I'm having difficulty getting my Arduino Mkr 1010 to send http request
I have a sketch which I'm using to connect to a Google Apps Script URL (desired URL: https://script.google.com/a/macros/edwardmarno.com/s/XXXXXX/exec?Weight=3450*) in order to pass a weight parameter to a Google Sheet. The sketch connects to my wifi fine but then it doesn't go to the URL correctly. Please could someone point me in the right direction?
Thanks!
(* Script ID redacted)
#include <SPI.h>
#include <WiFiNINA.h>
#include <ArduinoHttpClient.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
/////// WiFi Settings ///////
char ssid[] = SECRET_SSID;
char pass[] = SECRET_PASS;
int status = WL_IDLE_STATUS;         // the WiFi connection status
  Serial.begin(9600);  // initialize serial communication
  while (!Serial);
  // attempt to connect to WiFi network
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, pass);  // connect to WPA/WPA2 network
    delay(10000);  // wait 10 seconds for connection
  // print connection details
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  // establish a new client connection
  WiFiClient client;
  const int httpPort = 443;
  if (!client.connect("script.google.com", httpPort)) {
    Serial.println("Connection failed");
    return;
  // send the HTTP request
  client.print(String("GET ") + "/a/macros/edmarno.com/s/XXXXXXXXXXXXXX/exec?Weight=3450" + " HTTP/1.1\r\n" +
               "Host: " + "script.google.com" + "\r\n" +
               "Connection: close\r\n\r\n");
  // wait for response
  while (!client.available()) {
    delay(10);
  // read response
  while (client.available()) {
    char c = client.read();
    Serial.write(c);
  // disconnect
  client.stop();
  delay(600000);  // wait 10 minutes before repeating
Did you add SSL certificates to you board for your endpoint (https://script.google.com) ?
Thank you, I have done so now, but it's still not working. The serial monitor just stops after printing the IP address.
I have just tried changing the port (line 44) to 80 and I now get a 301 error in the serial monitor:
12:11:37.125 -> WiFi connected
12:11:37.125 -> IP address:
12:11:37.126 -> 192.168.1.163
12:11:37.485 -> HTTP/1.1 301 Moved Permanently
12:11:37.485 -> Content-Type: text/html; charset=UTF-8
12:11:37.486 -> <HTML>
12:11:37.486 -> <HEAD>
12:11:37.486 -> <TITLE>Moved Permanently</TITLE>
12:11:37.486 -> </HEAD>
12:11:37.486 -> <BODY BGCOLOR="#FFFFFF" TEXT="#000000">
12:11:37.486 -> <H1>Moved Permanently</H1>
12:11:37.486 -> The document has moved <A HREF="https://script.google.com/a/macros/edwardmarno.com/s/XXXXXXXXXXX/exec?Weight=999">here</A>.
12:11:37.537 -> </BODY>
12:11:37.537 -> </HTML>
12:11:37.537 ->
12:11:37.537 -> 0
12:11:37.537 ->
When I go to the URL in my browser, I get the parameter logged in the sheet immediately so perhaps my code for the GET request is wrong? (Should I be using a GET request?)
This is normal. Your browser can follow the redirect automatically, while Arduino don't.
You can't use the url script.google.com without SSL handshaking on port 443, as far as I know.
OK thank you. I'll set the port back to 443 then.
I'm following this methodology (ESP32 Data Logging to Google Sheets with Google Scripts) and they accomplish what I am trying to do using an ESP32 instead of mkr1010. Do you know what I'd need to do on my 1010 to accomplish this?
Thanks and sorry for being dense!
