Hello
where can I download ctype.h library and what is the location in ArduinoIDE IDE, I am using latest version of IDE.
objective is to use isAlpha() function and isDigit() function in programming.
Thanks in Advance
Hello
Thanks in Advance
It's part of the ide install. No need to download just
#include <ctype.h>
Use the correct name (case matters)...
Serial.begin( 115200 );
if (Serial.available() > 0)
if( isalpha( Serial.read() ) );
Serial.println( F( "isalpha" ) );
I am not able to see in the installed library folder.
Objective is I need to check the user has entered only digit, otherwise the program should throw error message to the user to repeat the loop until correct input is achieved.
Thanks in advance
just do it. Report if there is an error. It's not in the 'library' folder. If you do a simple search, you'll find it.
