I want to use the 434MHz transmitter and receivers from sparkfun:
I have found out that I can increase the range of them by increasing the voltage and adding an antenna.
I had found one article where just a wire was added as an antenna.
I have also found articles for build antennas for 5.8GHz and so on, but they all had these male and female connectors.
How can I add a better antenna to my modules? Could I just recalculate the wavelength and rebuild the antennas for e.g. 5.8GHz devices, but how do I connect the modules I have to the female or male connectors. Or can I leave them out and connect GND to GND and the other to my antenna pin?
I have just found the one article:
which is about building a cloverleaf antenna, and it is also said that GND and signal is connected so to speak a short circuit, could I just put this into my antenna pin if I use the right math calculations?
But how then I do the receiver as these antennas are not really used for receivers?
I am looking forward to ehar from you.
King regards,
Greenality
