I want a code that can be used to change the setting of a setting, but trying to simplify things a bit, I had some difficulties with making an array, and then changing the array to something else like { 30, 5, 1 } to { 1, 5, 30 }
Here's the code I'm using;
#define RAINBOWSPEED 1 // the larger the number, the slower the rate of change (1 default)
#define LED_PIN 13 // Pin where the LED strip is connected
#define NUM_LEDS 36 // Number of LEDs in the strip
#define LIGHTCHANGESPEED 1 // the larger the number, the slower the rate of change (1 default)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, LED_PIN, NEO_GRB + NEO_KHZ800);
bool reset_on_exit = false;
const int buttonPin = 11; // Pin where the button is connected
const int Relay_enable_IALS_input = 12; // Pin where the Relay is connected
bool ledState = false; // holds the state of the LED
int speaker_pin1 = 10;
int speaker_pin2 = 8;
int cur_pos = 13;
int rst_pin = 9;
digitalWrite(9, HIGH);
pinMode(rst_pin, OUTPUT);
digitalWrite(speaker_pin1, HIGH);
strip.setPixelColor(cur_pos, 255, 0, 255);
strip.show();
strip.begin(); // Initialize the strip
strip.show();
pinMode(speaker_pin1, OUTPUT);
pinMode(speaker_pin2, OUTPUT); // Initialize all pixels to 'off'
pinMode(buttonPin, INPUT); // Set the button pin as an input
pinMode(Relay_enable_IALS_input, OUTPUT); // Set the Relay_enable_IALS_input as an output
digitalWrite(Relay_enable_IALS_input, ledState); // Initialize the relay state 255 * (1 / 100)
delay(100);
colorWipe(0, 0, 0, 0, false);
strip.show();
int action = 0;
bool action_deleteCurSprite = true;
if (action > 0 && action_deleteCurSprite == true) {
strip.setPixelColor(cur_pos, 0, 0, 0);
strip.show();
action_deleteCurSprite = false;
} else if (action == 0) {
initiative();
reset();
buttonpanelRead();
stop(0);
actionAray();
button_sequence();
// Fill the dots one after the other with a color
bool selector = true;
float potVal = analogRead(0); // stores the input from the potentiometer
float brightness = potVal / 1000;
bool lastButtonState = LOW; // holds the last button state
bool pause = false;
float timer = 0;
bool timerEnabled = false;
void button_sequence() {
if (timerEnabled == true) {
timer = timer - 0.001;
// Serial.println(timer);
if (timer <= 0 && timerEnabled == true) {
action = 0;
pause = true;
delay(300);
// Serial.println("action completed");
for (int oe = 0; oe < 37; oe++) {
strip.setPixelColor(oe, 0, 0, 0);
strip.show();
selector = true;
cur_pos = 13;
strip.show();
bool buttonState = digitalRead(buttonPin);
if (buttonState != lastButtonState) {
if (buttonState == HIGH) {
ledState = !ledState;
delay(50);
lastButtonState = buttonState;
int button_left = 4;
int button_right = 5;
int button_up = 7;
int button_down = 6;
int button_ok = 3;
int button_back = 2;
void actionAray() {
if (action == 1) {
runAction_defaultColorpattern();
} else if (action == 2) {
runAction_flashlight();
} else if (action == 3) {
runAction_globalflashlight();
} else if (action == 4) {
runAction_speaker();
} else if (action == 5) {
runAction_5();
} else if (action == 6) {
runAction_6();
} else if (action == 7) {
runAction_lowpowerconsumption();
} else if (action == 8) {
runAction_8();
} else if (action == 9) {
runAction_SOS();
// normal rainbow pattern
int wait = 0;
int Delay_between_colorWipe_cycle = 0;
int r = 255;
int g = 255;
int b = 255;
int cnt = 0;
int cnt2 = 1;
void runAction_defaultColorpattern() {
if (wait == 0) {
wait = 1;
while (action == 1) {
colorWipe(0, 0, 0, 0, true);
colorWipe(255 * brightness, 0 * brightness, 0 * brightness, LIGHTCHANGESPEED * 50, true); // Red color
delay(Delay_between_colorWipe_cycle);
colorWipe(255 * brightness, 100 * brightness, 0 * brightness, LIGHTCHANGESPEED * 50, true); // Orange color
colorWipe(255 * brightness, 200 * brightness, 0 * brightness, LIGHTCHANGESPEED * 50, true); // Yellow color
colorWipe(100 * brightness, 255 * brightness, 0 * brightness, LIGHTCHANGESPEED * 50, true); // Lime color
colorWipe(0 * brightness, 255 * brightness, 0 * brightness, LIGHTCHANGESPEED * 50, true); // Green color
colorWipe(0 * brightness, 255 * brightness, 50 * brightness, LIGHTCHANGESPEED * 50, true); // Turquoise color
colorWipe(0 * brightness, 255 * brightness, 255 * brightness, LIGHTCHANGESPEED * 50, true); // Cyan color
colorWipe(0 * brightness, 100 * brightness, 255 * brightness, LIGHTCHANGESPEED * 50, true); // Light Blue color
colorWipe(0 * brightness, 0 * brightness, 255 * brightness, LIGHTCHANGESPEED * 50, true); // Blue color
colorWipe(120 * brightness, 0 * brightness, 255 * brightness, LIGHTCHANGESPEED * 50, true); // Purple color
colorWipe(255 * brightness, 0 * brightness, 200 * brightness, LIGHTCHANGESPEED * 50, true); // Magenta color
colorWipe(255 * brightness, 255 * brightness, 255 * brightness, LIGHTCHANGESPEED * 50, true); // No color shift
double lumn_temp = brightness;
r = 255;
g = 255;
b = 255;
cnt = 0;
cnt2 = 1;
striprainbowGenerator(200, 1, brightness, 0, 37); // Rainbow effect speed
wait = 0;
// front flashlight
float brightness_mem = brightness;
bool repeater = false;
int waitonfirstactivation1 = 100;
void runAction_flashlight() {
bool wait = true;
primeBrightness();
if (repeater == false || round(brightness_mem * 20) != round(brightness * 20)) {
if (digitalRead(button_ok) == LOW) {
wait = true;
wait = false;
if (wait == true) {
// Serial.println(brightness_mem);
// Serial.println(brightness);
repeater = true;
for (int i = 1; i < 10; i++) {
strip.setPixelColor(i + 8, r * brightness, g * brightness, b * brightness);
strip.show();
if (digitalRead(button_right) == HIGH) {
repeater = false;
striprainbowGenerator(100, 0, brightness, 1, 0);
} else if (digitalRead(button_back) == HIGH) {
if (reset_on_exit == true) {
cnt2 = 1;
cnt = 0;
r = 255;
g = 255;
b = 255;
if (repeater == true) {
strip.setPixelColor(cur_pos, r * brightness, g * brightness, b * brightness);
strip.show();
// global flashlight
void runAction_globalflashlight() {
bool wait = true;
primeBrightness();
wait = true;
wait = false;
if (wait == true) {
repeater = true;
colorWipe(r * brightness, g * brightness, b * brightness, 0, true);
repeater = false;
striprainbowGenerator(100, 0, brightness, 0, 0);
cnt2 = 1;
cnt = 0;
r = 255;
g = 255;
b = 255;
strip.show();
void runAction_speaker() {
uint64_t myInts[] = { 200, 400, 800, 16, 1000, 1000 }; // audio input here delayed by 300 ms
int deltym = 300;
for (int ds = 0; ds < sizeof(myInts) / 8; ds++) {
if (selector == false) {
tone(speaker_pin1, myInts[ds], deltym);
stop(deltym);
void runAction_5() {
random_ColorGenerator();
stop(0);
float SubDelay = 0;
int sleep_color = 1;
// sleep length is equivalent to the minnuts it takes to auto power off. 5 min is default
int sleep_length = 5;
int sleep_;
int setting = 1;
void runAction_6() {
while (digitalRead(button_ok) == HIGH) {
delay(1);
if (repeater == false) {
// 3 modes/lengths that play music, and show a peaceful lighting
if (setting == 1) {
if (digitalRead(button_up) == HIGH && sleep_color < 3) {
delay(300);
sleep_color = sleep_color + 1;
} else if (digitalRead(button_down) == HIGH && sleep_color > 1) {
delay(300);
sleep_color = sleep_color - 1;
} else if (setting == 0) {
if (digitalRead(button_up) == HIGH && sleep_length < 30) {
delay(300);
sleep_length = sleep_length + 1;
} else if (digitalRead(button_down) == HIGH && sleep_length > 1) {
delay(300);
sleep_length = sleep_length - 1;
uint32_t cl[]; This part is giving me trouble.
for (int px = 0; px < sleep_length; px++) {
if (sleep_color = 1) {
cl = 1;
strip.setPixelColor(px, cl);
if (sleep_color == 1) {
strip.setPixelColor(10, 0, 0, 0);
strip.setPixelColor(13, 0, 0, 0);
strip.setPixelColor(16, 255, 0, 0);
strip.show();
} else if (sleep_color == 2) {
strip.setPixelColor(13, 255, 255, 0);
strip.show();
} else if (sleep_color == 3) {
strip.setPixelColor(10, 0, 0, 255);
strip.show();
delay(50);
if (digitalRead(button_left) == HIGH && setting < 1) {
setting = setting + 1;
} else if (digitalRead(button_right) == HIGH && setting > -1) {
setting = setting - 1;
if (digitalRead(button_ok) == HIGH) {
repeater = true;
// sleep 2 minuts
SubDelay = 12000;
while (SubDelay > 0) {
SubDelay = 0;
action = 0;
stop(0);
for (int p = 0; p < 37; p++) {
strip.setPixelColor(p, random(30), random(4), random(1));
strip.show();
delay(1);
SubDelay = SubDelay - 5;
// Serial.println(SubDelay);
exit();
repeater = true;
// sleep 5 minuts
SubDelay = 30000;
SubDelay = 0;
action = 0;
stop(0);
strip.setPixelColor(p, random(30), random(30), random(4));
strip.show();
delay(1);
exit();
repeater = true;
// sleep 10 minuts
SubDelay = 60000;
SubDelay = 0;
action = 0;
stop(0);
strip.setPixelColor(p, random(1), random(10), random(30));
strip.show();
delay(1);
exit();
void runAction_lowpowerconsumption() {
int wait3 = true;
wait3 = false;
if (digitalRead(button_up) == HIGH && timer < 37) {
timer = timer + 1;
for (int pixletimer_num = 0; pixletimer_num < timer; pixletimer_num++) {
strip.setPixelColor(pixletimer_num, 255, 255, 255);
strip.show();
} else if (digitalRead(button_down) == HIGH && timer >= 0) {
strip.setPixelColor(timer, 0, 0, 0);
strip.show();
timer = timer - 1;
delay(150);
if (wait3 == false && digitalRead(button_ok) == HIGH) {
action = 0;
repeater = false;
cur_pos = 13;
delay(300);
strip.show();
selector = true;
timerEnabled = true;
void runAction_8() {
repeater = true;
colorWipe(0, 0, 0, 0, true); // No color shift
// SOS
void runAction_SOS() {
if (wait == 0) {
wait = 9;
while (action == 9) {
colorWipe(255, 255, 25, 0, true);
colorWipe(255, 255, 25, 2, true);
colorWipe(0, 0, 0, 3, true);
colorWipe(0, 0, 0, 5, true);
colorWipe(255, 255, 25, 20, true);
colorWipe(0, 0, 0, 1, true);
colorWipe(0, 0, 0, 40, true);
wait = 0;
void testcolor() {
if (cur_pos == 9) {
strip.setPixelColor(cur_pos, 255, 100, 100);
strip.show();
} else if (cur_pos == 10) {
strip.setPixelColor(cur_pos, 255, 100, 255);
strip.show();
} else if (cur_pos == 11) {
strip.setPixelColor(cur_pos, 255, 255, 255);
strip.show();
} else if (cur_pos == 12) {
strip.show();
} else if (cur_pos == 13) {
strip.show();
} else if (cur_pos == 14) {
strip.show();
} else if (cur_pos == 15) {
strip.show();
} else if (cur_pos == 16) {
strip.show();
} else if (cur_pos == 17) {
strip.setPixelColor(cur_pos, 255, 255, 0);
strip.show();
bool Initializer = true;
void initiative() {
if (Initializer == true) {
delay(1050);
for (int j = 0; j < 256; j++) {
for (int i = 0; i < 37; i++) {
strip.setPixelColor(i, 0, j, j);
strip.show();
strip.setPixelColor(i, 0, 0, 0);
strip.show();
for (int o = 0; o < 10; o++) {
for (int i = -1; i < 37; i++) {
int xp = i - 18;
if (xp < 0) {
xp = 37 + xp;
strip.setPixelColor(i, 0, 255, 255);
strip.show();
delay(20);
strip.setPixelColor(xp, 0, 50, 255);
strip.show();
delay(20);
strip.show();
delay(20);
strip.show();
delay(20);
for (int h = 1; h < 4; h++) {
delay(100);
for (int hi = 0; hi < 8; hi++) {
strip.setPixelColor(i, 0, hi * 32, 255);
strip.show();
delay(1);
strip.show();
strip.show();
strip.show();
Initializer = false;
float timer1 = 0;
int cur_save;
void buttonpanelRead() {
if (selector == true) {
reset();
if (digitalRead(button_up) == HIGH) {
cur_save = cur_pos;
if (cur_pos - 3 > 8) {
cur_pos = cur_pos - 3;
strip.setPixelColor(cur_save, 0, 0, 0);
strip.show();
delay(200);
testcolor();
if (digitalRead(button_down) == HIGH) {
cur_save = cur_pos;
if (cur_pos + 3 < 18) {
cur_pos = cur_pos + 3;
strip.show();
delay(200);
testcolor();
cur_save = cur_pos;
if (cur_pos == 9 || cur_pos == 10 || cur_pos == 12 || cur_pos == 13 || cur_pos == 15 || cur_pos == 16) {
cur_pos = cur_pos + 1;
strip.show();
delay(200);
testcolor();
if (digitalRead(button_left) == HIGH) {
cur_save = cur_pos;
if (cur_pos == 10 || cur_pos == 11 || cur_pos == 13 || cur_pos == 14 || cur_pos == 16 || cur_pos == 17) {
cur_pos = cur_pos - 1;
strip.show();
delay(200);
testcolor();
action = 0;
repeater = false;
for (int hqi = 0; hqi < 10; hqi++) {
if (cur_pos == hqi + 8) {
action = hqi;
delay(100);
selector = false;
delay(10);
repeater = false;
if (digitalRead(button_up) == LOW && digitalRead(button_down) == LOW && digitalRead(button_left) == LOW && digitalRead(button_right) == LOW && digitalRead(button_ok) == LOW && digitalRead(button_back) == LOW) {
if (timer1 != 70000) {
timer1 = timer1 + 1;
if (timer1 == 50000) {
strip.setPixelColor(cur_pos, 50, 0, 50);
strip.show();
if (timer1 >= 70000) {
strip.show();
// if (digitalRead(button_up) == HIGH || digitalRead(button_down) == HIGH || digitalRead(button_left) == HIGH || digitalRead(button_right) == HIGH || digitalRead(button_ok) == HIGH || digitalRead(button_back) == HIGH) {
timer1 = 0;
delay(3);
strip.show();
void striprainbowGenerator(int wait, bool loop, float brightness_v3, int pixle_number_start, int pixle_number_end) {
if (loop == 1) {
for (int ax = 0; ax <= 88; ax++) {
if (r == 255 && g == 255 && b == 255) {
r = 255;
g = 0;
b = 0;
if (cnt2 == 1) {
g = g + 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 2;
cnt = 0;
r = 255;
g = 255;
b = 0;
if (cnt2 == 2) {
r = r - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 3;
cnt = 0;
r = 0;
g = 255;
b = 0;
if (cnt2 == 3) {
b = b + 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
r = 0;
g = 255;
b = 255;
cnt2 = 4;
cnt = 0;
if (cnt2 == 4) {
g = g - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 5;
cnt = 0;
r = 0;
g = 0;
b = 255;
if (cnt2 == 5) {
r = r + 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 6;
cnt = 0;
r = 255;
g = 255;
b = 255;
if (cnt2 == 6) {
g = g - 31.875;
b = b - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 7;
cnt = 0;
r = 255;
g = 255;
b = 255;
if (cnt2 == 7) {
b = b - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 8;
cnt = 0;
r = 255;
g = 255;
b = 255;
if (cnt2 == 8) {
b = b - 31.875;
r = r - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 9;
cnt = 0;
r = 255;
g = 255;
b = 255;
if (cnt2 == 9) {
r = r - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 10;
cnt = 0;
r = 255;
g = 255;
b = 255;
if (cnt2 == 10) {
r = r - 31.875;
g = g - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 11;
cnt = 0;
r = 255;
g = 255;
b = 255;
if (cnt2 == 11) {
g = g - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 1;
cnt = 0;
r = 255;
g = 255;
b = 255;
for (int pxn = pixle_number_start; pxn <= pixle_number_end; pxn++) {
primeBrightness();
brightness_v3 = brightness;
strip.setPixelColor(pxn, r * brightness_v3, g * brightness_v3, b * brightness_v3);
strip.show();
cnt = 0;
cnt2 = 1;
r = 255;
g = 255;
b = 255;
} else if (loop == 0) {
r = 255;
g = 0;
b = 0;
primeBrightness();
if (cnt2 == 1) {
g = g + 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 2;
cnt = 0;
r = 255;
g = 255;
b = 0;
if (cnt2 == 2) {
r = r - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 3;
cnt = 0;
r = 0;
g = 255;
b = 0;
if (cnt2 == 3) {
b = b + 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
r = 0;
g = 255;
b = 255;
cnt2 = 4;
cnt = 0;
if (cnt2 == 4) {
g = g - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 5;
cnt = 0;
r = 0;
g = 0;
b = 255;
if (cnt2 == 5) {
r = r + 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 6;
cnt = 0;
r = 255;
g = 255;
b = 255;
if (cnt2 == 6) {
g = g - 31.875;
b = b - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 7;
cnt = 0;
r = 255;
g = 255;
b = 255;
if (cnt2 == 7) {
b = b - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 8;
cnt = 0;
r = 255;
g = 255;
b = 255;
if (cnt2 == 8) {
b = b - 31.875;
r = r - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 9;
cnt = 0;
r = 255;
g = 255;
b = 255;
if (cnt2 == 9) {
r = r - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 10;
cnt = 0;
r = 255;
g = 255;
b = 255;
if (cnt2 == 10) {
r = r - 31.875;
g = g - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 11;
cnt = 0;
r = 255;
g = 255;
b = 255;
if (cnt2 == 11) {
g = g - 31.875;
stop(wait);
cnt = cnt + 1;
if (cnt == 9) {
cnt2 = 1;
cnt = 0;
r = 255;
g = 255;
b = 255;
primeBrightness();
strip.show();
int R = 255;
int G = 255;
int B = 255;
int difference = 255 * brightness; // difference between each pixel color before and after. The smaller, the more difference. 255 is default.
int previousColor_r = 255;
int previousColor_g = 255;
int previousColor_b = 255;
void random_ColorGenerator() {
for (int ls = 0; ls < NUM_LEDS; ls++) {
if (timer > 0.01 || timerEnabled == false) {
primeBrightness();
R = random(255 * brightness);
G = random(255 * brightness);
B = random(255 * brightness);
if (previousColor_r + R > difference) {
R = random(128 * brightness * 2);
R = random(64 * brightness * 4);
R = random(32 * brightness * 8);
R = random(16 * brightness * 16);
if (previousColor_g + G > difference) {
G = random(128 * brightness * 2);
G = random(64 * brightness * 4);
G = random(32 * brightness * 8);
G = random(16 * brightness * 16);
if (previousColor_b + B > difference) {
B = random(128 * brightness * 2);
B = random(64 * brightness * 4);
B = random(32 * brightness * 8);
B = random(16 * brightness * 16);
strip.setPixelColor(ls, R, G, B);
strip.show();
button_sequence();
previousColor_r = R;
previousColor_g = G;
previousColor_b = B;
int potPin = 0; // Potentiometer output connected to analog pin 3
void colorWipe(int red, int green, int blue, int wait, bool use_custom_brightness_var) {
stop(0);
primeBrightness();
if (use_custom_brightness_var == true) {
for (int pixle_number = 0; pixle_number < strip.numPixels(); pixle_number++) {
stop(0);
primeBrightness();
strip.setPixelColor(pixle_number, red * brightness, green * brightness, blue * brightness);
strip.show();
stop(wait);
button_sequence();
} else if (use_custom_brightness_var == false) {
stop(0);
strip.setPixelColor(pixle_number, red, green, blue);
strip.show();
stop(wait);
button_sequence();
void stop(float Delay) {
int time_del = 0;
if (time_del >= Delay) {
while (digitalRead(button_back) == HIGH) {
reset();
action = 0;
repeater = false;
cur_pos = 13;
delay(200);
strip.show();
selector = true;
while (Delay > 0) {
Delay = 0;
action = 0;
stop(0);
delay(1);
Delay = Delay - 1;
float reset_timer = 0;
void reset() {
if (digitalRead(button_back) == HIGH) { // If serial print is disabled, enable the delay. If delay is disabled, enable serial print.
// Serial.println(reset_timer);
delay(20);
if (reset_timer > 200) {
digitalWrite(rst_pin, LOW);
reset_timer = reset_timer + 1;
reset_timer = 0;
void primeBrightness() {
brightness = analogRead(potPin);
brightness = brightness / 1000;
if (brightness > 1) {
brightness = 1;
void exit() {
action = 0;
repeater = false;
cur_pos = 13;
delay(200);
strip.show();
selector = true;
