Hello guys!
I am trying to run the following IMU at high frequency rate (above 100hz) while outputing raw 9dof measurements for linear and rotational acceleration and the magnetic field.
I am using esp32 pico d4 connected by I2C but cannot reach high frequency output.
How can I optimize the code to do so?
#include <Adafruit_BNO08x.h>
// For SPI mode, we need a CS pin
#define BNO08X_CS 10
#define BNO08X_INT 9
// For SPI mode, we also need a RESET
//#define BNO08X_RESET 5
// but not for I2C or UART
#define BNO08X_RESET -1
Adafruit_BNO08x bno08x(BNO08X_RESET);
sh2_SensorValue_t sensorValue;
void setup(void) {
while (!Serial)
delay(10); // will pause Zero, Leonardo, etc until serial console opens
Serial.println("Adafruit BNO08x test!");
// Try to initialize!
if (!bno08x.begin_I2C()) {
// if (!bno08x.begin_UART(&Serial1)) { // Requires a device with > 300 byte
// UART buffer! if (!bno08x.begin_SPI(BNO08X_CS, BNO08X_INT)) {
Serial.println("Failed to find BNO08x chip");
while (1) {
delay(10);
Serial.println("BNO08x Found!");
for (int n = 0; n < bno08x.prodIds.numEntries; n++) {
Serial.print("Part ");
Serial.print(bno08x.prodIds.entry[n].swPartNumber);
Serial.print(": Version :");
Serial.print(bno08x.prodIds.entry[n].swVersionMajor);
Serial.print(".");
Serial.print(bno08x.prodIds.entry[n].swVersionMinor);
Serial.print(".");
Serial.print(bno08x.prodIds.entry[n].swVersionPatch);
Serial.print(" Build ");
Serial.println(bno08x.prodIds.entry[n].swBuildNumber);
setReports();
Serial.println("Reading events");
delay(100);
// Here is where you define the sensor outputs you want to receive
void setReports(void) {
Serial.println("Setting desired reports");
if (!bno08x.enableReport(SH2_ACCELEROMETER)) {
Serial.println("Could not enable accelerometer");
if (!bno08x.enableReport(SH2_GYROSCOPE_CALIBRATED)) {
Serial.println("Could not enable gyroscope");
if (!bno08x.enableReport(SH2_MAGNETIC_FIELD_CALIBRATED)) {
Serial.println("Could not enable magnetic field calibrated");
if (!bno08x.enableReport(SH2_LINEAR_ACCELERATION)) {
Serial.println("Could not enable linear acceleration");
if (!bno08x.enableReport(SH2_GRAVITY)) {
Serial.println("Could not enable gravity vector");
if (!bno08x.enableReport(SH2_ROTATION_VECTOR)) {
Serial.println("Could not enable rotation vector");
if (!bno08x.enableReport(SH2_GEOMAGNETIC_ROTATION_VECTOR)) {
Serial.println("Could not enable geomagnetic rotation vector");
if (!bno08x.enableReport(SH2_GAME_ROTATION_VECTOR)) {
Serial.println("Could not enable game rotation vector");
if (!bno08x.enableReport(SH2_STEP_COUNTER)) {
Serial.println("Could not enable step counter");
if (!bno08x.enableReport(SH2_STABILITY_CLASSIFIER)) {
Serial.println("Could not enable stability classifier");
if (!bno08x.enableReport(SH2_RAW_ACCELEROMETER)) {
Serial.println("Could not enable raw accelerometer");
if (!bno08x.enableReport(SH2_RAW_GYROSCOPE)) {
Serial.println("Could not enable raw gyroscope");
if (!bno08x.enableReport(SH2_RAW_MAGNETOMETER)) {
Serial.println("Could not enable raw magnetometer");
if (!bno08x.enableReport(SH2_SHAKE_DETECTOR)) {
Serial.println("Could not enable shake detector");
if (!bno08x.enableReport(SH2_PERSONAL_ACTIVITY_CLASSIFIER)) {
Serial.println("Could not enable personal activity classifier");
delay(10);
if (bno08x.wasReset()) {
Serial.print("sensor was reset ");
setReports();
if (!bno08x.getSensorEvent(&sensorValue)) {
return;
switch (sensorValue.sensorId) {
// case SH2_ACCELEROMETER:
// Serial.print("Accelerometer - x: ");
// Serial.print(sensorValue.un.accelerometer.x);
// Serial.print(" y: ");
// Serial.print(sensorValue.un.accelerometer.y);
// Serial.print(" z: ");
// Serial.println(sensorValue.un.accelerometer.z);
// break;
// case SH2_GYROSCOPE_CALIBRATED:
// Serial.print("Gyro - x: ");
// Serial.print(sensorValue.un.gyroscope.x);
// Serial.print(sensorValue.un.gyroscope.y);
// Serial.println(sensorValue.un.gyroscope.z);
// break;
// case SH2_MAGNETIC_FIELD_CALIBRATED:
// Serial.print("Magnetic Field - x: ");
// Serial.print(sensorValue.un.magneticField.x);
// Serial.print(sensorValue.un.magneticField.y);
// Serial.println(sensorValue.un.magneticField.z);
// break;
case SH2_RAW_ACCELEROMETER:
Serial.print("Raw Accelerometer - x: ");
Serial.print(sensorValue.un.rawAccelerometer.x);
Serial.print(sensorValue.un.rawAccelerometer.y);
Serial.println(sensorValue.un.rawAccelerometer.z);
case SH2_RAW_GYROSCOPE:
Serial.print("Raw Gyro - x: ");
Serial.print(sensorValue.un.rawGyroscope.x);
Serial.print(sensorValue.un.rawGyroscope.y);
Serial.println(sensorValue.un.rawGyroscope.z);
case SH2_RAW_MAGNETOMETER:
Serial.print("Raw Magnetic Field - x: ");
Serial.print(sensorValue.un.rawMagnetometer.x);
Serial.print(sensorValue.un.rawMagnetometer.y);
Serial.println(sensorValue.un.rawMagnetometer.z);
