I'm using a DC 0-25V voltage meter on the Arduino Uno and would like it to activate another port when it reaches a desired voltage
//Estou fazendo para um sistema de proteção da minha casa e quero que quando o sensor atinga a uma voltagem desejada ele de um pulso para outra porta, por exemplo ligar um led ou ativar um buzzer. mas nao achei nada que me ajudasse a fazer e não estou conseguindo fazer sozinho.
I'm doing it for a protection system in my house and I want that when the sensor reaches a desired voltage it pulses to another door, for example turning on an LED or activating a buzzer. but I didn't find anything that helped me to do it and I'm not able to do it alone.//
HARDWARE:
ARDUINO SENSOR DE TENSÃO
VCC //entrada positiva até 25V
GND //terra da entrada
GND //-
A0 // S
ARDUINO DISPLAY I2C
GND //GND
5V //VCC
A4 //SDA
A5 //SCL
HARDWARE:
ARDUINO VOLTAGE SENSOR
VCC //positive input up to 25V
GND // input ground
GND //-
A0 // S
ARDUINO DISPLAY I2C
GND //GND
5V //VCC
A4 // SDA
A5 // SCL
// --- Bibliotecas - Libraries ---
#include <Wire.h>
// --- Declaração de Constantes - Declaration of Constants ---
LiquidCrystal_I2C lcd(0x27,2,1,0,4,5,6,7,3, POSITIVE);
float volts = 0.0;
lcd.begin (16,2);
lcd.setCursor(0,0);
lcd.print("|");
lcd.setCursor(0,1);
lcd.print("|");
lcd.setCursor(15,0);
lcd.print("|");
lcd.setCursor(15,1);
lcd.print("|");
lcd.setCursor(3,0);
lcd.print("Voltimetro");
lcd.setCursor(6,1);
lcd.print("NHS");
delay(5000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("|");
lcd.setCursor(0,1);
lcd.print("|");
lcd.print("|");
lcd.print("|");
lcd.setCursor(4,0);
lcd.print("Voltagem");
volts = analogRead(0)*(5.0/1023.0);
volts = volts*5.0;
Serial.println(volts);
lcd.setCursor(6,1);
lcd.print(volts);
delay(450);
Should be:
analogRead(A0)...
And then:
float someVoltage=10.0;
byte whateverPin=6;
pinMode(whateverPin, OUTPUT);
if (volt>someVoltage){
   digitalWrite(whateverPin, HIGH);
Wow, it worked, thank you so much, you don't know how much it helped me! It was killing me trying to do this. :joy:
Thanks Build_1971
