I am posting my arduino code that I am using for this sensor as an example of how to use it. So far I am impressed with its stability and can be found here 3DSensor.
The first thing you should do is read the data sheet and ensure you have it wired correctly. The most important thing to do is ensure that your SDA/SCL lines are at 3.3V. The UNO has 5V on the SDA/SCL line and so you will need a logic level shifter, which will protect your 3D sensor. The code is rough and I am sure there are some useful tips that I could use to improve the code, hence I am posting it here.
I surface mounted this sensor on a milled out breakout board and wired it on a solder less board to a Huzzah Feather adafruit-feather-huzzah-esp8266. This feather's SDA/SCL lines work at 3.3V, so I did not need a level shifter. I am using 10KOhm pull-up-resistors on the SDA and SCL line. This gives me about a 100Hz sample rate. If wired correctly the sensor can run at 3.3MHz sampling rate, more than I need currently. I have a 0.1uF capacitor between Vdd and GND (datasheet has an example application circuit that I am following).
You will need to run I2C scanner code first to determine the devices I2C address. After, update the HallAddressWrite variable to reflect the address.
The sensor is not yet sold on a breakout board, but you should be able to buy a TSOP-6 pin breakout board and mount the sensor to it.
// Define includes
#include <Wire.h> // Wire header file for I2C and 2 wire
int HallAddressWrite = 0x1F; // Device address
byte X_Axis_Register1 = 0x1; //
// Declare some variables
int const numOfBytes = 7;
int baudRate = 9600;
byte readByte[numOfBytes];
float counter=0.0;
byte configReg = 0x00; // Address of Configuration
byte powerMode = 0x05; // Set to low power mode
Serial.begin(baudRate); // Set Serial Port speed
Wire.pins(4, 5);
Wire.begin(); // Join the I2C bus as a master
Wire.beginTransmission(HallAddressWrite); // Address the sensor
Wire.write(configReg); // Address the Configuration register
Wire.write(powerMode); // Set the Power Mode to Low
Wire.endTransmission(); // Stop transmitting
delay(100);
// Main Program Infinite loop
getBytes(HallAddressWrite, X_Axis_Register1, numOfBytes, readByte); //Read first 8 bytes
float temp = getTemp();
if(temp<-50){ //re-read address banks, bad measurement
while(temp<-50){
temp = getTemp();
Serial.print("\t");
getMagX();
Serial.print("\t");
getMagY();
Serial.print("\t");
getMagZ();
Serial.println("-----");
delay(250);
float getFrameCounter() { //every ADC conversion the frame is incremented,this function captures that
//This would be needed probaly in fast mode to ensure data
//was succesfully written to the registries
int i;
int a[8];
int lsb = readByte[3];
int tableI[8] = { 0, 0, 0, 0, 1, 1, 0, 0};
for ( i = 7; i >= 0; i--)
if ( (1 << i) & lsb)
a[7 - i] = 1*tableI[7-i];
a[7 - i] = 0;
counter += a[7 - i];
Serial.print(counter);
return counter;
float getTemp()
int i;
int a[8];
int b[8];
int tableI[8] = { -2048, 1024, 512, 256, 0, 0, 0, 0};
int tableII[8] = {128, 64, 32, 16, 8, 4, 2, 1};
float Celsius = 0;
int msb = readByte[3];
int lsb = readByte[6];
//msb conversion
if ( (1 << i) & msb)
a[7 - i] = 1 * tableI[7 - i];
a[7 - i] = 0;
// Serial.print(a[7 - i]);Serial.print(" ");
Celsius += a[7 - i];
// Serial.print("\t");
a[8] = 0; // ascii terminating character
//lsb conversion
b[7 - i] = 1 * tableII[7 - i];
b[7 - i] = 0;
// Serial.print(b[7 - i]);Serial.print(" ");
Celsius += b[7 - i];
b[8] = 0; // ascii terminating character
Celsius -= 320;
Celsius *= 1.1;
if(Celsius>-50){
Serial.print(Celsius);
return Celsius;
void getBytes(byte address, byte registry, int numOfBytes, byte* readByte)
Wire.beginTransmission(address); //Begin Transmission
//Ask for data register
Wire.write(registry);
Wire.endTransmission(); //End Transmission
delay(20); //at least 12msec for ADC conversion and storage
Wire.requestFrom(address, numOfBytes); //Request Transmission
for (int i = 0; i < numOfBytes; i++) {
readByte[i] = Wire.read();
float getMagX()
int i;
int a[8];
int b[8];
int tableI[8] = { -2048, 1024, 512, 256, 128, 64, 32, 16};
int tableII[8] = {8, 4, 2, 1, 0, 0, 0, 0};
float magX = 0;
int msb = readByte[0];
int lsb = readByte[4];
//msb conversion
a[7 - i] = 0;
magX += a[7 - i];
//lsb conversion
b[7 - i] = 0;
magX += b[7 - i];
magX *= 0.098 * 10.0; //0.098mT/LSB 10Gauss/mT
if(abs(magX)<3) //the sensor has about a 0.2mT | 2Gauss units drift
magX = 0; //this is a software filter that suppress most of the noise
Serial.print(magX);
return magX;
float getMagY()
int i;
int a[8];
int b[8];
int tableII[8] = {0, 0, 0, 0, 8, 4, 2, 1};
float magY = 0;
int msb = readByte[1];
//msb conversion
a[7 - i] = 0;
magY += a[7 - i];
//lsb conversion
b[7 - i] = 0;
magY += b[7 - i];
magY *= 0.098 * 10.0; //0.098mT/LSB 10Gauss/mT
if(abs(magY)<3) //the sensor has about a 0.2mT | 2Gauss units drift
magY = 0; //this is a software filter that suppress most of the noise
Serial.print(magY);
return magY;
float getMagZ()
int i;
int a[8];
int b[8];
float magZ = 0;
int msb = readByte[2];
int lsb = readByte[5];
//msb conversion
a[7 - i] = 0;
magZ += a[7 - i];
//lsb conversion
b[7 - i] = 0;
magZ += b[7 - i];
magZ *= 0.098 * 10.0; //0.098mT/LSB 10Gauss/mT
if(abs(magZ)<3) //the sensor has about a 0.2mT | 2Gauss units drift
magZ = 0; //this is a software filter that suppress most of the noise
Serial.print(magZ);
return magZ;
