Hi, I'm trying to make a project with my arduino but I don't know if I have correctly positioned all the components, if anyone could help me I would be grateful. Thanks!
Hi, in which program I can make this dhiagram myself, I'll show you correct version
You need a common GND between the Arduino and the servo supply.
Pins 1 and 2 on the Arduino are hardware serial
The converter output connections are swapped.
You must put GND between the servo and Arduino
I used Fritzing. I think you can easily find a crack on youtube
So i have to reverse the "out" and "in" of the converter and add a gnd. But I don't understand what I should do with the two pins.
You have the converter output connections reversed i.e. positive and negative are reversed.
Converter output positive needs to go the servo positive (red wire).
Converter output negative needs to go the servo negative (black wire).
Also, converter negative needs to connect to Arduino GND.
Simply take a piece of paper and a pencil to draw a hardware schematic.
It uses the paper and pencil or it gets the asciimatics again!
| +---|EXT|--------|USB|---+ |
| | PWR A5/SCL | +---------------+ |
| | A4/SDA | | +-------+ | |
| | UNO AREF | | |SERVO 1| | |
| | GND |-+ | GND|-+ |
| | IOREF SCK/D13 | +---|SIG VCC|-|-+
| | RST DI/D12 | | +-------+ | |
| | 3V3 DO/D11~|---+ | |
| | +5V D10~|---+ +-------+ | |
| | GND D9~| | |SERVO 2| | |
+--|--| GND D8 | | | GND|-+ |
| +--| Vin D7 | +---|SIG VCC|-|-+
| | | D6~| +-------+ | |
| | | A0 D5~| | |
| | | A1 D4 | | |
| | | A2 INT1/D3 | +-------+ | |
| | | A3 INT0/D2~| | HC-05 | | |
| | | A4/DA RS CK DI TX>D1 |-------|RXD GND|-+ |
| | | A5/CL GD D0 5V RX<D0 |-------|TXD VCC|---+
| | |BUCK CONVERTER|
| +--|OUT+ IN+|---(EXT+V)
+-----|OUT- IN-|---(EXT-V)
You need to use software serial for the HC-05, pins 0 (TX) and 1 (RX) are for communicating with the PC (Serial Monitor).
