I'm using a micro SD for a sensor, and I'm recording the data for an hour. Sometimes the data saves, and sometimes it doesn't, with no changes to the code or hardware. Is there any way I can fix this? It's really annoying. I'm using a DFRobot MicroSD Card Module For Arduino, and a few other sensors. It always recognises the SD card as well, but I'll check afterwards and its just an empty file sometimes.
#include <Arduino.h>
#include <SensirionI2CSen5x.h>
#include <Wire.h>
#include <SD.h>
#include <SPI.h>
#include <dht.h>
LiquidCrystal_I2C lcd(0x27,20,4);
File myFile;
const int chipselect = 4;
dht DHT;
#define DHT11_PIN 7
// The used commands use up to 48 bytes. On some Arduino's the default buffer
// space is not large enough
#define MAXBUF_REQUIREMENT 48
#if (defined(I2C_BUFFER_LENGTH) && \
(I2C_BUFFER_LENGTH >= MAXBUF_REQUIREMENT)) || \
(defined(BUFFER_LENGTH) && BUFFER_LENGTH >= MAXBUF_REQUIREMENT)
#define USE_PRODUCT_INFO
#endif
int timer=0;
SensirionI2CSen5x sen5x;
float massConcentrationPm1p0;
float massConcentrationPm2p5;
float massConcentrationPm4p0;
float massConcentrationPm10p0;
float ambientHumidity;
float ambientTemperature;
float vocIndex;
float noxIndex;
lcd.init();
lcd.backlight();
while (!Serial) {
delay(100);
lcd.clear();
if (SD.begin(chipselect)){
lcd.println("SD card accepted");
}else{
lcd.println("SD card missing or rejected");
while(1);
lcd.clear();
myFile =SD.open("RESULTS.TXT", FILE_WRITE);
if (myFile){
lcd.print("Wrting headers to csv");
myFile.println("\n------------------NEW TEST-----------------");
myFile.print("pm1,pm2.5,pm4,pm10,temp,humid\n");
}else{
lcd.print("Error opening csv");
Wire.begin();
sen5x.begin(Wire);
sen5x.deviceReset();
sen5x.setTemperatureOffsetSimple(0);
// Start Measurement
sen5x.startMeasurement();
timer++;
if (timer<=3600){
// Read Measurement
sen5x.readMeasuredValues(
massConcentrationPm1p0, massConcentrationPm2p5, massConcentrationPm4p0,
massConcentrationPm10p0, ambientHumidity, ambientTemperature, vocIndex,
noxIndex);
int chk =DHT.read11(DHT11_PIN);
String temp=String(massConcentrationPm1p0)+","+String(massConcentrationPm2p5)+","+String(massConcentrationPm4p0)+","+String(massConcentrationPm10p0)+","+String(DHT.temperature)+","+String(DHT.humidity)+"\n";
myFile.print(temp);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("PM1:");
lcd.setCursor(9,0);
lcd.print("PM25:");
lcd.setCursor(0,1);
lcd.print("PM4:");
lcd.setCursor(9,1);
lcd.print("PM10:");
lcd.setCursor(0,2);
lcd.print("Temp:");
lcd.setCursor(11,2);
lcd.print("Hum.:");
lcd.setCursor(4,0);
lcd.print(String(massConcentrationPm1p0));
lcd.setCursor(14,0);
lcd.print(String(massConcentrationPm2p5));
lcd.setCursor(4,1);
lcd.print(String(massConcentrationPm4p0));
lcd.setCursor(13,1);
lcd.print(String(massConcentrationPm10p0));
lcd.setCursor(5,2);
lcd.print(DHT.temperature);
lcd.setCursor(16,2);
lcd.print(DHT.humidity);
lcd.setCursor(0,3);
lcd.print("Datapoint:");
lcd.print(timer);
}else{
myFile.close();
lcd.clear();
lcd.setCursor(0,0);
lcd.println("Please eject");
lcd.setCursor(1,0);
lcd.println("the SD Card");
lcd.println("Experiment complete!");
delay(1000000);
