Hi, I seem to be having some trouble getting the Arduino midi library to print correctly to the serial, I get random symbols appearing like this "⸮$⸮$ ⸮$⸮$ ⸮$⸮$ ⸮$⸮$ ⸮$⸮$" instead of the midi notes I want printing. Because of this I cant then connect to hairless Midi and then connect to Ableton. I did have this script working at one point and I haven't changed it since so I'm not sure why the serial is not working. I also have the serial set to a baud rate of 115200 which I need.
This is the code I'm using below, any help would be greatly appreciated thanks!!
Based on Sketch built by Gustavo Silveira (aka Music Nerd)
Modified by Dolce Wang
This code is only for Arduinos that use ATmega328 (like Uno, Mega, Nano, Beetle...)
// Change values with //***
// LIBRARIES
#include <MIDI.h> // by Francois Best
MIDI_CREATE_DEFAULT_INSTANCE();
// BUTTONS
const int NButtons = 1; //*** total number of push buttons
const int buttonPin[NButtons] = {2,}; //*** define digital pins connected from button to Arduino; (ie {10, 16, 14, 15, 6, 7, 8, 9, 2, 3, 4, 5}; 12 buttons)
//** Button NOTE will go up chromatically. ie. if button is digi pin 2, C; Pin 3, C#; Pin 3, D; etc
int buttonCState[NButtons] = {}; // stores the button current value
int buttonPState[NButtons] = {}; // stores the button previous value
// debounce
unsigned long lastDebounceTime[NButtons] = {0}; // the last time the output pin was toggled
unsigned long debounceDelay = 50; //* the debounce time; increase if the output flickers
// POTENTIOMETERS
const int NPots = 1; //*** total numbers of pots (slide & rotary)
const int potPin[NPots] = {A0}; //*** Analog pins of each pot connected straight to the Arduino i.e 4 pots, {A3, A2, A1, A0};
// have nothing in the array if 0 pots {}
int potCState[NPots] = {0}; // Current state of the pot; delete 0 if 0 pots
int potPState[NPots] = {0}; // Previous state of the pot; delete 0 if 0 pots
int potVar = 0; // Difference between the current and previous state of the pot
int midiCState[NPots] = {0}; // Current state of the midi value; delete 0 if 0 pots
int midiPState[NPots] = {0}; // Previous state of the midi value; delete 0 if 0 pots
const int TIMEOUT = 300; //** Amount of time the potentiometer will be read after it exceeds the varThreshold
const int varThreshold = 10; //** Threshold for the potentiometer signal variation
boolean potMoving = true; // If the potentiometer is moving
unsigned long PTime[NPots] = {0}; // Previously stored time; delete 0 if 0 pots
unsigned long timer[NPots] = {0}; // Stores the time that has elapsed since the timer was reset; delete 0 if 0 pots
// MIDI
byte midiCh = 1; //** MIDI channel to be used; You can add more if you need to reorganize or have a billion buttons/pots
byte note = 36; //** First note to be used for digital buttons, then go up chromatically in scale according to the sequence in your "buttonPin" array
// you can look up on a Midi Note chart; 36=C2; 60=Middle C
byte cc = 1; //** First MIDI CC to be used for pots on Analog Pins in order of the "potPin" array; then goes up by 1
// SETUP
MIDI.begin();
Serial.begin(115200); //** Baud Rate 31250 for MIDI class compliant jack | 115200 for Hairless MIDI
// Buttons
// Initialize buttons with pull up resistors
for (int i = 0; i < NButtons; i++) {
pinMode(buttonPin[i], INPUT_PULLUP);
// LOOP
buttons();
potentiometers();
// BUTTONS
void buttons() {
buttonCState[i] = digitalRead(buttonPin[i]); // read pins from arduino
if ((millis() - lastDebounceTime[i]) > debounceDelay) {
if (buttonPState[i] != buttonCState[i]) {
lastDebounceTime[i] = millis();
if (buttonCState[i] == LOW) {
// Sends the MIDI note ON accordingly to the chosen board
MIDI.sendNoteOn(note + i, 127, midiCh); // note, velocity, channel
else {
// Sends the MIDI note OFF accordingly to the chosen board
MIDI.sendNoteOn(note + i, 0, midiCh); // note, velocity, channel
buttonPState[i] = buttonCState[i];
// POTENTIOMETERS
void potentiometers() {
for (int i = 0; i < NPots; i++) { // Loops through all the potentiometers
potCState[i] = analogRead(potPin[i]); // reads the pins from arduino
midiCState[i] = map(potCState[i], 0, 1023, 0, 127); // Maps the reading of the potCState to a value usable in midi
potVar = abs(potCState[i] - potPState[i]); // Calculates the absolute value between the difference between the current and previous state of the pot
if (potVar > varThreshold) { // Opens the gate if the potentiometer variation is greater than the threshold
PTime[i] = millis(); // Stores the previous time
timer[i] = millis() - PTime[i]; // Resets the timer 11000 - 11000 = 0ms
if (timer[i] < TIMEOUT) { // If the timer is less than the maximum allowed time it means that the potentiometer is still moving
potMoving = true;
else {
potMoving = false;
if (potMoving == true) { // If the potentiometer is still moving, send the change control
if (midiPState[i] != midiCState[i]) {
// Sends the MIDI CC
MIDI.sendControlChange(cc + i, midiCState[i], midiCh); // cc number, cc value, midi channel
potPState[i] = potCState[i]; // Stores the current reading of the potentiometer to compare with the next
midiPState[i] = midiCState[i];
