":0.00,"rmonth":1.00,"ryear":30.38,"IsRaining":0,"moonphase":"Waning Crescent"})" };
  mqtt.loop();
  static auto testLen = strlen(testPayload);
  static auto last = millis();
  auto now = millis();
  if (now - last > 2500) {
    last = now;
    printPayload(testPayload, testLen);
Yes, I am sure my code is working as it should, but what I am trying to do is subscribe to the MQTT topic ”CumulusMX/DataUpdate” and read the data from there. That topic is updated every 1.5 seconds from my Weather Station.
Thanks Ken, this also runs fine but is not returning the live data from the MQTT connection.
My apologies for the confusion.
#include
<WiFi.h>
// WiFi
// MQTT Broker
WiFiClient wifi;
  JsonDocument doc;
  //Serial.println(jsonString);
  if (error) {
    return;
        delay(5000);
            delay(2000);
  mqtt.loop();
  if (millis() - last > 2500) {
    last = now;
Then you should not be defining a global pointer named payload as "const"
and treating is as a variable that your program can modify internally.
See @kenb4 post above.
I apricate everyone’s help!! Thank you! I am sure my problem is in reading and parsing that topic data.
I will keep at it and let you know when I get it working!
I am still stuck, below is my latest sketch which is bit different than previous attempts.
Again,
I can connect to my MQTT server and publish successfully using the following line (verified using MQTT explorer).
client.publish(topic, "ESP32 Connected! ^^"); // for testing
I added this line to the callback section, but nothing prints to the serial monitor
Serial.print("Message Arrived!");
So I think I am not seeing the incoming messages on the topic “CumulusMX/DataUpdate” for some reason? The json pay load is 630 byts.
I tried expanding the message buffer size as well as subscribing to a smaller topic.
Sorry if this code is a bit of a Frankenstein, I am just getting started at all of this.
FULL SKETCH:
#include <WiFi.h>
// WiFi
// MQTT Broker
const char *topic = "CumulusMX/DataUpdate";
        Serial.println("Connecting to WiFi..");    }
        String client_id = "esp32-client";
            Serial.print("Connected to the MQTT Broker:");
            Serial.print ( topic) ;
            delay(2000);
//client.publish(topic, "ESP32 Connected! ^^"); // for testing
//client.subscribe("CumulusMX/DataUpdate"); // for testing
void callback(char* topic, byte* payload, unsigned int length)
    char messageBuffer[1000];                 //an array to hold the payload
    memcpy(messageBuffer, payload, length);  //copy the payload into the array
    messageBuffer[length] = '\0';            //turn the char array into a C string
    Serial.printf("%s\n", messageBuffer);
    parseMessage(messageBuffer);
void parseMessage(char* json)
    StaticJsonDocument<1000> doc;
    DeserializationError error = deserializeJson(doc, json);
    if (error)
        return;
    const char* time = doc["time"];
    int temp = doc["temp"];
    Serial.printf("Time : %s\n", time);
    Serial.printf("Out Door Temp : %d\n", temp);
    Serial.printf("Wind Direction : %d\n", winddir);
    Serial.printf("Pressure : %f\n", press);
    client.loop();
This prints the topic name when connecting, but that has nothing to do with anything. Might give a false sense of progress; remove it.
The actual call to subscribe uses a hard-coded string instead of the topic variable. And of course, at the moment, it is commented-out.
If that's not the obvious blunder, then
you might try shortening the client ID. If this is your MQTT server, how many others are there? Maybe include a random-ish value. Some library examples use millis(); its variance might depend on your WL_CONNECTED loop. Just in case the server gets confused with you retrying as the same client.
You're not being that consistent with print vs println. Include a line break at the front of the string -- "\nMessage Arrived" -- to be sure you don't miss it.
Check if (length < sizeof(messageBuffer) -1). Probably unrelated to your current problem, but it could become one later.
Thanks again for all your patience.
I dumbed down the clientId:
if (client.connect("ESP32")) {
Added the line break:"
Serial.print("\nMessage Arrived!");
Using these lines to pub/sub:
client.publish("test-Pub", "ESP32 Connected2! ^^"); // for testing
I also added a reconnect: Not seeing any errors at this time.
void reconnect() {
  // Loop until we're reconnected
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
      Serial.println("connected");
      // Subscribe
      Serial.print("failed, rc=");
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
I added a test line to publish some simple text and my code does publish every 2 seconds so I know my connection to the MQTT server is good.
  if (!client.connected()) {
    reconnect();
  delay(2000);
    client.loop();
I was also able to publish to “CumulusMX/DataUpdate” as another test.
I still can’t seem get that callback function to fire to even test reading and parsing the messages being sent on “CumulusMX/DataUpdate” I temporarily added a serial print line in that callback function to kinda watch it.
The broker runs locally and is wide open using “allow_anonymous true”
I have 3 other clients attached that can sub/pub just fine without credentials
I am still trying!
Current Sketch:
#include <WiFi.h>
// WiFi
// MQTT Broker
            delay(2000);
    Serial.print("ParseMessage Called!");
    if (error)
        return;
    Serial.print(time);
    Serial.print(temp);
    Serial.print(winddir);
    Serial.print( press);
    void reconnect() {
      // Subscribe
      delay(5000);
    reconnect();
  //client.publish("test-Pub", "ESP32 Connected2! ^^");
  //delay(2000);
    client.loop();
Are any of them ESP32? Here is a test program that grabs whatever is being published through test.mosquitto.org by using the ro:readonly creds to access the top-level # wildcard topic, as required by that server. (Maybe you can try the same wildcard locally.)
#include <WiFi.h>
#include "arduino_secrets.h"
WiFiClient wifi;
auto broker = "test.mosquitto.org";
auto port = 1884;
auto user = "ro";
auto pass = "readonly";
String id = "rand";
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i=0;i<length;i++) {
    Serial.print((char)payload[i]);
void reconnect() {
    Serial.print("Attempting MQTT connection as ");
    Serial.print(id);
    Serial.print("...");
    if (mqtt.connect(id.c_str(), user, pass)) {
      // Once connected, publish an announcement...
      // mqtt.publish("outTopic","hello world");
      // ... and resubscribe
      mqtt.subscribe("#");
      delay(5000);
  WiFi.begin(SECRET_SSID, SECRET_PASS);
  for (int i = 0; WiFi.status() != WL_CONNECTED; i++) {
    Serial.print(i % 50 ? "." : "\n.");
    delay(20);
  id += micros();
  Serial.println(WiFi.macAddress());
  id += WiFi.macAddress().substring(10);
  mqtt.setServer(broker, port);
  reconnect();
  // Commented-out so that it doesn't run forever
  // if (!mqtt.connected()) {
  //   reconnect();
  mqtt.loop();
Just to prove that the PubSubClient works.
