Take out line 38. That sets the time to the time that the sketch was compiled.
And your sketch is small enough to fit in a post; next time please post in your post instead of attaching it. Post it between
** **[code]** **
and
** **[/code]** **
so it looks like below (your code)
/*Arduino-Based Rain Gauge and Flood Early Warning System Code*/
// List of libraries (provide extra functionality for use in sketches) used in code:
#include <LiquidCrystal.h>
#include "Wire.h"
#include <RTClib.h>
#include <avr/wdt.h>
RTC_DS1307 RTC;
// States the numbers of the Arduino pins that are connected to the rs, enable, d4, d5, d6, d7 pins
// RS pin - the register select pin enables a user to select the instruction mode or the character mode of a LCD
// Enable pin - it enables the writing to the registers
// d4, d5, d6, d7 - are optional but if omitted, the LCD will be controlled using only the four data lines
LiquidCrystal lcd(12,11,5,4,3,2);
// Integers (primary data-type for number storage)
int Buzzer = 8;
int RainPin = 7;
// Double precision floating point number (the changing variable in the code)
double rainfall = 0.000;
// A bool (holds one of two values, true or false)
bool bucketPositionA = false;
// constant float (used for creating numeric or string constants)
const float LowAmt=0.031;
const float HiAmt=0.031;
// Long variables (are extended size variables for number storage)
long minorflood = 2;
long majorflood = 8;
// A byte (stores an 8-bit unsigned number, from 0 to 255)
byte lastSec=0;
// The setup() function (is called when a sketch starts. it initializes variables, pin modes, start using libraries, etc.)
Wire.begin();
RTC.begin();
RTC.adjust(DateTime(__DATE__,__TIME__));
wdt_disable();
wdt_enable(WDTO_2S);
pinMode(RainPin, INPUT);
pinMode(Buzzer, OUTPUT);
lcd.begin(20,4);
lcd.clear();
lcd.setCursor(0,2);
lcd.print("Total Rainfall:");
if (digitalRead(RainPin)==HIGH)
bucketPositionA=true;
bucketPositionA=false;
delay(500); // every half-second
if((bucketPositionA==false)&&(digitalRead(RainPin)==HIGH))
rainfall+=LowAmt;
if((bucketPositionA==true)&&(digitalRead(RainPin)==LOW))
rainfall+=HiAmt;
lcd.setCursor(0,3);
lcd.print(rainfall);
lcd.print(" inches");
if(minorflood < rainfall)
digitalWrite(Buzzer, HIGH);
tone(Buzzer, 3000, 500);
delay(200);
digitalWrite(Buzzer, LOW);
noTone(Buzzer);
delay(200);
lcd.begin(20,4);
lcd.clear();
lcd.setCursor(0,2);
lcd.print("FLOOD WARNING");
if(majorflood < rainfall)
tone(Buzzer, 10000, 500);
delay(200);
noTone(Buzzer);
delay(200);
lcd.begin(20,4);
lcd.clear();
lcd.setCursor(0,2);
lcd.print("FORCED EVACUATION");
DateTime now = RTC.now();
if(lastSec!=now.second())
lastSec=now.second();
lcd.begin();
lcd.setCursor(0,0);
lcd.print(now.year(), DEC);
lcd.print('/');
lcd.print(now.month(), DEC);
lcd.print('/');
lcd.print(now.day(), DEC);
lcd.setCursor(0,1);
lcd.print(now.hour(), DEC);
lcd.print(':');
lcd.print(now.minute(), DEC);
lcd.print(':');
lcd.print(now.second(), DEC);
