I'm an 8th grader making a science fair project where I create a pulse oximeter using an Arduino Nano Every chip. I uploaded all the libraries, however, for the MAX30100, I couldn't find a library named, "MAX30100_PulseOximeter.h", which the program code calls for. Below is the output after I verify my sketch. Could you please help me find out what I'm doing wrong, and what that output is telling me to do, as I am completely new to Arduino.
The Output:
C:\Users\omera\AppData\Local\Temp.arduinoIDE-unsaved2024015-1856-3310eq.vha6y\sketch_jan15b\sketch_jan15b.ino:2:10: fatal error: MAX30100_PulseOximeter.h: No such file or directory #include "MAX30100_PulseOximeter.h"
compilation terminated.
exit status 1
Compilation error: MAX30100_PulseOximeter.h: No such file or directory
Arduino framework version: Arduino Ide is at version 2.2.1.
MAX30100 library version: The MAX30100 library that I used is simply called "MAX30100". It was the one made by Connor Huffine.
i don't know what max30100 breakout is
Once you have decided which library to use, look at examples (in the menu of the Arduino IDE or online on Github) how to use it.
Arduino seems to point to the library by Conner Huffine. I would try that first.
