Increase the datarate of Accelerometer to 3200Hz (Maximum Value)
Hey Guys,
I am working on a project which is using Arduino Due (Board Model DUE R3) connected with ADXL345 accelerometer. The board is connected with Pc with a usb cable at 9600 baud rate. Right now I am using the following code to recieve the x,y and z readings from the accelerometer:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
Adafruit_ADXL345_Unified BSens = Adafruit_ADXL345_Unified(1);
BSens.begin();
sensors_event_t event;
BSens.getEvent(&event);
Serial.print(event.acceleration.x);
Serial.print(" ");
Serial.print(event.acceleration.y);
Serial.print(" ");
Serial.println(event.acceleration.z);
With this code right now I am recieving the readings from the accelerometer at 310 Hz datarate. Increasing the data rate starts to give errors in the reception of the data (printing of data on the screen at once). The ADXL345 manual says that we can increase the data rate of the accelerometer to upto 3200Hz. So my plan is to increase the datarate of the accelerometer to 3200Hz(maximum value) and store it as a packet of data in the Arduino Due Board and recieve that data after every 1 or 2 seconds as a packet file.
So can anyone please explain me that what changes should I make in my code or settings to set the sampling rate of accelerometer to 3200Hz. Please state clear and explained answers as I am a newbie in this kind of project. (a detailed answer to make the datarate of the accelerometer to 3200 Hz, the maximum value).
Note: Increasing the Baud does not make much difference in the datarate.
Will be really grateful to you in this regard.
Regards,
Daniyal Khan
How are you increasing the rate? What are you changing in that code?
I'm not familiar with the Adafruit sensors library. It looks like it's wrapping all possible sensors in a large data object that can hold data from every sensor. Copying that large data object around in memory is probably slowing you down.
Are you able to make it faster by using the more direct ADXL345 library?
The Arduino framework isn't able to use all of the capabilities of the Due. I don't know if it's able to switch the I2C communications to "fast mode". This is easy to do on the AVR based Arduinos.
Can you use SPI communication? That's a lot faster than even fast I2C.
This would probably be faster on any other board that Due, because Due lacks transmit buffering for Serial.
