Inconsistent UART results from ESP32 and Arduino Uno
I have a spare IR remote that I wanted to use with an ESP32 project, so I used an Arduino Uno (the ESP32 was hooked up to another circuit at the moment) to capture the signals. I wrote them down and left to work with them later. Today I wanted to finally use the remote, so I connected the receiver to an ESP32, and the results were COMPLETELY different, kinda seeming random at times. I've captured some images just now to show the inconsistencies.
Arduino Uno: image
ESP32: image
The ESP32 pulse doesn't even resemble a signal and just spits out seemingly random zero's. How can I fix this? I need to use the ESP32, because the Arduino is way too slow for my uses.
Shall we assume an IR receiver? Which.
Are you using an IR library? Which w/ link.
What ESP32 module?
IDE settings for ESP32: freq, etc?
Code? Show.
Schematic of test hookup? Provide.
Review and do your best to provide:
How to get the best out of this forum - Using Arduino / Project Guidance - Arduino Forum
IR receiver: TSOP1230
IR library: none
ESP module: ESP-WROOM-32D
IDE settings: image
code:
#define pin 2
bool _read = 0;
  pinMode(pin, INPUT_PULLUP);
  _read = digitalRead(pin);
schematic: literally the receiver hooked up to pin 2 with ground and 5v connected.
Try a different library: The ESP32 is a 32-bit processor! (INT is 32 bit wide)
ESP32 and Infrared receiver example | ESP32 Learning
Seems like the website is broken. Images don't display. Big thanks still, the code snippet at the bottom works perfectly
ESP32 and Infrared receiver example _ ESP32 Learning.pdf (551.9 KB)
GitHub - Arduino-IRremote/Arduino-IRremote: Infrared remote library for Arduino: send and receive infrared signals with multiple protocols
