int IN1 = 2; //IN1 a pin digital 2
int IN2 = 3; //IN2 a pin digital 3
int ENA = 5; //ENA a pin digital 5
int IN3 = 7; //IN3 a pin digital 7
int IN4 = 8; //IN4 a pin digital 8
int ENE = 9; //ENE a pin digital 9
int SENSOR= 12;
int Valor= 0;
int ANTERIOR = 1;
pinMode(IN1, OUTPUT); //IN1 como salida
pinMode(IN2, OUTPUT); //IN2 como salida
pinMode(ENA, OUTPUT); //ENA como salida
pinMode(IN3, OUTPUT); //IN3 como salida
pinMode(IN4, OUTPUT); //IN4 como salida
pinMode(ENE, OUTPUT); //ENE como salida
pinMode(SENSOR, INPUT);
VALOR = digitalRead(SENSOR);
if (VALOR != ANTERIOR){
if (VALOR == HIGH)
digitalWrite(ENA, HIGH); //ENA en alto habilita motor A
digitalWrite(IN1, LOW); //IN1 en cero logico
digitalWrite(IN2, HIGH); //IN2 en uno logico
digitalWrite(ENE, HIGH); //ENA en alto habilita motor A
digitalWrite(IN3, LOW); //IN3 en cero logico
digitalWrite(IN4, HIGH); //IN4 en uno logico
delay(3000); //demora de 3 seg.
digitalWrite(ENA, LOW); //ENA en bajo deshabilita motor A
digitalWrite(ENE, LOW); //ENE en bajo deshabilita motor
delay(2000); //demora de 2 seg.
int Estado =0;
int sensor =2;
int led =3;
int salida =0;
void setup ()
pinMode(sensor, INPUT); //entrada de sensor
pinMode (led, OUTPUT); //salida de led
digitalWrite (led, LOW); //apagar el led
if loop()
Estado = digitalRead(sensor);
if (Estado == 1 && salida==0)
digitalWrite (led, HIGH); //se prende el led
while(Estado ==1) //cambia sensor a 1
salida = 1;
if (Estado ==1 && salida ==1)
digitalWrite(led, LOW);
while (Estado ==1)
Estado =digitalRead(sensor);
errores:
In function 'void loop()':
RETO11:27:3: error: 'VALOR' was not declared in this scope
In function 'void setup()':RETO11:53:6: error: redefinition of 'void setup()'
void setup ()
note: 'void setup()' previously defined here
RETO11:61:1: error: expected unqualified-id before 'if'
if loop()
exit status 1
To be fair, the old forum had a subtitle to the "installation and troubleshooting" section that said something like "For problems with Arduino itself, NOT your project".
The new forum lacks this useful (but largely neglected) subtitle.
You had two sketches in the same file. After removing the second sketch and fixing "VALOR" to "Valor" it compiles without error.
int SENSOR = 12;
int Valor = 0;
int ANTERIOR = 1;
Valor = digitalRead(SENSOR);
if (Valor != ANTERIOR)
if (Valor == HIGH)
The second sketch in the file also compiles if you fix "if loop()" to "void loop()":
int Estado = 0;
int sensor = 2;
int led = 3;
int salida = 0;
void setup ()
if (Estado == 1 && salida == 0)
while (Estado == 1) //cambia sensor a 1
salida = 1;
if (Estado == 1 && salida == 1)
while (Estado == 1)
