3D magnetic sensor
Hello everyone !
I want to detect magnetic fields using a 3D magnetic sensor from Infineon. The goal is simple, getting a magnetic fields following x-axisn y-axis, z-axis.
To do that, I wrote this code (I found some part on the internet tho).
#include <Tle493d_w2b6.h>
Tle493d_w2b6 Tle493dMagnetic3DSensor = Tle493d_w2b6();
  while (!Serial);
  Tle493dMagnetic3DSensor.begin();
  Tle493dMagnetic3DSensor.enableTemp();
  Tle493dMagnetic3DSensor.updateData();
  Serial.print(Tle493dMagnetic3DSensor.getX());
  Serial.print(" ; ");
  Serial.print(Tle493dMagnetic3DSensor.getY());
  Serial.println(Tle493dMagnetic3DSensor.getZ());
But then, I only get a serie of the same value for each axis : -266,24…
Following that, there’s the red LED that is lighted (mom told me whenever you see red things, start thinking about things not working joking), and my device is going really hot.
Could someone help me please ? :slight_smile:
Best regards.
Here’s the instruction manual (I didn’t find the datasheet).
Here’s the GitHub link :https://github.com/Infineon/TLV493D-A1B6-3DMagnetic-Sensor
Nevermind guys, I found what was wrong, just to discover that there’s another error.
The library I was using was not for this version of sensor.
So I downloaded the right library and such, and I’m currently using this code :
#include <Tlv493d.h>
// Tlv493d Opject
Tlv493d Tlv493dMagnetic3DSensor = Tlv493d();
  while(!Serial);
  Tlv493dMagnetic3DSensor.begin();
  Tlv493dMagnetic3DSensor.setAccessMode(Tlv493dMagnetic3DSensor.MASTERCONTROLLEDMODE);
  Tlv493dMagnetic3DSensor.disableTemp();
  delay(Tlv493dMagnetic3DSensor.getMeasurementDelay());
  Tlv493dMagnetic3DSensor.updateData();
  Serial.print(Tlv493dMagnetic3DSensor.getX());
  Serial.print(Tlv493dMagnetic3DSensor.getY());
  Serial.println(Tlv493dMagnetic3DSensor.getZ());
But here I go on an error like :
Arduino : 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Carte : "XMC1100 XMC2Go, PC"
libraries\true\Tlv493d.cpp.o: In function `Tlv493d::getRegBits(unsigned char)':
C:\Users\arnau\OneDrive\Documents\Arduino\libraries\true/Tlv493d.cpp:312: undefined reference to `tlv493d::getFromRegs(tlv493d::RegMask_t const*, unsigned char*)'
libraries\true\Tlv493d.cpp.o: In function `Tlv493d::setRegBits(unsigned char, unsigned char)':
C:\Users\arnau\OneDrive\Documents\Arduino\libraries\true/Tlv493d.cpp:297: undefined reference to `tlv493d::setToRegs(tlv493d::RegMask_t const*, unsigned char*, unsigned char)'
libraries\true\Tlv493d.cpp.o: In function `Tlv493d::setAccessMode(Tlv493d::AccessMode_e)':
C:\Users\arnau\OneDrive\Documents\Arduino\libraries\true/Tlv493d.cpp:106: undefined reference to `tlv493d::writeOut(tlv493d::BusInterface_t*)'
libraries\true\Tlv493d.cpp.o: In function `Tlv493d::begin(TwoWire&, Tlv493d_Address, bool)':
C:\Users\arnau\OneDrive\Documents\Arduino\libraries\true/Tlv493d.cpp:67: undefined reference to `tlv493d::initInterface(tlv493d::BusInterface_t*, TwoWire*, unsigned char)'
C:\Users\arnau\OneDrive\Documents\Arduino\libraries\true/Tlv493d.cpp:78: undefined reference to `tlv493d::readOut(tlv493d::BusInterface_t*)'
libraries\true\Tlv493d.cpp.o: In function `Tlv493d::updateData()':
C:\Users\arnau\OneDrive\Documents\Arduino\libraries\true/Tlv493d.cpp:179: undefined reference to `tlv493d::readOut(tlv493d::BusInterface_t*, unsigned char)'
libraries\true\Tlv493d.cpp.o: In function `Tlv493d::disableInterrupt()':
C:\Users\arnau\OneDrive\Documents\Arduino\libraries\true/Tlv493d.cpp:127: undefined reference to `tlv493d::writeOut(tlv493d::BusInterface_t*)'
libraries\true\Tlv493d.cpp.o: In function `Tlv493d::disableTemp()':
C:\Users\arnau\OneDrive\Documents\Arduino\libraries\true/Tlv493d.cpp:142: undefined reference to `tlv493d::writeOut(tlv493d::BusInterface_t*)'
collect2.exe: error: ld returned 1 exit status
exit status 1
Erreur de compilation pour la carte XMC1100 XMC2Go //Compilation error for ... card
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
First time I’m seeing this, anyone ?
You are missing some code.
Probably not, or not all of it.
