ILI9341 Display Code.
Hello,
I have a TFT LCD module, 2.4 inch.
details on the display (spec, pinout, ect...) can be found here
The display is using ILI9341 built-in controller.
All I need is a good library for this display, which I can use with Arduino Uno.
I already have UTFT, but I do not know how to wire the display. So if you know - it will be very helpful.
Be aware that the logic level of this display is maximum of 3V3, and resistors can be used here, but I am gonna try transistors.
If you have an example code, please submit.
Thanks for ANY help!
Arad.
u'll find adafruits in the libs manager.
Connections are shown in the examples with the lib
