Is there someone who has adapted the Adafruit BNO055 library for Simulink?
Thank you in advance,
Pm
Pm
Anyone?
What is the best choice:
Pm
Finally I have managed the first method but I am not able to reach 100 Hz!
If someone is interested:
1/ Create a folder (change your Matlab current directory) and copy the following libraries into the folder:
Wire.h
BNO055.h
BNO055.c
Wire.cpp
twi.h
twi.c
NAxisMotion.h
NAxisMotion.cpp
2/ Create a Simulink file, add a S-function builder, open it and set the parameters as it follows:
3/ Buil it and return to your folder directory
4/ Change XXXXXXX_wrapper.c to XXXXXXX_wrapper.cpp
5/ Open XXXXXXX_wrapper.cpp and add 'extern "C" ' before each function (i.e. before each 'void')
6/ In Simulink chose External mode and in configuration parameters set Arduino board in Hardware implementation.
But the problem is the following, when I try to set the sample rate to 100 Hz (0.01s) either in initialization parameter in the S-function builder (sample mode 0.01) either in simulink solver configuration parameters; the IMU output data stay locked after around 2-3 seconds ![]()
I would appreciate some help.
Thank you,
Pm
Anyone ?
Thanks,
Pm
Hello,
I came across your post while attempting to solve the same problem you were having. Thank you very much for posting such a great rundown of how you overcame! I unfortunately wasn't as skilled, and sent a plea to Mathworks, which they responded to. Turns out just this summer (I think) the created a toolbox which includes a .slx file for the BNO055! You might be aware of this already, but thought I would drop a line just in case. The toolbox is called "Arduino_Engineering_Kit_Hardware". Cheers!
