inconsistent readings from hcsr04
HI all,
I found this code to use a servo by means of the HCSR04 sensor. But the sensor seems to give really inconsistent readings. its either 0cm or 4563cm, and only when i move it around, and only briefly. I cant seem to figure out how to solve this.
Found the code here:
// Turning a Servo using a HC-SRO4 Ping Sensor
   This sketch reads a HC-SR04 ultrasonic rangefinder and returns the
   distance to the closest object in range. To do this, it sends a pulse
   to the sensor to initiate a reading, then listens for a pulse
   to return.  The length of the returning pulse is proportional to
   the distance of the object from the sensor.
   The Arduino then takes this information and initiates a series of
   sweeps. A sweep is defined as the servo moving its horn from the
   0 position to 180 and back to 0 then to -180 and back to 0.
   This code was developed partially from Ping))) code found in the public domain
   written by David A. Mellis, and adapted to the HC-SRO4 by Tautvidas Sipavicius,
   while other portions were written by Charles Gantt and Curtis Gauger from
   http://www.themakersworkbench.com.
   This code was written for a tutorial on http://www.themakersworkbench.com,
   and was designed for use in a project built by The Young Makers of Greater Augusta.
//Tell the Arduino Ide to include the Servo.h library.
#include <Servo.h>
 //Setup the variables for the HC-SR04
 const int trigPin = 12;
 const int echoPin = 13;
 // create servo object to control a servo
 // a maximum of eight servo objects can be created
Servo myservo;
// variable to store the servo position
int pos = 0;
  // initialize serial communication:
// attaches the servo on pin 2 to the servo object
  myservo.attach(2);
  // establish variables for duration of the ping,
  // and the distance result in inches and centimeters:
  long duration, cm;
  // The sensor is triggered by a HIGH pulse of 10 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  pinMode(trigPin, OUTPUT);
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Read the signal from the sensor: a HIGH pulse whose
  // duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(echoPin, INPUT);
  duration = pulseIn(echoPin, HIGH);
  // convert the time into a distance
  cm = microsecondsToCentimeters(duration);
  //Tell the Arduino to print the measurement in the serial console
  Serial.print(cm);
  Serial.print("cm");
  // This if-else statement tells the Arduino at what distance
  // it should trigger the servo, what the servo should do,
  // and what it should do if the distance is too far away.
   if (cm <= 24)  {sweep(3);
   else if (cm >= 24) {myservo.write(pos);
   // Tell the Arduino to wait 0.10 seconds before pinging the
   // Ultrasonic Sensor again.
   delay(100);
//Converts the Microseconds Reading to Centimeters
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
//This sub-routein is what dictates the movement of the servo
void sweep(int NUM_OF_CYCLES)
// Tells the Arduino to start this loop at 0 and incriment it by 1
// each time the loop completes. This is how the Arduino knows to
// stop the loop when a specific number of the Sweep routein has been ran.
  for (int j=0; j<NUM_OF_CYCLES; j++)
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(10);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
Review the pulsln() documentation. You will see there are three parameter and the third one is for a time-out time. Without a value the code waits for a full second and then returns zero. Your code does not supply a time-out value and that may be part of the problem.
Paul
