I'm using an Arduino Leonardo and a Trellis for the button part of this. I'm also using Hairless MIDI and loopMIDI for the conversions from serial to MIDI. The problem I'm having is whenever I press a button, nothing shows up on the serial monitor of HairlessMIDI. I've checked the wiring between the Leonardo and the Trellis and there's nothing wrong with it. Here is the code I'm using for this, can anyone point out any errors?
#include <Wire.h>
#include "Adafruit_Trellis.h"
#include "MIDIUSB.h"
#define MOMENTARY 1
#define LATCHING 0
// set the mode here
#define MODE MOMENTARY
//Call upon Trellis libary for button pad commands
Adafruit_Trellis matrix0 = Adafruit_Trellis();
Adafruit_TrellisSet trellis = Adafruit_TrellisSet(&matrix0);
// set to however many you're working with here
#define numKeys 16
// Connect Trellis Vin to 5V and Ground to ground.
// Connect the INT wire to pin #A2
#define INTPIN A2
// Connect I2C SDA pin to your Arduino SDA line
// Connect I2C SCL pin to your Arduino SCL line
// All Trellises share the SDA, SCL and INT pin
int velocity = 100;//velocity of MIDI notes, must be between 0 and 127
//higher velocity usually makes MIDI instruments louder
int noteON = 144;//144 = 10010000 in binary, note on command
int noteOFF = 128;//128 = 10000000 in binary, note off command
// Set MIDI baud rate:
//9600 to interface with Hairless midi software
// INT pin requires a pullup
pinMode(INTPIN, INPUT);
digitalWrite(INTPIN, HIGH);
// begin() with the addresses of each panel in order
trellis.begin(0x70); // only one
// light up all the LEDs in order and play the lick
for (uint8_t i=0; i<numKeys; i++) {
trellis.setLED(i);
trellis.writeDisplay();
if (i == 2 || i == 4 || i == 5 || i == 7) {
MIDImessage(noteON, 48+i, velocity);//turn note on
delay(100);//hold note for 300ms
MIDImessage(noteOFF, 48+i, velocity);//turn note off
} else if (i == 8) {
MIDImessage(noteON, 48+4, velocity);//turn note on
MIDImessage(noteOFF, 48+4, velocity);//turn note off
} else if (i == 13 || i == 15) {
MIDImessage(noteON, 48+i-13, velocity);//turn note on
MIDImessage(noteOFF, 48+i-13, velocity);//turn note off
// then turn them all off
trellis.clrLED(i);
delay(30);
delay(30); // 30ms delay helps for latency
if (MODE == MOMENTARY) {
// If a button was just pressed or released
if (trellis.readSwitches()) {
// go through every button and check new status
// if it was pressed, turn it on
if (trellis.justPressed(i)) {
trellis.setLED(i);
// if it was released, turn it off
if (trellis.justReleased(i)) {
trellis.clrLED(i);
// tell the trellis to set the LEDs we requested
//send MIDI message through USB port
void MIDImessage(int command, int MIDInote, int MIDIvelocity) {
Serial.write(command);//send note on or note off command
Serial.write(MIDInote);//send pitch data
Serial.write(MIDIvelocity);//send velocity data
