IMU 5 DOF
Hey guys,
I just bought a IMU 5DOF sensor, and when i run the program
int x=0;
int y=1;
int z=2;
  Serial.begin(9600);      // sets the serial port to 9600
  x = analogRead(0);       // read analog input pin 0
  y = analogRead(1);       // read analog input pin 1
  z = analogRead(2);
  Serial.print("accelerations are x, y: ");
  Serial.print(x, DEC);    // print the acceleration in the X axis
  Serial.print(" ");       // prints a space between the numbers
  Serial.print(y, DEC);
  Serial.println(z, DEC);
    delay(100);              // wait 100ms for next reading
i get the foll: output that doesnt change even though i tilt or move the sensor
accelerations are x, y, z : 103 105 106
etc
(I use an old version of arduino , so i used a voltage divider network of 12K and 20K resistors to get 3.3V from 5 V)
Please help, what would be wrong??
Sounds like something isn't wired correctly.
Exactly what sensor do you have and how is it wired?
I have a IMU 5 DOF (adxl335 and IDG500).........i connected the 3.3V pin of the sensor to a voltage divider arrangement of 12k and 20k to get 3.3V from the 5V of my arduino, then i connected the X-acc,Y-acc,Z-acc pins to analog 0,1,2 respectively and connected the GND.This is the product page of my sensor:http://www.rhydolabz.com/index.php?main_page=product_info&cPath=137_148&products_id=581.Please help.
The specification for the accelerometer shows that the output should be about 1/2 the supply voltage +/- 0.3v
3.3/2 = 1.65v
That SHOULD produce an analog input value of 338 +/-61. Something is definitely wrong.
It's just a guess but a resistor voltage divider might not be good enough for powering an active device. You should supply a regulated voltage. You can use the regulated 3.3v supply from the Arduino.
