Image increased the buffer during a serial transfer
Team,
Question I have project that is using this code
Sender which is a ESP32Cam which sends a image to the master (receiver).
My question is this. I added a wide angle camera over the standard and it appears to send more data (guess this is expected) to the receiver.
Image is set here from what I understand.
//  if(psramFound()){
//    config.frame_size = FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
//    config.jpeg_quality = 10;
//    config.fb_count = 2;
//  } else {
//    config.frame_size = FRAMESIZE_SVGA;
//    config.jpeg_quality = 12;
//    config.fb_count = 1;
So can I simply increase the buffer below on the receieve to accomodate the addtional data during the transfer? Apologies if this is a stupid question but the wide angle camera works but sometimes dependant on the image taken to me generates more that the 32000 buffer?
struct img_meta_data{
  uint16_t counter;
  uint16_t imSize;
  uint16_t numLoops;
  uint16_t sizeLastLoop;
} ImgMetaData;
uint16_t packetCounter=1;
uint16_t bufferPointer=0;
char tempImageBuffer[32000];
#define DEBUG_ESP              //comment out to deactivate debug console
#ifdef DEBUG_ESP
  #define pDBGln(x) Serial.println(x)
  #define pDBG(x)   Serial.print(x)
#else
  #define pDBG(...)
  #define pDBGln(...)
#endif
#include "esp_camera.h"
#include "Arduino.h"
#include "soc/soc.h"           // Disable brownour problems
#include "soc/rtc_cntl_reg.h"  // Disable brownour problems
#include "driver/rtc_io.h"
#include "SerialTransfer.h"
// Pin definition for CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
SerialTransfer myTransfer;
HardwareSerial Comm(1);
  uint16_t counter;
  uint16_t imSize;
  uint16_t numLoops;
} ImgMetaData;
const uint16_t PIXELS_PER_PACKET = MAX_PACKET_SIZE - sizeof(ImgMetaData);
void setup(){
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
  Serial.begin(115200);                     // Define and start serial monitor
  // 115200,256000,512000,962100
  Comm.begin(962100, SERIAL_8N1,15,14);     //, Comm_Txd_pin, Comm_Rxd_pin); // Define and start Comm serial port
  myTransfer.begin(Comm);
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
//  } else {
  // Init Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK){
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
void loop(){
  uint16_t startIndex = 0;
  camera_fb_t * fb = NULL;
  //Take Picture with Camera
  fb = esp_camera_fb_get();
  ImgMetaData.imSize       = fb->len;                             //sizeof(myFb);
  ImgMetaData.numLoops     = (fb->len / PIXELS_PER_PACKET) + 1;   //(sizeof(myFb)/PIXELS_PER_PACKET) + 1;
  ImgMetaData.sizeLastLoop = fb->len % PIXELS_PER_PACKET;         //(sizeof(myFb)%PIXELS_PER_PACKET);
  for(ImgMetaData.counter=1; ImgMetaData.counter<=ImgMetaData.numLoops; ImgMetaData.counter++){
    myTransfer.txObj(ImgMetaData, sizeof(ImgMetaData));
    //printStructBuf();
    stuffPixels(fb->buf, startIndex, sizeof(ImgMetaData), PIXELS_PER_PACKET);
    //stuffPixels(myFb, startIndex, sizeof(ImgMetaData), PIXELS_PER_PACKET);
    //printStructBuf();
    myTransfer.sendData(MAX_PACKET_SIZE);
    pDBGln(F("Sent:"));
    pDBG(F("img.counter: "));      pDBGln((uint16_t)((myTransfer.txBuff[1] << 8) | myTransfer.txBuff[0]));
    pDBG(F("img.imSize: "));       pDBGln((uint16_t)((myTransfer.txBuff[3] << 8) | myTransfer.txBuff[2]));
    pDBG(F("img.numLoops: "));     pDBGln((uint16_t)((myTransfer.txBuff[5] << 8) | myTransfer.txBuff[4]));
    pDBG(F("img.sizeLastLoop: ")); pDBGln((uint16_t)((myTransfer.txBuff[7] << 8) | myTransfer.txBuff[6]));
    startIndex += PIXELS_PER_PACKET;
    delay(100);
    //printBuf();
  esp_camera_fb_return(fb);   //clear camera memory
  delay(10000);
void printStructBuf(){
  pDBG(F("Internal Struct: { "));
  for (uint16_t k=0; k<sizeof(ImgMetaData); k++){
    pDBG(myTransfer.txBuff[k]);
    if (k<(sizeof(ImgMetaData)-1))
      pDBG(F(", "));
      pDBGln(F(" }"));
void printBuf(){
  pDBG(F("Pixel Values: { "));
  for (uint16_t k=8; k<MAX_PACKET_SIZE; k++){
    if (k < (MAX_PACKET_SIZE - 1))
      pDBG(F(", "));
      pDBGln(F(" }"));
  pDBGln();
void stuffPixels(const uint8_t * pixelBuff, const uint16_t &bufStartIndex, const uint16_t &txStartIndex, const uint16_t &len){
  uint16_t txi = txStartIndex;
  for (uint16_t i=bufStartIndex; i<(bufStartIndex + len); i++)  {
    myTransfer.txBuff[txi] = pixelBuff[i];
    txi++;
Receiver code
/Receives picture via serial and saves to ftp/
#ifdef DEBUG_ESP
#else
  #define pDBG(...)
  #define pDBGln(...)
#endif
  uint16_t counter;
  uint16_t imSize;
  uint16_t numLoops;
} ImgMetaData;
#include <WiFi.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
// Define NTP Client to get time
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
// Variables to save date and time
String formattedDate;
String dayStamp;
String timeStamp;
// FTP Client Lib
#include "ESP32_FTPClient.h"
// Your WiFi credentials.
char ssid[] = "myssid";
char pass[] = "mypass";
// FTP Server credentials
char ftp_server[] = "192.168.0.1";
char ftp_user[]   = "pcborges";
char ftp_pass[]   = "mypass";
// picture name
String picPrefix ="";
String pic_name;
// Connection timeout;
#define CON_TIMEOUT   10*1000                     // milliseconds
ESP32_FTPClient ftp(ftp_server, ftp_user, ftp_pass);
void setup(){
  //Serial.begin(Baud Rate, Data Protocol, Txd pin, Rxd pin);
  Serial2.begin(962100, SERIAL_8N1); //Receiver_Txd_pin, Receiver_Rxd_pin); // Define and start Receiver serial port
  myTransfer.begin(Serial2);
  WiFi.begin(ssid, pass);
  pDBGln("Connecting Wifi...");
      pDBG(".");
  pDBGln("");
  pDBG("IP address: ");
  pDBGln(WiFi.localIP());
  pDBGln();
  // Initialize a NTPClient to get time
  timeClient.begin();
  // Set offset time in seconds to adjust for your timezone, for example:
  // GMT +1 = 3600, GMT +8 = 28800, GMT -1 = -3600, GMT 0 = 0
  timeClient.setTimeOffset(3600*-3);
void loop(){
  if(myTransfer.available())  {
    myTransfer.rxObj(ImgMetaData, sizeof(ImgMetaData));
    pDBG("Struct Data: ");
    pDBG(ImgMetaData.counter);
    pDBG(", ");
    pDBG(ImgMetaData.imSize);
    pDBG(", ");
    pDBG(ImgMetaData.numLoops);
    pDBG(", ");
    pDBG(ImgMetaData.sizeLastLoop);
    pDBG(", PacketCounter: ");
    pDBGln(packetCounter);
    if(ImgMetaData.counter==1){
      copyToImageBuff(MAX_PACKET_SIZE-sizeof(ImgMetaData));
    }else{
      if(ImgMetaData.counter==packetCounter){
        if(packetCounter<ImgMetaData.numLoops){
        }else if(ImgMetaData.counter==packetCounter){
          copyToImageBuff(ImgMetaData.sizeLastLoop);
    if(packetCounter>ImgMetaData.numLoops){
      pic_name  = picPrefix;
      pic_name += getDateTime() + ".jpg";
      FTP_upload();
      packetCounter=1;
      bufferPointer=0;
      delay(2000);
      //while(1){}
  }else if(myTransfer.status < 0) {
    pDBG("ERROR: ");
    if(myTransfer.status == -1)
      pDBGln(F("CRC_ERROR"));
    else if(myTransfer.status == -2)
      pDBGln(F("PAYLOAD_ERROR"));
    else if(myTransfer.status == -3)
      pDBGln(F("STOP_BYTE_ERROR"));
void copyToImageBuff(uint16_t dataLenght){
  for(int y=0;y<dataLenght;y++){
    tempImageBuffer[bufferPointer+y] = myTransfer.rxBuff[y+sizeof(ImgMetaData)];
  bufferPointer+=dataLenght;
  packetCounter++;
  pDBG("dataLenght: ");
  pDBG(dataLenght);
  pDBG(", bufferPointer: ");
  pDBGln(bufferPointer);
void printBuf(char localBuff){
  for (uint16_t k=0; k<sizeof(myTransfer.rxBuff); k++){
    pDBG(myTransfer.rxBuff[k]);
    if (k < (sizeof(myTransfer.rxBuff) - 1))
      pDBG(F(", "));
      pDBGln(F(" }"));
void FTP_upload(){
  pDBG("Uploading via FTP: ");
  ftp.OpenConnection();
  //ftp.ChangeWorkDir("/public_html/zyro/");
  //Create a file and write the image data to it;
  ftp.InitFile("Type I");
  const char *f_name = pic_name.c_str();
  ftp.NewFile( f_name );
  pDBGln( f_name );
  ftp.WriteData((unsigned char*)tempImageBuffer, ImgMetaData.imSize);
  ftp.CloseFile();
  // Breath, withouth delay URL failed to update.
  pDBGln("Done... Waiting next transfer...");
  delay(100);
String getDateTime(){
  String curDateTime="";
  while(!timeClient.update()) {
    timeClient.forceUpdate();
  // The formattedDate comes with the following format:
  // 2018-05-28T16:00:13Z
  // We need to extract date and time
  formattedDate = timeClient.getFormattedDate();
  #ifdef DEGUB_ESP
    // Extract date
    int splitT = formattedDate.indexOf("T");
    dayStamp = formattedDate.substring(0, splitT);
    // Extract time
    timeStamp = formattedDate.substring(splitT+1, formattedDate.length()-1);
    pDBGln(formattedDate);
    pDBG("DATE: ");
    pDBGln(dayStamp);
    pDBG("HOUR: ");
    pDBGln(timeStamp);
  #endif
  curDateTime  = formattedDate.substring(8,10);  //day
  curDateTime += formattedDate.substring(5,7);   //month
  curDateTime += formattedDate.substring(2,4);   //year
  curDateTime += formattedDate.substring(11,13); //hour
  curDateTime += formattedDate.substring(14,16); //minute
  curDateTime += formattedDate.substring(17,19); //seconds
  return curDateTime;
The image buffer must be declared large enough to contain the entire image, and you can allocate memory for it "on the fly" inside a function. Or declare (as global) a fixed size image buffer large enough to handle all expected cases.
The image size is available from the code.
