Increasing flex sensor sensitivity
I'm working on a project that's using a 2.2 inch spectra symbol flex sensor (https://www.sparkfun.com/products/10264) mounted on a glove to control a servo. Testing with a multimeter revealed a resistance rage of about 20k to 80k, so I constructed a voltage divider (5v connected to the flex sensor, and a 47k resistor going to ground), connecting the output to the A0 pin, as with any other resistive sensor.
Something isn't working properly, though, because when I look at the values from the analogRead function, they only range from about 1 to 6. I checked to see that the voltage divider was working with a multimeter and got values ranging from .5 to 2v, but for some reason the arduino isn't properly detecting the change. Replacing the flex sensor with a variable resistor produced normal analogRead values from ~22 to 1024, and a few other sensors also seemed to work normally.
I tried changing the value of the resistor in the voltage divider, and found that even when it was removed completely, the value continued to stay between 1 and 6. The datasheet for the flex sensor recommended the use of an impedance buffer, which I tried, but that failed to produce any significant change. Of course, I had never used an op-amp before, so I might have been constructed incorrectly.
Any ideas as to what might be going wrong, and how to fix it?
Can you post your code used?
It's just the stock example code included with the arduino IDE:
  AnalogReadSerial
  Reads an analog input on pin 0, prints the result to the serial monitor.
  Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
 This example code is in the public domain.
// the setup routine runs once when you press reset:
  // initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
  // read the input on analog pin 0:
  int sensorValue = analogRead(A0);
  // print out the value you read:
  Serial.println(sensorValue);
  delay(1);        // delay in between reads for stability
Did you try bending it in both directions? Bending them in one of the directions results in little resistance change.
Yes, I'm quite certain that I'm bending it the right way. The problem seems to be with the way the sensor and the arduino are interacting, since everything works fine when I look at voltage changes with a multimeter, and when I use a different type of sensor.
Edit: I found a different op-amp chip and used that for an impedance amplifier, and everything is working just fine now.
Ethliel: Edit: I found a different op-amp chip and used that for an impedance amplifier, and everything is working just fine now.
And thus, to help other people who come across this thread, you are going to say which op-amp that was and how you used it. Right?
